Instrument panel - error in VCDS
Polobeginer
- Drives: Polo V, 1.4 16V, 63KW
Hello members,
I have a request for you, has anyone encountered the error below (read via VCDS)?
The car does not indicate any problems, the control indicator does not illuminate, but the error is and cannot be cleared.
Does anyone know exactly what this means and how it can be removed / repaired?
Or someone who knows at MSK?
Thanks in advance
(sorry for my english - translator)
Polo 6R, 1,4 16V, 63KW, r.v. 5/2012
Control unit SW: 6R0 920 860 G HW: 6R0 920 860 G
Part: KOMBI H04 0206
Serial number: 00000010645082
Coding: 140E01
Workshop #: WSC 00788 648 00255
ASAM Dataset: EV_DashBoardUDSJCIPQ25 A01015
ROD: EV_DashBoardUDSJCIPQ25_A01_VW25.rod
VCID: 382928FD22D0751BAA2-806C
1 error found
10485825 - Control unit defective
B2000 41 [137] - Wrong checksum
[Control unit defect (EEPROM area total route)]
Fault LED ON - Acknowledged - Tested since memory was cleared
fault information:
Defect condition: 00000001
Priority of faults: 2
Frequency of faults: 1
Thanks in advance
Coding: 140E01
1 error found
fault information:
Re: Instrument panel - error in VCDS
I see it all the time. If the panel works, leave it.
Polobeginer
Yes, everything works yet.
How is it handled if it doesn't work?
Replacement or can be repaired?
Thank you.
Thank you.
Most likely replacement, yes. Car electronics are hardly repaired nowadays.
- Platinum Member
maybe someone tries to edit something in eeprom of your cluster and it went wrong.
Maybe flashing the eeprom with working dump and adjusting it to your car might fix it
H2Deetoo
- Drives: VW UP/Passat B6
In my experience error 10485825 occurs with JC clusters when a mileage change is done (but not properly).
Although some people claim it happened after a battery disconnect...
It can be solved by correcting the eeprom content.
You can contact me PM if you're interested.
Rgs H2Deetoo
Rgs H2Deetoo
Polobeginer
Hi, I would be interested in more info.
But unfortunately I can't create a PM, the function is blocked for now ..
Wouldn't it be emailed?
spacewalker
- Drives: Just a VW
post epp here
Polobeginer
hello unfortunately i don't understand the term "epp"
can you explain what to publish?
spacewalker
- Drives: Just a VW
Polobeginer
unfortunately I don't know how to read eeprom ..
can you advise how to do it?
- Platinum Member
you need a eeprom programator and sop8/ soic8 clip. eeprom is behind the speed dial, meaning you have to disasemble your instrument cluster.
save your abs long coding, if you decide to take the cluster out.
Polobeginer
I can get a programmer.
Removing the cluster is not a problem
The problem will be detected by the long ABS coding.
When I read via the VCDS function autoscan, the status of the ABS unit is OK in the Gateway report.
But the ABS unit pretends not to be installed, while the ABS is functional.
It is not possible to connect to the ABS control unit itself, it reports that it is not installed.
Can anyone advise why this is so and what the problem is?
part of the log:
Model: 6R-VW25 (6N0)
Sken: 01 03 04 08 09 10 15 17 19 25 44 56
01-Engine - condition: OK 0000
03-ABS brakes - condition: OK 0000
04-Steering angle sensor - status: OK 0000
08-Air conditioning / heating - condition: OK 0000
09-Central electrics - condition: Not working 0010
10-Park assist / control - condition: OK 0000
15-Airbags - condition: OK 0000
17-Dashboard - status: Not working 0010
Gate 19-CAN - status: OK 0000
25-Immobilizer - condition: OK 0000
44-Power steering - status: OK 0000
56-Radio - status: OK 0000
Address 01: Engine nameplate: 03C-906-024-BXW.lbl
Control unit SW: 03C 906 024 CN HW: 03C 906 024 BH
Part: CGGB MM4HV G 8994
Revision: --H09 --- Serial Number:
Coding: 0000071
VCID: 6C81C4AD2A9809BB9EA-5160
No error found.
Readiness: 0000 0000
Address 03: ABS brakes
Not installed
Address 08: Climate / heating (J301) Tag: SVO \ 6R0-820-045-9AB.clb
Control unit SW: 6R0 820 045 M HW: 6R0 820 045 M
Part: Man AC H02 0202
Revision: 0003SH02
VCID: 382928FD2250751BAA2-806C
No error found.
part of the log:
Coding: 0000071
No error found.
Not installed
Revision: 0003SH02
No error found.
