Problems with BCM MAX Upgrade
86c-polo
Drives: Polo 6r
Post by 86c-polo »
Hello my Polo-friends,
I want to replace the original BCM 6Rxxx087 against the 7Exxx090 but i have some problems.
I am working with VCDS.
So far I replaced the two CAN-wires and took over the codes from 6Rxxx087 to 7Exxx090
1st problem:
Failures with clamp 30 from 09-central-electric and a wrong-coding-failure in the 19-gateway. Battery-regulation is disabeld in the List! Where is the problem? Maybe I have to code something by "coding II" in the gateway - here I need a special security-access.
2nd problem:
The Tailgate don't want to open. "Tailgate-lock short-circute to ground". With the 6Rxxx87 BCM the tailgate-lock is working. In my autoscan the failure is missing, I am sorry, I only noticed it later.
3rd problem:
The cornering-light doesen't works with the 7Exxx090.
Can you please help me? Is the T6-BCM brokken or am I stupid?.
Thank you.
Freitag,15,Mai,2020,00:10:47:28270
VCDS -- Windows-basierter VAG/VAS-Emulator läuft auf Windows 10 x86
VCDS Version: DRV 19.6.2.1
Datenstand: 20191020 DS308.0
www.Ross-Tech.de
Fahrzeug-Ident.-Nr.: WVWZZZ6RZCY094318   KFZ-Kennzeichen: T TEST
Kilometerstand: 153770km   Reparaturauftrag:
Fahrzeugtyp: 6R-VW25 (7E0)
Scan: 01 03 04 08 09 10 15 17 19 25 44 56
Fahrzeug-Ident.-Nr.: WVWZZZ6RZCY094318   Kilometerstand: 153770km
01-Motorelektronik -- Status: i.O. 0000
03-Bremsenelektronik -- Status: i.O. 0000
04-Lenkwinkelsensor -- Status: i.O. 0000
08-Klima-/Heizungsel. -- Status: i.O. 0000
09-Zentralelektrik -- Status: Fehler 0010
10-Einparkhilfe 2 -- Status: i.O. 0000
15-Airbag -- Status: i.O. 0000
17-Schalttafeleinsatz -- Status: i.O. 0000
19-Diagnoseinterface -- Status: Fehler 0010
25-Wegfahrsperre -- Status: i.O. 0000
44-Lenkhilfe -- Status: i.O. 0000
56-Radio -- Status: nicht angemeldet 0000
61-Batterieregelung -- Status: Fehler 0010
Adresse 01: Motorelektronik (J623-CAYB)       Labeldatei:. DRV\03L-906-023-CAY.clb
   Teilenummer SW: 03L 906 023 MA    HW: 03L 907 425 B
   Bauteil: R4 1.6l TDI   H33 9978
   Revision: --H33---    Seriennummer:
   Codierung: 00114036002400080000
   Betriebsnr.: WSC 00788 648 00255
   ASAM Datensatz: EV_ECM16TDI02103L906023MA 003011
   ROD: EV_ECM16TDI02103L906023LL.rod
   VCID: 71EF91F4A0C774C759-8024
Kein(e) Fehlercode(s) gefunden.
Readiness: 0 0 0 0 0
Adresse 03: Bremsenelektronik (J104)       Labeldatei:. DRV\6R0-907-37x-ESP82.clb
   Teilenummer SW: 6R0 907 379 AK    HW: 6R0 907 379 AF
   Bauteil: ESP8.2i front H05 0001
   Revision: --------
   Codierung: 210228E3417600B6842814E382D900421700
   VCID: 071BDF2CB2435A77E7-8052
Adresse 08: Klima-/Heizungsel. (J255)       Labeldatei: 6R0-907-044.clb
   Teilenummer SW: 6R0 907 044 H    HW: 6R0 907 044 H
   Bauteil: Climatronic   H11 0711
   Revision: V0000000
   VCID: 38796CD08B3DE58F5E-806C
Adresse 09: Zentralelektrik (J519)       Labeldatei:. DRV\7E0-937-BCM-V1.clb
   Teilenummer SW: 7E0 937 090     HW: 7E0 937 090
   Bauteil: BCM PQ25 Max4 H80 0736
   Revision: B9080001    Seriennummer: 0771 188151302
   Codierung: 3CB029BF08A1000001280E006D2B0FD00080412F008E0844200000000000
   Betriebsnr.: WSC 36402 001 104857
   VCID: 68D9FC909B1DB50F0E-803C
   Subsystem 1 - Teilenummer: 1K0 955 559 AH  Labeldatei: DRV\1K0-955-559-AG.CLB
   Bauteil: RLS 150911 05  54  0403
   Codierung: 03302D
   Subsystem 2 - Teilenummer SW: 6R0 959 801 AB    HW: 6R0 959 801 AB  Labeldatei: 6R0-959-801.CLB
   Bauteil: J386__TSG_FT  008 1621
   Seriennummer: KU0KU005091100014001
   Codierung: 00BC30
   Subsystem 3 - Teilenummer SW: 6R0 959 802 AD    HW: 6R0 959 802 AD  Labeldatei: 6R0-959-802.CLB
   Bauteil: J387__TSG_BT  008 1621
   Seriennummer: KU0KU006091100011135
   Codierung: 08BC30
   Subsystem 4 - Teilenummer SW: 5K0 959 542 C    HW: 5K0 959 542 C
   Bauteil: E221__MFL-TAS  H31 0033
   Seriennummer: 0410525
   Codierung: 820000
2 Fehlercodes gefunden:
01516 - Klemme 30 links
            011 - Unterbrechung
             Umgebungsbedingungen:
                    Fehlerstatus: 01101011
                    Fehlerpriorität: 3
                    Fehlerhäufigkeit: 4
                    Verlernzähler: 67
                    Zeitangabe: 0
00927 - Klemme 30 rechts
            011 - Unterbrechung
                    Fehlerpriorität: 3
                    Fehlerhäufigkeit: 4
                    Verlernzähler: 67
                    Zeitangabe: 0
Adresse 10: Einparkhilfe 2 (J446)       Labeldatei:| DRV\6R0-919-475.clb
   Teilenummer SW: 6R0 919 475 C    HW: 7E0 919 475
   Bauteil: PARKHILFE 4K  H11 0013
   Revision: --------    Seriennummer: 47301125100288
   Codierung: 108001
   ASAM Datensatz: EV_VW250ParkiAssis2 S01008
   ROD: EV_VW250ParkiAssis2.rod
   VCID: 3E757AC8A119DBBF94-806A
Adresse 15: Airbag (J234)       Labeldatei:| DRV\5K0-959-655.clb
   Teilenummer SW: 6R0 959 655 K    HW: 6R0 959 655 K
   Bauteil: VW10Airbag01K H09 0020
   Revision: --------    Seriennummer: 003GX00VMR8B
   Codierung: 00314B
   ASAM Datensatz: EV_AirbaVW10BPAVW250 A01001
   ROD: EV_AirbaVW10BPAVW250.rod
   VCID: 4A9D2618EDD1671F38-801E
   Crashsensor für Seitenairbag Fahrerseite:
   Seriennummer: 3575HRB405F0P3TEG8R6
   Crashsensor für Seitenairbag Beifahrerseite:
   Seriennummer: 3585HRB405F0P3TE9O5.
   Crashsensor für Seitenairbag hinten Fahrerseite:
   Seriennummer: 3515RRB405D0N4A8H1IA
   Crashsensor für Seitenairbag hinten Beifahrerseite:
   Seriennummer: 3525RRB405D0N4A8K0NI
Adresse 17: Schalttafeleinsatz (J285)       Labeldatei:| DRV\5K0-920-xxx-17.clb-SRI1
   Teilenummer SW: 6R0 920 861 H    HW: 6R0 920 861 H
   Bauteil: KOMBI         H04 0206
   Seriennummer: 00000008724442
   Codierung: 140E01
   Betriebsnr.: WSC 49271 126 82202
   ASAM Datensatz: EV_DashBoardUDSJCIPQ25 A01015
   ROD: EV_DashBoardUDSJCIPQ25_A01.rod
   VCID: 3A7D76D8BD31F79FA8-806E
Adresse 19: Diagnoseinterface (J533)       Labeldatei:. DRV\7E0-909-901.clb
   Teilenummer SW: 7E0 909 901     HW: 7E0 937 090
   Bauteil: GW-K-CAN TP20 H80 0736
   Revision: B9080001
   Codierung: 042000
1 Fehler gefunden:
01044 - Steuergerät falsch codiert
            000 - -
                    Fehlerstatus: 01100000
                    Fehlerpriorität: 2
                    Fehlerhäufigkeit: 1
                    Verlernzähler: 255
                    Kilometerstand: 153777 km
                    Zeitangabe: 0
                    Datum: 2014.10.06
                    Zeit: 00:03:56
Adresse 25: Wegfahrsperre (J285)       Labeldatei:. DRV\5K0-920-xxx-25.clb
   Bauteil: IMMO          H04 0014
   Seriennummer:
   ASAM Datensatz: EV_ImmobUDSJCIPQ25 A01001
   ROD: EV_ImmobUDSJCIPQ25.rod
Adresse 44: Lenkhilfe        Labeldatei: DRV\6Q0-423-156.clb
   Teilenummer: 6R0 423 156 B
   Bauteil: LenkhilfeTRW        V277
   Codierung: 11280
   VCID: 2F6B578CEA7322370F-807A
Adresse 56: Radio (J503)       Labeldatei:. DRV\5M0-035-1xx-56.clb
   Teilenummer SW: 6RD 035 187 A    HW: 6RD 035 187 A
   Bauteil: MIB2-S-R-CN   025 0210
   Revision: -----001    Seriennummer: 11185GD2114114
   Codierung: 0000040002000A
   Betriebsnr.: WSC 00081 790 00127
   VCID: 45871524CCCF8867D5-8010
Ende----------------------------(Dauer: 02:19)-----------------------------
Re: Problems with BCM MAX Upgrade
Well, what you need to do:
- Get the coding of your 087 BCM + gateway + gateway installation list
- Make adaptations of BCM and gateway
- Place the 7E0 BCM and paste coding + adaptations into the BCM and gateway and restore gateway instalation list
- Check 61 battery monitor on gateway
- Code 61 battery monitor to 000000
- Remove 61 battery monitor from gateway installation list
- Match keys
- Verify all is working
Now you need to adapt the wiring of your BCM 087 to the 7E0 BCM Max.
You indeed need new wires for the CAN network of the instrument cluster.
But you need to do more. Depending on the current equipment you need to add another set of wiring.
And the you need to code the BCM Max for the new wiring configuration.
86c-polo
Drives: Polo 6r
Post by 86c-polo »
61 battery-monitor is disabel in the installation-list - neverthesless the gateway think battery-monitor installed!? I don*t know what to do next. Is VCDS enought or is somthing to flash?
Here I have a new Autoscan from this evening.
Mittwoch,03,Juni,2020,23:13:55:28270
www.Ross-Tech.de
Fahrzeug-Ident.-Nr.: WVWZZZ6RZCY094318   KFZ-Kennzeichen: 7E090 87
Kilometerstand: 154060km   Reparaturauftrag:
Fahrzeug-Ident.-Nr.: WVWZZZ6RZCY094318   Kilometerstand: 154060km
56-Radio -- Status:  i.O. 0000
   Revision: --------
   Revision: V0000000
   Codierung: 3CB02DBF08A1000001280E006D2B0FD09080412F008E0854200000000000
   Codierung: 03302D
   Codierung: 00BC30
   Codierung: 08BC30
   Codierung: 820000
3 Fehlercodes gefunden:
00329 - Ansteuerung für Entriegelung Heckklappe
            007 - Kurzschluss nach Masse
                    Fehlerstatus: 01100111
                    Fehlerpriorität: 2
                    Fehlerhäufigkeit: 1
                    Verlernzähler: 78
                    Kilometerstand: 154064 km
                    Zeitangabe: 0
                    Datum: 2014.10.25
                    Zeit: 23:10:55
            011 - Unterbrechung
                    Fehlerpriorität: 3
                    Fehlerhäufigkeit: 5
                    Verlernzähler: 78
                    Zeitangabe: 0
                    Datum: 2014.10.25
                    Zeit: 23:01:38
            011 - Unterbrechung
                    Fehlerpriorität: 3
                    Fehlerhäufigkeit: 5
                    Verlernzähler: 78
                    Zeitangabe: 0
                    Datum: 2014.10.25
                    Zeit: 23:01:38
   Codierung: 108001
   Codierung: 00314B
   Codierung: 140E01
   Revision: B9080001
   Codierung: 002000
1 Fehler gefunden:
            000 - -
                    Fehlerpriorität: 2
                    Fehlerhäufigkeit: 1
                    Verlernzähler: 255
                    Kilometerstand: 153812 km
                    Zeitangabe: 0
                    Datum: 2014.10.06
                    Zeit: 01:14:48
   Seriennummer:
   Codierung: 11280
Ende----------------------------(Dauer: 02:18)-----------------------------
But the tailgate which does*t working is the bigger Problem. Have you some electrical-plans from the T6? I have them only from the 6R.
86c-polo
Drives: Polo 6r
Post by 86c-polo »
Nobody an idea about the Tailgate??
Franciswat
Drives: 6R 1.6 Bifuel
Post by Franciswat »
In order to get help you have to specify all the wirings and coding you have made. Without this informations no one can help you.
If you search on forums there are many tutorials about how installing a bcm max in a 6R.
Hallo 86c-polo
Please post an autoscan with the old BCM 087 installed. Look in the 'logs' folder of the VCDS program.
New BCM coding
3CB02DBF08A1000001280E006D2B0FD09080412F608E0854200000000000
Tell us the result.
At least the fault in the GW must be gone. Maybe now the opening of the Tailgate works. :?:
The donor car's BCM 090 had a Bluemotion system, which means it had a Battery Monitoring Control Module (61).
Module 61 can be removed from the installation list with the following procedure:
1- Go to Gateway 19, installation list, enable 61 (again).
2- Go to Battery monitoring 61 (now enabled), codify to 000000.
3- Come back to Gateway 19, installation list, disable 61.
4- Go to autoscan, click on GW installation list (not on Start), wait the result, clear all DTCs, wait the result ...
Module 61 must have disappeared from the installation list.
5- Check with a new Autoscan (Start button).
86c-polo
Drives: Polo 6r
Post by 86c-polo »
61 - Battery Monitor is now disabeled! Thank you!
But the Tailgate still doesn*t working, and the clamp-30-failure is still available.
I made two new Autoscans, one with the old 087 and one with the 090 inclusive your new codes in byte 20
Montag,08,Juni,2020,13:12:48:28270
www.Ross-Tech.de
Fahrzeug-Ident.-Nr.: WVWZZZ6RZCY094318   KFZ-Kennzeichen: 090 8.6.
Kilometerstand: 154520km   Reparaturauftrag:
Fahrzeug-Ident.-Nr.: WVWZZZ6RZCY094318   Kilometerstand: 154520km
56-Radio -- Status: nicht angemeldet 0001
Readiness: 0 0 0 0 1
   Revision: --------
   Revision: V0000000
   Codierung: 3CB02DBF08A1000001280E006D2B0FD0F08041FF608E0854200000000000
   Codierung: 03302D
   Codierung: 00BC30
   Codierung: 08BC30
   Codierung: 820000
            011 - Unterbrechung
                    Fehlerpriorität: 3
                    Fehlerhäufigkeit: 1
                    Verlernzähler: 78
                    Kilometerstand: 154521 km
                    Zeitangabe: 0
                    Datum: 2014.10.30
                    Zeit: 13:08:04
            011 - Unterbrechung
                    Fehlerpriorität: 3
                    Fehlerhäufigkeit: 1
                    Verlernzähler: 78
                    Zeitangabe: 0
                    Datum: 2014.10.30
                    Zeit: 13:08:04
   Codierung: 108001
   Codierung: 00314B
   Codierung: 140E01
   Revision: B9080001
   Codierung: 002000
1 Fehler gefunden:
            000 - -
                    Fehlerpriorität: 2
                    Fehlerhäufigkeit: 1
                    Verlernzähler: 255
                    Zeitangabe: 0
                    Datum: 2014.10.30
                    Zeit: 13:08:04
   Seriennummer:
   Codierung: 11280
Ende----------------------------(Dauer: 02:37)-----------------------------
ps. I know all the tutorials for BCM Max in this forum, but I didn't found some informations about the tailgate! They describe only the wiring for the light.
- The faults related to terminal 30 will remain until the adaptation wiring for the new BCM is installed. (logically)
- Tailgate (rear lid):
The current BCM coding is correct for it to function properly.
In BCM Adaptation channels, verify that channel 7 has a value = 0
If it has a value = 0 and the tailgate doesn't open, it is highly possible that the microswitch for opening has broken. 6R6827469D ULM
If you want, check again with BCM 087 that the tailgate opening works... :?: :?
It is not important, but:
... you have changed the HEX value of Byte19 in BCM coding, from 2F to FF, any special reason?
86c-polo
Drives: Polo 6r
Post by 86c-polo »
Yeah, the detetion for light-failures (Byte 19) is useless for me. I use LED retrofits 8)
The microswitch is working. I tested it with the diagnosic-tool and at the moment I am driving with the 087 - because the tailgate doesn't want to open with 090.
I think the tailgate-motor V53 gets his current from clamp 30 by the 090, too. So I have to install the other wires and test the Tailgate again.
Your help is pretty usefull.
The BCMs for Transporter (T5.1 - T6), Amarok, 6R have the same current input (+30) assigned for the central locking system (ZV).
It is a +30 power cable that reaches T73a/16, this cable is present in your 6R. (from SB48)
The power cables (in addition to the other signals) for the new BCM that you have to install in the future are only for the lighting system.
Something weird is going on here ... :lol: ... maybe it's some adaptation channel.
If you want, post here the values ​​of the adaptation channels of both BCMs ... or check them yourself to find the differences. (remember, the same coding for both BCMs)
:arrow: https://drive.google.com/drive/folders/ ... sp=sharing
