6c headlights onto 6r ?
Re: 6c headlights onto 6r ?
can it be any junior power timer? and must it be 0.5mm or above
i think it's best to respect the minimum wire thickness
update, i bought this wire http://dataton.net/vw/electrical/VW-000 ... 1-scan.jpg
but it doesn’t seem to want to go into my headlight switch, any idea why?
Try harder
forgot to update, finally got them working after a painful session of lying on my back snipping wires. but it worked. thanks for all the help
Hello guys!
I read the the whole thread but I'm not absolutely sure in a question so I ask you to help me pls.
If I read it correctly in this thread, the changing from a 6R H7/H7 headlight to a 6C H7/H7 is plug and play?!
For example: 6R1941007E -> 6C1941005B
Thanks in advance!
limparka
Thanks in advance!
limparka
- mirceaculita
- Drives: 6R 1.2TDI 75hp
Thank you!
This wire set also fit on skoda with max bcm and bixenon drl?https://nbcarperformance.nl/shop/polo-6 ... pterkabel/
