Re: iichels Polo 6R 1.6TDI DSG --> OEM++ R-Line conversion
Saturday,18,December,2021,11:24:11:11868
VCDS Version: 21.9.0.2 (x64)  HEX-V2 CB: 0.4604.4
Data version: 20210903 DS330.0
www.Ross-Tech.com
Workshop Code: 123 30389 056831
Chassis Type: 6R-VW25 (7E0)
Scan: 01 02 03 04 05 08 09 10 15 17 19 20 25 2B 37 3C 44 47 55 5F
          61 65 69 77 B9
05-Acc/Start Auth. -- Status: OK 0000
2B-Steer. Col. Lock -- Status: OK 0000
47-Sound System -- Status: OK 0000
69-Trailer -- Status: OK 0000
B9-Aux. Display -- Status: OK 0000
Address 01: Engine (J623-CAYC)       Labels: None
   Part No SW: 03L 906 023 KE    HW: 03L 907 425 C
   Component: R4 1.6l TDI   H43 9978
   Revision: --H43---    Serial number: 00000000000000 CVN: 3BB1FB41
   Coding: 00254036032401080000
   Shop #: WSC 00066 000 00237
   ASAM Dataset: EV_ECM16TDI02103L906023KE 003009
   ROD: GV_ECM16TDI021VW32X.rod
   VCID: 73B3228D2B37CD53AA3-8026
   VINID: 9E69EAAAA1A2A92A42085185103550A70A
Readiness: 0 0 0 0 0
Address 02: Auto Trans
Cannot be reached
   Part No SW: 6R0 907 379 AS    HW: 6R0 907 379 AS
   Component: ESP9.0i front H02 0002
   Serial number: --------------
   Coding: 21DD2885412500C5841A146E825500521504
   Shop #: WSC 30389 123 56831
   ASAM Dataset: EV_Brake1ESP90iBOSCH 003020
   VCID: 0F7B4E7D27DF89B32EB-805A
Address 05: Acc/Start Auth. (J518)       Labels:| 5K0-959-434.clb
   Part No SW: 5K0 959 434 E    HW: 5K0 959 434
   Component: VWKESSYPQ35GP 092 1202
   Revision: 00092000    Serial number: 0346244897
   Coding: 030C0C
   Shop #: WSC 31889 047 31889
   ASAM Dataset: EV_KESSYPQ35G A02717
   ROD: EV_KESSY_PQ35GP.rod
   VCID: 372BD69D7FCF617356B-8062
   Part No SW: 6R0 907 044 H    HW: 6R0 907 044 H
   Component: Climatronic   H12 0812
   Revision: V0000000
   VCID: 3829D5A172516E0B5F1-806C
   Part No SW: 7E0 937 090 C    HW: 7E0 937 090 C
   Revision: B9082001    Serial number: 4000 173171327
   Coding: 3EB82BBFA8EB3400B33807E0FFCB9FF0E68067EFE08D78D031E400030800
   VCID: 2B03FAEDB307D593223-807E
   Component: RLHS 220816 0  42  0106
   Coding: 0214DD
   Subsystem 2 - Part No SW: 6R0 959 801 BD    HW: 6R0 959 801 BD  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  003 8611
   Serial number: KU0KU011111300010103
   Coding: 0200A3
   Subsystem 3 - Part No SW: 6R0 959 802 BF    HW: 6R0 959 802 BF  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  003 8611
   Serial number: KU0KU007111300016463
   Coding: 1000AB
   Subsystem 7 - Part No SW: 6R0 959 811 G    HW: 6R0 959 811 G
   Component: J388__TSG_HL  008 1611
   Serial number: KU0KU027011200011418
   Coding: 58BC32
   Subsystem 8 - Part No SW: 6R0 959 812 B    HW: 6R0 959 812 B
   Component: J389__TSG_HR  002 0803
   Serial number: KU0-KU004.06.0913330
   Coding: 08BC32
Address 10: Park/Steer Assist (J446)       Labels:| 5Q0-919-294.clb
   Part No SW: 1K8 919 472 C    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0480
   Revision: --------    Serial number: 39391528804191
   Coding: 0031195151
   ASAM Dataset: EV_EPHVA18VW364GP00 001007
   ROD: EV_EPHVA18VW364GP00_VW32.rod
1 Fault Found:
12718592 - Databus
          U1121 00 [008] - Missing Message
          [Steuerger‰t f¸r Lenks‰ulenelektronik-J527/BCM - mZAS_1 - kein Signal/keine Kommunikation]
                    Fault Status: 00000001
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 90
                    Mileage: km
                    Date: 2021.12.17
                    Time: 10:33:48
   Component: VW10Airbag01M H10 0020
   Revision: --------    Serial number: 003GX0142TCE
   Coding: 00314D
   Shop #: WSC 01383 785 00200
   ROD: EV_AirbaVW10BPAVW250.rod
   VCID: 4ACD9F691C3DEC9B395-801E
   Serial number: 3575HRB40650BI7U48C8
   Serial number: 3585HRB405J09RECEOUJ
   Serial number: 3515RRB405T0BTBEF9G7
   Serial number: 3525RRB405R0BTBEKPFQ
   Part No SW: 6R0 920 870 A    HW: 6R0 920 870 A
   Component: KOMBI         H04 0709
   Coding: 140F01
   Shop #: WSC 12345 123 12345
   VCID: 3333E28D6BB78D536A3-8066
   Part No SW: 7E0 909 901     HW: 7E0 937 090 C
   Revision: B9082001
   Coding: 042204
   VCID: 688945E162713E8B0F1-803C
   Revision: AA001001
   Coding: 0404000000000000010000
   VCID: 2E05F3F98095A0BB05D-807A
   Component: IMMO          H04 0709
   Coding: 000007
   VCID: 6A8D3FE97CFD0C9B195-803E
Address 2B: Steer. Col. Lock (J764)       Labels:* 5K0-905-861.clb
   Part No SW: 5K0 905 861 B    HW: 5K0 905 861 B
   Component: ELV-PQ35      H20 0240
   Revision: 00000000    Serial number: 11000256123005
   Coding: 4900000000000000
   Shop #: WSC 31889 470 31889
   ASAM Dataset: EV_ELVMarquMPVW36X A01001
   ROD: EV_ELVMarquMPVW36X.rod
   VCID: 2F3BEEFD879FA9B30EB-807A
Address 37: Navigation
Cannot be reached
Address 3C: Lane Change        Labels: Redir Fail!
   Part No SW: 7E0 907 566 B    HW: 4L0 907 566 A
   Component: J0769 SWA MasterH13 0120
   Revision: 00H13000    Serial number: 6PZ 009 014-07
   Coding: 0010161
   Shop #: WSC 02756 790 00000
   VCID: 2F3BEEFD8B1FA9B30EB-807A
   Subsystem 1 - Part No: 7E0 907 568 B
   Component: J0770 SWA Slave H09 0110
   Subsystem 2 - Serial number: 6PZ 009 014-27
   Subsystem 3 - Serial number: 5F31.03.1100H090003CH21982ˇ
   Subsystem 4 - Serial number: H21982ˇ
Address 44: Steering Assist (J792)       Labels:| 6Rx-909-144-V2.clb
   Part No SW: 6R1 909 144 AD    HW: 6R1 909 144 E
   Component: EPS_TRW_ALow  312 3124
   Serial number: CF3F0205
   Coding: 001F00
   ASAM Dataset: EV_SteerAssisUDSTRW 014026
   ROD: EV_SteerAssisUDSTRW_014.rod
   VCID: 79AF10A5095BB703E0F-802C
Address 47: Sound System (R12)       Labels: 5K0-035-456.clb
   Part No SW: 5C6 035 456 C    HW: 5C6 035 456 C
   Component: KonzernAmp10K H08 6831
   Revision: --------    Serial number: EAA098C0000052
   ASAM Dataset: EV_AudioVerst10KanalSTT4 001001
   ROD: EV_AudioVerst10KanalSTT4.rod
   VCID: 280905E1A271FE8BCF1-807C
   Part No SW: 6R0 907 357 C    HW: 6R0 907 357 B
   Component: AFS-ECU       005 0050
   Revision: --------    Serial number: --------------
   Coding: 0D4A000001000000
   ROD: EV_HeadlRegulVWLWRCC.rod
   VCID: 3A2DCFA94CDD7C1BA95-806E
   Component: MU-S-ND-ER    H41 0478
   Serial number: VWZAZ2W1425226
   Coding: 02620001AA00000011111103C00D0A201F0100D401200100CE
   ROD: EV_MUStd4CTSAT_VW26.rod
   VCID: 25170CD5D563E3E3F47-8070
   Data carrier:
   Subsystem 1 - Part No SW: V03 825 254 AD    HW: -----------
   Component: ECE DL2 22/23  --- 1810
1 Fault Found:
15360256 - Component Protection
          U1101 00 [009] - Active
          [Anti-theft protection - component protection active (0xEA6100)]
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 90
                    Mileage: km
                    Date: 2021.12.18
                    Time: 01:11:11
                    Voltage terminal 30: 11.8 V
   Part No SW: 7E0 907 534     HW: 7E0 937 090 C
   Component: Batt.regelung H82 0752
   Coding: 030F0A5A
   Subsystem 1 - Part No SW: 6C0 915 181     HW: 6C0 915 181
   Component: J367-BDM  H08 0223
   Serial number: 61083A44504351928092
   Serial number: 40000000058319
   ROD: EV_RDKBERU30_005.rod
Address 69: Trailer (J345)       Labels:. 1K0-907-383-V2.clb
   Part No SW: 1K0 907 383 E    HW: 1K0 907 383 E
   Component: Anhaenger     H07 0080
   Revision: 3A002002    Serial number: 00000116932377
   Coding: 0100000100000000
   VCID: 2F3BEEFD871FA9B30EB-807A
Address 77: Telephone
Cannot be reached
Address B9: Aux. Display (J285)       Labels:* 5C5-919-527.clb
   Part No SW: 1K8 919 527     HW: 1K8 919 527
   Component: ZUSATZANZEIGE H08 0003
   Coding: 05
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_Auxi_Disp_Unit_UDS_VDD 001010
   ROD: EV_Auxi_Disp_Unit_UDS_VDD.rod
   VCID: 75B71C952543D363847-8020
End----------(Elapsed Time: 02:10, VBatt start/end: 12.2V/12.2V)-----------
Powertrain controllers:
	SW:03L-906-023-KE   HW:03L-907-425-C ---  Engine
	Component:R4 1.6l TDI   H43 9978, Coding:00254036032401080000
	EV_ECM16TDI02103L906023KE,003009,GV_ECM16TDI021VW32X.rod
	Saturday,18,December,2021,16:54:56:11868
	VCDS Version: Release 21.9.0 (x64)  Data version: 20210903 DS330.0
IDE00263-Injector 1 correction value,B1JGHK0 ,7
IDE00264-Injector 2 correction value,79DCCC ,7
IDE00265-Injector 3 correction value,B4HGHL0 ,7
IDE00266-Injector 4 correction value,6EE9AC0 ,7
IDE00275-Particle filter initialization,0.9971 g,4
IDE00820-MAS01172-Activating and deactivating all development messages-Development messages,not active ,1
IDE00820-ENG98891-Activating and deactivating all development messages-Reserved,0 ,1
IDE01637-Service regeneration of particulate filter while driving,00 00 ,2
IDE01711-Blocking of particle filter regeneration,not active ,1
IDE02247-Static maximum speed limit,190.0 km/h,2
IDE02248-Individually adjustable top speed limit,250.0 km/h,2
IDE02632-MAS00478-Activation of static maximum speed limit-Reserved,0 ,1
IDE02632-Activation of static maximum speed limit-,OFF ,1
IDE02633-Deactivation of static maximum speed limit,00 00 ,2
IDE02635-MAS00478-Activation of A/C-Reserved,0 ,1
IDE02635-Activation of A/C-,OFF ,1
IDE03237-Compensation for empty stroke,FF F0 04 F9 04 5B 00 00 00 07 03 E8 03 E8 03 E8 00 00 00 02 87 87 00 04 3F F1 00 04 40 1D 00 00 00 00 00 0F 7F FF 7F FF 7F FF 7F FF 7F FF 7F FF 7F FF 7F FF 00 07 00 51 00 51 00 51 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,78
IDE04158-Activation of start/stop function,active ,1
Elapsed Time: 00:04
;SW:0AM-300-050-P   HW:0AM-927-769-D ---  Auto Trans
;Component:GSG DSG AG7     403 2321, Coding:0000020
;Saturday,18,December,2021,11:26:40:11868
;VCDS Version: Release 21.9.0 (x64)  Data version: 20210903 DS330.0
;VCID: 3635DB997455987B4DD-513C
	SW:6R0-907-379-AS   HW:6R0-907-379-AS ---  ABS Brakes
	Component:ESP9.0i front H02 0002, Coding:21DD2885412500C5841A146E825500521504
	EV_Brake1ESP90iBOSCH,003020,EV_Brake1ESP90iBOSCH_003_VW21.rod
	Saturday,18,December,2021,11:26:54:11868
IDE00820-ENG121980-Activating and deactivating all development messages-BOSCH Messages,not activated ,1
IDE00820-ENG121981-Activating and deactivating all development messages-Dynamic Messages 1,not activated ,1
IDE00820-ENG121982-Activating and deactivating all development messages-Dynamic Messages 2,not activated ,1
IDE00820-ENG121983-Activating and deactivating all development messages-Dynamic Messages 3,not activated ,1
IDE00820-ENG121979-Activating and deactivating all development messages-VW Messages,not activated ,1
IDE03659-Roller test bench mode,activated ,1
IDE04643-Overboost in brake system,120BAR ,1
IDE04949-Engine drag torque control,activated ,1
IDE05055-Hydraulic brake assistant,normal ,1
IDE05161-Straight ahead brake stabilization,activated ,1
IDE05286-Expanded electronic differential lock,Medium ,1
IDE05498-Rear axle hard braking,activated ,1
MAS02080-XCP calibration protocol,not activated ,1
MAS02138-Hill-start assistant,normal ,1
Elapsed Time: 00:03
	SW:1K8-919-472-C   HW:5Q0-919-294-A ---  Park/Steer Assist
	Component:PARKHILFE 8K  H03 0480, Coding:0031195151
	EV_EPHVA18VW364GP00,001007,EV_EPHVA18VW364GP00_VW32.rod
	Saturday,18,December,2021,11:29:26:11868
IDE00001-Production mode,Deactivating ,3
IDE01165-Park assist activation tone,On ,1
IDE01169-Audio lowering request,On ,1
IDE01170-Visual display for park assist,automatic ,1
IDE02332-Deactivate production mode,0 ,3
IDE03782-Switch-off speed for parking assist,15 km/h,1
IDE04159-Deactivation of start/stop function,Start-stop function in control module active ,1
MAS01426-Rear parking aid buzzer: volume,Stage 5 ,1
MAS01427-Speaker frequency for rear park assist,Stage 4 ,1
MAS01428-Front parking aid buzzer: volume,Stage 2 ,1
MAS01429-Speaker frequency for front park assist,Stage 6 ,1
Elapsed Time: 00:05
	SW:6R0-959-655-K   HW:6R0-959-655-K ---  Airbags
	Component:VW10Airbag01M H10 0020, Coding:00314D
	EV_AirbaVW10BPAVW250,A01001,EV_AirbaVW10BPAVW250.rod
	Saturday,18,December,2021,11:29:41:11868
MAS00975-MAS00001-Airbag adaptations-Driver airbag igniter,activated ,4
MAS00975-MAS00003-Airbag adaptations-Front passenger airbag igniter,activated ,4
MAS00975-MAS00005-Airbag adaptations-Driver thorax airbag igniter,activated ,4
MAS00975-MAS00006-Airbag adaptations-Front passenger side airbag igniter,activated ,4
MAS00975-MAS00009-Airbag adaptations-Driver head curtain airbag igniter,not defined ,4
MAS00975-MAS00010-Airbag adaptations-Front passenger head curtain airbag igniter,not defined ,4
MAS00975-MAS00013-Airbag adaptations-Driver side seat belt tension igniter,activated ,4
MAS00975-MAS00014-Airbag adaptations-Front passenger side seat belt tension igniter,activated ,4
MAS00975-MAS00022-Airbag adaptations-Battery Interrupt Igniter,not defined ,4
MAS00975-MAS00030-Airbag adaptations-Seat occupied recognition,not defined ,4
MAS00975-MAS00079-Airbag adaptations-Key switch,Airbag deactivation key switch installed ,4
MAS00975-MAS00478-Airbag adaptations-Reserved,Unknown (3),4
MAS00975-MAS00478-Airbag adaptations-Reserved,not defined ,4
Elapsed Time: 00:00
;SW:7E0-907-566-B   HW:4L0-907-566-A ---  Lane Change
;Component:J0769 SWA MasterH13 0120, Coding:0010161
;Saturday,18,December,2021,11:31:39:11868
;VCID: 2F3BEEFD8B1FA9B30EB-807A
A01,0,
;5
A01,1,
;5.0
A01,2,
;N/A
A01,3,
;N/A
A01,4,
;N/A
;02 N/A
A03,0,
;1
A03,1,
;1.0
A03,2,
;N/A
A03,3,
;N/A
A03,4,
;N/A
A04,0,
;3
A04,1,
;3.0
A04,2,
;N/A
A04,3,
;N/A
A04,4,
;N/A
A05,0,
;0
A05,1,
;OFF
A05,2,
;N/A
A05,3,
;N/A
A05,4,
;N/A
A06,0,
;0
A06,1,
;OFF
A06,2,
;N/A
A06,3,
;N/A
A06,4,
;N/A
	SW:6R1-909-144-AD   HW:6R1-909-144-E ---  Steering Assist
	Component:EPS_TRW_ALow  312 3124, Coding:001F00
	EV_SteerAssisUDSTRW,014026,EV_SteerAssisUDSTRW_014.rod
	Saturday,18,December,2021,11:31:58:11868
IDE00820-Activating and deactivating all development messages,not active ,1
IDE03724-Straight line running,active ,1
IDE03734-Support power,100% ,1
IDE04130-Characteristic curve of steering assistance,Comfort ,1
IDE04555-Activation of pwr steering asst without engine running,not active ,1
IDE05162-Software end stop,active ,1
IDE06419-Driving profile switchover,Incremental: controlled over time ,1
IDE07540-Download without rest bus,not active ,1
MAS02080-XCP calibration protocol,not active ,1
Elapsed Time: 00:02
	SW:6R0-907-357-C   HW:6R0-907-357-B ---  Headlight Range
	Component:AFS-ECU       005 0050, Coding:0D4A000001000000
	EV_HeadlRegulVWLWRCC,002006,EV_HeadlRegulVWLWRCC.rod
	Saturday,18,December,2021,11:32:17:11868
IDE03642-Presentation mode,not active ,1
IDE03787-Activate left/right hand drive switch-over,not active ,1
ENG99749-LWR Offset Left,0 mm,1
ENG104030-LWR Offset Right,0 mm,1
ENG100660-PWM to Level Scaling Factor Front,3.00 mm/%,2
ENG103748-PWM to Level Scaling Factor Rear,8.00 mm/%,2
ENG103979-Reference_Run_Start_Condition,Reference run is carried out from an engine speed of 500 rpm ,1
Elapsed Time: 00:02
;SW:7E0-907-534   HW:7E0-937-090-C ---  Battery Regul.
;Component:Batt.regelung H82 0752, Coding:030F0A5A
;Saturday,18,December,2021,11:33:32:11868
;VCID: 688945E162713E8B0F1-803C
;01 N/A
A02,0,
A02,1,
;N/A
A02,2,
;N/A
A02,3,
;N/A
A02,4,
;N/A
A03,0,
;0
A03,1,
;Init
A03,2,
;Test Complete
A03,3,
;N/A
A03,4,
;N/A
A04,0,
;110 VA0 1111111115
A04,1,
;N/A
A04,2,
;N/A
A04,3,
;N/A
A04,4,
;N/A
;05 N/A
;06 N/A
A07,0,
A07,1,
;N/A
A07,2,
;N/A
A07,3,
;N/A
A07,4,
;N/A
A08,0,
;0
A08,1,
;0.00 V
A08,2,
;N/A
A08,3,
;N/A
A08,4,
;N/A
A09,0,
;0
A09,1,
;0.00 V
A09,2,
;N/A
A09,3,
;N/A
A09,4,
;N/A
A10,0,
;0
A10,1,
;0.00 V
A10,2,
;N/A
A10,3,
;N/A
A10,4,
;N/A
A11,0,
;0
A11,1,
;0.00 V
A11,2,
;N/A
A11,3,
;N/A
A11,4,
;N/A
A12,0,
;0
A12,1,
;N/A
A12,2,
;N/A
A12,3,
;N/A
A12,4,
;N/A
A13,0,
;002000
A13,1,
;-50.0∞C
A13,2,
;-50.0∞C
A13,3,
;N/A
A13,4,
;N/A
;14 N/A
A15,0,
;0
A15,1,
;N/A
A15,2,
;N/A
A15,3,
;N/A
A15,4,
;N/A
	SW:3AA-907-273-F   HW:5Q0-907-273 ---  Tire Pressure
	Component:RDKBERU30     H04 0011, Coding:
	EV_RDKBERU30,005005,EV_RDKBERU30_005.rod
	Saturday,18,December,2021,11:33:56:11868
IDE03508-SPECIFIED pressure line selection (end of assembly line),3 ,1
IDE03511-Front-axle SPECIFIED pressure fully loaded,255 ,1
IDE03512-Rear-axle SPECIFIED pressure fully loaded,255 ,1
IDE03513-IDE03525-Write sensor identification number-Sensor identification number (sensor ID),0 ,5
IDE03513-IDE06104-Write sensor identification number-Wheel position,Left front ,5
IDE03532-Load status selected,Standard ,1
IDE08521-Front-axle SPECIFIED pressure comfort,255 ,1
IDE08522-Rear-axle SPECIFIED pressure comfort,255 ,1
IDE08523-Front-axle SPECIFIED pressure standard,255 ,1
IDE08524-Rear-axle SPECIFIED pressure standard,255 ,1
MAS02356-Type of calibration,Menu ,1
Elapsed Time: 00:02
;SW:1K0-907-383-E   HW:1K0-907-383-E ---  Trailer
;Component:Anhaenger     H07 0080, Coding:0100000100000000
;Saturday,18,December,2021,11:34:05:11868
;VCID: 2F3BEEFD871FA9B30EB-807A
Instrument CAN:
	SW:6R0-920-870-A   HW:6R0-920-870-A ---  Instruments
	Component:KOMBI         H04 0709, Coding:140F01
	EV_Kombi_UDS_VDD_RM09,A04723,EV_Kombi_UDS_VDD_RM09_004_VW25.rod
	Saturday,18,December,2021,11:29:49:11868
IDE00301-Mileage,1 km,2
IDE00342-ESI: Resetting ESI,Resetting ,1
IDE00343-Language variant,English ,1
IDE00344-Seat belt warning,Variant 4 ,1
IDE00492-MAS00900-ESI: Coding of Service Interval Extension (SIE)-Oil level,Oil level evaluation ,1
IDE00492-MAS02003-ESI: Coding of Service Interval Extension (SIE)-Status ESI or SID,ESI or SIA ON ,1
IDE00492-MAS02006-ESI: Coding of Service Interval Extension (SIE)-Selection of ESI or SID,Extended Service Intervals (ESI) ,1
IDE00492-MAS02010-ESI: Coding of Service Interval Extension (SIE)-Oil pressure,dynamic oil pressure ,1
IDE00492-MAS02011-ESI: Coding of Service Interval Extension (SIE)-Remote clock receiver,without remote clock receiver ,1
IDE00492-MAS02012-ESI: Coding of Service Interval Extension (SIE)-Oil quality,poor oil quality ,1
IDE00492-MAS02013-ESI: Coding of Service Interval Extension (SIE)-TOG,Oil level thermal sensor connected to instrument cluster ,1
IDE00493-Display correction of fuel gauge,0.0 ,1
IDE00499-Display correction of consumptions and operating range,106 %,1
IDE00500-Hour,11 H,1
IDE00501-Minute,30 min,1
IDE00505-Speed threshold of dynamic oil pressure warning,kein Offset ,1
IDE00510-ESI: distance driven from inspection,2100 km,2
IDE00511-ESI: time from inspection,34 d,2
IDE00515-ESI: oil quality,poor oil quality ,1
IDE00517-ESI: soot entry,1200 km,2
IDE00518-ESI: thermal load,1200 km,2
IDE00714-MAS00888-Additional coding-Tank characteristic curve,1 ,1
IDE00714-MAS01209-Additional coding-Speed source,via CAN ,1
IDE00714-MAS01210-Additional coding-Coolant temperature source,via CAN ,1
IDE00714-MAS01211-Additional coding-Locking bit,locked ,1
IDE00714-MAS04066-Additional coding-Number of fuel level sensors,1 ,1
IDE01153-SIA: maximum value of distance to service,15000 km,2
IDE01154-SIA: maximum value of time to service,372 d,2
IDE02327-Indicator light for start-stop operation,not active ,1
IDE02489-Display depiction,Not available ,1
IDE02494-Automatic door locking,Yes ,1
IDE03177-MAS02569-Acoustics for timeout signaling-All-wheel drive electronics,Not available ,1
IDE03177-MAS02570-Acoustics for timeout signaling-Differential lock electronics,Not available ,1
IDE03346-IDE00301-Units adjusted-Mileage,Kilometers ,2
IDE03346-IDE00316-Units adjusted-Time,24h ,2
IDE03346-MAS01230-Units adjusted-Date,dd_mm_yy ,2
IDE03346-MAS01456-Units adjusted-Speed,Kilometers per hour ,2
IDE03346-MAS02201-Units adjusted-Temperature,∞C ,2
IDE03346-MAS03032-Units adjusted-Volume,Liters ,2
IDE03346-MAS03033-Units adjusted-Consumption,Liters per 100 km ,2
IDE03346-MAS03034-Units adjusted-Pressure,bar ,2
IDE03349-FIX:Max. distance driven until next mileage-related inspection,30000 km,2
IDE03350-FIX: Maximum time until next time-dependent inspection,730 d,2
IDE03351-FIX: Distance covered since last mileage-dependent inspection,2100 km,2
IDE03352-FIX: Time since last time-dependent inspection,35 d,2
IDE03481-MAS01632-Emergency telephone number-Status,not active ,25
IDE03481-MAS04225-Emergency telephone number-Preselection,000000000000000000000000 ,25
IDE03481-MAS04226-Emergency telephone number-Telephone number,000000000000000000000000 ,25
IDE03568-ENG99943-Service-key settings-p_forcewrite_qual_time,10 s,5
IDE03568-ENG102019-Service-key settings-p_main_switch_basis,On ,5
IDE03568-ENG102414-Service-key settings-p_main_switch_keyless,On ,5
IDE03568-ENG102611-Service-key settings-p_write_delay_speed,20 km/h,5
IDE03568-ENG103545-Service-key settings-p_write_delay_time,40 s,5
IDE03568-ENG104099-Service-key settings-p_write_distance,20 km,5
IDE04848-Volume to be replenished,Yes ,1
IDE05583-Break recommendation,Yes ,1
IDE05930-Service notification in days,30 d,1
IDE05931-FIX: Reset value for next mileage-dependent inspection,30000 km,2
IDE05932-FIX: Reset value for next time-dependent inspections,365 d,2
IDE06418-Light warning buzzer: condition,closed ,1
IDE07221-Cylinder shut-off,No ,1
IDE08753-IDE00837-MFA display cylinder shut down-Instantaneous consumption,No ,1
IDE08753-MAS03930-MFA display cylinder shut down-Average consumption,No ,1
IDE08753-MAS03934-MFA display cylinder shut down-Range,No ,1
IDE08753-MAS05871-MFA display cylinder shut down-Full engine operation,No ,1
IDE09257-Power steering,Variant 1 ,1
ENG112420-MAS03095-additional_adaption-Function status,No ,3
ENG112420-MAS03118-additional_adaption-Logic address,0 ,3
ENG112417-indicator_celebration,active ,1
ENG108924-Service_Key_Clear_All_Counters,Yes ,1
ENG112416-IDE01766-velocity_detection-Distance impulses,4 ,1
ENG112416-MAS01209-velocity_detection-Speed source,Distance impulses ,1
Elapsed Time: 00:25
	SW:7E0-857-511-G   HW:7E0-857-511-E ---  High Beam Assist.
	Component:FLA           H10 0003, Coding:0404000000000000010000
	EV_HighBeamAssisAU316,001004,EV_HighBeamAssisAU316.rod
	Saturday,18,December,2021,11:30:37:11868
IDE03885-Speed threshold for high beam recommendation off,28 km/h,2
IDE03886-Activation speed for high beam assistant,38 km/h,2
IDE03888-Left / right hand traffic,Right ,1
IDE04034-Compass: magnetic field zone,Zone 8 ,1
IDE08662-Speed threshold for immediate high beam recommendation off,5 km/h,2
IDE08708-Inter. light-depending deactivation of dimming function,via discreet wire ,1
IDE08712-Brightness of indicator light for day/night interior mirror,Terminal 58xd ,1
IDE11047-MAS11967-Function characteristics predictive route data-Drive sequence,not activated ,2
IDE11047-MAS11968-Function characteristics predictive route data-HIgh beam suppression when driving uphill/downhill,not activated ,2
IDE11047-MAS11969-Function characteristics predictive route data-Delayed high beams on freeway,not activated ,2
IDE11047-MAS11970-Function characteristics predictive route data-High beam suppression in residential areas,not activated ,2
IDE11047-MAS11971-Function characteristics predictive route data-High beam suppression outside residential areas,not activated ,2
IDE11047-MAS11972-Function characteristics predictive route data-High beam suppression on freeway entry and exit ramps,not activated ,2
IDE11047-MAS11973-Function characteristics predictive route data-HIgh beam suppression in tunnels,not activated ,2
IDE11047-MAS11974-Function characteristics predictive route data-High beam suppression before tunnels,not activated ,2
IDE11047-MAS11975-Function characteristics predictive route data-HIgh beam suppression in traffic circles,not activated ,2
IDE11047-MAS11976-Function characteristics predictive route data-Dynamic adaptation of built-up areas recognition parameters,not activated ,2
IDE11047-MAS12004-Function characteristics predictive route data-High beam suppression before traffic circles,not activated ,2
ENG128953-IDE80001-AA_Parameters-Analysis 1,-100 ,6
ENG128953-IDE80002-AA_Parameters-Analysis 2,84 ,6
ENG128953-IDE80003-AA_Parameters-Analysis 3,62 ,6
ENG128944-IDE80170-AS_Parameters-Analysis 170,144 ,3
ENG128944-IDE80171-AS_Parameters-Analysis 171,112 ,3
ENG128944-IDE80172-AS_Parameters-Analysis 172,80 ,3
ENG128938-IDE80105-BC_Parameters-Analysis 105,50 ,5
ENG128938-IDE80106-BC_Parameters-Analysis 106,100 ,5
ENG128938-IDE80107-BC_Parameters-Analysis 107,100 ,5
ENG128934-IDE80010-BCS_Parameters-Analysis 10,700000 ms,12
ENG128934-IDE80011-BCS_Parameters-Analysis 11,60000 ms,12
ENG128934-IDE80012-BCS_Parameters-Analysis 12,5000 ms,12
ENG128948-ENG128957-Compass_display_dimming_curve_manipulation-Point_0_Bus_Value,0 ,12
ENG128948-ENG128958-Compass_display_dimming_curve_manipulation-Point_0_PWM_Value,1 ,12
ENG128948-ENG128959-Compass_display_dimming_curve_manipulation-Point_1_Bus_Value,25 ,12
ENG128948-ENG128960-Compass_display_dimming_curve_manipulation-Point_1_PWM_Value,1 ,12
ENG128948-ENG128961-Compass_display_dimming_curve_manipulation-Point_2_Bus_Value,51 ,12
ENG128948-ENG128962-Compass_display_dimming_curve_manipulation-Point_2_PWM_Value,4 ,12
ENG128948-ENG128963-Compass_display_dimming_curve_manipulation-Point_3_Bus_Value,75 ,12
ENG128948-ENG128964-Compass_display_dimming_curve_manipulation-Point_3_PWM_Value,15 ,12
ENG128948-ENG128965-Compass_display_dimming_curve_manipulation-Point_4_Bus_Value,99 ,12
ENG128948-ENG128966-Compass_display_dimming_curve_manipulation-Point_4_PWM_Value,80 ,12
ENG128948-ENG128967-Compass_display_dimming_curve_manipulation-Point_5_Bus_Value,100 ,12
ENG128948-ENG128968-Compass_display_dimming_curve_manipulation-Point_5_PWM_Value,80 ,12
ENG128949-Compass_display_memory,activated ,1
ENG128942-IDE80152-DLD_Parameters-Analysis 152,3000 ms,16
ENG128942-IDE80153-DLD_Parameters-Analysis 153,3000 ms,16
ENG128942-IDE80154-DLD_Parameters-Analysis 154,3000 ms,16
ENG128942-IDE80155-DLD_Parameters-Analysis 155,1500 ms,16
ENG128941-IDE80150-DLE_Parameters-Analysis 150,1015807 ,5
ENG128941-IDE80151-DLE_Parameters-Analysis 151,OFF ,5
ENG128940-DS_Parameters,200 m,2
ENG128952-ENG128992-DTC_Mask_CAN-30_DTC_reserved_0,activated ,2
ENG128952-ENG128993-DTC_Mask_CAN-31_DTC_0xCA0001,activated ,2
ENG128952-ENG128994-DTC_Mask_CAN-32_DTC_0xCA0002,activated ,2
ENG128952-ENG128995-DTC_Mask_CAN-33_DTC_0xCA0003,activated ,2
ENG128952-ENG128996-DTC_Mask_CAN-34_DTC_0xCA0004,activated ,2
ENG128952-ENG128997-DTC_Mask_CAN-35_DTC_0xCA0005,activated ,2
ENG128952-ENG128998-DTC_Mask_CAN-36_DTC_0xCA0D00,activated ,2
ENG128952-ENG128999-DTC_Mask_CAN-37_DTC_0xCA0104,activated ,2
ENG128952-ENG129000-DTC_Mask_CAN-38_DTC_0xCA0E00,activated ,2
ENG128952-ENG129001-DTC_Mask_CAN-39_DTC_0xCA0E01,activated ,2
ENG128951-ENG128969-DTC_Mask_functional-0_DTC_0xEC0100,activated ,3
ENG128951-ENG128970-DTC_Mask_functional-1_DTC_reserved,activated ,3
ENG128951-ENG128979-DTC_Mask_functional-10_DTC_0xEC0D07,activated ,3
ENG128951-ENG128980-DTC_Mask_functional-11_DTC_0xEC0D08,activated ,3
ENG128951-ENG128981-DTC_Mask_functional-12_DTC_0xEC0E00,activated ,3
ENG128951-ENG128982-DTC_Mask_functional-13_DTC_0xEC0E01,activated ,3
ENG128951-ENG128983-DTC_Mask_functional-14_DTC_0xEC0E02,activated ,3
ENG128951-ENG128984-DTC_Mask_functional-15_DTC_0xEC0E03,activated ,3
ENG128951-ENG128985-DTC_Mask_functional-16_DTC_0xEC0E04,activated ,3
ENG128951-ENG128986-DTC_Mask_functional-17_DTC_0xEC0E05,activated ,3
ENG128951-ENG128987-DTC_Mask_functional-18_DTC_0xEC0E06,activated ,3
ENG128951-ENG128988-DTC_Mask_functional-19_DTC_0xEC0E07,activated ,3
ENG128951-ENG128971-DTC_Mask_functional-2_DTC_0xEC0102,activated ,3
ENG128951-ENG128989-DTC_Mask_functional-20_DTC_0xEC0E08,activated ,3
ENG128951-ENG128990-DTC_Mask_functional-21_DTC_0xEC0E09,activated ,3
ENG128951-ENG128991-DTC_Mask_functional-22_DTC_0xEC0E0A,activated ,3
ENG128951-ENG128972-DTC_Mask_functional-3_DTC_0xEC0D00,activated ,3
ENG128951-ENG128973-DTC_Mask_functional-4_DTC_0xEC0D01,activated ,3
ENG128951-ENG128974-DTC_Mask_functional-5_DTC_0xEC0D02,activated ,3
ENG128951-ENG128975-DTC_Mask_functional-6_DTC_0xEC0D03,activated ,3
ENG128951-ENG128976-DTC_Mask_functional-7_DTC_0xEC0D04,activated ,3
ENG128951-ENG128977-DTC_Mask_functional-8_DTC_0xEC0D05,not activated ,3
ENG128951-ENG128978-DTC_Mask_functional-9_DTC_0xEC0E0B,activated ,3
ENG128947-ENG128957-EC_indicator_dimming_curve_manipulation-Point_0_Bus_Value,0 ,12
ENG128947-ENG128958-EC_indicator_dimming_curve_manipulation-Point_0_PWM_Value,1 ,12
ENG128947-ENG128959-EC_indicator_dimming_curve_manipulation-Point_1_Bus_Value,25 ,12
ENG128947-ENG128960-EC_indicator_dimming_curve_manipulation-Point_1_PWM_Value,1 ,12
ENG128947-ENG128961-EC_indicator_dimming_curve_manipulation-Point_2_Bus_Value,51 ,12
ENG128947-ENG128962-EC_indicator_dimming_curve_manipulation-Point_2_PWM_Value,4 ,12
ENG128947-ENG128963-EC_indicator_dimming_curve_manipulation-Point_3_Bus_Value,75 ,12
ENG128947-ENG128964-EC_indicator_dimming_curve_manipulation-Point_3_PWM_Value,15 ,12
ENG128947-ENG128965-EC_indicator_dimming_curve_manipulation-Point_4_Bus_Value,99 ,12
ENG128947-ENG128966-EC_indicator_dimming_curve_manipulation-Point_4_PWM_Value,80 ,12
ENG128947-ENG128967-EC_indicator_dimming_curve_manipulation-Point_5_Bus_Value,100 ,12
ENG128947-ENG128968-EC_indicator_dimming_curve_manipulation-Point_5_PWM_Value,80 ,12
ENG128954-IDE80040-FA_Parameters-Analysis 40,0 ,18
ENG128954-IDE80041-FA_Parameters-Analysis 41,500000 ,18
ENG128954-IDE80042-FA_Parameters-Analysis 42,105 ,18
ENG128954-IDE80043-FA_Parameters-Analysis 43,118 ,18
ENG128954-IDE80044-FA_Parameters-Analysis 44,0 ,18
ENG128954-IDE80045-FA_Parameters-Analysis 45,0 ,18
ENG128954-IDE80046-FA_Parameters-Analysis 46,250 ,18
ENG128954-IDE80047-FA_Parameters-Analysis 47,160 ,18
ENG128954-IDE80048-FA_Parameters-Analysis 48,5 s,18
ENG128935-IDE80020-FRTB_Parameters-Analysis 20,500 ms,26
ENG128935-IDE80021-FRTB_Parameters-Analysis 21,1200 ms,26
ENG128935-IDE80022-FRTB_Parameters-Analysis 22,1600 ms,26
ENG128935-IDE80023-FRTB_Parameters-Analysis 23,2000 ms,26
ENG128935-IDE80024-FRTB_Parameters-Analysis 24,1600 ms,26
ENG128935-IDE80025-FRTB_Parameters-Analysis 25,2000 ms,26
ENG128935-IDE80026-FRTB_Parameters-Analysis 26,417 ms,26
ENG128943-HBOT_Parameters,100 ,1
ENG128945-IDE80180-LLD_Parameters-Analysis 180,115 ,4
ENG128945-IDE80181-LLD_Parameters-Analysis 181,125 ,4
ENG128937-IDE80090-MD_Parameters-Analysis 90,150 km/h,8
ENG128937-IDE80091-MD_Parameters-Analysis 91,70 km/h,8
ENG128937-IDE80092-MD_Parameters-Analysis 92,40 km/h,8
ENG128937-IDE80093-MD_Parameters-Analysis 93,80 km/h,8
ENG128950-IDE80110-PSD_Parameters-Analysis 110,10 s,10
ENG128950-IDE80111-PSD_Parameters-Analysis 111,1 s,10
ENG128950-IDE80112-PSD_Parameters-Analysis 112,100 m,10
ENG128950-IDE80113-PSD_Parameters-Analysis 113,200 m,10
ENG128950-IDE80114-PSD_Parameters-Analysis 114,2 s,10
ENG128950-IDE80115-PSD_Parameters-Analysis 115,100 m,10
ENG128950-IDE80116-PSD_Parameters-Analysis 116,250 m,10
ENG128950-IDE80117-PSD_Parameters-Analysis 117,1 s,10
ENG128950-IDE80118-PSD_Parameters-Analysis 118,150 m,10
ENG128950-IDE80119-PSD_Parameters-Analysis 119,70 km/h,10
ENG128946-IDE80185-Village_Detect_Parameters-Analysis 185,254000 ,27
ENG128946-IDE80186-Village_Detect_Parameters-Analysis 186,350 ,27
ENG128946-IDE80187-Village_Detect_Parameters-Analysis 187,45000 ,27
ENG128946-IDE80188-Village_Detect_Parameters-Analysis 188,9 ,27
ENG128946-IDE80189-Village_Detect_Parameters-Analysis 189,4 ,27
ENG128946-IDE80190-Village_Detect_Parameters-Analysis 190,174000 ,27
ENG128946-IDE80191-Village_Detect_Parameters-Analysis 191,9 ,27
ENG128946-IDE80192-Village_Detect_Parameters-Analysis 192,2000 ,27
ENG128946-IDE80193-Village_Detect_Parameters-Analysis 193,5000 ,27
ENG128946-IDE80194-Village_Detect_Parameters-Analysis 194,3 ,27
ENG128946-IDE80195-Village_Detect_Parameters-Analysis 195,3 ,27
ENG128946-IDE80196-Village_Detect_Parameters-Analysis 196,28 ,27
ENG128946-IDE80197-Village_Detect_Parameters-Analysis 197,48 ,27
ENG128946-IDE80198-Village_Detect_Parameters-Analysis 198,100 km/h,27
ENG128939-VOS_Parameters,58 km/h,2
ENG128936-IDE80030-WG_Parameters-Analysis 30,100 ,3
ENG128936-IDE80031-WG_Parameters-Analysis 31,100 ,3
ENG128936-IDE80032-WG_Parameters-Analysis 32,100 ,3
ENG128933-XCP_Settings,not activated ,1
Elapsed Time: 00:09
	SW:5K0-953-234   HW:5K0-953-234 ---  Immobilizer
	Component:IMMO          H04 0709, Coding:000007
	EV_Immo_UDS_VDD_RM09,A03710,EV_Immo_UDS_VDD_RM09_VW21.rod
	Saturday,18,December,2021,11:30:53:11868
Elapsed Time: 00:01
	SW:1K8-919-527   HW:1K8-919-527 ---  Aux. Display
	Component:ZUSATZANZEIGE H08 0003, Coding:05
	EV_Auxi_Disp_Unit_UDS_VDD,001010,EV_Auxi_Disp_Unit_UDS_VDD.rod
	Saturday,18,December,2021,11:34:22:11868
IDE07175-Countdown,Variant 1 ,1
IDE07476-Zero-point calibration for stopwatch,OFF ,1
MAS00194-ENG125770-----Default_mode,mode_8 ,1
MAS00194-ENG125771-----Index_movement,OFF ,1
MAS03205-MAS05611-Stopwatch-Mode 2,On ,1
MAS03205-MAS05612-Stopwatch-Mode 3,On ,1
MAS03205-MAS05613-Stopwatch-Mode 4,On ,1
MAS03205-MAS05614-Stopwatch-Mode 5,On ,1
MAS03205-MAS05615-Stopwatch-Mode 6,On ,1
MAS03205-MAS05804-Stopwatch-Mode 7,On ,1
MAS03205-MAS07010-Stopwatch-Mode 8,On ,1
ENG121829-MAS01632-MFL Operation-Status,On ,1
ENG121829-ENG121824-MFL Operation-Mode 1,OFF ,1
ENG121829-ENG112405-MFL Operation-Mode 7,OFF ,1
ENG121830-MAS01632-Stopwatch Acoustics-Status,On ,1
ENG121830-ENG121826-Stopwatch Acoustics-acoustic_mfl,On ,1
ENG121830-ENG121825-Stopwatch Acoustics-acoustic_mode_7,On ,1
ENG125759-Stopwatch Pointer_Return,clockwise ,1
Elapsed Time: 00:02
Infotainment and comfort CAN:
	SW:5K0-959-434-E   HW:5K0-959-434 ---  Acc/Start Auth.
	Component:VWKESSYPQ35GP 092 1202, Coding:030C0C
	EV_KESSYPQ35G,A02717,EV_KESSY_PQ35GP.rod
	Saturday,18,December,2021,11:27:04:11868
ENG105462-CAN-timeout service-key message,260 ms,1
ENG105634-Correction value LED dimming,1.0 ,1
ENG105791-Delta value LED dimming curve first point 40 percent dimming,11.0 %,1
ENG105792-Delta value LED dimming curve forth point 100 percent dimming,34.0 %,1
ENG105793-Delta value LED dimming curve second point 60 percent dimming,23.0 %,1
ENG105794-Delta value LED dimming curve third point 80 percent dimming,28.0 %,1
ENG105802-ENG98487-DeveloperCoding: Fahrzeugumfeld-Convertible,not active ,1
ENG105802-ENG100924-DeveloperCoding: Fahrzeugumfeld-Pre Catch for Trunk,installed ,1
ENG105802-ENG101347-DeveloperCoding: Fahrzeugumfeld-RAM / ROM Check,not active ,1
ENG105802-ENG103200-DeveloperCoding: Fahrzeugumfeld-Steering wheel,Left hand steering ,1
ENG105803-ENG112090-DeveloperCoding: Key Minder (Byte 1)-Remotestartauswertung,not active ,1
ENG105803-ENG101923-DeveloperCoding: Key Minder (Byte 1)-Retry handling big car / expanded search,activated ,1
ENG105803-ENG100928-DeveloperCoding: Key Minder (Byte 1)-Seat Memory: scan after driver door opening,not active ,1
ENG105803-ENG99649-DeveloperCoding: Key Minder (Byte 1)-Seat Memory: scan after driver door opening no KESSY unlocking,activated ,1
ENG105803-ENG99417-DeveloperCoding: Key Minder (Byte 1)-Softtouch mounted,installed ,1
ENG105804-ENG99123-DeveloperCoding: Key Minder (Byte 2)-Inhibit ID-transmitter for passive go,activated ,1
ENG105804-ENG102581-DeveloperCoding: Key Minder (Byte 2)-Lock prevention tailgate,not active ,1
ENG105804-ENG101018-DeveloperCoding: Key Minder (Byte 2)-No locking with ID-transmitter last used interior,activated ,1
ENG105804-ENG103451-DeveloperCoding: Key Minder (Byte 2)-Re-open after passive comfort closing,activated ,1
ENG105804-ENG99711-DeveloperCoding: Key Minder (Byte 2)-Re-open last handling,ZV entriegeln ,1
ENG105804-ENG103237-DeveloperCoding: Key Minder (Byte 2)-Re-open tailgate,activated ,1
ENG105804-ENG104103-DeveloperCoding: Key Minder (Byte 2)-Send numbers of ID-transmitters interior (ELV-Scan),activated ,1
ENG105805-ENG102436-DeveloperCoding: LF Transmission-Standardisation of ZAT,activated ,1
ENG105805-ENG101761-DeveloperCoding: LF Transmission-ZAT active during clamp 58d on,not active ,1
ENG105805-ENG99363-DeveloperCoding: LF Transmission-ZAT active during clamp 58t on,activated ,1
ENG105806-ENG104126-DeveloperCoding: Naeherungssensor-AUDI doorknobs mounted,not active ,1
ENG105806-ENG102457-DeveloperCoding: Naeherungssensor-Detection of an repeated failed doorknob actuation,activated ,1
ENG105806-ENG102353-DeveloperCoding: Naeherungssensor-No turn off for driver doorknob while passive,Fahrert¸rgriff wird nicht abgeschaltet ,1
ENG105806-ENG99826-DeveloperCoding: Naeherungssensor-Proximity Sensor: sensor stays active after fault detection,not active ,1
ENG105806-ENG102252-DeveloperCoding: Naeherungssensor-Suppress fault manager entry "Falschverbau aktiv",Fehlerspeichereintrag wird nicht unterdrueckt ,1
ENG105807-ENG99763-DeveloperCoding: Passiv Entry Exit (Byte 1)-Passive Exit: access door not open,activated ,1
ENG105807-ENG103722-DeveloperCoding: Passiv Entry Exit (Byte 1)-Passive Exit: all doors not open,not active ,1
ENG105808-ENG101891-DeveloperCoding: Passiv Entry Exit (Byte 2)-Auto lock,not active ,1
ENG105808-ENG98383-DeveloperCoding: Passiv Entry Exit (Byte 2)-Auto unlock,not active ,1
ENG105808-ENG100534-DeveloperCoding: Passiv Entry Exit (Byte 2)-Passiv Entry Exit,activated ,1
ENG105808-ENG100246-DeveloperCoding: Passiv Entry Exit (Byte 2)-Passive Entry bei Tuer verriegelt/gesafed ODER ZV ist gesafed,activated ,1
ENG105808-ENG103289-DeveloperCoding: Passiv Entry Exit (Byte 2)-Passive Entry Exit: control by pulling door handle during active DSL,activated ,1
ENG105808-ENG103620-DeveloperCoding: Passiv Entry Exit (Byte 2)-Passive Entry Exit: retry with antennastep 1,activated ,1
ENG105808-ENG103529-DeveloperCoding: Passiv Entry Exit (Byte 2)-Passive Entry: second control concept,not active ,1
ENG105809-ENG100524-DeveloperCoding: Passiv Go-GO only via antenna IN1 if sliding door open,not active ,1
ENG105809-ENG102049-DeveloperCoding: Passiv Go-GO only via antenna IN1 if tailgate open,not active ,1
ENG105809-ENG102152-DeveloperCoding: Passiv Go-Passive Go,activated ,1
ENG105809-ENG99072-DeveloperCoding: Passiv Go-Passive Go: tailgate authorized to start,activated ,1
ENG105810-ENG103075-DeveloperCoding: Sonstiges-Battery manager mounted,not active ,1
ENG105810-ENG102728-DeveloperCoding: Sonstiges-Diagnostic: service 86 - response on event,not active ,1
ENG105810-ENG102125-DeveloperCoding: Sonstiges-Gesture controlled tailgate,not active ,1
ENG105810-ENG98656-DeveloperCoding: Sonstiges-internal,not active ,1
ENG105810-ENG102591-DeveloperCoding: Sonstiges-Response extension for scan procedure,not active ,1
ENG105810-ENG99430-DeveloperCoding: Sonstiges-Scan Procedure: Timeoutcontrol active,activated ,1
ENG105810-ENG104010-DeveloperCoding: Sonstiges-Use default antenna data,not active ,1
ENG105825-Diagnostic: wait time after power on,3000 ms,1
ENG105898-Doorknob contact sensor disconnecting time,5400 min,1
ENG107050-Interior scan: deceleration after comfort closing,3200 ms,1
ENG107051-Interior scan: max. engine speed for standing engine,10 km/h,1
ENG107052-Interior scan: opening threshold sliding roof,1 %,1
ENG107053-Interior scan: opening threshold window lifter,5.0 %,1
ENG107054-Interior scan: Speed - threshold,20 km/h,1
ENG98656-internal,0 B,1
ENG107211-Key Minder: delay reunlocking tailgate,500 ms,1
ENG107212-Key Minder: p_keyless_eventsearch_holding_time,10 s,1
ENG107213-Key Minder: p_keyless_eventsearch_retries,4 ,1
ENG107363-LED dimming curve first point 20 percent dimming,4.0 %,1
ENG107592-MCTX Pause,1 B,1
ENG107593-MCTX pause for Go / Key Minder,10 ms,1
ENG107594-MCTX pause for Go authentification,7 B,1
ENG107595-MCTX settling phase,7 B,1
ENG108165-Passive Entry Exit: control by pulling the door handle during active DSL (timeout),2.00 s,1
ENG108166-Passive Entry Exit: entry request e-sliding door active time,500 ms,1
ENG108167-Passive Entry Exit: minimum activity time locking sensor,140 ms,1
ENG108168-Passive Entry Exit: PARA_T_TIMOUT_PROXIMITY_ENTRY,210 ms,1
ENG108169-Passive Entry Exit: T_ACT_OP_2,5000 ms,1
ENG108297-Proximity Sensor: Comfort Exit-Enlargement,200 ms,1
ENG108298-Proximity Sensor: duration of proximity Signal,10 s,1
ENG108299-Proximity Sensor: lower limit Impuls,2000 µs,1
ENG108300-Proximity Sensor: lower limit proximity-Impuls,12200 µs,1
ENG108301-Proximity Sensor: max Vehiclespeed for a standing vehicle,10.0 km/h,1
ENG108302-Proximity Sensor: max. Impulslength,75 ms,1
ENG108303-Proximity Sensor: max. Impulslength of proximity-Impuls,20400 µs,1
ENG108304-Proximity Sensor: max. intermission-length Diagnostic,14 ms,1
ENG108305-Proximity Sensor: max. length of Diagnosticimpuls,71 ms,1
ENG108306-Proximity Sensor: max. length of Entryimpuls,10400 µs,1
ENG108307-Proximity Sensor: max. length of Exitimpuls,40400 µs,1
ENG108308-Proximity sensor: max. length of signal hall sensor,100 s,1
ENG108309-Proximity Sensor: max. signal-length,120 s,1
ENG108310-Proximity sensor: max. tolerance data bit length,20000 µs,1
ENG108311-Proximity Sensor: min Vehiclespeed for a driving vehicle,20.0 km/h,1
ENG108312-Proximity Sensor: min. enginespeed for a running engine,300 /min,1
ENG108313-Proximity Sensor: min. length of Diagnosticimpuls,42 ms,1
ENG108314-Proximity Sensor: min. length of Entryimpuls,6200 µs,1
ENG108315-Proximity Sensor: min. length of Exitimpuls,24200 µs,1
ENG108316-Proximity sensor: min. tolerance data bit length,12000 µs,1
ENG108317-Proximity Sensor: SP_X2,10 min,1
ENG108318-Proximity Sensor: SP_X3,1 ,1
ENG108319-Proximity Sensor: SP_X4,80 ,1
ENG108320-Proximity Sensor: SP_X5,1 ,1
ENG108321-Proximity Sensor: SP_X6,30 min,1
ENG108322-Proximity Sensor: SP_X7,1 ,1
ENG108323-Proximity Sensor: Time Power On,1960 ms,1
ENG108324-Proximity Sensor: Timervalue for ExitReverseOption (BCM: par_t_Komfort_Umtasten),2000 ms,1
ENG108325-Proximity sensor: turn-off limit from battery-manager,2 ,1
ENG108326-Proximity Sensor: upper limit intermission-length,10 ms,1
ENG108575-Scan Procedure: current limiting on undervoltage at Go-protocol,5 Step,1
ENG108576-Scan Procedure: cycle convenience coverage limiting,65 ms,1
ENG108577-Scan Procedure: Number of Repeats,1 ,1
ENG108578-Scan Procedure: p_keyless_eventsuche_retries_pause,1000 ms,1
ENG108579-Scan Procedure: Timeout Authentification Result,150 ms,1
ENG108580-Scan Procedure: timeout ID-transmitter ready-to-receive after LF-error (Go),190 ms,1
ENG108581-Scan Procedure: timeout ID-transmitter ready-to-receive after LF-error (Kombi),700 ms,1
ENG108582-Scan Procedure: Timeout LF Repetition,100 ms,1
ENG108583-Scan Procedure: Timeoutcontrol,20.00 s,1
ENG108585-ScanProcedure: Timeout Entry Response,250 ms,1
ENG108586-ScanProcedure: Timeout Response,100 ms,1
ENG109053-Standard dimming value ZAT,70 %,1
ENG100492-Stop_enabling_for_Start_/_Stop_function,According to function requirements ,1
ENG109436-Time Overvoltage one,100 ms,1
ENG102207-Time Sensor Power Off Group 2,3600 min,1
ENG109974-Voltage monitoring: overvoltage Delta,500 mV,1
ENG109975-Voltage monitoring: overvoltage for KESSY ECU,16000 mV,1
ENG109976-Voltage monitoring: overvoltage for Keyless Go,27000 mV,1
ENG109977-Voltage monitoring: overvoltage Jumpstart 2 Delta,0 mV,1
ENG109978-Voltage monitoring: undervoltage Delta,500 mV,1
ENG109979-Voltage monitoring: undervoltage for KESSY ECU,9000 mV,1
ENG109980-Voltage monitoring: undervoltage for Keyless Go,6000 mV,1
ENG109981-Voltage monitoring: undervoltage Jumpstart 1 Delta,0 mV,1
ENG110364-ZAT nominal voltage,13.0 V,1
ENG110365-ZAT post-carridge during clamp 15 off,10 min,1
Elapsed Time: 00:21
;SW:7E0-937-090-C   HW:7E0-937-090-C ---  Cent. Elect.
;Component:BCM PQ25 Max4 H82 0752, Coding:3EB82BBFA8EB3400B33807E0FFCB9FF0E68067EFE08D78D031E400030800
;Saturday,18,December,2021,11:27:48:11868
;VCID: 2B03FAEDB307D593223-807E
A01,0,
;0
A01,1,
;N/A
A01,2,
;N/A
A01,3,
;N/A
A01,4,
;N/A
;02 N/A
A03,0,
;1
A03,1,
;N/A
A03,2,
;N/A
A03,3,
;N/A
A03,4,
;N/A
A04,0,
;1
A04,1,
;N/A
A04,2,
;N/A
A04,3,
;N/A
A04,4,
;N/A
A05,0,
;1
A05,1,
;N/A
A05,2,
;N/A
A05,3,
;N/A
A05,4,
;N/A
A06,0,
;0
A06,1,
;N/A
A06,2,
;N/A
A06,3,
;N/A
A06,4,
;N/A
A07,0,
;1
A07,1,
;N/A
A07,2,
;N/A
A07,3,
;N/A
A07,4,
;N/A
A08,0,
;1
A08,1,
;N/A
A08,2,
;N/A
A08,3,
;N/A
A08,4,
;N/A
A09,0,
;0
A09,1,
;N/A
A09,2,
;N/A
A09,3,
;N/A
A09,4,
;N/A
A10,0,
;1
A10,1,
;N/A
A10,2,
;N/A
A10,3,
;N/A
A10,4,
;N/A
A11,0,
;1
A11,1,
;N/A
A11,2,
;N/A
A11,3,
;N/A
A11,4,
;N/A
A12,0,
;1
A12,1,
;N/A
A12,2,
;N/A
A12,3,
;N/A
A12,4,
;N/A
A13,0,
;1
A13,1,
;N/A
A13,2,
;N/A
A13,3,
;N/A
A13,4,
;N/A
A14,0,
;0
A14,1,
;N/A
A14,2,
;N/A
A14,3,
;N/A
A14,4,
;N/A
A15,0,
;0
A15,1,
;N/A
A15,2,
;N/A
A15,3,
;N/A
A15,4,
;N/A
;16 N/A
;17 N/A
;18 N/A
;19 N/A
A20,0,
;1
A20,1,
;N/A
A20,2,
;N/A
A20,3,
;N/A
A20,4,
;N/A
;21 N/A
A22,0,
;1
A22,1,
;N/A
A22,2,
;N/A
A22,3,
;N/A
A22,4,
;N/A
A23,0,
;1
A23,1,
;N/A
A23,2,
;N/A
A23,3,
;N/A
A23,4,
;N/A
A24,0,
;0
A24,1,
;N/A
A24,2,
;N/A
A24,3,
;N/A
A24,4,
;N/A
A25,0,
;0
A25,1,
;N/A
A25,2,
;N/A
A25,3,
;N/A
A25,4,
;N/A
A26,0,
;1
A26,1,
;N/A
A26,2,
;N/A
A26,3,
;N/A
A26,4,
;N/A
A27,0,
;1
A27,1,
;N/A
A27,2,
;N/A
A27,3,
;N/A
A27,4,
;N/A
A28,0,
;1
A28,1,
;N/A
A28,2,
;N/A
A28,3,
;N/A
A28,4,
;N/A
A29,0,
;1
A29,1,
;N/A
A29,2,
;N/A
A29,3,
;N/A
A29,4,
;N/A
A30,0,
;2
A30,1,
;N/A
A30,2,
;N/A
A30,3,
;N/A
A30,4,
;N/A
A31,0,
;0
A31,1,
;N/A
A31,2,
;N/A
A31,3,
;N/A
A31,4,
;N/A
A32,0,
;50
A32,1,
;N/A
A32,2,
;N/A
A32,3,
;N/A
A32,4,
;N/A
A33,0,
;50
A33,1,
;N/A
A33,2,
;N/A
A33,3,
;N/A
A33,4,
;N/A
A34,0,
;20
A34,1,
;N/A
A34,2,
;N/A
A34,3,
;N/A
A34,4,
;N/A
A35,0,
;2
A35,1,
;N/A
A35,2,
;N/A
A35,3,
;N/A
A35,4,
;N/A
A36,0,
;2
A36,1,
;N/A
A36,2,
;N/A
A36,3,
;N/A
A36,4,
;N/A
A37,0,
;80
A37,1,
;N/A
A37,2,
;N/A
A37,3,
;N/A
A37,4,
;N/A
A38,0,
;21
A38,1,
;N/A
A38,2,
;N/A
A38,3,
;N/A
A38,4,
;N/A
A39,0,
;20
A39,1,
;N/A
A39,2,
;N/A
A39,3,
;N/A
A39,4,
;N/A
A40,0,
;14
A40,1,
;N/A
A40,2,
;N/A
A40,3,
;N/A
A40,4,
;N/A
A41,0,
;20
A41,1,
;N/A
A41,2,
;N/A
A41,3,
;N/A
A41,4,
;N/A
A42,0,
;1
A42,1,
;N/A
A42,2,
;N/A
A42,3,
;N/A
A42,4,
;N/A
A43,0,
;4
A43,1,
;N/A
A43,2,
;N/A
A43,3,
;N/A
A43,4,
;N/A
A44,0,
;5
A44,1,
;N/A
A44,2,
;N/A
A44,3,
;N/A
A44,4,
;N/A
A45,0,
;80
A45,1,
;N/A
A45,2,
;N/A
A45,3,
;N/A
A45,4,
;N/A
A46,0,
;1
A46,1,
;N/A
A46,2,
;N/A
A46,3,
;N/A
A46,4,
;N/A
A47,0,
;25
A47,1,
;N/A
A47,2,
;N/A
A47,3,
;N/A
A47,4,
;N/A
A48,0,
;25
A48,1,
;N/A
A48,2,
;N/A
A48,3,
;N/A
A48,4,
;N/A
;49 N/A
A50,0,
;0
A50,1,
;N/A
A50,2,
;N/A
A50,3,
;N/A
A50,4,
;N/A
A51,0,
;0
A51,1,
;N/A
A51,2,
;N/A
A51,3,
;N/A
A51,4,
;N/A
A52,0,
;0
A52,1,
;N/A
A52,2,
;N/A
A52,3,
;N/A
A52,4,
;N/A
A53,0,
;1
A53,1,
;N/A
A53,2,
;N/A
A53,3,
;N/A
A53,4,
;N/A
A54,0,
;1
A54,1,
;N/A
A54,2,
;N/A
A54,3,
;N/A
A54,4,
;N/A
A55,0,
;0
A55,1,
;N/A
A55,2,
;N/A
A55,3,
;N/A
A55,4,
;N/A
A56,0,
;0
A56,1,
;N/A
A56,2,
;N/A
A56,3,
;N/A
A56,4,
;N/A
A57,0,
;0
A57,1,
;N/A
A57,2,
;N/A
A57,3,
;N/A
A57,4,
;N/A
A58,0,
;0
A58,1,
;N/A
A58,2,
;N/A
A58,3,
;N/A
A58,4,
;N/A
A59,0,
;1
A59,1,
;N/A
A59,2,
;N/A
A59,3,
;N/A
A59,4,
;N/A
A60,0,
;200
A60,1,
;N/A
A60,2,
;N/A
A60,3,
;N/A
A60,4,
;N/A
A61,0,
;200
A61,1,
;N/A
A61,2,
;N/A
A61,3,
;N/A
A61,4,
;N/A
A62,0,
;5
A62,1,
;N/A
A62,2,
;N/A
A62,3,
;N/A
A62,4,
;N/A
A63,0,
;21
A63,1,
;N/A
A63,2,
;N/A
A63,3,
;N/A
A63,4,
;N/A
A64,0,
;1
A64,1,
;N/A
A64,2,
;N/A
A64,3,
;N/A
A64,4,
;N/A
A65,0,
;1
A65,1,
;N/A
A65,2,
;N/A
A65,3,
;N/A
A65,4,
;N/A
A66,0,
;2
A66,1,
;N/A
A66,2,
;N/A
A66,3,
;N/A
A66,4,
;N/A
A67,0,
;24
A67,1,
;N/A
A67,2,
;N/A
A67,3,
;N/A
A67,4,
;N/A
A68,0,
;0
A68,1,
;N/A
A68,2,
;N/A
A68,3,
;N/A
A68,4,
;N/A
A69,0,
;0
A69,1,
;N/A
A69,2,
;N/A
A69,3,
;N/A
A69,4,
;N/A
A70,0,
;20
A70,1,
;N/A
A70,2,
;N/A
A70,3,
;N/A
A70,4,
;N/A
A71,0,
;0
A71,1,
;N/A
A71,2,
;N/A
A71,3,
;N/A
A71,4,
;N/A
A72,0,
;0
A72,1,
;N/A
A72,2,
;N/A
A72,3,
;N/A
A72,4,
;N/A
A73,0,
;0
A73,1,
;N/A
A73,2,
;N/A
A73,3,
;N/A
A73,4,
;N/A
A74,0,
;0
A74,1,
;N/A
A74,2,
;N/A
A74,3,
;N/A
A74,4,
;N/A
A75,0,
;0
A75,1,
;N/A
A75,2,
;N/A
A75,3,
;N/A
A75,4,
;N/A
A76,0,
;0
A76,1,
;N/A
A76,2,
;N/A
A76,3,
;N/A
A76,4,
;N/A
A77,0,
;0
A77,1,
;N/A
A77,2,
;N/A
A77,3,
;N/A
A77,4,
;N/A
A78,0,
;0
A78,1,
;N/A
A78,2,
;N/A
A78,3,
;N/A
A78,4,
;N/A
A79,0,
;255
A79,1,
;N/A
A79,2,
;N/A
A79,3,
;N/A
A79,4,
;N/A
A80,0,
;0
A80,1,
;N/A
A80,2,
;N/A
A80,3,
;N/A
A80,4,
;N/A
A81,0,
;0
A81,1,
;N/A
A81,2,
;N/A
A81,3,
;N/A
A81,4,
;N/A
A82,0,
;0
A82,1,
;N/A
A82,2,
;N/A
A82,3,
;N/A
A82,4,
;N/A
A83,0,
;0
A83,1,
;N/A
A83,2,
;N/A
A83,3,
;N/A
A83,4,
;N/A
A84,0,
;0
A84,1,
;N/A
A84,2,
;N/A
A84,3,
;N/A
A84,4,
;N/A
A85,0,
;0
A85,1,
;N/A
A85,2,
;N/A
A85,3,
;N/A
A85,4,
;N/A
A86,0,
;0
A86,1,
;N/A
A86,2,
;N/A
A86,3,
;N/A
A86,4,
;N/A
A87,0,
;0
A87,1,
;N/A
A87,2,
;N/A
A87,3,
;N/A
A87,4,
;N/A
A88,0,
;0
A88,1,
;N/A
A88,2,
;N/A
A88,3,
;N/A
A88,4,
;N/A
A89,0,
;0
A89,1,
;N/A
A89,2,
;N/A
A89,3,
;N/A
A89,4,
;N/A
A90,0,
;0
A90,1,
;N/A
A90,2,
;N/A
A90,3,
;N/A
A90,4,
;N/A
A91,0,
;0
A91,1,
;N/A
A91,2,
;N/A
A91,3,
;N/A
A91,4,
;N/A
A92,0,
;0
A92,1,
;N/A
A92,2,
;N/A
A92,3,
;N/A
A92,4,
;N/A
A93,0,
;0
A93,1,
;N/A
A93,2,
;N/A
A93,3,
;N/A
A93,4,
;N/A
A94,0,
;0
A94,1,
;N/A
A94,2,
;N/A
A94,3,
;N/A
A94,4,
;N/A
A95,0,
;0
A95,1,
;N/A
A95,2,
;N/A
A95,3,
;N/A
A95,4,
;N/A
A96,0,
;0
A96,1,
;N/A
A96,2,
;N/A
A96,3,
;N/A
A96,4,
;N/A
A97,0,
;0
A97,1,
;N/A
A97,2,
;N/A
A97,3,
;N/A
A97,4,
;N/A
;98 N/A
A99,0,
;0
A99,1,
;N/A
A99,2,
;N/A
A99,3,
;N/A
A99,4,
;N/A
;SW:7E0-909-901   HW:7E0-937-090-C ---  CAN Gateway
;Component:GW-K-CAN TP20 H82 0752, Coding:042204
;Saturday,18,December,2021,11:30:22:11868
;01 N/A
;02 N/A
;03 N/A
;04 N/A
A05,0,
;1
A05,1,
;N/A
A05,2,
;N/A
A05,3,
;N/A
A05,4,
;N/A
	SW:5K0-905-861-B   HW:5K0-905-861-B ---  Steer. Col. Lock
	Component:ELV-PQ35      H20 0240, Coding:4900000000000000
	EV_ELVMarquMPVW36X,A01001,EV_ELVMarquMPVW36X.rod
	Saturday,18,December,2021,11:31:00:11868
ENG111170-Subbus-Slave: FAZITIdentificationString,01 ,2
Elapsed Time: 00:01
	SW:5C0-035-680-G   HW:5C0-035-680-G ---  Information Electr.
	Component:MU-S-ND-ER    H41 0478, Coding:02620001AA00000011111103C00D0A201F0100D401200100CE
	EV_MUStd4CTSAT,001022,EV_MUStd4CTSAT_VW26.rod
	Saturday,18,December,2021,11:32:27:11868
IDE00001-Production mode,00 00 00 ,3
IDE00346-Summertime-automatic,none ,1
IDE00758-Base volume of telephone,50 %,1
IDE00759-Base volume of speech output,50 %,1
IDE00760-Microphone sensitivity,0 dB,1
IDE00769-Call number 1 for info call,5E 07 A1 80 00 68 55 97 42 63 FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE00770-Number 1 for roadside assistance,5E 07 A1 80 00 98 37 87 24 F3 FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE00820-ENG117828-Activating and deactivating all development messages-Infotainment_CAN_Messages,OFF ,1
IDE00820-ENG117829-Activating and deactivating all development messages-MIB_CAN_Messages,OFF ,1
IDE00845-Wheel circumference,1843 mm,2
IDE02121-CD eject button,Enabled ,1
IDE02122-Developer mode,activated ,1
IDE02330-Call number 2 for info call,5E 08 91 94 81 20 68 55 97 42 63 FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE02331-Number 2 for roadside assistance,5E 06 91 94 81 60 11 21 31 FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE02476-MAS03001-Electrical test of speakers-Mode,automatic ,49
IDE02476-ENG117360-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_1_Test_Frequency,19000 Hz,49
IDE02476-ENG117361-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_1_Test_Volume,36 ,49
IDE02476-ENG117378-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_10_Test_Frequency,19000 Hz,49
IDE02476-ENG117379-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_10_Test_Volume,36 ,49
IDE02476-ENG117380-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_11_Test_Frequency,19000 Hz,49
IDE02476-ENG117381-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_11_Test_Volume,36 ,49
IDE02476-ENG117382-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_12_Test_Frequency,19000 Hz,49
IDE02476-ENG117383-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_12_Test_Volume,36 ,49
IDE02476-ENG117384-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_13_Test_Frequency,19000 Hz,49
IDE02476-ENG117385-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_13_Test_Volume,36 ,49
IDE02476-ENG117386-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_14_Test_Frequency,19000 Hz,49
IDE02476-ENG117387-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_14_Test_Volume,36 ,49
IDE02476-ENG117388-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_15_Test_Frequency,19000 Hz,49
IDE02476-ENG117389-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_15_Test_Volume,36 ,49
IDE02476-ENG117390-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_16_Test_Frequency,19000 Hz,49
IDE02476-ENG117391-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_16_Test_Volume,36 ,49
IDE02476-ENG117362-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_2_Test_Frequency,19000 Hz,49
IDE02476-ENG117363-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_2_Test_Volume,36 ,49
IDE02476-ENG117364-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_3_Test_Frequency,19000 Hz,49
IDE02476-ENG117365-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_3_Test_Volume,36 ,49
IDE02476-ENG117366-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_4_Test_Frequency,19000 Hz,49
IDE02476-ENG117367-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_4_Test_Volume,36 ,49
IDE02476-ENG117368-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_5_Test_Frequency,19000 Hz,49
IDE02476-ENG117369-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_5_Test_Volume,36 ,49
IDE02476-ENG117370-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_6_Test_Frequency,19000 Hz,49
IDE02476-ENG117371-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_6_Test_Volume,36 ,49
IDE02476-ENG117372-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_7_Test_Frequency,19000 Hz,49
IDE02476-ENG117373-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_7_Test_Volume,36 ,49
IDE02476-ENG117374-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_8_Test_Frequency,19000 Hz,49
IDE02476-ENG117375-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_8_Test_Volume,36 ,49
IDE02476-ENG117376-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_9_Test_Frequency,19000 Hz,49
IDE02476-ENG117377-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_9_Test_Volume,36 ,49
IDE02502-Confirmation of installation change,AE 9A ,2
IDE02607-Wheel pulse,0 ,2
IDE02699-Number 1 for roadside assistance,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE02701-Number 1 (roaming) for roadside assistance,5E 02 A1 11 F2 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE04331-Selection of release codes for a SWaP function,FF FF FF FF ,4
IDE04550-Bluetooth: Sniff mode,OFF ,1
IDE05111-Fee-based traffic information (TMC),32768 ,2
IDE05113-Infotainment Recorder,activated ,1
IDE08814-IDE04033-Navigation receiver GNSS configuration-Compass,OFF ,1
IDE08814-MAS01570-Navigation receiver GNSS configuration-Default,OFF ,1
IDE08814-MAS02614-Navigation receiver GNSS configuration-GPS,On ,1
IDE08814-MAS07828-Navigation receiver GNSS configuration-Galileo,OFF ,1
IDE08814-MAS07829-Navigation receiver GNSS configuration-Glonass,OFF ,1
IDE08814-ENG142047-Navigation receiver GNSS configuration-external_gps_1,OFF ,1
IDE08814-ENG142048-Navigation receiver GNSS configuration-external_gps_2,OFF ,1
IDE10221-MAS00839-Audio Management Input Gain Generation 2-TV Tuner,-128 ,40
IDE10221-MAS00846-Audio Management Input Gain Generation 2-Satellite radio,5 ,40
IDE10221-MAS01984-Audio Management Input Gain Generation 2-Radio (FM),4 ,40
IDE10221-MAS01985-Audio Management Input Gain Generation 2-Radio (AM),7 ,40
IDE10221-MAS01986-Audio Management Input Gain Generation 2-Digital radio (DAB),4 ,40
IDE10221-ENG125854-Audio Management Input Gain Generation 2-Exbox_DMB,-128 ,40
IDE10221-ENG117430-Audio Management Input Gain Generation 2-HFP,-128 ,40
IDE10221-ENG125846-Audio Management Input Gain Generation 2-Media_Airplay,-128 ,40
IDE10221-ENG125837-Audio Management Input Gain Generation 2-Media_AUX_Adapter,-128 ,40
IDE10221-ENG125836-Audio Management Input Gain Generation 2-Media_AUXIN,-128 ,40
IDE10221-ENG125843-Audio Management Input Gain Generation 2-Media_Bluray,-128 ,40
IDE10221-ENG125841-Audio Management Input Gain Generation 2-Media_BTDevice,-128 ,40
IDE10221-ENG125838-Audio Management Input Gain Generation 2-Media_CDA,0 ,40
IDE10221-ENG125848-Audio Management Input Gain Generation 2-Media_Cloud,-128 ,40
IDE10221-ENG125839-Audio Management Input Gain Generation 2-Media_DVD,-128 ,40
IDE10221-ENG125844-Audio Management Input Gain Generation 2-Media_HDMI,-128 ,40
IDE10221-ENG125840-Audio Management Input Gain Generation 2-Media_MFP,0 ,40
IDE10221-ENG125847-Audio Management Input Gain Generation 2-Media_UPNP,-128 ,40
IDE10221-ENG125855-Audio Management Input Gain Generation 2-Mirrorlink,-128 ,40
IDE10221-ENG125859-Audio Management Input Gain Generation 2-Phone_Ringer_MFP,-128 ,40
IDE10221-ENG125860-Audio Management Input Gain Generation 2-Phone_Ringer_OB,-128 ,40
IDE10221-ENG125858-Audio Management Input Gain Generation 2-Phone_Voice,-128 ,40
IDE10221-ENG125842-Audio Management Input Gain Generation 2-TA_Tuner_FM,7 ,40
IDE10221-ENG125850-Audio Management Input Gain Generation 2-Tone_Beep,-128 ,40
IDE10221-ENG125853-Audio Management Input Gain Generation 2-Tone_Messaging,-128 ,40
IDE10221-ENG125852-Audio Management Input Gain Generation 2-Tone_Touchscreen,6 ,40
IDE10221-ENG125851-Audio Management Input Gain Generation 2-Tone_Warning,-128 ,40
IDE10221-ENG125856-Audio Management Input Gain Generation 2-TTS_Nav,-128 ,40
IDE10221-ENG125857-Audio Management Input Gain Generation 2-TTS_SDS,-128 ,40
IDE10221-ENG125845-Audio Management Input Gain Generation 2-Tuner_Online,-128 ,40
IDE10221-ENG125849-Audio Management Input Gain Generation 2-Tuner_Personal,-128 ,40
IDE10221-ENG125835-Audio Management Input Gain Generation 2-Tuner_TI,-128 ,40
IDE10221-ENG125861-Audio Management Input Gain Generation 2-TV_AV_IN,-128 ,40
IDE10480-MAS10741-Interface for external media: activation-Connection 1,activated ,4
IDE10480-MAS10742-Interface for external media: activation-Connection 2,activated ,4
IDE10480-MAS10743-Interface for external media: activation-Connection 3,not activated ,4
IDE10480-MAS10744-Interface for external media: activation-Connection 4,not activated ,4
IDE10604-Menu entries for mobile online services,activated ,1
IDE11122-Country identification: country of sale HMI,DE ,2
IDE11502-ENG127601-Locked menu contents-FB_CAR_0,non_blocked ,21
IDE11502-ENG127602-Locked menu contents-FB_CAR_1,non_blocked ,21
IDE11502-ENG127611-Locked menu contents-FB_CAR_10,non_blocked ,21
IDE11502-ENG127612-Locked menu contents-FB_CAR_11,non_blocked ,21
IDE11502-ENG127613-Locked menu contents-FB_CAR_12,non_blocked ,21
IDE11502-ENG127614-Locked menu contents-FB_CAR_13,non_blocked ,21
IDE11502-ENG127615-Locked menu contents-FB_CAR_14,non_blocked ,21
IDE11502-ENG127616-Locked menu contents-FB_CAR_15,non_blocked ,21
IDE11502-ENG127617-Locked menu contents-FB_CAR_16,non_blocked ,21
IDE11502-ENG127618-Locked menu contents-FB_CAR_17,non_blocked ,21
IDE11502-ENG127619-Locked menu contents-FB_CAR_18,non_blocked ,21
IDE11502-ENG127620-Locked menu contents-FB_CAR_19,non_blocked ,21
IDE11502-ENG127603-Locked menu contents-FB_CAR_2,non_blocked ,21
IDE11502-ENG127621-Locked menu contents-FB_CAR_20,non_blocked ,21
IDE11502-ENG127622-Locked menu contents-FB_CAR_21,non_blocked ,21
IDE11502-ENG127623-Locked menu contents-FB_CAR_22,non_blocked ,21
IDE11502-ENG127624-Locked menu contents-FB_CAR_23,non_blocked ,21
IDE11502-ENG127604-Locked menu contents-FB_CAR_3,non_blocked ,21
IDE11502-ENG127605-Locked menu contents-FB_CAR_4,non_blocked ,21
IDE11502-ENG127606-Locked menu contents-FB_CAR_5,non_blocked ,21
IDE11502-ENG127607-Locked menu contents-FB_CAR_6,non_blocked ,21
IDE11502-ENG127608-Locked menu contents-FB_CAR_7,non_blocked ,21
IDE11502-ENG127609-Locked menu contents-FB_CAR_8,non_blocked ,21
IDE11502-ENG127610-Locked menu contents-FB_CAR_9,non_blocked ,21
IDE11502-ENG127521-Locked menu contents-FB_MEDIA_0,non_blocked ,21
IDE11502-ENG127522-Locked menu contents-FB_MEDIA_1,non_blocked ,21
IDE11502-ENG127531-Locked menu contents-FB_MEDIA_10,non_blocked ,21
IDE11502-ENG127532-Locked menu contents-FB_MEDIA_11,non_blocked ,21
IDE11502-ENG127533-Locked menu contents-FB_MEDIA_12,non_blocked ,21
IDE11502-ENG127534-Locked menu contents-FB_MEDIA_13,non_blocked ,21
IDE11502-ENG127535-Locked menu contents-FB_MEDIA_14,non_blocked ,21
IDE11502-ENG127536-Locked menu contents-FB_MEDIA_15,non_blocked ,21
IDE11502-ENG127537-Locked menu contents-FB_MEDIA_16,non_blocked ,21
IDE11502-ENG127538-Locked menu contents-FB_MEDIA_17,non_blocked ,21
IDE11502-ENG127539-Locked menu contents-FB_MEDIA_18,non_blocked ,21
IDE11502-ENG127540-Locked menu contents-FB_MEDIA_19,non_blocked ,21
IDE11502-ENG127523-Locked menu contents-FB_MEDIA_2,non_blocked ,21
IDE11502-ENG127541-Locked menu contents-FB_MEDIA_20,non_blocked ,21
IDE11502-ENG127542-Locked menu contents-FB_MEDIA_21,non_blocked ,21
IDE11502-ENG127543-Locked menu contents-FB_MEDIA_22,non_blocked ,21
IDE11502-ENG127544-Locked menu contents-FB_MEDIA_23,non_blocked ,21
IDE11502-ENG127524-Locked menu contents-FB_MEDIA_3,non_blocked ,21
IDE11502-ENG127525-Locked menu contents-FB_MEDIA_4,non_blocked ,21
IDE11502-ENG127526-Locked menu contents-FB_MEDIA_5,non_blocked ,21
IDE11502-ENG127527-Locked menu contents-FB_MEDIA_6,non_blocked ,21
IDE11502-ENG127528-Locked menu contents-FB_MEDIA_7,non_blocked ,21
IDE11502-ENG127529-Locked menu contents-FB_MEDIA_8,non_blocked ,21
IDE11502-ENG127530-Locked menu contents-FB_MEDIA_9,non_blocked ,21
IDE11502-ENG127625-Locked menu contents-FB_MISC_0,non_blocked ,21
IDE11502-ENG127626-Locked menu contents-FB_MISC_1,non_blocked ,21
IDE11502-ENG127635-Locked menu contents-FB_MISC_10,non_blocked ,21
IDE11502-ENG127636-Locked menu contents-FB_MISC_11,non_blocked ,21
IDE11502-ENG127637-Locked menu contents-FB_MISC_12,non_blocked ,21
IDE11502-ENG127638-Locked menu contents-FB_MISC_13,non_blocked ,21
IDE11502-ENG127639-Locked menu contents-FB_MISC_14,non_blocked ,21
IDE11502-ENG127640-Locked menu contents-FB_MISC_15,non_blocked ,21
IDE11502-ENG127641-Locked menu contents-FB_MISC_16,non_blocked ,21
IDE11502-ENG127642-Locked menu contents-FB_MISC_17,non_blocked ,21
IDE11502-ENG127643-Locked menu contents-FB_MISC_18,non_blocked ,21
IDE11502-ENG127644-Locked menu contents-FB_MISC_19,non_blocked ,21
IDE11502-ENG127627-Locked menu contents-FB_MISC_2,non_blocked ,21
IDE11502-ENG127645-Locked menu contents-FB_MISC_20,non_blocked ,21
IDE11502-ENG127646-Locked menu contents-FB_MISC_21,non_blocked ,21
IDE11502-ENG127647-Locked menu contents-FB_MISC_22,non_blocked ,21
IDE11502-ENG127648-Locked menu contents-FB_MISC_23,non_blocked ,21
IDE11502-ENG127649-Locked menu contents-FB_MISC_24,non_blocked ,21
IDE11502-ENG127650-Locked menu contents-FB_MISC_25,non_blocked ,21
IDE11502-ENG127651-Locked menu contents-FB_MISC_26,non_blocked ,21
IDE11502-ENG127652-Locked menu contents-FB_MISC_27,non_blocked ,21
IDE11502-ENG127653-Locked menu contents-FB_MISC_28,non_blocked ,21
IDE11502-ENG127654-Locked menu contents-FB_MISC_29,non_blocked ,21
IDE11502-ENG127628-Locked menu contents-FB_MISC_3,non_blocked ,21
IDE11502-ENG127655-Locked menu contents-FB_MISC_30,non_blocked ,21
IDE11502-ENG127656-Locked menu contents-FB_MISC_31,non_blocked ,21
IDE11502-ENG127657-Locked menu contents-FB_MISC_32,non_blocked ,21
IDE11502-ENG127658-Locked menu contents-FB_MISC_33,non_blocked ,21
IDE11502-ENG127659-Locked menu contents-FB_MISC_34,non_blocked ,21
IDE11502-ENG127660-Locked menu contents-FB_MISC_35,non_blocked ,21
IDE11502-ENG127661-Locked menu contents-FB_MISC_36,non_blocked ,21
IDE11502-ENG127662-Locked menu contents-FB_MISC_37,non_blocked ,21
IDE11502-ENG127663-Locked menu contents-FB_MISC_38,non_blocked ,21
IDE11502-ENG127664-Locked menu contents-FB_MISC_39,non_blocked ,21
IDE11502-ENG127629-Locked menu contents-FB_MISC_4,non_blocked ,21
IDE11502-ENG127665-Locked menu contents-FB_MISC_40,non_blocked ,21
IDE11502-ENG127666-Locked menu contents-FB_MISC_41,non_blocked ,21
IDE11502-ENG127667-Locked menu contents-FB_MISC_42,non_blocked ,21
IDE11502-ENG127668-Locked menu contents-FB_MISC_43,non_blocked ,21
IDE11502-ENG127669-Locked menu contents-FB_MISC_44,non_blocked ,21
IDE11502-ENG127670-Locked menu contents-FB_MISC_45,non_blocked ,21
IDE11502-ENG127671-Locked menu contents-FB_MISC_46,non_blocked ,21
IDE11502-ENG127672-Locked menu contents-FB_MISC_47,non_blocked ,21
IDE11502-ENG127630-Locked menu contents-FB_MISC_5,non_blocked ,21
IDE11502-ENG127631-Locked menu contents-FB_MISC_6,non_blocked ,21
IDE11502-ENG127632-Locked menu contents-FB_MISC_7,non_blocked ,21
IDE11502-ENG127633-Locked menu contents-FB_MISC_8,non_blocked ,21
IDE11502-ENG127634-Locked menu contents-FB_MISC_9,non_blocked ,21
IDE11502-ENG127561-Locked menu contents-FB_NAV_0,non_blocked ,21
IDE11502-ENG127562-Locked menu contents-FB_NAV_1,non_blocked ,21
IDE11502-ENG127571-Locked menu contents-FB_NAV_10,non_blocked ,21
IDE11502-ENG127572-Locked menu contents-FB_NAV_11,non_blocked ,21
IDE11502-ENG127573-Locked menu contents-FB_NAV_12,non_blocked ,21
IDE11502-ENG127574-Locked menu contents-FB_NAV_13,non_blocked ,21
IDE11502-ENG127575-Locked menu contents-FB_NAV_14,non_blocked ,21
IDE11502-ENG127576-Locked menu contents-FB_NAV_15,non_blocked ,21
IDE11502-ENG127577-Locked menu contents-FB_NAV_16,non_blocked ,21
IDE11502-ENG127578-Locked menu contents-FB_NAV_17,non_blocked ,21
IDE11502-ENG127579-Locked menu contents-FB_NAV_18,non_blocked ,21
IDE11502-ENG127580-Locked menu contents-FB_NAV_19,non_blocked ,21
IDE11502-ENG127563-Locked menu contents-FB_NAV_2,non_blocked ,21
IDE11502-ENG127581-Locked menu contents-FB_NAV_20,non_blocked ,21
IDE11502-ENG127582-Locked menu contents-FB_NAV_21,non_blocked ,21
IDE11502-ENG127583-Locked menu contents-FB_NAV_22,non_blocked ,21
IDE11502-ENG127584-Locked menu contents-FB_NAV_23,non_blocked ,21
IDE11502-ENG127585-Locked menu contents-FB_NAV_24,non_blocked ,21
IDE11502-ENG127586-Locked menu contents-FB_NAV_25,non_blocked ,21
IDE11502-ENG127587-Locked menu contents-FB_NAV_26,non_blocked ,21
IDE11502-ENG127588-Locked menu contents-FB_NAV_27,non_blocked ,21
IDE11502-ENG127589-Locked menu contents-FB_NAV_28,non_blocked ,21
IDE11502-ENG127590-Locked menu contents-FB_NAV_29,non_blocked ,21
IDE11502-ENG127564-Locked menu contents-FB_NAV_3,non_blocked ,21
IDE11502-ENG127591-Locked menu contents-FB_NAV_30,non_blocked ,21
IDE11502-ENG127592-Locked menu contents-FB_NAV_31,non_blocked ,21
IDE11502-ENG127593-Locked menu contents-FB_NAV_32,non_blocked ,21
IDE11502-ENG127594-Locked menu contents-FB_NAV_33,non_blocked ,21
IDE11502-ENG127595-Locked menu contents-FB_NAV_34,non_blocked ,21
IDE11502-ENG127596-Locked menu contents-FB_NAV_35,non_blocked ,21
IDE11502-ENG127597-Locked menu contents-FB_NAV_36,non_blocked ,21
IDE11502-ENG127598-Locked menu contents-FB_NAV_37,non_blocked ,21
IDE11502-ENG127599-Locked menu contents-FB_NAV_38,non_blocked ,21
IDE11502-ENG127600-Locked menu contents-FB_NAV_39,non_blocked ,21
IDE11502-ENG127565-Locked menu contents-FB_NAV_4,non_blocked ,21
IDE11502-ENG127566-Locked menu contents-FB_NAV_5,non_blocked ,21
IDE11502-ENG127567-Locked menu contents-FB_NAV_6,non_blocked ,21
IDE11502-ENG127568-Locked menu contents-FB_NAV_7,non_blocked ,21
IDE11502-ENG127569-Locked menu contents-FB_NAV_8,non_blocked ,21
IDE11502-ENG127570-Locked menu contents-FB_NAV_9,non_blocked ,21
IDE11502-ENG127545-Locked menu contents-FB_PHONE_0,non_blocked ,21
IDE11502-ENG127546-Locked menu contents-FB_PHONE_1,non_blocked ,21
IDE11502-ENG127555-Locked menu contents-FB_PHONE_10,non_blocked ,21
IDE11502-ENG127556-Locked menu contents-FB_PHONE_11,non_blocked ,21
IDE11502-ENG127557-Locked menu contents-FB_PHONE_12,non_blocked ,21
IDE11502-ENG127558-Locked menu contents-FB_PHONE_13,non_blocked ,21
IDE11502-ENG127559-Locked menu contents-FB_PHONE_14,non_blocked ,21
IDE11502-ENG127560-Locked menu contents-FB_PHONE_15,non_blocked ,21
IDE11502-ENG127547-Locked menu contents-FB_PHONE_2,non_blocked ,21
IDE11502-ENG127548-Locked menu contents-FB_PHONE_3,non_blocked ,21
IDE11502-ENG127549-Locked menu contents-FB_PHONE_4,non_blocked ,21
IDE11502-ENG127550-Locked menu contents-FB_PHONE_5,non_blocked ,21
IDE11502-ENG127551-Locked menu contents-FB_PHONE_6,non_blocked ,21
IDE11502-ENG127552-Locked menu contents-FB_PHONE_7,non_blocked ,21
IDE11502-ENG127553-Locked menu contents-FB_PHONE_8,non_blocked ,21
IDE11502-ENG127554-Locked menu contents-FB_PHONE_9,non_blocked ,21
IDE11502-ENG127505-Locked menu contents-FB_TUNER_0,non_blocked ,21
IDE11502-ENG127506-Locked menu contents-FB_TUNER_1,non_blocked ,21
IDE11502-ENG127515-Locked menu contents-FB_TUNER_10,non_blocked ,21
IDE11502-ENG127516-Locked menu contents-FB_TUNER_11,non_blocked ,21
IDE11502-ENG127517-Locked menu contents-FB_TUNER_12,non_blocked ,21
IDE11502-ENG127518-Locked menu contents-FB_TUNER_13,non_blocked ,21
IDE11502-ENG127519-Locked menu contents-FB_TUNER_14,non_blocked ,21
IDE11502-ENG127520-Locked menu contents-FB_TUNER_15,non_blocked ,21
IDE11502-ENG127507-Locked menu contents-FB_TUNER_2,non_blocked ,21
IDE11502-ENG127508-Locked menu contents-FB_TUNER_3,non_blocked ,21
IDE11502-ENG127509-Locked menu contents-FB_TUNER_4,non_blocked ,21
IDE11502-ENG127510-Locked menu contents-FB_TUNER_5,non_blocked ,21
IDE11502-ENG127511-Locked menu contents-FB_TUNER_6,non_blocked ,21
IDE11502-ENG127512-Locked menu contents-FB_TUNER_7,non_blocked ,21
IDE11502-ENG127513-Locked menu contents-FB_TUNER_8,non_blocked ,21
IDE11502-ENG127514-Locked menu contents-FB_TUNER_9,non_blocked ,21
MAS00950-Audio Parameter,3 ,1
MAS00951-Bluetooth,On ,1
MAS02809-MAS02870-Check tone frequency-High note frequency range,4000 Hz,6
MAS02809-MAS02871-Check tone frequency-Medium note frequency range,1000 Hz,6
MAS02809-MAS02872-Check tone frequency-Low note frequency range,100 Hz,6
MAS03782-WLAN,On ,1
ENG117917-BAP_Debug_Mode_Release,not_released ,1
ENG104140-Bluetooth_Phonebook_Access_Profile,PBAP ,1
ENG122227-ENG125811-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization,not activated ,60
ENG122227-ENG125814-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_after_disclaimer,not activated ,60
ENG122227-ENG126995-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_clamp_15_off,not activated ,60
ENG122227-ENG125812-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_over_threshold_high,not activated ,60
ENG122227-ENG125813-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_standstill,not activated ,60
ENG122227-ENG152538-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation,not activated ,60
ENG122227-ENG152539-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_after_disclaimer,not activated ,60
ENG122227-ENG152540-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_clamp_15_off,not activated ,60
ENG122227-ENG152541-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_over_threshold_high,not activated ,60
ENG122227-ENG152542-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_standstill,not activated ,60
ENG122227-ENG152543-Car_Function_Adaptations_Gen2-menu_crossroad_assistent,not activated ,60
ENG122227-ENG152544-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_after_disclaimer,not activated ,60
ENG122227-ENG152545-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_clamp_15_off,not activated ,60
ENG122227-ENG152546-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_over_threshold_high,not activated ,60
ENG122227-ENG152547-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_standstill,not activated ,60
ENG122227-ENG117486-Car_Function_Adaptations_Gen2-menu_display_ACC,not activated ,60
Re: iichels Polo 6R 1.6TDI DSG --> OEM++ R-Line conversion
ENG122227-ENG117490-Car_Function_Adaptations_Gen2-menu_display_ACC_after_disclaimer,not activated ,60
ENG122227-ENG117487-Car_Function_Adaptations_Gen2-menu_display_ACC_operation_clamp_15_off,not activated ,60
ENG122227-ENG117488-Car_Function_Adaptations_Gen2-menu_display_ACC_over_threshold_high,not activated ,60
ENG122227-ENG117489-Car_Function_Adaptations_Gen2-menu_display_ACC_standstill,not activated ,60
ENG122227-ENG117646-Car_Function_Adaptations_Gen2-menu_display_adaptive_key,not activated ,60
ENG122227-ENG117650-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_after_disclaimer,not activated ,60
ENG122227-ENG117647-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_clamp_15_off,not activated ,60
ENG122227-ENG117648-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_over_threshold_high,not activated ,60
ENG122227-ENG117649-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_standstill,not activated ,60
ENG122227-ENG126152-Car_Function_Adaptations_Gen2-menu_display_Adblue,not activated ,60
ENG122227-ENG126155-Car_Function_Adaptations_Gen2-menu_display_Adblue_after_disclaimer,not activated ,60
ENG122227-ENG127002-Car_Function_Adaptations_Gen2-menu_display_Adblue_clamp_15_off,not activated ,60
ENG122227-ENG126153-Car_Function_Adaptations_Gen2-menu_display_Adblue_over_threshold_high,not activated ,60
ENG122227-ENG126154-Car_Function_Adaptations_Gen2-menu_display_Adblue_standstill,not activated ,60
ENG122227-ENG117591-Car_Function_Adaptations_Gen2-menu_display_air_damper,not activated ,60
ENG122227-ENG117595-Car_Function_Adaptations_Gen2-menu_display_air_damper_after_disclaimer,not activated ,60
ENG122227-ENG117592-Car_Function_Adaptations_Gen2-menu_display_air_damper_clamp_15_off,not activated ,60
ENG122227-ENG117593-Car_Function_Adaptations_Gen2-menu_display_air_damper_over_threshold_high,not activated ,60
ENG122227-ENG117594-Car_Function_Adaptations_Gen2-menu_display_air_damper_standstill,not activated ,60
ENG122227-ENG117491-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination,not activated ,60
ENG122227-ENG117495-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_after_disclaimer,not activated ,60
ENG122227-ENG117492-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_clamp_15_off,not activated ,60
ENG122227-ENG117493-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_over_threshold_high,activated ,60
ENG122227-ENG117494-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_standstill,not activated ,60
ENG122227-ENG122296-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope,activated ,60
ENG122227-ENG122300-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_after_disclaimer,not activated ,60
ENG122227-ENG122297-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_clamp_15_off,not activated ,60
ENG122227-ENG122298-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_over_threshold_high,activated ,60
ENG122227-ENG122299-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_standstill,not activated ,60
ENG122227-ENG117641-Car_Function_Adaptations_Gen2-menu_display_attention_identification,not activated ,60
ENG122227-ENG117645-Car_Function_Adaptations_Gen2-menu_display_attention_identification_after_disclaimer,not activated ,60
ENG122227-ENG117642-Car_Function_Adaptations_Gen2-menu_display_attention_identification_clamp_15_off,not activated ,60
ENG122227-ENG117643-Car_Function_Adaptations_Gen2-menu_display_attention_identification_over_threshold_high,not activated ,60
ENG122227-ENG117644-Car_Function_Adaptations_Gen2-menu_display_attention_identification_standstill,not activated ,60
ENG122227-ENG117531-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating,not activated ,60
ENG122227-ENG117535-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_after_disclaimer,not activated ,60
ENG122227-ENG117532-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_clamp_15_off,not activated ,60
ENG122227-ENG117533-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_over_threshold_high,not activated ,60
ENG122227-ENG117534-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_standstill,not activated ,60
ENG122227-ENG117501-Car_Function_Adaptations_Gen2-menu_display_awv,not activated ,60
ENG122227-ENG117505-Car_Function_Adaptations_Gen2-menu_display_awv_after_disclaimer,not activated ,60
ENG122227-ENG117502-Car_Function_Adaptations_Gen2-menu_display_awv_clamp_15_off,not activated ,60
ENG122227-ENG117503-Car_Function_Adaptations_Gen2-menu_display_awv_over_threshold_high,not activated ,60
ENG122227-ENG117504-Car_Function_Adaptations_Gen2-menu_display_awv_standstill,not activated ,60
ENG122227-ENG122301-Car_Function_Adaptations_Gen2-menu_display_battery_management,not activated ,60
ENG122227-ENG122305-Car_Function_Adaptations_Gen2-menu_display_battery_management_after_disclaimer,not activated ,60
ENG122227-ENG122302-Car_Function_Adaptations_Gen2-menu_display_battery_management_clamp_15_off,not activated ,60
ENG122227-ENG122303-Car_Function_Adaptations_Gen2-menu_display_battery_management_over_threshold_high,not activated ,60
ENG122227-ENG122304-Car_Function_Adaptations_Gen2-menu_display_battery_management_standstill,not activated ,60
ENG122227-ENG117666-Car_Function_Adaptations_Gen2-menu_display_BCmE,not activated ,60
ENG122227-ENG117670-Car_Function_Adaptations_Gen2-menu_display_BCmE_after_disclaimer,not activated ,60
ENG122227-ENG117667-Car_Function_Adaptations_Gen2-menu_display_BCmE_clamp_15_off,not activated ,60
ENG122227-ENG117668-Car_Function_Adaptations_Gen2-menu_display_BCmE_over_threshold_high,not activated ,60
ENG122227-ENG117669-Car_Function_Adaptations_Gen2-menu_display_BCmE_standstill,not activated ,60
ENG122227-ENG117536-Car_Function_Adaptations_Gen2-menu_display_board_computer,activated ,60
ENG122227-ENG117540-Car_Function_Adaptations_Gen2-menu_display_board_computer_after_disclaimer,not activated ,60
ENG122227-ENG117537-Car_Function_Adaptations_Gen2-menu_display_board_computer_clamp_15_off,not activated ,60
ENG122227-ENG117538-Car_Function_Adaptations_Gen2-menu_display_board_computer_over_threshold_high,activated ,60
ENG122227-ENG117539-Car_Function_Adaptations_Gen2-menu_display_board_computer_standstill,not activated ,60
ENG122227-ENG117671-Car_Function_Adaptations_Gen2-menu_display_Brake_Function,not activated ,60
ENG122227-ENG117675-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_after_disclaimer,not activated ,60
ENG122227-ENG117672-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_clamp_15_off,not activated ,60
ENG122227-ENG117673-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_over_threshold_high,not activated ,60
ENG122227-ENG117674-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_standstill,not activated ,60
ENG122227-ENG117651-Car_Function_Adaptations_Gen2-menu_display_car_mirror,activated ,60
ENG122227-ENG117655-Car_Function_Adaptations_Gen2-menu_display_car_mirror_after_disclaimer,not activated ,60
ENG122227-ENG117652-Car_Function_Adaptations_Gen2-menu_display_car_mirror_clamp_15_off,not activated ,60
ENG122227-ENG117653-Car_Function_Adaptations_Gen2-menu_display_car_mirror_over_threshold_high,activated ,60
ENG122227-ENG117654-Car_Function_Adaptations_Gen2-menu_display_car_mirror_standstill,activated ,60
ENG122227-ENG117561-Car_Function_Adaptations_Gen2-menu_display_central_locking,not activated ,60
ENG122227-ENG117565-Car_Function_Adaptations_Gen2-menu_display_central_locking_after_disclaimer,not activated ,60
ENG122227-ENG117562-Car_Function_Adaptations_Gen2-menu_display_central_locking_clamp_15_off,not activated ,60
ENG122227-ENG117563-Car_Function_Adaptations_Gen2-menu_display_central_locking_over_threshold_high,not activated ,60
ENG122227-ENG117564-Car_Function_Adaptations_Gen2-menu_display_central_locking_standstill,not activated ,60
ENG122227-ENG117601-Car_Function_Adaptations_Gen2-menu_display_central_unit_master,not activated ,60
ENG122227-ENG117605-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_after_disclaimer,not activated ,60
ENG122227-ENG117602-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_clamp_15_off,not activated ,60
ENG122227-ENG117603-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_over_threshold_high,not activated ,60
ENG122227-ENG117604-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_standstill,not activated ,60
ENG122227-ENG117571-Car_Function_Adaptations_Gen2-menu_display_charisma,not activated ,60
ENG122227-ENG117575-Car_Function_Adaptations_Gen2-menu_display_charisma_after_disclaimer,not activated ,60
ENG122227-ENG117572-Car_Function_Adaptations_Gen2-menu_display_charisma_clamp_15_off,not activated ,60
ENG122227-ENG117573-Car_Function_Adaptations_Gen2-menu_display_charisma_over_threshold_high,not activated ,60
ENG122227-ENG117574-Car_Function_Adaptations_Gen2-menu_display_charisma_standstill,not activated ,60
ENG122227-ENG117526-Car_Function_Adaptations_Gen2-menu_display_clima_configuration,not activated ,60
ENG122227-ENG117530-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_after_disclaimer,not activated ,60
ENG122227-ENG117527-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_clamp_15_off,not activated ,60
ENG122227-ENG117528-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_over_threshold_high,not activated ,60
ENG122227-ENG117529-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_standstill,not activated ,60
ENG122227-ENG117586-Car_Function_Adaptations_Gen2-menu_display_clock,activated ,60
ENG122227-ENG117590-Car_Function_Adaptations_Gen2-menu_display_clock_after_disclaimer,not activated ,60
ENG122227-ENG117587-Car_Function_Adaptations_Gen2-menu_display_clock_clamp_15_off,not activated ,60
ENG122227-ENG117588-Car_Function_Adaptations_Gen2-menu_display_clock_over_threshold_high,activated ,60
ENG122227-ENG117589-Car_Function_Adaptations_Gen2-menu_display_clock_standstill,not activated ,60
ENG122227-ENG117566-Car_Function_Adaptations_Gen2-menu_display_compass,activated ,60
ENG122227-ENG117570-Car_Function_Adaptations_Gen2-menu_display_compass_after_disclaimer,not activated ,60
ENG122227-ENG117567-Car_Function_Adaptations_Gen2-menu_display_compass_clamp_15_off,not activated ,60
ENG122227-ENG117568-Car_Function_Adaptations_Gen2-menu_display_compass_over_threshold_high,activated ,60
ENG122227-ENG117569-Car_Function_Adaptations_Gen2-menu_display_compass_standstill,not activated ,60
ENG122227-ENG125823-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist,not activated ,60
ENG122227-ENG125826-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_after_disclaimer,not activated ,60
ENG122227-ENG126998-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_clamp_15_off,not activated ,60
ENG122227-ENG125824-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_over_threshold_high,not activated ,60
ENG122227-ENG125825-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_standstill,not activated ,60
ENG122227-ENG142087-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration,activated ,60
ENG122227-ENG142091-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_after_disclaimer,not activated ,60
ENG122227-ENG142088-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_clamp_15_off,not activated ,60
ENG122227-ENG142089-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_over_threshold_high,activated ,60
ENG122227-ENG142090-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_standstill,not activated ,60
ENG122227-ENG117656-Car_Function_Adaptations_Gen2-menu_display_driving_school,activated ,60
ENG122227-ENG117660-Car_Function_Adaptations_Gen2-menu_display_driving_school_after_disclaimer,not activated ,60
ENG122227-ENG117657-Car_Function_Adaptations_Gen2-menu_display_driving_school_clamp_15_off,not activated ,60
ENG122227-ENG117658-Car_Function_Adaptations_Gen2-menu_display_driving_school_over_threshold_high,activated ,60
ENG122227-ENG117659-Car_Function_Adaptations_Gen2-menu_display_driving_school_standstill,not activated ,60
ENG122227-ENG125034-Car_Function_Adaptations_Gen2-menu_display_Ecall,not activated ,60
ENG122227-ENG125038-Car_Function_Adaptations_Gen2-menu_display_Ecall_after_disclaimer,not activated ,60
ENG122227-ENG126999-Car_Function_Adaptations_Gen2-menu_display_eCall_clamp_15_off,not activated ,60
ENG122227-ENG125036-Car_Function_Adaptations_Gen2-menu_display_Ecall_over_threshold_high,not activated ,60
ENG122227-ENG125037-Car_Function_Adaptations_Gen2-menu_display_Ecall_standstill,not activated ,60
ENG122227-ENG126160-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist,activated ,60
ENG122227-ENG126163-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_after_disclaimer,not activated ,60
ENG122227-ENG127004-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_clamp_15_off,not activated ,60
ENG122227-ENG126161-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_over_threshold_high,activated ,60
ENG122227-ENG126162-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_standstill,not activated ,60
ENG122227-ENG126144-Car_Function_Adaptations_Gen2-menu_display_ENI,not activated ,60
ENG122227-ENG126147-Car_Function_Adaptations_Gen2-menu_display_ENI_after_disclaimer,not activated ,60
ENG122227-ENG127000-Car_Function_Adaptations_Gen2-menu_display_ENI_clamp_15_off,not activated ,60
ENG122227-ENG126145-Car_Function_Adaptations_Gen2-menu_display_ENI_over_threshold_high,not activated ,60
ENG122227-ENG126146-Car_Function_Adaptations_Gen2-menu_display_ENI_standstill,not activated ,60
ENG122227-ENG117516-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination,not activated ,60
ENG122227-ENG117520-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_after_disclaimer,not activated ,60
ENG122227-ENG117517-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_clamp_15_off,not activated ,60
ENG122227-ENG117518-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_over_threshold_high,not activated ,60
ENG122227-ENG117519-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_standstill,not activated ,60
ENG122227-ENG117596-Car_Function_Adaptations_Gen2-menu_display_headup_display,activated ,60
ENG122227-ENG117600-Car_Function_Adaptations_Gen2-menu_display_headup_display_after_disclaimer,not activated ,60
ENG122227-ENG117597-Car_Function_Adaptations_Gen2-menu_display_headup_display_clamp_15_off,not activated ,60
ENG122227-ENG117598-Car_Function_Adaptations_Gen2-menu_display_headup_display_over_threshold_high,activated ,60
ENG122227-ENG117599-Car_Function_Adaptations_Gen2-menu_display_headup_display_standstill,not activated ,60
ENG122227-ENG117606-Car_Function_Adaptations_Gen2-menu_display_hybrid,not activated ,60
ENG122227-ENG117610-Car_Function_Adaptations_Gen2-menu_display_hybrid_after_disclaimer,not activated ,60
ENG122227-ENG117607-Car_Function_Adaptations_Gen2-menu_display_hybrid_clamp_15_off,not activated ,60
ENG122227-ENG117608-Car_Function_Adaptations_Gen2-menu_display_hybrid_over_threshold_high,not activated ,60
ENG122227-ENG117609-Car_Function_Adaptations_Gen2-menu_display_hybrid_standstill,not activated ,60
ENG122227-ENG125805-Car_Function_Adaptations_Gen2-menu_display_lane_assistant,not activated ,60
ENG122227-ENG125809-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_after_disclaimer,not activated ,60
ENG122227-ENG125806-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_clamp_15_off,not activated ,60
ENG122227-ENG125807-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_over_threshold_high,not activated ,60
ENG122227-ENG125808-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_standstill,not activated ,60
ENG122227-ENG117506-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning,activated ,60
ENG122227-ENG117510-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_after_disclaimer,not activated ,60
ENG122227-ENG117507-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_clamp_15_off,not activated ,60
ENG122227-ENG117508-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_over_threshold_high,activated ,60
ENG122227-ENG117509-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_standstill,not activated ,60
ENG122227-ENG117631-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker,not activated ,60
ENG122227-ENG117635-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_after_disclaimer,not activated ,60
ENG122227-ENG117632-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_clamp_15_off,not activated ,60
ENG122227-ENG117633-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_over_threshold_high,not activated ,60
ENG122227-ENG117634-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_standstill,not activated ,60
ENG122227-ENG117616-Car_Function_Adaptations_Gen2-menu_display_night_vision,not activated ,60
ENG122227-ENG117620-Car_Function_Adaptations_Gen2-menu_display_night_vision_after_disclaimer,not activated ,60
ENG122227-ENG117617-Car_Function_Adaptations_Gen2-menu_display_night_vision_clamp_15_off,not activated ,60
ENG122227-ENG117618-Car_Function_Adaptations_Gen2-menu_display_night_vision_over_threshold_high,not activated ,60
ENG122227-ENG117619-Car_Function_Adaptations_Gen2-menu_display_night_vision_standstill,not activated ,60
ENG122227-ENG117576-Car_Function_Adaptations_Gen2-menu_display_oil_level,activated ,60
ENG122227-ENG117580-Car_Function_Adaptations_Gen2-menu_display_oil_level_after_disclaimer,not activated ,60
ENG122227-ENG117577-Car_Function_Adaptations_Gen2-menu_display_oil_level_clamp_15_off,not activated ,60
ENG122227-ENG117578-Car_Function_Adaptations_Gen2-menu_display_oil_level_over_threshold_high,activated ,60
ENG122227-ENG117579-Car_Function_Adaptations_Gen2-menu_display_oil_level_standstill,not activated ,60
ENG122227-ENG117496-Car_Function_Adaptations_Gen2-menu_display_pdc,activated ,60
ENG122227-ENG117500-Car_Function_Adaptations_Gen2-menu_display_pdc_after_disclaimer,not activated ,60
ENG122227-ENG117497-Car_Function_Adaptations_Gen2-menu_display_pdc_clamp_15_off,not activated ,60
ENG122227-ENG117498-Car_Function_Adaptations_Gen2-menu_display_pdc_over_threshold_high,activated ,60
ENG122227-ENG117499-Car_Function_Adaptations_Gen2-menu_display_pdc_standstill,not activated ,60
ENG122227-ENG125815-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist,not activated ,60
ENG122227-ENG125818-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_after_disclaimer,not activated ,60
ENG122227-ENG126996-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_clamp_15_off,not activated ,60
ENG122227-ENG125816-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_over_threshold_high,not activated ,60
ENG122227-ENG125817-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_standstill,not activated ,60
ENG122227-ENG117541-Car_Function_Adaptations_Gen2-menu_display_rdk,activated ,60
ENG122227-ENG117545-Car_Function_Adaptations_Gen2-menu_display_rdk_after_disclaimer,not activated ,60
ENG122227-ENG117542-Car_Function_Adaptations_Gen2-menu_display_rdk_clamp_15_off,not activated ,60
ENG122227-ENG117543-Car_Function_Adaptations_Gen2-menu_display_rdk_over_threshold_high,activated ,60
ENG122227-ENG117544-Car_Function_Adaptations_Gen2-menu_display_rdk_standstill,not activated ,60
ENG122227-ENG122306-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment,not activated ,60
ENG122227-ENG122310-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_after_disclaimer,not activated ,60
ENG122227-ENG122307-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_clamp_15_off,not activated ,60
ENG122227-ENG122308-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_over_threshold_high,not activated ,60
ENG122227-ENG122309-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_standstill,not activated ,60
ENG122227-ENG117626-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load,not activated ,60
ENG122227-ENG117630-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_after_disclaimer,not activated ,60
ENG122227-ENG117627-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_clamp_15_off,not activated ,60
ENG122227-ENG117628-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_over_threshold_high,not activated ,60
ENG122227-ENG117629-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_standstill,not activated ,60
ENG122227-ENG117636-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification,not activated ,60
ENG122227-ENG117640-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_after_disclaimer,not activated ,60
ENG122227-ENG117637-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_clamp_15_off,not activated ,60
ENG122227-ENG117638-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_over_threshold_high,not activated ,60
ENG122227-ENG117639-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_standstill,not activated ,60
ENG122227-ENG117556-Car_Function_Adaptations_Gen2-menu_display_seat_configuration,not activated ,60
ENG122227-ENG117560-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_after_disclaimer,not activated ,60
ENG122227-ENG117557-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_clamp_15_off,not activated ,60
ENG122227-ENG117558-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_over_threshold_high,not activated ,60
ENG122227-ENG117559-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_standstill,not activated ,60
ENG122227-ENG125819-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic,not activated ,60
ENG122227-ENG125822-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_after_disclaimer,not activated ,60
ENG122227-ENG126997-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_clamp_15_off,not activated ,60
ENG122227-ENG125820-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_over_threshold_high,not activated ,60
ENG122227-ENG125821-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_standstill,not activated ,60
ENG122227-ENG117551-Car_Function_Adaptations_Gen2-menu_display_sia,activated ,60
ENG122227-ENG117555-Car_Function_Adaptations_Gen2-menu_display_sia_after_disclaimer,not activated ,60
ENG122227-ENG117552-Car_Function_Adaptations_Gen2-menu_display_sia_clamp_15_off,not activated ,60
ENG122227-ENG117553-Car_Function_Adaptations_Gen2-menu_display_sia_over_threshold_high,activated ,60
ENG122227-ENG117554-Car_Function_Adaptations_Gen2-menu_display_sia_standstill,not activated ,60
ENG122227-ENG117621-Car_Function_Adaptations_Gen2-menu_display_side_view,not activated ,60
ENG122227-ENG117625-Car_Function_Adaptations_Gen2-menu_display_side_view_after_disclaimer,not activated ,60
ENG122227-ENG117622-Car_Function_Adaptations_Gen2-menu_display_side_view_clamp_15_off,not activated ,60
ENG122227-ENG117623-Car_Function_Adaptations_Gen2-menu_display_side_view_over_threshold_high,not activated ,60
ENG122227-ENG117624-Car_Function_Adaptations_Gen2-menu_display_side_view_standstill,not activated ,60
ENG122227-ENG122311-Car_Function_Adaptations_Gen2-menu_display_special_functions,activated ,60
ENG122227-ENG122314-Car_Function_Adaptations_Gen2-menu_display_special_functions_after_disclaimer,not activated ,60
ENG122227-ENG125810-Car_Function_Adaptations_Gen2-menu_display_special_functions_clamp_15_off,not activated ,60
ENG122227-ENG122312-Car_Function_Adaptations_Gen2-menu_display_special_functions_over_threshold_high,activated ,60
ENG122227-ENG122313-Car_Function_Adaptations_Gen2-menu_display_special_functions_standstill,not activated ,60
ENG122227-ENG142082-Car_Function_Adaptations_Gen2-menu_display_Spoiler,not activated ,60
ENG122227-ENG142086-Car_Function_Adaptations_Gen2-menu_display_Spoiler_after_disclaimer,not activated ,60
ENG122227-ENG142083-Car_Function_Adaptations_Gen2-menu_display_Spoiler_clamp_15_off,not activated ,60
ENG122227-ENG142084-Car_Function_Adaptations_Gen2-menu_display_Spoiler_over_threshold_high,not activated ,60
ENG122227-ENG142085-Car_Function_Adaptations_Gen2-menu_display_Spoiler_standstill,not activated ,60
ENG122227-ENG126148-Car_Function_Adaptations_Gen2-menu_display_SportHMI,activated ,60
ENG122227-ENG126151-Car_Function_Adaptations_Gen2-menu_display_SportHMI_after_disclaimer,not activated ,60
ENG122227-ENG127001-Car_Function_Adaptations_Gen2-menu_display_SportHMI_clamp_15_off,not activated ,60
ENG122227-ENG126149-Car_Function_Adaptations_Gen2-menu_display_SportHMI_over_threshold_high,activated ,60
ENG122227-ENG126150-Car_Function_Adaptations_Gen2-menu_display_SportHMI_standstill,not activated ,60
ENG122227-ENG117676-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons,not activated ,60
ENG122227-ENG117680-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_after_disclaimer,not activated ,60
ENG122227-ENG117677-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_clamp_15_off,not activated ,60
ENG122227-ENG117678-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_over_threshold_high,not activated ,60
ENG122227-ENG117679-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_standstill,not activated ,60
ENG122227-ENG122315-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant,not activated ,60
ENG122227-ENG122319-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_after_disclaimer,not activated ,60
ENG122227-ENG122316-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_clamp_15_off,not activated ,60
ENG122227-ENG122317-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_over_threshold_high,not activated ,60
ENG122227-ENG122318-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_standstill,not activated ,60
ENG122227-ENG122320-Car_Function_Adaptations_Gen2-menu_display_TV_tuner,not activated ,60
ENG122227-ENG122324-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_after_disclaimer,not activated ,60
ENG122227-ENG122321-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_clamp_15_off,not activated ,60
ENG122227-ENG122322-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_over_threshold_high,not activated ,60
ENG122227-ENG122323-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_standstill,not activated ,60
ENG122227-ENG117611-Car_Function_Adaptations_Gen2-menu_display_ugdo,activated ,60
ENG122227-ENG117615-Car_Function_Adaptations_Gen2-menu_display_ugdo_after_disclaimer,not activated ,60
ENG122227-ENG117612-Car_Function_Adaptations_Gen2-menu_display_ugdo_clamp_15_off,not activated ,60
ENG122227-ENG117613-Car_Function_Adaptations_Gen2-menu_display_ugdo_over_threshold_high,activated ,60
ENG122227-ENG117614-Car_Function_Adaptations_Gen2-menu_display_ugdo_standstill,not activated ,60
ENG122227-ENG122291-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating,activated ,60
ENG122227-ENG122295-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_after_disclaimer,not activated ,60
ENG122227-ENG122292-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_clamp_15_off,not activated ,60
ENG122227-ENG122293-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_over_threshold_high,activated ,60
ENG122227-ENG122294-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_standstill,not activated ,60
ENG122227-ENG117581-Car_Function_Adaptations_Gen2-menu_display_vin,not activated ,60
ENG122227-ENG117585-Car_Function_Adaptations_Gen2-menu_display_vin_after_disclaimer,not activated ,60
ENG122227-ENG117582-Car_Function_Adaptations_Gen2-menu_display_vin_clamp_15_off,not activated ,60
ENG122227-ENG117583-Car_Function_Adaptations_Gen2-menu_display_vin_over_threshold_high,not activated ,60
ENG122227-ENG117584-Car_Function_Adaptations_Gen2-menu_display_vin_standstill,not activated ,60
ENG122227-ENG117661-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition,activated ,60
ENG122227-ENG117665-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_after_disclaimer,not activated ,60
ENG122227-ENG117662-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_clamp_15_off,not activated ,60
ENG122227-ENG117663-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_over_threshold_high,activated ,60
ENG122227-ENG117664-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_standstill,not activated ,60
ENG122227-ENG117521-Car_Function_Adaptations_Gen2-menu_display_windows,not activated ,60
ENG122227-ENG117525-Car_Function_Adaptations_Gen2-menu_display_windows_after_disclaimer,not activated ,60
ENG122227-ENG117522-Car_Function_Adaptations_Gen2-menu_display_windows_clamp_15_off,not activated ,60
ENG122227-ENG117523-Car_Function_Adaptations_Gen2-menu_display_windows_over_threshold_high,not activated ,60
ENG122227-ENG117524-Car_Function_Adaptations_Gen2-menu_display_windows_standstill,not activated ,60
ENG122227-ENG117546-Car_Function_Adaptations_Gen2-menu_display_wiper,not activated ,60
ENG122227-ENG117550-Car_Function_Adaptations_Gen2-menu_display_wiper_after_disclaimer,not activated ,60
ENG122227-ENG117547-Car_Function_Adaptations_Gen2-menu_display_wiper_clamp_15_off,not activated ,60
ENG122227-ENG117548-Car_Function_Adaptations_Gen2-menu_display_wiper_over_threshold_high,not activated ,60
ENG122227-ENG117549-Car_Function_Adaptations_Gen2-menu_display_wiper_standstill,not activated ,60
ENG122227-ENG142092-Car_Function_Adaptations_Gen2-menu_soundcontrol,activated ,60
ENG122227-ENG142096-Car_Function_Adaptations_Gen2-menu_soundcontrol_after_disclaimer,not activated ,60
ENG122227-ENG142093-Car_Function_Adaptations_Gen2-menu_soundcontrol_clamp_15_off,not activated ,60
ENG122227-ENG142094-Car_Function_Adaptations_Gen2-menu_soundcontrol_over_threshold_high,activated ,60
ENG122227-ENG142095-Car_Function_Adaptations_Gen2-menu_soundcontrol_standstill,not activated ,60
ENG122229-ENG117700-Car_Function_List_BAP_Gen2-ACC_0x05,not activated ,64
ENG122229-ENG117701-Car_Function_List_BAP_Gen2-ACC_0x05_msg_bus,not activated ,64
ENG122229-ENG117702-Car_Function_List_BAP_Gen2-air_suspension_0x06,not activated ,64
ENG122229-ENG117703-Car_Function_List_BAP_Gen2-air_suspension_0x06_msg_bus,not activated ,64
ENG122229-ENG117764-Car_Function_List_BAP_Gen2-Amplifier_0x2D,activated ,64
ENG122229-ENG117765-Car_Function_List_BAP_Gen2-Amplifier_0x2D_msg_bus,Infotainment data bus ,64
ENG122229-ENG122334-Car_Function_List_BAP_Gen2-Angle_Of_Slope_0x24,not activated ,64
ENG122229-ENG122335-Car_Function_List_BAP_Gen2-Angle_Of_Slope_0x24_msg_bus,Terminal 15 ,64
ENG122229-ENG117696-Car_Function_List_BAP_Gen2-auxilary_heating_0x03,not activated ,64
ENG122229-ENG117697-Car_Function_List_BAP_Gen2-auxilary_heating_0x03_msg_bus,not activated ,64
ENG122229-ENG117744-Car_Function_List_BAP_Gen2-AWV_0x1B,not activated ,64
ENG122229-ENG117745-Car_Function_List_BAP_Gen2-AWV_0x1B_msg_bus,not activated ,64
ENG122229-ENG122336-Car_Function_List_BAP_Gen2-Battery_Management_0x25,not activated ,64
ENG122229-ENG122337-Car_Function_List_BAP_Gen2-Battery_Management_0x25_msg_bus,not activated ,64
ENG122229-ENG117758-Car_Function_List_BAP_Gen2-BCmE_0x23,not activated ,64
ENG122229-ENG117759-Car_Function_List_BAP_Gen2-BCmE_0x23_msg_bus,not activated ,64
ENG122229-ENG117760-Car_Function_List_BAP_Gen2-Brake_0x26,not activated ,64
ENG122229-ENG117761-Car_Function_List_BAP_Gen2-Brake_0x26_msg_bus,not activated ,64
ENG122229-ENG117717-Car_Function_List_BAP_Gen2-central_locking_0x0D,not activated ,64
ENG122229-ENG117716-Car_Function_List_BAP_Gen2-central_locking_0x0D_msg_bus,not activated ,64
ENG122229-ENG117736-Car_Function_List_BAP_Gen2-charisma_0x17,not activated ,64
ENG122229-ENG117737-Car_Function_List_BAP_Gen2-charisma_0x17_msg_bus,not activated ,64
ENG122229-ENG117734-Car_Function_List_BAP_Gen2-clima_slave_2_0x16,not activated ,64
ENG122229-ENG117735-Car_Function_List_BAP_Gen2-clima_slave_2_0x16_msg_bus,not activated ,64
ENG122229-ENG117692-Car_Function_List_BAP_Gen2-climatic_master_0x01,not activated ,64
ENG122229-ENG117693-Car_Function_List_BAP_Gen2-climatic_master_0x01_msg_bus,not activated ,64
ENG122229-ENG117694-Car_Function_List_BAP_Gen2-climatic_slave_0x02,not activated ,64
ENG122229-ENG117695-Car_Function_List_BAP_Gen2-climatic_slave_0x02_msg_bus,not activated ,64
ENG122229-ENG117724-Car_Function_List_BAP_Gen2-clock_0x11,activated ,64
ENG122229-ENG117725-Car_Function_List_BAP_Gen2-clock_0x11_msg_bus,Terminal 15 ,64
ENG122229-ENG117732-Car_Function_List_BAP_Gen2-compass_0x15,not activated ,64
ENG122229-ENG117733-Car_Function_List_BAP_Gen2-compass_0x15_msg_bus,not activated ,64
ENG122229-ENG117722-Car_Function_List_BAP_Gen2-driver_seat_0x10,not activated ,64
ENG122229-ENG117723-Car_Function_List_BAP_Gen2-driver_seat_0x10_msg_bus,not activated ,64
ENG122229-ENG125039-Car_Function_List_BAP_Gen2-Ecall_0x33,not activated ,64
ENG122229-ENG125828-Car_Function_List_BAP_Gen2-eCall_0x33_msg_bus,not activated ,64
ENG122229-ENG127500-Car_Function_List_BAP_Gen2-efficiency_assis_msg_bus_0x3C,Terminal 15 ,64
ENG122229-ENG127499-Car_Function_List_BAP_Gen2-efficiency_assist_0x3C,activated ,64
ENG122229-ENG125829-Car_Function_List_BAP_Gen2-ENI_0x37,not activated ,64
ENG122229-ENG125830-Car_Function_List_BAP_Gen2-ENI_0x37_msg_bus,not activated ,64
ENG122229-ENG152531-Car_Function_List_BAP_Gen2-ExBoxM2_0x38,activated ,64
ENG122229-ENG152532-Car_Function_List_BAP_Gen2-ExBoxM2_0x38_msg_bus,Comfort data bus ,64
ENG122229-ENG117708-Car_Function_List_BAP_Gen2-exterieur_light_0x09,not activated ,64
ENG122229-ENG117709-Car_Function_List_BAP_Gen2-exterieur_light_0x09_msg_bus,not activated ,64
ENG122229-ENG117698-Car_Function_List_BAP_Gen2-headup_displ_0x04,not activated ,64
ENG122229-ENG117699-Car_Function_List_BAP_Gen2-headup_displ_0x04_msg_bus,not activated ,64
ENG122229-ENG117746-Car_Function_List_BAP_Gen2-Hybrid_0x1D,not activated ,64
ENG122229-ENG117747-Car_Function_List_BAP_Gen2-Hybrid_0x1D_msg_bus,not activated ,64
ENG122229-ENG117706-Car_Function_List_BAP_Gen2-interieur_light_0x08,not activated ,64
ENG122229-ENG117707-Car_Function_List_BAP_Gen2-interieur_light_0x08_msg_bus,not activated ,64
ENG122229-ENG117740-Car_Function_List_BAP_Gen2-LDW_HCA_0x19,not activated ,64
ENG122229-ENG117741-Car_Function_List_BAP_Gen2-LDW_HCA_0x19_msg_bus,not activated ,64
ENG122229-ENG117720-Car_Function_List_BAP_Gen2-MFA_0x0F,activated ,64
ENG122229-ENG117721-Car_Function_List_BAP_Gen2-MFA_0x0F_msg_bus,Terminal 15 ,64
ENG122229-ENG117767-Car_Function_List_BAP_Gen2-MFL_Jocker_0x34,not activated ,64
ENG122229-ENG117766-Car_Function_List_BAP_Gen2-MFL_Jocker_msg_bus_0x34,not activated ,64
ENG122229-ENG117719-Car_Function_List_BAP_Gen2-mirror_0x0E,activated ,64
ENG122229-ENG117718-Car_Function_List_BAP_Gen2-mirror_0x0E_msg_bus,Terminal 15 ,64
ENG122229-ENG117738-Car_Function_List_BAP_Gen2-Night_Vision_0x18,not activated ,64
ENG122229-ENG117739-Car_Function_List_BAP_Gen2-Night_Vision_0x18_msg_bus,not activated ,64
ENG122229-ENG117710-Car_Function_List_BAP_Gen2-parking_assist_0x0A,activated ,64
ENG122229-ENG117711-Car_Function_List_BAP_Gen2-parking_assist_0x0A_msg_bus,Terminal 15 ,64
ENG122229-ENG117752-Car_Function_List_BAP_Gen2-Passenger_Seat_0x20,not activated ,64
ENG122229-ENG117753-Car_Function_List_BAP_Gen2-Passenger_Seat_0x20_msg_bus,not activated ,64
ENG122229-ENG125831-Car_Function_List_BAP_Gen2-Pedestrian_Assist_0x3A,not activated ,64
ENG122229-ENG125832-Car_Function_List_BAP_Gen2-Pedestrian_Assist_msg_bus_0x3A,not activated ,64
ENG122229-ENG122333-Car_Function_List_BAP_Gen2-Range_Data_0x39,activated ,64
ENG122229-ENG125827-Car_Function_List_BAP_Gen2-Range_Data_msg_bus_0x39,Terminal 15 ,64
ENG122229-ENG122327-Car_Function_List_BAP_Gen2-RearSeatEntertainment_0x2E,not activated ,64
ENG122229-ENG122328-Car_Function_List_BAP_Gen2-RearSeatEntertainment_0x2E_msg_bus,not activated ,64
ENG122229-ENG117750-Car_Function_List_BAP_Gen2-Reversible_Seat_Belt_Tightener_0x1F,not activated ,64
ENG122229-ENG117751-Car_Function_List_BAP_Gen2-Reversible_Seat_Belt_Tightener_0x1F_msg_bus,not activated ,64
ENG122229-ENG125833-Car_Function_List_BAP_Gen2-Seat_Pneumatic_0x3B,not activated ,64
ENG122229-ENG125834-Car_Function_List_BAP_Gen2-Seat_Pneumatic_msg_bus_0x3B,not activated ,64
ENG122229-ENG139200-Car_Function_List_BAP_Gen2-Seatmemory_codriver_rear_0x3F,not activated ,64
ENG122229-ENG139201-Car_Function_List_BAP_Gen2-Seatmemory_codriver_rear_msg_bus_0x3F,not activated ,64
ENG122229-ENG139198-Car_Function_List_BAP_Gen2-Seatmemory_driver_rear_0x3E,not activated ,64
ENG122229-ENG139199-Car_Function_List_BAP_Gen2-Seatmemory_driver_rear_msg_bus_0x3E,not activated ,64
ENG122229-ENG117726-Car_Function_List_BAP_Gen2-service_interval_display_0x12,activated ,64
ENG122229-ENG117727-Car_Function_List_BAP_Gen2-service_interval_display_0x12_msg_bus,Terminal 15 ,64
ENG122229-ENG117748-Car_Function_List_BAP_Gen2-SideView_0x1E,activated ,64
ENG122229-ENG117749-Car_Function_List_BAP_Gen2-SideView_0x1E_msg_bus,Infotainment data bus ,64
ENG122229-ENG122329-Car_Function_List_BAP_Gen2-Special_Functions_0x35,activated ,64
ENG122229-ENG122330-Car_Function_List_BAP_Gen2-Special_Functions_msg_bus_0x35,Terminal 15 ,64
ENG122229-ENG117762-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27,not activated ,64
ENG122229-ENG117763-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27_msg_bus,not activated ,64
ENG122229-ENG117742-Car_Function_List_BAP_Gen2-SWA_0x1A,not activated ,64
ENG122229-ENG117743-Car_Function_List_BAP_Gen2-SWA_0x1A_msg_bus,Terminal 15 ,64
ENG122229-ENG117704-Car_Function_List_BAP_Gen2-tire_pressure_system_0x07,not activated ,64
ENG122229-ENG117705-Car_Function_List_BAP_Gen2-tire_pressure_system_0x07_msg_bus,not activated ,64
ENG122229-ENG117754-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21,not activated ,64
ENG122229-ENG117755-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21_msg_bus,not activated ,64
ENG122229-ENG122331-Car_Function_List_BAP_Gen2-Trailer_Assistant_0x36,not activated ,64
ENG122229-ENG122332-Car_Function_List_BAP_Gen2-Trailer_Assistant_msg_bus_0x36,not activated ,64
ENG122229-ENG122325-Car_Function_List_BAP_Gen2-TV_tuner_0x2C,not activated ,64
ENG122229-ENG122326-Car_Function_List_BAP_Gen2-TV_tuner_0x2C_msg_bus,not activated ,64
ENG122229-ENG117730-Car_Function_List_BAP_Gen2-UGDO_0x14,activated ,64
ENG122229-ENG117731-Car_Function_List_BAP_Gen2-UGDO_0x14_msg_bus,Terminal 15 ,64
ENG122229-ENG117728-Car_Function_List_BAP_Gen2-unit_master_0x13,not activated ,64
ENG122229-ENG117729-Car_Function_List_BAP_Gen2-unit_master_0x13_msg_bus,not activated ,64
ENG122229-ENG117712-Car_Function_List_BAP_Gen2-VPS_0x0B,not activated ,64
ENG122229-ENG117713-Car_Function_List_BAP_Gen2-VPS_0x0B_msg_bus,not activated ,64
ENG122229-ENG117756-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22,activated ,64
ENG122229-ENG117757-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22_msg_bus,Terminal 15 ,64
ENG122229-ENG117714-Car_Function_List_BAP_Gen2-wiper_comfort_0x0C,not activated ,64
ENG122229-ENG117715-Car_Function_List_BAP_Gen2-wiper_comfort_0x0C_msg_bus,not activated ,64
ENG122228-ENG127498-Car_Function_List_CAN_Gen2-Adaptive_key,Not available ,8
ENG122228-ENG117690-Car_Function_List_CAN_Gen2-Adaptive_key_msg_bus,Not available ,8
ENG122228-ENG117688-Car_Function_List_CAN_Gen2-Driving_school,available. ,8
ENG122228-ENG117689-Car_Function_List_CAN_Gen2-Driving_school_msg_bus,Terminal 15 ,8
ENG122228-ENG107608-Car_Function_List_CAN_Gen2-MFL,available. ,8
ENG122228-ENG117681-Car_Function_List_CAN_Gen2-MFL_msg_bus,Terminal 15 ,8
ENG122228-ENG117683-Car_Function_List_CAN_Gen2-Oil_level,available. ,8
ENG122228-ENG117684-Car_Function_List_CAN_Gen2-Oil_level_msg_bus,Terminal 15 ,8
ENG122228-ENG117685-Car_Function_List_CAN_Gen2-PDC_audio_lowering,available. ,8
ENG122228-ENG117686-Car_Function_List_CAN_Gen2-PDC_audio_lowering_msg_bus,Terminal 15 ,8
ENG122228-ENG98891-Car_Function_List_CAN_Gen2-Reserved,available. ,8
ENG122228-ENG101416-Car_Function_List_CAN_Gen2-Reserved_1,Terminal 15 ,8
ENG122228-ENG99458-Car_Function_List_CAN_Gen2-Reserved_2,Terminal 15 ,8
ENG122228-ENG99668-Car_Function_List_CAN_Gen2-Reserved_3,available. ,8
ENG122228-ENG99892-Car_Function_List_CAN_Gen2-VIN,available. ,8
ENG122228-ENG117687-Car_Function_List_CAN_Gen2-VIN_msg_bus,Terminal 15 ,8
ENG117913-ENG101574-Dimming_Ambient_Illumination_Information_Control_Unit-X1,0 ,6
ENG117913-ENG99557-Dimming_Ambient_Illumination_Information_Control_Unit-X2,20 ,6
ENG117913-ENG102140-Dimming_Ambient_Illumination_Information_Control_Unit-X3,50 ,6
ENG117913-ENG99777-Dimming_Ambient_Illumination_Information_Control_Unit-Y1,0 ,6
ENG117913-ENG100480-Dimming_Ambient_Illumination_Information_Control_Unit-Y2,20 ,6
ENG117913-ENG100773-Dimming_Ambient_Illumination_Information_Control_Unit-Y3,50 ,6
ENG117916-ENG101574-Dimming_Illumination_for_Display_Unit-X1,3 ,12
ENG117916-ENG99557-Dimming_Illumination_for_Display_Unit-X2,10 ,12
ENG117916-ENG102140-Dimming_Illumination_for_Display_Unit-X3,15 ,12
ENG117916-ENG102936-Dimming_Illumination_for_Display_Unit-X4,60 ,12
ENG117916-ENG103548-Dimming_Illumination_for_Display_Unit-X5,0 ,12
ENG117916-ENG113992-Dimming_Illumination_for_Display_Unit-X6,0 ,12
ENG117916-ENG99777-Dimming_Illumination_for_Display_Unit-Y1,2 %,12
ENG117916-ENG100480-Dimming_Illumination_for_Display_Unit-Y2,10 %,12
ENG117916-ENG100773-Dimming_Illumination_for_Display_Unit-Y3,15 %,12
ENG117916-ENG100631-Dimming_Illumination_for_Display_Unit-Y4,90 %,12
ENG117916-ENG102174-Dimming_Illumination_for_Display_Unit-Y5,0 %,12
ENG117916-ENG113993-Dimming_Illumination_for_Display_Unit-Y6,0 %,12
ENG141636-ENG142049-Key_code_monitoring-monitoring_keycode_0x00_0x07,FF ,32
ENG141636-ENG142050-Key_code_monitoring-monitoring_keycode_0x08_0x0F,FF ,32
ENG141636-ENG142051-Key_code_monitoring-monitoring_keycode_0x10_0x17,FF ,32
ENG141636-ENG142052-Key_code_monitoring-monitoring_keycode_0x18_0x1F,FF ,32
ENG141636-ENG142053-Key_code_monitoring-monitoring_keycode_0x20_0x27,FF ,32
ENG141636-ENG142054-Key_code_monitoring-monitoring_keycode_0x28_0x2F,FF ,32
ENG141636-ENG142055-Key_code_monitoring-monitoring_keycode_0x30_0x37,FF ,32
ENG141636-ENG142056-Key_code_monitoring-monitoring_keycode_0x38_0x3F,FF ,32
ENG141636-ENG142057-Key_code_monitoring-monitoring_keycode_0x40_0x47,FF ,32
ENG141636-ENG142058-Key_code_monitoring-monitoring_keycode_0x48_0x4F,FF ,32
ENG141636-ENG142059-Key_code_monitoring-monitoring_keycode_0x50_0x57,FF ,32
ENG141636-ENG142060-Key_code_monitoring-monitoring_keycode_0x58_0x5F,FF ,32
ENG141636-ENG142061-Key_code_monitoring-monitoring_keycode_0x60_0x67,FF ,32
ENG141636-ENG142062-Key_code_monitoring-monitoring_keycode_0x68_0x6F,FF ,32
ENG141636-ENG142063-Key_code_monitoring-monitoring_keycode_0x70_0x77,FF ,32
ENG141636-ENG142064-Key_code_monitoring-monitoring_keycode_0x78_0x7F,FF ,32
ENG141636-ENG142065-Key_code_monitoring-monitoring_keycode_0x80_0x87,FF ,32
ENG141636-ENG142066-Key_code_monitoring-monitoring_keycode_0x88_0x8F,FF ,32
ENG141636-ENG142067-Key_code_monitoring-monitoring_keycode_0x90_0x97,FF ,32
ENG141636-ENG142068-Key_code_monitoring-monitoring_keycode_0x98_0x9F,FF ,32
ENG141636-ENG142069-Key_code_monitoring-monitoring_keycode_0xA0_0xA7,FF ,32
ENG141636-ENG142070-Key_code_monitoring-monitoring_keycode_0xA8_0xAF,FF ,32
ENG141636-ENG142071-Key_code_monitoring-monitoring_keycode_0xB0_0xB7,FF ,32
ENG141636-ENG142072-Key_code_monitoring-monitoring_keycode_0xB8_0xBF,FF ,32
ENG141636-ENG142073-Key_code_monitoring-monitoring_keycode_0xC0_0xC7,FF ,32
ENG141636-ENG142074-Key_code_monitoring-monitoring_keycode_0xC8_0xCF,FF ,32
ENG141636-ENG142075-Key_code_monitoring-monitoring_keycode_0xD0_0xD7,FF ,32
ENG141636-ENG142076-Key_code_monitoring-monitoring_keycode_0xD8_0xDF,FF ,32
ENG141636-ENG142077-Key_code_monitoring-monitoring_keycode_0xE0_0xE7,FF ,32
ENG141636-ENG142078-Key_code_monitoring-monitoring_keycode_0xE8_0xEF,FF ,32
ENG141636-ENG142079-Key_code_monitoring-monitoring_keycode_0xF0_0xF7,FF ,32
ENG141636-ENG142080-Key_code_monitoring-monitoring_keycode_0xF8_0xFF,FF ,32
ENG167428-ENG167502-nhtsa_properties-limitation_dependency,gear_selection ,5
ENG167428-ENG167510-nhtsa_properties-nhtsa_limitation_switches_for_androidauto_limit_displayed_message_length,not activated ,5
ENG167428-ENG167511-nhtsa_properties-nhtsa_limitation_switches_for_androidauto_no_setup_configuration,not activated ,5
ENG167428-ENG167512-nhtsa_properties-nhtsa_limitation_switches_for_androidauto_no_text_input,not activated ,5
ENG167428-ENG167513-nhtsa_properties-nhtsa_limitation_switches_for_androidauto_no_video_playback,not activated ,5
ENG167428-ENG167514-nhtsa_properties-nhtsa_limitation_switches_for_androidauto_no_voice _input,not activated ,5
ENG167428-ENG167515-nhtsa_properties-nhtsa_limitation_switches_for_carplay_limit_musicLists,not activated ,5
ENG167428-ENG167516-nhtsa_properties-nhtsa_limitation_switches_for_carplay_limit_nonMusicLists,not activated ,5
ENG167428-ENG167517-nhtsa_properties-nhtsa_limitation_switches_for_carplay_no_japanMaps,not activated ,5
ENG167428-ENG167518-nhtsa_properties-nhtsa_limitation_switches_for_carplay_no_softKeyboard,not activated ,5
ENG167428-ENG167519-nhtsa_properties-nhtsa_limitation_switches_for_carplay_no_softPhoneKeypad,not activated ,5
ENG117921-Operating_and_Display_Unit_1_Proximity_Sensor_Basic_Adaptation,00 00 00 00 01 00 00 00 00 01 00 00 00 00 01 00 00 00 00 01 DC C8 96 82 96 82 DC C8 07 64 1E 04 10 03 0A 00 00 00 02 28 ,40
ENG122219-ENG122287-Radio_Level_Quality_Offsets-Set_AM_Quality_Level_Offset,0 ,2
ENG122219-ENG122288-Radio_Level_Quality_Offsets-Set_FM_Quality_Level_Offset,0 ,2
ENG117919-Startup_Screen_Sticker_HMI,00 02 ,2
ENG109862-ENG117847-Vehicle_configuration-advanced_range_display,On ,30
ENG109862-ENG249824-Vehicle_configuration-AliBox,OFF ,30
ENG109862-ENG142146-Vehicle_configuration-allow_message_editing,OFF ,30
ENG109862-ENG130249-Vehicle_configuration-Apple_DIO,On ,30
ENG109862-ENG185764-Vehicle_configuration-Apple_DIO_Wireless,OFF ,30
ENG109862-ENG152525-Vehicle_configuration-Baidu_Car_Life,OFF ,30
ENG109862-ENG152559-Vehicle_configuration-Baidu_Car_Life_ios,OFF ,30
ENG109862-ENG185765-Vehicle_configuration-Baidu_Car_Life_ios_Wireless,OFF ,30
ENG109862-ENG185766-Vehicle_configuration-Baidu_Car_Life_Wireless,OFF ,30
ENG109862-ENG152560-Vehicle_configuration-block_hmi_function_p_epb,locked ,30
ENG109862-ENG142151-Vehicle_configuration-conditioning_variant,0 ,30
ENG109862-ENG263540-Vehicle_configuration-correction_e_mileage,0 ,30
ENG109862-ENG125043-Vehicle_configuration-Dtmf_without_active_call,On ,30
ENG109862-ENG142145-Vehicle_configuration-esim_data_only_sms_support,OFF ,30
ENG109862-ENG185778-Vehicle_configuration-FoD,SWaP ,30
ENG109862-ENG130248-Vehicle_configuration-Google_GAL,On ,30
ENG109862-ENG185779-Vehicle_configuration-Google_GAL_Wireless,OFF ,30
ENG109862-ENG117850-Vehicle_configuration-gracenote_local_coverarts,OFF ,30
ENG109862-ENG117851-Vehicle_configuration-gracenote_local_other,OFF ,30
ENG109862-ENG117848-Vehicle_configuration-gracenote_online_coverarts,OFF ,30
ENG109862-ENG117849-Vehicle_configuration-gracenote_online_other,OFF ,30
ENG109862-ENG152533-Vehicle_configuration-Hybrid_Radio_additional_online_data,not activated ,30
ENG109862-ENG152534-Vehicle_configuration-Hybrid_Radio_Range_Extender,Deactivated ,30
ENG109862-ENG261211-Vehicle_configuration-internet_over_WLAN_default_setting,OFF ,30
ENG109862-ENG125049-Vehicle_configuration-Joker_button_1,not installed ,30
ENG109862-ENG125050-Vehicle_configuration-Joker_button_2,not installed ,30
ENG109862-ENG127492-Vehicle_configuration-LGI,OFF ,30
ENG109862-ENG130246-Vehicle_configuration-LTE_modul,activated ,30
ENG109862-ENG142142-Vehicle_configuration-map_email_support,OFF ,30
ENG109862-ENG142143-Vehicle_configuration-map_instant_messaging_support,OFF ,30
ENG109862-ENG142141-Vehicle_configuration-map_sms_support,OFF ,30
ENG109862-ENG142152-Vehicle_configuration-Map_Style,0 ,30
ENG109862-ENG152537-Vehicle_configuration-media_control,not activated ,30
ENG109862-ENG138662-Vehicle_configuration-Mirror_link,On ,30
ENG109862-ENG142148-Vehicle_configuration-MirrorLink_Country_Code,MIB_EU ,30
ENG109862-ENG142150-Vehicle_configuration-MirrorLink_RGB_Preference,RGB565 ,30
ENG109862-ENG117843-Vehicle_configuration-my_audi,OFF ,30
ENG109862-ENG117845-Vehicle_configuration-online_dictation,OFF ,30
ENG109862-ENG127495-Vehicle_configuration-online_media,OFF ,30
ENG109862-ENG117840-Vehicle_configuration-online_navigation,OFF ,30
ENG109862-ENG117837-Vehicle_configuration-online_POI,OFF ,30
ENG109862-ENG117838-Vehicle_configuration-online_POI_voice,OFF ,30
ENG109862-ENG117839-Vehicle_configuration-online_portal_browser_services,OFF ,30
ENG109862-ENG152553-Vehicle_configuration-online_radio,Deactivated ,30
ENG109862-ENG117841-Vehicle_configuration-online_street_view,OFF ,30
ENG109862-ENG125048-Vehicle_configuration-OPS_display_in_dash_board_display_unit,On ,30
ENG109862-ENG167521-Vehicle_configuration-perso_v_threshold,00 ,30
ENG109862-ENG167522-Vehicle_configuration-perso_v_threshold_hysteresis,00 ,30
ENG109862-ENG152554-Vehicle_configuration-Phone_HMI_Privacy,0 ,30
ENG109862-ENG125046-Vehicle_configuration-Phone_module_operation_mode,Data & language service active ,30
ENG109862-ENG117844-Vehicle_configuration-picture_navi,On ,30
ENG109862-ENG167523-Vehicle_configuration-Pilot_Parking,not activated ,30
ENG109862-ENG167525-Vehicle_configuration-Popup_if_GPS_services_in_use,not activated ,30
ENG109862-ENG152555-Vehicle_configuration-Privacy_WithPINRequest,0 ,30
ENG109862-ENG127496-Vehicle_configuration-ProbeCar_lgi,OFF ,30
ENG109862-ENG137646-Vehicle_configuration-ProbeCar_vzo,OFF ,30
ENG109862-ENG125047-Vehicle_configuration-PSD_Protocol_Version,PSD_1.5 ,30
ENG109862-ENG117846-Vehicle_configuration-remote_HMI,OFF ,30
ENG109862-ENG138661-Vehicle_configuration-RSE_software_component,activated ,30
ENG109862-ENG245031-Vehicle_configuration-rvc_low_black_screen_trunk_open,not activated ,30
ENG109862-ENG244966-Vehicle_configuration-rvc_low_black_screen_velocity_threshold,not activated ,30
ENG109862-ENG245015-Vehicle_configuration-rvc_low_failsafe,not activated ,30
ENG109862-ENG126143-Vehicle_configuration-RVC_video_input,FBAS ,30
ENG109862-ENG152556-Vehicle_configuration-scon_telephony,not activated ,30
ENG109862-ENG142081-Vehicle_configuration-sd_slot_deactivation,no restriction ,30
ENG109862-ENG138660-Vehicle_configuration-SDS_Region_Flag,no_region ,30
ENG109862-ENG152557-Vehicle_configuration-show_volte_hmi_switch,not activated ,30
ENG109862-ENG125045-Vehicle_configuration-Sim_card_mode_switch,not installed ,30
ENG109862-ENG142144-Vehicle_configuration-sim_data_only_sms_support,OFF ,30
ENG109862-ENG138663-Vehicle_configuration-Smartphone_interface_for_rhmi,activated ,30
ENG109862-ENG126993-Vehicle_configuration-Station_Logo_DB_Mode,1 ,30
ENG109862-ENG125044-Vehicle_configuration-Support_for_response_and_hold,OFF ,30
ENG109862-ENG125042-Vehicle_configuration-Support_of_threeway_calling,OFF ,30
ENG109862-ENG130247-Vehicle_configuration-Support_second_phone,On ,30
ENG109862-ENG167531-Vehicle_configuration-Tencent_myCar_canceling_share_location,OFF ,30
ENG109862-ENG126994-Vehicle_configuration-TPEG_availability,OFF ,30
ENG109862-ENG152571-Vehicle_configuration-unblock_functions_while_piloted_driving,locked ,30
ENG109862-ENG137647-Vehicle_configuration-UOTA,OFF ,30
ENG109862-ENG167532-Vehicle_configuration-UOTA_2,OFF ,30
ENG109862-ENG117852-Vehicle_configuration-UPnP,On ,30
ENG109862-ENG142149-Vehicle_configuration-vehicle_leaving_sound,not activated ,30
ENG109862-ENG142147-Vehicle_configuration-vehicle_readiness_sound,not activated ,30
ENG109862-ENG152558-Vehicle_configuration-voice_over_lte,not activated ,30
ENG109862-ENG117836-Vehicle_configuration-VZAPro,OFF ,30
ENG109862-ENG127494-Vehicle_configuration-VZO,OFF ,30
ENG109862-ENG137648-Vehicle_configuration-WiFi_Client_HMI,OFF ,30
ENG109862-ENG117842-Vehicle_configuration-WIFI_Hotspot,On ,30
ENG109862-ENG152572-Vehicle_configuration-wlan_5ghz_switch,not activated ,30
Elapsed Time: 00:30
Skoda washer bottle top, folding into a very useful opening with rubber edges standing up
6V0955485
My little Polo on the test track, during the approval of the engine change:
https://imgur.com/a/EKJvMc2
Beautiful and powerful!👌
Something unimportant, please refresh my memory ...
Are they oranges? for what?
ciclo wrote: Tue Dec 21, 2021 7:36 pm Beautiful and powerful!👌
No, just standard incandescent P21W bulbs. You're probably seeing the reflection of the metal interior of the light.
They're not connected to anything, apart from themselves :D
Ah ok ... I thought you installed additional indicators (which is possible via BCM).
I have never liked the original indicators of our 6Rs, neither with bi-xenon headlights, nor with LED headlights - location and power -.
I still need to find a useful purpose for these lights. I considered additional indicator but I don't like two of them.
Perhaps an SOS light :mrgreen:
Hahaha, with SOS red button, ...or, SC lights?... 🏎🏎 🚖 ...😁
ag69
Drives: 1.2TSi 77Kw 7DSG
Post by ag69 »
SOS light
Safety car like blinkers
Good one
"Safetycar is driving too slowly man"
images of iichel furiously wiring his G8 MFSW
I think it's called, my steering wheel is LIT
