Thanks guys
Help to retrofit 090 BCM
Hi guys. I’ve read few discussion of same job here on forum, but i want to retrofit only the bcm and for the moment i don’t need the automatic light module. Is this possible to do? Someone can help and assist me in this job? I can pay without problem.
Thanks guys
Thanks guys
Re: Help to retrofit 090 BCM
Here the Autoscan
Wednesday,15,April,2020,18:35:01:50743
VCDS Version: 20.4.0.1 (x64) HEX-NET CB: 0.4508.4
www.Ross-Tech.com
VIN: WVWZZZ6RZBU054344 License Plate:
Mileage: 95560km-59378mi Repair Order:
Chassis Type: 6R-VW25 (6N0)
Scan: 01 03 04 08 09 15 17 19 25 44 56 69
VIN: WVWZZZ6RZBU054344 Mileage: 95560km-59378miles
56-Radio -- Status: OK 0000
69-Trailer -- Status: OK 0000
Address 01: Engine (J623-CAYB) Labels:. 03L-906-023-CAY.clb
Part No SW: 03L 906 023 MA HW: 03L 907 425 B
Component: R4 1.6l TDI H33 9978
Revision: --H33--- Serial number:
Coding: 00114016002400080000
Shop #: WSC 31414 790 50316
ASAM Dataset: EV_ECM16TDI02103L906023MA 003011
ROD: EV_ECM16TDI02103L906023LK_SK25.rod
VCID: 71AADAEEA06F2D0EFD-8024
Readiness: 0 0 0 0 1
Address 03: ABS Brakes (J104) Labels:. 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 AK HW: 6R0 907 379 AF
Revision: --------
Coding: 210228E3427200B6842814E642D500421300
Shop #: WSC 31414 790 31414
VCID: 075E9436B2EB03BE43-8052
Part No SW: 6R0 907 044 E HW: 6R0 907 044 E
Component: Climatronic H09 0609
Revision: V0000000
VCID: 35222EFE9C87412EE1-8060
Part No SW: 6R0 937 087 H HW: 6R0 937 087
Component: BCM PQ25 H+4 H46 0230
Revision: BF046001 Serial number: 0394 356105170
Coding: 24B02BBF08A10000003808003C299CD00080410F60060000200000000000
VCID: 42C84522DD49E69654-8016
Subsystem 1 - Part No SW: 6R0 959 801 AB HW: 6R0 959 801 AB Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 007 1611
Serial number: KU0-KU014.12.1011470
Coding: 18BC30
Subsystem 2 - Part No SW: 6R0 959 802 AD HW: 6R0 959 802 AD Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 007 1611
Serial number: KU0-KU009.12.1015641
Coding: 08BC30
Subsystem 3 - Part No SW: 5G0 959 442 J HW: 5G0 959 442 J
Component: E221__MFL-DC1 H17 0103
Serial number: 29150002308170125467
Coding: A40000
Subsystem 4 - Part No SW: 6R0 959 811 G HW: 6R0 959 811 G
Component: J388__TSG_HL 007 1611
Serial number: KU0-KU021.12.1016901
Coding: 08BC32
Subsystem 5 - Part No SW: 6R0 959 812 G HW: 6R0 959 812 G
Component: J389__TSG_HR 007 1611
Serial number: KU0-KU022.12.1011373
Coding: 08BC32
Component: VW10Airbag022 H09 0020
Revision: -------- Serial number: 003GX00EWV44
Coding: 003232
ROD: EV_AirbaVW10BPAVW250.rod
VCID: 4AD86D02ED793ED69C-801E
Serial number: 3575HRB405T0DGES88UF
Serial number: 3585HRB40610DGES29B8
Serial number: 3515RRB40610AMH0GP08
Serial number: 3525RRB40610AMH0IOAK
Part No SW: 6JA 920 840 C HW: 6JA 920 840 C
Component: KOMBI H05 0709
Coding: 110A01
Shop #: WSC 73430 031 00222
VCID: 3B3638C6B2A3975E17-806E
1 Fault Found:
10485825 - Internal Control Module Memory Check Sum Error
B2000 41 [137] - General checksum failure
[Steuergerät defekt (EEPROM-Bereich Gesamtwegstrecke)]
Address 19: CAN Gateway (J533) Labels:. 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 6R0 937 087
Component: GW-K-CAN TP20 0230
Coding: 002200
VCID: 70ACDFEAA3652406F2-8024
Component: IMMO H05 0709
Serial number:
Shop #: WSC 00000 000 00000
VCID: 6A98CD828DB9DED6BC-803E
Part No: 6R0 423 156 B
Component: LenkhilfeTRW V277
Coding: 11230
Shop #: WSC 31414
VCID: 2F2E1C96EADB7BFEAB-807A
Part No SW: 6RD 035 187 B HW: 6RD 035 187 B
Component: Radio 541 5518
Revision: -------- Serial number: VWZZZ4J6252547
Coding: 06000400020005
Shop #: WSC 00078 790 00101
VCID: 46C05932F161DAB678-8012
Address 69: Trailer (J345) Labels:. 8K0-907-383.clb
Part No SW: 8K0 907 383 HW: 8K0 907 383
Component: Anhaenger H14 0080
VCID: 71AADAEEA86F2D0EFD-8024
End(Elapsed Time: 01:28, VBatt start/end: 12.1V/12.0V. VIgn 11.9V, udsna)--
www.Ross-Tech.com
Revision: --------
Revision: V0000000
Coding: 18BC30
Coding: 08BC30
Coding: A40000
Coding: 08BC32
Coding: 08BC32
Coding: 003232
Coding: 110A01
1 Fault Found:
Coding: 002200
Serial number:
Coding: 11230
Shop #: WSC 31414
Here the photo of light switch
https://ibb.co/PNQKTN1
https://ibb.co/VjRsfVp
https://ibb.co/vsnvcGJ
https://ibb.co/njGvBKS
