Boot release motor broken
Alisdair
Drives: 2016 VW Polo GTI
Post by Alisdair »
Hi everyone,
The other day I went to open my boot on my 2011 1.2 TSI. As I lifted the VW sign on the boot, it made a noise like a battery powered machine gun. Now the catch won’t stay locked and you can just pull the boot open without using the VW badge.
Is this just a simple motor replacement or can it be fixed?
benzinkopf
Drives: 1.2TSI 105HP DSG7
Re: Boot release motor broken
Post by benzinkopf »
Most likely the nylon gear inside already broken. You have to replace the whole locking/latch unit.
Alisdair
Post by Alisdair »
benzinkopf wrote: Tue Mar 24, 2020 5:29 pm Most likely the nylon gear inside already broken. You have to replace the whole locking/latch unit.
Ordered new unit. Thanks for your help
benzinkopf
Ive studied the mechanism and the gear operation before. i even tried 3dprinted the worm gear for replacement. so i found out its not wear and tear issue. its not worn out issue. It is normally how you operate the latch. Never ever pull the emblem logo while you closing the lid. thats the trick. only for opening.
