6C Full LED Headlights number
ZahariGeorgiev
- Drives: Polo 6R 1.6 TDI
Hello,
Can somebody help me a little bit.... Everywhere in descriptions of retrofitting the Led headlights, is written to use for the left headlight - 6C1 941 773 / and for the right - 6C1 941 774. I find them only with this numbers: 6C1 941 035 and 6C1 941 036, my question is: Are they compatible to retrofit in 6R??! I already change my BCM to 7E0937090 and install oem auto lights, so now the only thing i have to do, is to install the Automatic Headlight Range control and to find those headlights and connect them properly.
Re: 6C Full LED Headlights number
Yes, these are the correct numbers for LHD. 6C2... is RHD.
You BCM needs to be correct for LED headlights, remember this. it is not possible to tell by the part number, as written on the BCM itself, whether it's correct. You need to check the Z code to. But unless you buy it new, it is very very difficult to find out what the Z code was.
ZahariGeorgiev
Thank you very much iichel!
And how to check that "Z" code
either you buy it new, or you must check in the official VW catalogue (ETKA/Partslink24), with the donor vehicles VIN
ZahariGeorgiev
Hmm i already buy 7E0937090 and install it on my car, in order to fix illumination for my new steering wheel. I hope it will be compatible with the new headlights
Today i just saw good offer for interior mirror with camera - 7E0857511F, order it and now the things are getting interesting
I found 2 secondhand LED headlights /still waiting answer from the seller/ and then i will order from Kufatec the automatic headlight range control set. Will gonna need little help with HBA and LED wirng... And i have 1 question: Do i need to replace my stalks in order to work that HBA? and if yes with what number
Thanks in advance!
Thanks in advance!
The BCM can be parameterized with VCP so that everything works correctly for your new LED headlights.
Check my reply to your private message in your inbox.
I subscribe to this thread, I think it is better that we continue talking here instead of by private message ...
ZahariGeorgiev
I just found and order used module - 6R0907357C, now the remaining parts are: holder for the module - 6R0971845K, level sensor - 6R0941273B, brake line holder - 6R0612405, and for the wiring i think to order this ones: https://www.kufatec.com/de/volkswagen/v ... o-6r-38394
and to reconfigure this : https://www.kufatec.com/de/volkswagen/v ... o-6r-38357
Much better than the original idea.
Don't forget to check out the firegrafik, TinyQ and CNK topics on Drive2.ru.
I think that with that information and the one I provided you by email, you already have all the information you need to have fun with your project.
If you get stuck at any point, come back here and ask.
ZahariGeorgiev
Can somebody tell me what is the part number for the cover cap for turn signals?
RelaxedRedPanda
- Drives: VW Polo 6C 1.2TSI
Cover cap should be 6R0 941 607
ZahariGeorgiev
Thanks iichel,
I order 2 pcs of 6R0941607, but inside of package are cover cap for dipped beam...
Last edited by ZahariGeorgiev on Wed Jun 09, 2021 12:33 pm, edited 1 time in total.
Interesting. Perhaps 6C0941607?
RelaxedRedPanda
That is the one you're talking about right?
ZahariGeorgiev
Yep, this is it!
