Can I use 7E0937090C for BCM upgrade?
Lucero79
Drives: Polo
Post by Lucero79 »
I see confusing things around upgrading to the Transporter 7E0937090C BCM.
Most people seem to understand the last character of the part to be revision (C in this case), but for the BCM, I have also seen that this can denote markets, and therefore radio frequency for the remote fobs
BCMs with 434 MHz radio carrier frequency BCM ends with the letters B, D, F, H, K, M, P, R, T. These BCMs are used in India, EU, South Africa and Russia.
BCMs with 315 MHz radio carrier frequency BCM ends with the letters A, C, E, G, J, L, N. These are used in Mexico.
Is this true for the 7E0 Transporter BCMs too?
Re: Can I use 7E0937090C for BCM upgrade?
No it is not, I believe, but am not sure, that 315MHz BCMs end in 189/190. But not sure.
Lucero79
Drives: Polo
Post by Lucero79 »
iichel wrote: Tue Jun 29, 2021 11:13 am No it is not, I believe, but am not sure, that 315MHz BCMs end in 189/190. But not sure.
Thanks iicehl, that makes sense, as opposed to 089/090
So am I ok to get this BCM?
Is anyone still making the looms/kits for the upgrade?
I'd say you're good to go, but would wait for a ciclo to confirm. Iirc you're in a seat Ibiza, there is someone upgrading an ibiza 2.0 TDI to 7e0 bcm. What is your current bcm?
Lucero79
Drives: Polo
Post by Lucero79 »
iichel wrote: Tue Jun 29, 2021 6:22 pm I'd say you're good to go, but would wait for a ciclo to confirm. Iirc you're in a seat Ibiza, there is someone upgrading an ibiza 2.0 TDI to 7e0 bcm. What is your current bcm?
Thanks iichel
I'll need to double check and get back to you.
Do you have a link to the other upgrade thread? I'm just trying to grab as much info as possible.
I mentioned in the other thread, some of the things I'd like to do:
Rear/Front parking sensors
Front Lights OEM Xenon upgrade (LH/CH)
Auto lights
RLS
Possibly swap the entire dash for a facelift model and grab the full screen infotainment, but I think that requires much more work with PQ26 although I did trial fit a RCD330 and that worked.
Sure there's more :)
