Armrest Height Adjuster
- J+silva
- Drives: polo conf.
Hi,can you tell me if you advise or not and where to buy a arm rest height adjuster,I took a trip on the highway and my arm was tired due to lack of support,thanks.
- mirceaculita
- Drives: 6R 1.2TDI 75hp
Re: Armrest Height Adjuster
the oem armrest can be adjusted. You can tilt it up and down.
- J+silva
You can adjust but do not allow you to hold the steering wheel and lean your arm ie either hold the steering wheel and keep your arm in the air or rest your arm and hold the steering wheel with just one hand.mirceaculita wrote: ↑Sun Aug 22, 2021 11:00 am the oem armrest can be adjusted. You can tilt it up and down.
- FFA76
- Drives: Polo 6R BlueGT
I think your posting this in the wrong forum.
Shouldn't it be the AW forum?
@J+silva; assuming you did mean to post on the AW Polo forum board, there is a product that can be fitted to the front lip of the storage compartment under the lid of the armrest to raise the height (available in three different heights)
https://www.diversionautomotive.com/pro ... t-adjuster
You may find similar products available cheaper elsewhere if you search on ‘VW Polo AW armrest height adjuster’ or similar search.
