Polo 6R - Useful Part Numbers
Yeah that one is a b***h, usually I cut them off and install a new one. They are very difficult to remove wires from.
ag69
Drives: 1.2TSi 77Kw 7DSG
Post by ag69 »
Thanks iichel.
ag69
Post by ag69 »
Can anyone help me differentiate/choose between sylvania 578 and 6411 41 mm festoon?
They have very less power consumption of 0.5W and I want to replace it for N 017 723 4 which is a 10W halogne in dome light.
Amazon uk has osram one
https://www.amazon.co.uk/OSRAM-6441CW-0 ... ive&sr=1-4
Amazon US has both
578 & 6411
https://www.amazon.com/SYLVANIA-6411-Fe ... r=8-3&th=1
JH1151
Drives: 2016 6R
Post by JH1151 »
Hi, hoping someone can help me.
Does anyone have a part number for a bonnet?
I believe it is 6R it's a 2016 match edition 1.2 TSI DSG.
I'm not even sure on that but the vin starts with WVWZZZ6R
I was driving and what looked like a brick flicked up from the middle of the road and ruined the bonnet, bounced off and hit the windscreen :shock: didn't go through but took a chunk out of both.
JH1151 wrote: Mon Mar 09, 2020 9:41 am Hi, hoping someone can help me.
A 2016 Polo will be a 6c, although the part no. will start 6r as the 6c is the facelift version of the original 6r Polo, and both the 6r and 6c use the same metal body panels.
A quick Google search turned up the part no. for the bonnet as 6R0823031A. Might also be worth trying breakers yards near to you as they may have undamaged used bonnets from cars that suffered rear end damage; you might also be able to locate one off a Pure White Polo, which would save on getting it painted.
JH1151
Drives: 2016 6R
Post by JH1151 »
That's brilliant thank you :)
Robbo770
Drives: Polo SEL 1.4 tdi 2014
Post by Robbo770 »
Can anyone confirm the new 1.4 tdi 3 cly glow plug part number 2014- think its 03L963319?
For CUSA CUSB --> 059963319AB
Robbo770
Post by Robbo770 »
Thanks ichel, got major service coming up and going to change as 6 yr old now
limparka
Drives: 6R 1.4
Post by limparka »
Hello guys!
I'm new on this forum but I reading this forum since a long time. I have a Polo 6R 2009 1.4 and I got one R-line wheel set with 215/45 R16 tires. After I put on the new wheels I realized that the rear axle is so high so I would like to buy a new coil springs set for the rear axle. I read ciclo's topic about his new springs and I found that he installed the 6Q0511115CK PR-1JS+0YE VAG number OEM springs on his car.
I looked for these springs at one of the local car parts dealer in Hungary but they said that spring is for the Polo 9N.
I'm a bit confused now. Will it fit on my Polo 6R or not? :roll:
Thank you for your help!
- limparka -
It is a suitable part for Polo 6R 2009-2014 :)
limparka
Drives: 6R 1.4
Post by limparka »
Thank you sir! :)
Do you suggest it instead of the factory springs? I dont want a racing car look, but with the factory springs it looks like a derby-cross car. :lol:
Robbo770
Post by Robbo770 »
Hi iichel,
Would these rear springs 6Q0511115CK
be able to be used on my 64 plate 1.4 tdi 6C?, want to lower the rear a bit.
Cheers Rob
CK should be suitable for your 6C, yes.
Will golf mk7 gti pedal covers fit 6r ( with zip ties modification?)
Sent from my Nokia 6.1 Plus using Tapatalk
