Franciswat's Polo 6R 1.6 Bifuel
Re: Franciswat's Polo 6R 1.6 Bifuel
Maybe and with great care you can remove that small wrinkle with a steamer, in which case you must also take into account the level of dirt on the entire roof.
- Franciswat
- Drives: 6R 1.6 Bifuel
thank u for the suggestion I like it.
I'm just a bit worried heat may compromise the glue . this roofs are not so good. I was thinking to try first by adding something behind the crack to increase the tension. what do you think mate?
I don't know, many ideas can come up to fix it and any one of them can be catastrophic... and you will be forced to buy a new roof.
I agree with you regarding the quality of the materials after a certain amount of time. Many peeled roofs can be seen...
Perhaps it is best to do nothing, time and environmental situations can cure it.
- Franciswat
That's true, I will wait sometime and see if time can fix it.ciclo wrote: Sun Aug 09, 2020 8:44 pm Perhaps it is best to do nothing, time and environmental situations can cure it.![]()
Thanks Fernando.
Today I retrofitted my new Composition Media MIB2 PQ.
Looks like my car doesn't like It.
It's not impossible to code Radio with 56-Radio, I think It's now in 5F-Information Electr.
My idea is now to untick Radio in Gateway list and tick 5F-Information Electr.
The major issue is volume which randomly works. I think it can be fixed with proper coding.
I'll try tomorrow. Hope no need to add a gateway.
Monday,10,August,2020,20:34:11:39744
VCDS Version: 17.1.3.0 (x64)
Data version: 20170203 DS267.2
www.Ross-Tech.com
VIN: WVWZZZ6RZCY540000 License Plate:
Chassis Type: 6R (7E0)
Scan: 01 03 04 08 09 10 15 17 19 25 44 55 56 5F 77 0B
VIN: WVWZZZ6RZCY540000 Mileage: 108200km-67232miles
56-Radio -- Status: OK 0000
5F-Information Electr. -- Status: Not registered 0011
61-Battery Regul. -- Status: Malfunction 0010
77-Telephone -- Status: Not registered 0001
Address 01: Engine
Cannot be reached
Address 03: ABS Brakes (J104) Labels: 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 BC HW: 6R0 907 379 AF
Component: ESP8.2i front H05 0002
Revision: --------
Coding: 210228E3217100B5842514E484D700401300
Shop #: WSC 00788 648 00255
VCID: 00085B4297984341E9-8054
Part No SW: 6R0 907 044 H HW: 6R0 907 044 H
Component: Climatronic H12 0812
Revision: V0000000
VCID: 3878F3A28BC8CB8111-806C
Address 09: Cent. Elect. (J519) Labels: 7E0-937-BCM-V1.clb
Part No SW: 7E0 937 090 HW: 7E0 937 090
Revision: B9080001 Serial number: 0771 060161479
Coding: 3CB02BB808E1240093380E916CEB0FD9DAC0672F608D30D1200000030000
Shop #: WSC 02737 534 00190
VCID: 68D863E29BE89B0141-803C
Subsystem 1 - Part No: 5K7 955 559 B Labels: 5K7-955-559.CLB
Component: RLS 080515 03 37 0059
Coding: 0228DD
Subsystem 2 - Part No SW: 6R0 959 801 AB HW: 6R0 959 801 AB Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 008 1611
Serial number: KU0KU004011200011991
Coding: 18BC30
Subsystem 3 - Part No SW: 6R0 959 802 AD HW: 6R0 959 802 AD Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 008 1611
Serial number: KU0KU005011200017885
Coding: 08BC30
Component: DWA-Sensor 00 001 0103
Subsystem 5 - Part No: 1K0 951 605 F
Component: LIN BACKUP HO H01 0008
Subsystem 8 - Part No SW: 6R0 959 811 G HW: 6R0 959 811 G
Component: J388__TSG_HL 008 1611
Serial number: KU0KU010011200012406
Coding: 08BC32
Subsystem 9 - Part No SW: 6R0 959 812 G HW: 6R0 959 812 G
Component: J389__TSG_HR 008 1611
Serial number: KU0KU009011200013136
Coding: 08BC32
Address 10: Park/Steer Assist (J446) Labels: 7E0-919-475.clb
Part No SW: 7E0 919 475 L HW: 56D 919 475
Component: PARKHILFE 8K H02 0106
Revision: -------- Serial number: 20231629400567
Coding: 108001
Shop #: WSC 12345 123 12345
ASAM Dataset: EV_VW75XParaKssis8K 001003
ROD: N/A
VCID: 3B72ECAEB2FEE099FC-806E
No ASAM data for: "EV_VW75XParaKssis8K" (VW25)
Component: VW10Airbag022 H09 0020
Revision: -------- Serial number: 003GX011W0JJ
Coding: 003232
ASAM Dataset: EV_AirbaV1W0BPAVW250 A01001
ROD: N/A
VCID: 4A9CB96AED24491177-801E
Subsystem 1 - Serial number: 3575HRB4059124B2F99H
Subsystem 2 - Serial number: 3585HRB4061131GQCOUS
Subsystem 3 - Serial number: 3515RRB405P0VC0I5P0W
Subsystem 4 - Serial number: 3525RRB40510VC0IA9B9
No ASAM data for: "EV_AirbaV1W0BPAVW250" (VW25)
Part No SW: 6R0 920 871 A HW: 6R0 920 871 A
Component: KOMBI H03 0505
Coding: 140E00
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04113
VCID: 3460C7929FA02FE13D-8060
Address 19: CAN Gateway (J533) Labels: None
Part No SW: 7E0 909 901 HW: 7E0 937 090
Revision: B9080001
Coding: 002200
1 Fault Found:
000 - -
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 2
Reset counter: 255
Mileage: 108202 km
Time Indication: 0
Date: 2015.01.01
Time: 02:15:35
Component: IMMO H03 0505
Serial number:
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_Immo_UDS_VDDR_M09 A03009
ROD: N/A
VCID: 6ADC19EA8DE4A91157-803E
No ASAM data for: "EV_Immo_UDS_VDDR_M09" (VW36 *)
Part No: 6R0 423 156 B
Component: LenkhilfeTRW V277
Coding: 11250
Shop #: WSC 00788
VCID: 2F6AC8FEEA860C3940-807A
Address 55: Headlight Range (J431) Labels: 6R0-907-357.clb
Part No SW: 6R0 907 357 HW: 6R0 907 357
Component: LWR-ECU H02 0070
Revision: -------- Serial number: --------------
Coding: 0110000001000000
ASAM Dataset: EV_HeadlReuglVWLWRPt 001004
ROD: N/A
VCID: 77FA309ECE5604F9D8-8022
No ASAM data for: "EV_HeadlReuglVWLWRPt" (VW25)
Address 56: Radio
Cannot be reached
Address 5F: Information Electr. (J794) Labels: None
Part No SW: 5K7 035 200 K HW: 5K7 035 200 K
Component: MU-S-D-ER H41 0449
Serial number: VWZAZ2T5211382
Coding: 02230500AA0000001111110300880A001F0100D40020010003
Shop #: WSC 00066 790 00451
ASAM Dataset: EV_MUStd4CTAST 001022
ROD: N/A
VCID: 2C50DFF24790772165-8078
No ASAM data for: "EV_MUStd4CTAST" (VW25)
4 Faults Found:
1562 - ROD - Unknown Error Code
- 00 [009]
Fault Status: 00000001
Fault Priority: 4
Fault Frequency: 1
Reset counter: 21
Mileage: 108202 km
Date: 2020.08.10
Time: 02:15:34
7169 - ROD - Unknown Error Code
- 00 [009]
Fault Priority: 6
Fault Frequency: 1
Reset counter: 21
Mileage: 108202 km
Date: 2020.08.10
Time: 02:15:36
7194 - ROD - Unknown Error Code
- 00 [009]
Fault Priority: 6
Fault Frequency: 1
Reset counter: 21
Mileage: 108202 km
Date: 2020.08.10
Time: 02:15:36
0001 - ROD - Unknown Error Code
- 00 [009]
Fault Priority: 6
Fault Frequency: 1
Reset counter: 21
Mileage: 108202 km
Date: 2020.08.10
Time: 02:15:34
Address 77: Telephone
Cannot be reached
End-------------------------(Elapsed Time: 03:39)--------------------------- Franciswat
After many troubles radio works fine.
Still got "open circuit error" for the Antenna, probably because I'm using an adaptor female twin -> male single (don't have diversity sound system).
I ordered a new adaptor so I can see If something change.
patil
Hello franciswat!
For correct operation of your composition media:
You should disable(deselect) address 56 in gateway installation list and enable (select) address 5F and address 77.
- Franciswat
Hi Patil, thanks for the info.
Have you installed a CM/DM?
This is my radio startup!
https://youtu.be/yjb7JuEbwo8
Today a package arrived!
patil
Nice composition mediaFranciswat wrote: Fri Aug 14, 2020 8:50 pm Hi Parole, thanks for the info.![]()
Today a package arrived!![]()
I have installed Discover media software unlocked version.
Good luck with your new side assist retrofit
- Franciswat
Nice radio Patil! I'm experimenting a slow startup with radio logos.
Do you have same issue with your DM?
patil
Have you loaded radio logo's manually or they are automatically loading from broadcasting radio stations?Franciswat wrote: Sun Aug 16, 2020 2:01 pm Nice radio Patil! I'm experimenting a slow startup with radio logos.
I have loaded logo's manually and they instantly load.
- Franciswat
Logos were loaded automatically, I just manually added few missing one.patil wrote: Sun Aug 16, 2020 2:24 pmHave you loaded radio logo's manually or they are automatically loading from broadcasting radio stations?Franciswat wrote: Sun Aug 16, 2020 2:01 pm Nice radio Patil! I'm experimenting a slow startup with radio logos.
I'll try to delete al of them and add manually, thanks.
- Franciswat
MIB2 PQ Composition Media with DAB+ and APP button
Software unlocked with Voice commands and Smartphone connectivity activated
New connectors, from left: quadlock, aux, FM, DAB
New quadlock connector
USB/aux wiring (glovebox)
USB/aux plug
FM radio
DAB radio
MFA+
USB/aux plug
FM radio
DAB radio
MFA+
Excellent!
Good pics.
Enjoy it Francesco!
I guess in Italy the hazard lights button is used a lot.
(as in many other places
Enjoy it Francesco!
benzinkopf
- Drives: 1.2TSI 105HP DSG7
i just cant laugh without posting here. [emoji23]ciclo’s eyes really sharp.
May I ask why 7E0 radars and not 5Q0?Franciswat wrote:Hi Patil, thanks for the info.![]()
Wysłane z mojego SM-G973F przy użyciu Tapatalka
