Somehow the long code for the ABS has magically poofed and it's causing the ABS light to illuminate on the dash, thus an MOT failure.
I have a 2011 1.2L 3cyl petrol, RHD.
Checked it in VCDS and the long code is all 0s and completely gone somehow.
I would really appreciate some help getting this long code back, I've been trying some I made myself based on research but everything I put in comes up with this error:
Coding rejected
Error 22: Conditions not correct or request sequence error
I'm attempting to code with the engine running.
Here is a full VCDS scan:
Friday,02,July,2021,14:33:41:21320
VCDS Version: 21.3.0.0 (x64) HEX-NET CB: 0.4544.4
Data version: 20210226 DS325.0
www.Ross-Tech.com
VIN: WVWZZZ6RZBU046162 License Plate:
Chassis Type: 6R-VW25 (6N0)
Scan: 01 03 04 08 09 15 17 19 25 44 56
VIN: WVWZZZ6RZBU046162 Mileage: 156360km-97157miles
56-Radio -- Status: Cannot be reached 1100
Address 01: Engine (J623-CGPB) Labels:. 03E-906-019-CGP.clb
Part No SW: 03E 906 019 M HW: 03E 906 019 B
Component: SIMOS11.1 H03 8319
Revision: -------- Serial number:
Coding: 00110016000400080000
Shop #: WSC 31414 790 50316
ASAM Dataset: EV_ECM12MPI02103E906019M 001005
ROD: EV_ECM12MPI02103E906019A.rod
VCID: 2E1001D671440DFB61-807A
3 Faults Found:
6056 - No Communications with HVAC Control Module (J301)
U0164 00 [032] - -
Intermittent - Not Confirmed - Tested Since Memory Clear
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 2
Mileage: 156367 km
Date: 2021.07.02
Time: 14:18:30
Engine RPM: 853.00 /min
Normed load value: 14.5 %
Vehicle speed: 0 km/h
Coolant temperature: 85 °C
Intake air temperature: 45 °C
Ambient air pressure: 1010 mbar
Voltage terminal 30: 13.507 V
Time since engine start: 807 s
Engine torque: 18.96875 Nm
Accelerator pedal travel-Accelerator position: 0.00 %
Ignition angle of current cylinder: actual value-Ignition angle: actual: 8.250 °
6070 - No Communication with Diagnostic Gateway
U0146 00 [032] - -
Fault Priority: 2
Fault Frequency: 2
Mileage: 156367 km
Date: 2021.07.02
Time: 14:18:30
Engine RPM: 846.00 /min
Normed load value: 13.7 %
Time since engine start: 808 s
Engine torque: 20.06250 Nm
Ignition angle of current cylinder: actual value-Ignition angle: actual: 10.125 °
13909 - Implausible Data Received from ABS Control Module
U0415 00 [032] - -
Fault Priority: 2
Fault Frequency: 1
Mileage: 156367 km
Date: 2000.00.00
Time: 00:00:00
Engine RPM: 856.00 /min
Vehicle speed: 6 km/h
Coolant temperature: 84 °C
Time since engine start: 777 s
Engine torque: 14.93750 Nm
Ignition angle of current cylinder: actual value-Ignition angle: actual: 0.375 °
Readiness: 0010 0101
Address 03: ABS Brakes (J104) Labels:. 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 AJ HW: 6R0 907 379 AF
Revision: --------
Coding: 000000000000000000000000000000000000
Shop #: WSC 31414 790 31414
VCID: 06409976B57465BBF9-8052
5 Faults Found:
03306 - Coding Not Valid
000 - -
Fault Status: 01100000
Fault Priority: 0
Fault Frequency: 44
Reset counter: 26
Mileage: 156367 km
Time Indication: 0
Date: 2015.11.23
Time: 14:29:53
Hex Value: 0x0007
Hex Value: 0x0002
Hex Value: 0x3209
Hex Value: 0x14AE
Hex Value: 0x007F
Hex Value: 0x7F7F
Hex Value: 0x7F00
01042 - Control Module; Not Coded
000 - -
Fault Priority: 0
Fault Frequency: 19
Reset counter: 26
Mileage: 156367 km
Time Indication: 0
Date: 2015.11.23
Time: 14:29:53
Hex Value: 0x0007
Hex Value: 0x0002
Hex Value: 0x3211
Hex Value: 0x14AE
Hex Value: 0x007F
Hex Value: 0x7F7F
Hex Value: 0x7F00
00493 - ESP-Sensor Unit (G419)
005 - No or Incorrect Basic Setting / Adaptation
Fault Status: 01100101
Fault Priority: 0
Fault Frequency: 19
Reset counter: 26
Mileage: 156367 km
Time Indication: 0
Date: 2015.11.23
Time: 14:29:53
Hex Value: 0x0007
Hex Value: 0x0002
Hex Value: 0x32E1
Hex Value: 0x20AE
Hex Value: 0x007F
Hex Value: 0x7F7F
Hex Value: 0x7F00
Fault Priority: 0
Fault Frequency: 44
Reset counter: 26
Mileage: 156367 km
Time Indication: 0
Date: 2015.11.23
Time: 14:29:53
Hex Value: 0x0007
Hex Value: 0x0002
Hex Value: 0x3209
Hex Value: 0x14AE
Hex Value: 0x007F
Hex Value: 0x7F7F
Hex Value: 0x7F00
00778 - Steering Angle Sensor (G85)
Fault Priority: 0
Fault Frequency: 2
Reset counter: 26
Mileage: 156369 km
Time Indication: 0
Date: 2015.11.23
Time: 16:54:44
Hex Value: 0x0003
Hex Value: 0x0002
Hex Value: 0x3251
Hex Value: 0x1BAB
Hex Value: 0x006B
Hex Value: 0x7F7F
Hex Value: 0x7C00
Address 08: Auto HVAC (J301) Labels: 6R0-820-045-9AB.clb
Part No SW: 6R0 820 045 F HW: 6R0 820 045 F
Component: Man AC 02 0101
Revision: 0002S 02
VCID: 312A1AAA687A12037C-8064
1 Fault Found:
01336 - Company Data Bus for Comfort System
014 - Defective - Intermittent
Fault Status: 00101110
Fault Priority: 6
Fault Frequency: 2
Reset counter: 12
Mileage: 156367 km
Time Indication: 0
Date: 2011.09.09
Time: 14:18:30
Part No SW: 6R0 937 085 D HW: 6R0 937 085
Component: BCM PQ25 M+ H46 0230
Revision: BB046001 Serial number: 0390 092110366
Coding: 64B02BBF08A10048002008003D2B0C900040410F60060000200000000000
VCID: 3C343B9EBF38EF6BDF-8068
Subsystem 1 - Part No SW: 6R0 959 802 R HW: 6R0 959 802 R Labels: 6R0-959-802.CLB
Component: J386__TSG_FT 006 0903
Serial number: KU0-KU001.10.1012191
Coding: 18BC30
Subsystem 2 - Part No SW: 6R0 959 801 T HW: 6R0 959 801 T Labels: 6R0-959-801.CLB
Component: J387__TSG_BT 006 0902
Serial number: KU0-KU012.10.1012407
Coding: 08BC30
14 Faults Found:
011 - Open Circuit - Intermittent
Fault Status: 00101011
Fault Priority: 2
Fault Frequency: 1
Reset counter: 66
Mileage: 156369 km
Time Indication: 0
Date: 2015.11.23
Time: 15:05:51
03432 - Activation of Right Parking Light
Fault Priority: 2
Fault Frequency: 1
Reset counter: 66
Mileage: 156369 km
Time Indication: 0
Date: 2015.11.23
Time: 15:05:51
03435 - Terminal 30 for Interior Light and Parking Light
Fault Priority: 3
Fault Frequency: 1
Reset counter: 66
Mileage: 156369 km
Time Indication: 0
Date: 2015.11.23
Time: 15:05:45
00329 - Control Circuit for Unlocking Rear Lid
Fault Priority: 2
Fault Frequency: 1
Reset counter: 66
Mileage: 156369 km
Time Indication: 0
Date: 2015.11.23
Time: 15:05:51
03301 - Response Closing Status of Drivers Door
008 - Implausible Signal
Fault Status: 01101000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 26
Mileage: 156369 km
Time Indication: 0
Date: 2015.11.23
Time: 15:05:45
03302 - Response Closing Status of Passenger's Door
Fault Priority: 2
Fault Frequency: 1
Reset counter: 26
Mileage: 156369 km
Time Indication: 0
Date: 2015.11.23
Time: 15:05:45
03303 - Response Closing Status of Rear Left Door
Fault Priority: 2
Fault Frequency: 1
Reset counter: 26
Mileage: 156369 km
Time Indication: 0
Date: 2015.11.23
Time: 15:05:45
03304 - Response Closing Status of Rear Right Door
Fault Priority: 2
Fault Frequency: 1
Reset counter: 26
Mileage: 156369 km
Time Indication: 0
Date: 2015.11.23
Time: 15:05:45
01179 - Incorrect Key Programming
000 - -
Fault Priority: 3
Fault Frequency: 1
Reset counter: 237
Mileage: 92873 km
Time Indication: 0
Date: 2015.02.22
Time: 01:26:06
03396 - Supply voltage terminal 30 for central locking
Fault Priority: 2
Fault Frequency: 1
Reset counter: 66
Mileage: 156369 km
Time Indication: 0
Date: 2015.11.23
Time: 15:05:45
00532 - Supply Voltage B+
002 - Lower Limit Exceeded - Intermittent
Fault Status: 00100010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 66
Time Indication: 0
00446 - Function Limitation due to Under-Voltage
Fault Priority: 6
Fault Frequency: 4
Reset counter: 66
Mileage: 93145 km
Time Indication: 0
Date: 2015.03.21
Time: 00:00:01
01598 - Drive Battery Voltage
000 - - - Intermittent
Fault Status: 00100000
Fault Priority: 3
Fault Frequency: 2
Reset counter: 66
Mileage: 93145 km
Time Indication: 0
Date: 2015.03.23
Time: 00:01:10
03591 - Control Circuit for Horn
Fault Priority: 3
Fault Frequency: 1
Reset counter: 66
Mileage: 156369 km
Time Indication: 0
Date: 2015.11.23
Time: 15:05:46
Component: VW10Airbag027 H09 0020
Revision: -------- Serial number: 003GX00A8L9E
Coding: 003237
ROD: EV_AirbaVW10BPAVW250.rod
VCID: 4AD86D46EDEC41DB5D-801E
Serial number: 3575HRB405N09RECB1DM
Serial number: 3585HRB4061096J64PB
Serial number: 3515RRB406500IUGD99H
Serial number: 3525RRB406500IUGL1LU
Part No SW: 6R0 920 960 E HW: 6R0 920 960 E
Component: KOMBI H04 0304
Coding: 440200
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04086
VCID: 373E24B28E1ECC3332-8062
1 Fault Found:
12664832 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[Steuergerät für BCM / Bordnetz / el. ZE: keine Kommunikation]
Fault Priority: 6
Fault Frequency: 2
Reset counter: 12
Mileage: 156367 km
Date: 2021.07.02
Time: 14:18:30
Address 19: CAN Gateway (J533) Labels:. 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 6R0 937 085
Component: GW-K-CAN TP20 0230
Coding: 002300
VCID: 70ACDFAEA3F05B0B33-8024
1 Fault Found:
01304 - Radio
004 - No Signal/Communication
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 61
Reset counter: 26
Mileage: 0 km
Time Indication: 0
Date: 2015.03.02
Time: 09:43:04
Component: IMMO H04 0304
Serial number:
Shop #: WSC 00000 000 00000
VCID: 6A98CDC68D2CA1DB7D-803E
Part No: 6R0 423 156 B
Component: LenkhilfeTRW V277
Coding: 11250
Shop #: WSC 31414
VCID: 2F2E1CD2EA4E04F36A-807A
1 Fault Found:
49-10 - No Communications - Intermittent
Address 56: Radio
Cannot be reached
End----------(Elapsed Time: 01:21, VBatt start/end: 13.2V/13.2V)-----------
ABS: Part No SW: 6R0 907 379 AJ HW: 6R0 907 379 AF
ESP8.2i
The code I came up with was as follows:
200224E3017100B8042624E884D300800170
Any help is greatly appreciated. I can only get it retested today before I need it for the weekend, so if someone comes in and saves me before the garage shuts in 3 hours you're a legend.
(I would post on RossTech but I don't have a forum account and I understand it takes a bit of time to get authorised to post in certain sections so hoping someone can help me here)
