Does anyone know how the side sills/skirts are mounted on the 6c GTI mine has started coming away.
See my picture.
It looks as if your sill has been pushed in behind the side skirt, creating a gap between the side skirt and the sill. Here’s the reverse side of a mk7 Golf GTI side skirt, which is the same design and uses the same fixing method as the skirts fitted to the Polo - the slot screw holes on the reverse side of the plastic side skirt fit over a series of bolts / screws that are threaded into the metal sill on the car.SamEvans wrote: Sun Mar 22, 2020 1:51 pm Hi all
See my picture.
