Rear Shock Absorbers
Barlis
Drives: 6N Saloon
Post by Barlis »
Hi all, I decided to change the rear shocks on my 99 Classic. When I removed the old shock, the upper spring plate was in a really bad way so I ordered a new one but it didn't come with the the spring seat (which was in a bad state as well). I can't seem to find anywhere that sells the upper spring seat (number 9 on the diagram attached).
Can anyone recommend a supplier that will stock these? Thanks, Barry
937carrera
Drives: 2000 Polo GTi
Re: Rear Shock Absorbers
Post by 937carrera »
You might find this site useful to get part numbers
https://volkswagen.7zap.com/en/rdw/polo ... 11-511010/
and then a quick google for the part number should get some useful sources :wink:
At the moment online is probably going to be easier than local motor factors or dealers
GSF and ECP give good support
Barlis
Drives: 6N Saloon
Post by Barlis »
That's brilliant - thank you so much! It would be so much simpler if you could just buy the whole unit, shock absorber, spring and all :)
Beachdude
Drives: VW Polo 6N2 1.4 16v
Post by Beachdude »
Did you find a replacement for number 9? It seems to be a part that is longer stocked anywhere that i have looked.
Beachdude
Post by Beachdude »
Barlis wrote: Sun May 03, 2020 10:11 am That's brilliant - thank you so much! It would be so much simpler if you could just buy the whole unit, shock absorber, spring and all :)
Did you find a replacement for number 9? Its a part that i cant find either. Its no longer stocked anywhere.
zoid
Drives: Polo 6n2 GTI
Post by zoid »
Long shot, but I need the exact same parts after trying to replace the rear springs and find the same parts in a bad way, but really struggling to find part no.9 which i think the upper rubber spring mount...
