Number plate lights
J_hutchison
Drives: 2017 1.2 TSI
Number plate lights
Post by J_hutchison »
Looking to see if anyone can link me some w5w led lamps. That are canbus error free without fitting in line resistors? Dont fancy messing about with them. Tried a couple led lamps but threw up error codes.
Want to get good leds on that part do the car as I'm planning to get some 3d gel plates.
heftyshooly
Drives: Polo 6C 1.4 TDI BMT
Re: Number plate lights
Post by heftyshooly »
The car expects an incandescent bulb, which draws a lot more current than an LED. There are two ways to get around this, you either make the LED draw more current (by adding a resistor, very dangerous if done incorrectly), or you change the type of load of that lamp in the BCM configurations.
For the latter you need something like VCDS.
J_hutchison wrote: Sun Feb 21, 2021 10:16 pm Looking to see if anyone can link me some w5w led lamps. That are canbus error free without fitting in line resistors? Dont fancy messing about with them. Tried a couple led lamps but threw up error codes.
The linked article in the first post of this discussion thread over on the mk10 forum board might be of interest;
https://www.uk-polos.net/viewtopic.php?f=71&t=75980
J_hutchison
heftyshooly wrote: Mon Feb 22, 2021 8:13 am The car expects an incandescent bulb, which draws a lot more current than an LED. There are two ways to get around this, you either make the LED draw more current (by adding a resistor, very dangerous if done incorrectly), or you change the type of load of that lamp in the BCM configurations.
Might just try find a couple nice looking halogens then. Dont want to start messing about with resistors and the wiring.
peter_dk25
Drives: Blue GT
Post by peter_dk25 »
Why not just buy 2 OEM LED: 1K8943021D works without any problems....
J_hutchison
peter_dk25 wrote: Sun Feb 28, 2021 8:19 am Why not just buy 2 OEM LED: 1K8943021D works without any problems....
Are either of the links below the right thing? Error free and right size?
Second link definelty covers polo 2017 in the list. First just says polo
https://www.ebay.co.uk/itm/2-LED-Licens ... 890.l49292
https://www.ebay.co.uk/itm/VW-Golf-GTI- ... 890.l49292
I'm only guessing here, but if you buy them you might need to mess about with the wiring so that the car side cabling fits.
Not an impossible job if it needs doing, though making sure that the new connector/joining is water proof would save a lot of bother later on.
J_hutchison
The second one I seen in a YT video and was just plug and play which is what I'm looking for cause I dont want to start messing with wiring tbh
peter_dk25
Drives: Blue GT
J_hutchison wrote: Mon Mar 01, 2021 9:03 pm
None of them are OEM. These will fit your Polo:
https://www.cars-equipment.com/en/shop/ ... ate-light/
J_hutchison
peter_dk25 wrote: Tue Mar 02, 2021 6:30 am
Thanks, so even though they dont say for polo they are still going to fit and not cause any errors? as it doesn't say anything about having resistors etc so its expensive at 14 quid each and doesnt seem to have anything to prevent canbus errors
peter_dk25
Drives: Blue GT
I have them installed in my Blue GT.
Works and fits perfect without any problems...
J_hutchison
peter_dk25 wrote: Wed Mar 03, 2021 6:30 am I have them installed in my Blue GT.
Thanks mate just wanted to make sure as errors are a pain!
Will get a couple to fit :mrgreen:
