Polo 1,4 TDI Cruise Controll
taylan34
Drives: Silver
Post by taylan34 »
Hallo
I wanted my Polo6C 1.4 TDI 3 cylinder 2014 75 HP
WVWZZZ6RZFY133526
Retrofitting cruise control, what have I done so far.
- Steering column switch exchanged
- 6 cables pinned to the steering column switch
- BCM (6C0937087A) 4 cables pinned
- 1 cable laid to fuse 37A
- 1 MSG pin 44 cable pinned
my problem as soon as I activate VCDS in MSG GRA I get a drive train error and an implausible signal
what doesn't fit there.
Re: Polo 1,4 TDI Cruise Controll
You need to visit the dealership with your activation document. It cannot be done with vcds
taylan34
Drives: Silver
Post by taylan34 »
Thanks for your trouble. One more question is pin 44 the right one.
taylan34
Drives: Silver
Post by taylan34 »
yes it is the right one for your 1.4 TDI engine
taylan34
Drives: Silver
Post by taylan34 »
Hi
Cruise Control successfully activated Toddy I had to buy an Aktivation document for the
GRA from the dealer and have it activated with Odis
@ iichel Thanks for your help.
Gerne :)
