[phpBB Debug] PHP Warning: in file [ROOT]/ext/cleantalk/antispam/model/CleantalkSFW.php on line 184: Undefined array key 1 Footwell light polo AW 2018 - Page 2 - UK-POLOS.NET - THE VW Polo Forum
grpipolo wrote: Wed Jun 17, 2020 4:43 am
My name is Gabriel and I’m from Brazil.
I’m also trying to retrofit the footwell lights on my 𝐏𝐨𝐥𝐨 aw.
I installed them and did the coding with vcds. Everything is working, except that the option to reduce/increase the brightness is not showing on my screen...
do you have any ideia what’s happening?
Thank you!
Hi grpipolo, I have a GTS also. I wire all like in this post and coding also but no idea why is not working.
I have in the infortainment the bar to set the % of the power light.
Out of interest, has anyone changed the colour of the LED bulbs in the ambient lighting?
Something other than white would be nice, my 2009 Mini allowed a choice of colours.
Should be do-able in the door handles, middle cubby hole and footwells?
Obviously the strips along the dash and door would be more difficult, I'm happy to leave those white.
Thank you!
Olá! Tu conseguiu resolver isto?
Qual o pino do chicote que instalou o positivo da footwell ?
Thank you!
Valeu
You must use the PIN 64 of Connector "C" from BCM, as image in the previous posts.
and use the code configuration above, about Leuchte32AMBL 2C64
