POLO 6R. HEATED SEATS. OEM.
habib_123
Drives: Polo 6R 2012 1.2TDI RHD
Re: POLO 6R. HEATED SEATS. OEM.
Post by habib_123 »
Sorry. Use the following link.
https://mega.nz/#F!3c1giQJb!KCDyfZgfmMMi8b8Y8ExJ9w
Robbo770
Drives: Polo SEL 1.4 tdi 2014
Post by Robbo770 »
Getting ready for this challenge, do I need to disconnect the battery from the car?, any risks doing this for module programming?, would the same battery need re coded?
To remove the front seats if no issue disconnection battery, can the seat wire be disconnected with no issues on air bag system?
Is the seat covers able to be removed and re attached with not to much issues?
Thanks in advance
Any clear issue pics on difficult bits greatly received.
Yes please disconnect the battery before working on the cars electrical installation. Always :)
The seat covers will come off nicely with some elbow grease.
Robbo770
Post by Robbo770 »
Hi ichel, any issues with disconnecting the seats for the airbags at all?
No problem, electronically speaking.
The manuals recommend a specific tool to isolate the dedicated terminals on the airbag connector, which must be installed when the seat is removed.
If you do not have this tool (and as a suggestion that you should never use :)) you can tape the connector with cloth tape so that nothing can get inside the connector and put the terminals in contact.
Robbo770
Post by Robbo770 »
Thanks Ciclo
Robbo770
Post by Robbo770 »
Looking for some guidance for my 6C heat seat retrofit,
The wiring shown here shows 1 control module for both seats, but the wiring has several fuses referenced thanks to ichel information, does anyone have each of this diagram with the ref for each item known in full to help. :D :D
Fuse sc26 - 5A, sc36 - 10A, sc55 - 10A?
Anyone with a 6c with heated seats able to help?
I got a 6C wiring loom kit and will photo the connections I have to compare to the diagram. :shock: :?
I don't really understand your question. What information do you need?
Mocro
Drives: Polo 6C 1.4TDI 105HP
Post by Mocro »
Hello iichel can you send me a private message?
I dont know how to do this.
Thank you
Hi Mocro, what exactly is your question?
Robbo770
Post by Robbo770 »
Hi iichel,
I am trying to complete my wiring in of the heated seats to the car
6R kit wiring looks like this I believe
The kit I got for a 6c looks like this, I need to change the seat plug ends to the same as the 6R as the GT seats have those plugs, but I only have the following wires available..
For up at fuse box
1 big wire with crimp for large fuse -Blue/black
1 x light wire for small fuse - red
A grey wire
A brown earth - with earth crimp
See pics
The control unit as shown with wires
And the 15 and 16 output to seats red/yellow and yellow/black which have own earths
I seem to short of bcm cable and or illumination cable and a third power cable....by wiring diagram....
Can you help as stuck till I get this sorted to finish install.
For up at fuse box
1 big wire with crimp for large fuse -Blue/black --> This one goes to the fuse box, suggest SC36 with 25A fuse
1 x light wire for small fuse - red --> this one goes to the BCM T73a/36
A grey wire --> this one is for the illumination
A brown earth - with earth crimp --> connect all of them to an earthing point
Robbo770
Post by Robbo770 »
Many thanks, outstanding support iichel
Is the bcm the black plug? Or white one on my motor, here is it’s chassis
Robbo770
Post by Robbo770 »
Thanks to iichel made progress wires clipped into fuse box on fuse 26 which is class 75, so should go off with ignition off I think..., red wire into plug A black plug on BCM terminal 36, awkward as hell, plug c is a arse to get back into the bcm.
Got earth onto nice main framing assemble bolt as it a solid earth.
Got to change the plugs on the wiring, but will try with the seat pads I have loose to ensure I know which switch switches on which set before running them under the carpet to the seat areas.
Then got the usb hub and rear additional usbs to get all wired in, and fix the bulb gone on the cigarette socket!!
You're not messing around... thorough job!
