For some reason my Polo randomly cut out the other day.
It was driving fine but then all of sudden i got no power when i was pressing the accelerator, it felt like no petrol was getting to the engine. The car continued to run but eventually cut out.
Since then I have been unable to start it up.
The fuel pump seems to be working. I can hear it humming and felt it vibrating when I've turned the engine on.
Does anyone have any ideas what it could be?
MK2F 1993 Not Starting - Help
Re: MK2F 1993 Not Starting - Help
The fuel pump seems to be working, but the pressure may be low
Musky
- Drives: Volkswagen Polo Coupe Genesis 1993
How do I check the fuel pressure?mannerboy wrote: Wed Feb 16, 2022 12:42 pm The fuel pump seems to be working, but the pressure may be low
Or do i just replace both pumps?
You can put a pressure gauge on the pump outlet before it comes to the injectors.
86cTom
- Drives: Silver 1992 86c 1043
Check your ignition, (rotor, cap, leads) I had similar on mine and the lead on the coil had become worn and corroded and worked it’s way loose.
