It's correct, I do not know why I thought your Ibiza is a SC.Skyscript wrote: Sun Jul 07, 2019 11:57 pm I have no Ibiza SC. I checked ELSA and my wiring should be like this :
Left side :
T73b/12 --> T6d/6 RFL
Right side :
T73b/12 --> T6e/2 RFL
Essentially it is the same, the fault is because there is no wire from the BCM T73b/12 to the reversing light/s.
I do not know what may be wrong with the electrical installation you did.Skyscript wrote: Sun Jul 07, 2019 11:57 pm Just checked the light switch and nothing is connected to T17/3. There was never anything connected with my knowledge.
With the old coding it also worked correctly.
I think the BCM coding I provided is correct, comes from an Ibiza same like yours but with 'BCM Max' and automatic lights from factory.
