Thermostat Housing
Docbooze
Thermostat Housing
Post by Docbooze »
Got a leak coming form the top bolt (head seal part) on my mk3 1050 genesis. Took the unit apart yesterday and the o - ring and housing seems in good condition but the groove that the o-ring sits in has a gap of about an inch at the bottom.
Is this supposed to be like this or is the groove supposed to go all the way round with no gaps?
Cheers for any advice ...............
polo_1.3_gt
Re: Thermostat Housing
Post by polo_1.3_gt »
did u manage to get the answer u wanted coz i am experincing the same leak cumin from top bolt so i rekin it wud need some sort ov sealant on there or possibly new ring dude
alexperkins
Site Admin
Post by alexperkins »
Its a common failure on these - The thermostat housing cracks around the bolt mounts and leaks and it just gets worse over time. Cheapest and most effective solution is to just buy a brand new thermostat and thermostat housing from GSF and replace it all :)
cannonfodder4j
Drives: 1.4
Post by cannonfodder4j »
Im about to change out the thermostat housing and thermostat.
Do i need to apply some type of sealant between the housing and block?
The thermostat came assembled already, should i remove, apply sealant and reassemble?
thanks
alexperkins
Site Admin
There isn’t a need to but a sealant such as Hylomar Blue can be used
