VW Polo 6R 2014 1.4 Multi Function Steering Wheel to normal Steering Wheel
- HakanAknesil
Hi everyone, I already use multi function steering wheel on my 2014 polo but I decided to change with non-multi function steering wheel. My current airbag has 2 wires yellow and black but in the new steering wheel I can not plug the black one because there is some special part in multi function steering wheel that I can not use and fit in the non function wheel. What should I do? Should I ignore the black wire and plug only the yellow one or I need to buy a new airbag that has only yellow wire?
Re: VW Polo 6R 2014 1.4 Multi Function Steering Wheel to normal Steering Wheel
Do you have some pictures of the old and the new wheel?
- HakanAknesil
I think you can use the same airbag and harness not 100% sure the horn works straight away.
- HakanAknesil
thank you:) Does anyone any idea?
