EPC and Check Engine
Nikolai001
Drives: Polo Mk6 2017
Post by Nikolai001 »
Quick post as I am currently in absolute despair
My EPC light and check engine randomly came on
Throttle feels like it's skipping
As soon as I turn the engine on it states that there is an error with the start/stop
Reverse refused to work
Revs capped at 2k I presume it's the engine limit since there is a malfunction
I hooked up my friend's OBD and 2 error codes came out before this occurred
14632
2838
Any guidance would be highly appreciated
Stuart_Rendall
Re: EPC and Check Engine
Post by Stuart_Rendall »
Nikolai001 wrote: Sat Aug 07, 2021 11:26 am Quick post as I am currently in absolute despair
14632
2838
From doing a quick google search 14632 appears to be coolant pump for intercooler and 2838 looks to be fuel rail pressure low. You could try clearing the codes and see if it happens again but I think be safe and contact VW and get them to pick the car and diagnose the problem.
ho8882000
Drives: 2019 (AW)
Post by ho8882000 »
Nikolai001
Do you reckon the EPC light is credited to the Coolant pump?
My Polo is under warranty, would that be covered?
Stuart_Rendall
Nikolai001 wrote: Sat Aug 07, 2021 11:56 am Do you reckon the EPC light is credited to the Coolant pump?
I can't see how it wouldn't be.
Nikolai001
Car has been taken to the dealership
Luckily it's still under warranty :)
