i have the same problemAnnoyed wrote: Fri Feb 18, 2022 1:13 pmHi Ciclo,ciclo wrote: Fri Feb 18, 2022 5:08 am Thanks for sharing the pictures.
They help when we take a look at the autoscan.![]()
This is Craig (ViperSlider)
The site is refusing to allow me to post under my other username and also refusing to allow me to post my autoscan stating it contains contacts and is classing it as spam.
I also can’t contact any admin as I am “forbidden”.
Not sure what to do. If the admin are reading, could they advise?!
Cris-87
- Drives: vw golf 6 and vw t5 2014
Viperslider
- Drives: Seat Leon 5F Cupra ST 290
Good afternoon Ciclo (or morning, depending on your timezone!)ciclo wrote: Fri Feb 18, 2022 5:08 am Thanks for sharing the pictures.
Today I have completed the following:
Added new 2.5mm/30a inputs to T73a63 and T73b68
Added new 1.5mm/15a outputs to T73a1/a2 and b1/b2 to fuses 5/6/27/28 including new signal to IC for HB. F5-A2, F6-B1, F27-B2, F28-A1
Added new 0.5mm outputs from T73a5/b3 to fuses 12/14 for DRLs
replaced 17pin light switch (E1) with 10 pin (3C8941431A) and added 6 outputs from T10 to relevant T73a/b plugs and +15/+30/earth feeds for switch
Replaced stalks with 7E0953507F and added new wires for T41/38/39/40/41 to +15, +30, T73a62, T73b8
Additional information that may be useful:
I would like to add a dimmer switch for the interior illumination but not checked what is needed yet, so T10/10 remains disconnected for now.
Originally I had H4 halogen headlights but now have aftermarket headlights that are T5.1 xenon REPLICAS which have LED Drls. I have also added Osram LED headlight bulbs (not pictured). Pic below:
As seen, I have genuine T6.1 LED tail lights too.
The result:
No DRLs
Side lights working
Low beam working (but showing Main beam display in IC)
No main beam control from stalks at all
But I suspect you expected the above results!
Recently added RLS and HBA(FLA) parts/looms but not concerned with those working yet until after the lights are working correctly.
Here is my latest autoscan (or part of, due to forum posting restrictions)
Part No SW: 7E0 937 090 HW: 7E0 937 090
Revision: B9080001 Serial number: 0771 035161868
Coding: F9A839BA0A212091012808D02CEB8E50F08043FF60020080320000010000
Shop #: WSC 12345 210 12345
VCID: 689C49DB9BB550C9E9-803C
Subsystem 1 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 030216 05 54 0403
Coding: 2630AD
Subsystem 2 - Part No SW: 7E0 959 801 Q HW: 7E0 959 801 R Labels: 7E0-959-80X-V2.CLB
Component: J386__TSG_FT 005 0653
Serial number: KU0KU022101992950515
Coding: 1000B3
Subsystem 3 - Part No SW: 7E0 959 802 Q HW: 7E0 959 802 Q Labels: 7E0-959-80X-V2.CLB
Component: J387__TSG_BT 004 0653
Serial number: KU0KU010041991001759
Coding: 0000B3
Subsystem 4 - Part No SW: 5G0 959 442 L HW: 5G0 959 442 L
Component: E221__MFL-DC1 H11 0103
Serial number: 29180000513380048213
Coding: A4FFFF
3 Faults Found:
00978 - Lamp for Low Beam; Left (M29)
010 - Open or Short to Plus
Fault Status: 01101010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 61
Mileage: 182371 km
Time Indication: 0
Date: 2016.07.11
Time: 01:28:01
00979 - Lamp for Low Beam; Right (M31)
Fault Priority: 3
Fault Frequency: 1
Reset counter: 61
Mileage: 182371 km
Time Indication: 0
Date: 2016.07.11
Time: 01:28:02
01504 - Bulb for License-Plate Light (X)
Fault Priority: 3
Fault Frequency: 1
Reset counter: 61
Mileage: 182371 km
Time Indication: 0
Date: 2016.07.11
Time: 01:28:02The only part I am finding a barrier is the coding due to lack of information.
I'll look forward to your input on the above!
If you want to discuss payment for your time then I'm happy to discuss
Viperslider
I forgot to mention, the headlights are designed for halogen bulbs, not xenon. Just in case there is any confusion.
Cris-87
ciclo wrote: Fri Feb 18, 2022 12:09 pm Hí.
It seems that you have not done this procedure correctly. Replacementhttp://wiki.ross-tech.com/wiki/index.ph ... eplacement
Please post an old Autoscan with BCM 7H0...087 installed.
edit: Please link me to the guide you have followed for your electrical installation.
this is the guide that i have followed
and this is the scan.
I apologize if it is a bit dirty but the t5 had just come out of the bodywork for a total painting and they disassembled it without then resetting the errors
VIN: WV2ZZZ7HZEH033380 Mileage: 227190km-141169miles
18-Aux. Heat -- Status: Malfunction 0010
22-AWD -- Status: OK 0000
56-Radio -- Status: Malfunction 1010
Address 09: Cent. Elect. (J519) Labels:. 7H0-937-08x-09.clb
Part No SW: 7H0 937 087 M HW: 7H0 937 087
Component: BCM T5GP H+4 H34 0411
Revision: BO034001 Serial number: 0573 210130420
Coding: F8B0793A4A21201201280E107EEB8FD50080412F60844000320000000000
Shop #: WSC 12345 123 12345
VCID: 3E76BB68A927877973-806A
Subsystem 1 - Part No SW: 7E0 959 801 HW: 7E0 959 801 Labels: 7E0-959-80X-V1.CLB
Component: J386__TSG_FT 002 3313
Subsystem 2 - Part No SW: 7E0 959 802 HW: 7E0 959 802 Labels: 7E0-959-80X-V1.CLB
Component: J387__TSG_BT 002 3313
10 Faults Found:
011 - Open Circuit - Intermittent
Fault Status: 00101011
Fault Priority: 2
Fault Frequency: 1
Reset counter: 46
Time Indication: 0
03432 - Activation of Right Parking Light
Fault Priority: 2
Fault Frequency: 1
Reset counter: 46
Time Indication: 0
00329 - Control Circuit for Unlocking Rear Lid
Fault Priority: 2
Fault Frequency: 1
Reset counter: 46
Time Indication: 0
03301 - Response Closing Status of Drivers Door
Fault Status: 00101000
Fault Priority: 2
Fault Frequency: 3
Reset counter: 58
Mileage: 226190 km
Time Indication: 0
Date: 2016.04.21
Time: 20:24:41
03302 - Response Closing Status of Passenger's Door
Fault Priority: 2
Fault Frequency: 3
Reset counter: 58
Mileage: 226190 km
Time Indication: 0
Date: 2016.04.21
Time: 20:24:41
03304 - Response Closing Status of Rear Right Door
Fault Priority: 2
Fault Frequency: 27
Reset counter: 70
Mileage: 225536 km
Time Indication: 0
Date: 2016.02.20
Time: 07:50:29
00920 - Heated Outside Mirrors; Driver Side (Z4) / Passenger Side (Z5)
006 - Short to Plus - Intermittent
Fault Status: 00100110
Fault Priority: 3
Fault Frequency: 1
Reset counter: 46
Mileage: 225590 km
Time Indication: 0
Date: 2016.03.05
Time: 10:44:28
00532 - Supply Voltage B+
002 - Lower Limit Exceeded - Intermittent
Fault Status: 00100010
Fault Priority: 3
Fault Frequency: 3
Reset counter: 46
Time Indication: 0
00446 - Function Limitation due to Under-Voltage
Fault Priority: 6
Fault Frequency: 6
Reset counter: 46
Time Indication: 0
01520 - Rain and Light Recognition Sensor (G397)
004 - No Signal/Communication
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 179
Mileage: 223303 km
Time Indication: 0
Date: 2015.11.28
Time: 18:21:22
Hello "Annoyed" ... LOL!
General rule:
You cannot use private messaging or post contacts until you have at least 10 posts.
The problem is that most of the time a contact is detected when posting a full VCDS Autoscan.
Please Craig, keep posting here with ViperSlider until you get those 10 posts needed. Thanks!
edit:
Sorry I didn't see the following posts before posting,
... at least it's already explained ...
General rule:
edit:
Hi Viperslider.
All your post read and understood
, ... you should now be able to post a Full Autoscan without any problems.
Hi Cris-87.
Please tell me the GW coding with the BCM 87. Thanks.
Hi Cris-87.
Viperslider
Woohoo!! It has been a long time since I was a "Newbie" on an internet forumciclo wrote: Fri Feb 18, 2022 8:13 pm Hi Viperslider.
All your post read and understood, ... you should now be able to post a Full Autoscan without any problems.
Here is my latest autoscan:
Friday,18,February,2022,10:35:17:50827
VCDS Version: 21.9.0.2 (x64) HEX-NET CB: 0.4555.4
Data version: 20210903 DS330.0
www.Ross-Tech.com
VIN: WV1ZZZ7HZEH09**** License Plate: L16TRO
Chassis Type: 7H-VN75 (7E0)
Scan: 01 03 04 08 09 15 17 19 20 25 37 56 61 77 0B
VIN: WV1ZZZ7HZEH09**** Mileage: 182370km-113319miles
37-Navigation -- Status: Cannot be reached 1100
56-Radio -- Status: Cannot be reached 1100
77-Telephone -- Status: Cannot be reached 1100
Address 01: Engine (J623-CAAC) Labels:. 03L-906-022-CAA.clb
Part No SW: 03L 906 019 GH HW: 03L 907 309 M
Component: R4 2,0L EDC X45 5576
Revision: 26X45--- Serial number: 00000000000000 CVN: 8C42185C
Coding: 01194012232400080000
Shop #: WSC 92521 052 00000
ASAM Dataset: EV_ECM20TDI01103L906019GH 003003
ROD: EV_ECM20TDI01103L906019FM_003.rod
VCID: 77BE1AA7CE0BCF3170-8022
VINID: 9E606AAAA1D8A956002430C50C00D7DA0A
Readiness: 0 0 0 0 1
Address 03: ABS Brakes (-----) Labels: 7E0-907-37x-MK25AXT.clb
Part No SW: 7E0 907 379 K HW: 7E0 907 379 E
Component: ESP MK25A XT H43 0110
Revision: 00H43001
Coding: 708724AD89AD0E9824A59176A96110
Shop #: WSC 02736 790 49152
VCID: 3A38C393B59912594F-806E
Serial number: 28011404650720
Coding: 01
Shop #: WSC 00000 000 00000
ROD: EV_LWSKLOVW25X.rod
VCID: 7EB00F83E131FE7933-802A
Address 08: Auto HVAC (J301) Labels:| 7E5-907-047.clb
Part No SW: 7E5 907 047 BN HW: 7E5 907 047 BN
Component: Climatic-T5 H20 0506
Revision: 00001012
Coding: 0000000002
Shop #: WSC 02736 790 50316
ROD: EV_ClimaT5Basis.rod
VCID: 7CB4058BF72DEC691D-8028
Coding: 2630AD
Coding: 1000B3
Coding: 0000B3
Coding: A4FFFF
3 Faults Found:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 61
Mileage: 182371 km
Time Indication: 0
Date: 2016.07.11
Time: 01:28:01
Fault Priority: 3
Fault Frequency: 1
Reset counter: 61
Mileage: 182371 km
Time Indication: 0
Date: 2016.07.11
Time: 01:28:02
Fault Priority: 3
Fault Frequency: 1
Reset counter: 61
Mileage: 182371 km
Time Indication: 0
Date: 2016.07.11
Time: 01:28:02
Part No SW: 7E0 959 655 B HW: 7E0 959 655 B
Component: VW10Airbag009 H07 0013
Revision: -------- Serial number: 003HL00MSSRH
Coding: 000000000000000000000000000000003039
Shop #: WSC 02734 790 50316
ROD: EV_AirbaVW10BPAVN750.rod
VCID: 3522D0AF9487FD21A2-8060
Part No SW: 7E0 920 970 J HW: 7E0 920 970 J
Component: KOMBI H04 0710
Coding: 760E01
ROD: EV_Kombi_UDS_VDD_RM09_004_VW36.rod
VCID: 312AE4BF60EFD101FE-8064
1 Fault Found:
13654544 - Databus
U1121 00 [009] - Missing Message
[Steuergerät für Telefon keine Kommunikation]
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 3
Reset counter: 61
Mileage: 182371 km
Date: 2022.02.18
Time: 01:28:02
Part No SW: 7E0 909 901 HW: 7E0 937 090
Revision: B9080001
Coding: 042300
3 Faults Found:
01304 - Radio
Fault Priority: 2
Fault Frequency: 1
Reset counter: 61
Mileage: 182371 km
Time Indication: 0
Date: 2016.07.11
Time: 01:28:06
01300 - Control Module for Navigation with CD-Rom (J401)
Fault Priority: 2
Fault Frequency: 1
Reset counter: 61
Mileage: 182371 km
Time Indication: 0
Date: 2016.07.11
Time: 01:28:06
01303 - Telephone Transceiver (R36)
Fault Priority: 2
Fault Frequency: 1
Reset counter: 61
Mileage: 182371 km
Time Indication: 0
Date: 2016.07.11
Time: 01:28:06
Address 20: High Beam Assist. (J844) Labels:. 8K0-857-511.clb
Part No SW: 1K8 857 511 E HW: 8J0 857 511 C
Component: FLA H03 0012
Revision: AA002001
Coding: 0102856B74745D545420363E01
Shop #: WSC 00020 790 12345
VCID: 3424EDAB97FDE42995-8060
Component: IMMO H04 0710
Serial number:
VCID: 6A9833D38DB962D9FF-803E
Address 37: Navigation
Cannot be reached
Address 56: Radio
Cannot be reached
Address 61: Battery Regul. (J840) Labels:. 1K0-907-534.clb
Part No SW: 7E0 907 534 HW: 7E0 937 090
Component: Batt.regelung H80 0736
Coding: 00001A00
Shop #: WSC 02739 790 12345
Address 77: Telephone
Cannot be reached
End----(Elapsed Time: 01:23, VBatt start/end: 11.5V/11.7V. VIgn 11.7V)-----
Kind regards
Thanks Viperslider, let me study the possible codings for your T5.
I'll post them tomorrow (or as soon as possible).
No type of payment is necessary, sharing your experiences in the forum with your T5 is more than enough.
Viperslider
Thank you Ciclo, if you have any need for more information then not a problem.ciclo wrote: Fri Feb 18, 2022 8:33 pm Thanks Viperslider, let me study the possible codings for your T5.
No type of payment is necessary, sharing your experiences in the forum with your T5 is more than enough.![]()
On a side note, I have a “D” revision 7E0 BCM here too. I ran into a wall with the keys so opted to get the other BCM to make the upgrade easier. I would think that there is no real disadvantage in having either BCM?
@Viperslider.
Previous clarifications:
- Same meridian, same time zone.
- The problem with the BCM 7E0 D is that it is probably parameterized for Kessy, hence that wall to match the keys.
Tip: It is better to buy a virgin BCM, I always recommend talking to firegrafik (forum user), he can help you buy one of the latest D, F models, which will be great for your future original LED headlights and other upgrades...
- You may have to power the license plate lights directly from the T73b/7 BCM pin. (pin dedicated to... if automatic lights).
- This first BCM coding is the starting point, don't panic if there are faults or malfunctions, everything will be solved later.
- Post the results, with your comments and a new Autoscan with the new codings.
Let's go with the first new BCM coding for automatic lights + CH/LH, with Replica headlights (Osram LED bulbs), without Dimmer, with original T6.1 taillights. The starting point.
09
New BCM coding:
F9A839BA0A21209101280E602CEB8E50C0807389600220C03200003D0800
09
Adaptation
54 Channel ... from 0 to 1 (stalks - momentary switch - return spring) https://www.uk-polos.net/viewtopic.php?p=503577#p503577
Note:
You must understand that due to the hardware of your Replica headlights some functions may not be possible. There have always been different versions of Replica headlights for the top selling VW models. The latest versions are better wired.
09
New BCM coding:
09
Adaptation
Note:
@Cris-87
If I understand you correctly, you still have the H7 headlights installed (waiting for the Bixenon headlights to arrive)...
In such a case:
09
New BCM coding: (BCM 7E0937090B, H7 headlights + auto lights + CH/LH)
F8B079BA4A21201201280E107EEB8FD50080612F60846001320000020000
19
GW coding:
042200
If I misunderstood you, we re-encode based on your instructions/information.
In this Autoscan
https://www.uk-polos.net/viewtopic.php?p=589273#p589273, I think that you did not transfer the codings from your old BCM and GW to the new one 090B, as indicated in the link I posted to ross-tech for BCM replacement, that is why I requested the Autoscan with the old BCM 087.
We will code the BCM 090B again once the Bixenon headlights are installed.
In such a case:
09
19
GW coding:
042200
In this Autoscan
Viperslider
Hiya Ciclo!
Thank you for looking into this so quickly!
So I had the chance to blat the coding onto the BCM and we have a great start:
DRLs fully functional including indicator wink - Perfect
Low beams working on “Auto” and Dipped beam - Perfect
High beam working correctly on all functions and stalk positions - Perfect
So the front lights are all working exactly as they should!
As expected, the number plate lights are no longer working but will make the wiring changes for that today (moving to T73b7, which makes sense as I’ll have auto headlights by the end).
I can’t test the full functionality of the auto headlights yet as the day is dramatic but it would appear that they are working. I’ll report back once I am able to test correctly.
Here is a new autoscan:
Saturday,19,February,2022,08:30:13:50827
www.Ross-Tech.com
VIN: WV1ZZZ7HZEH09^^^^ License Plate:
VIN: WV1ZZZ7HZEH09^^^^ Mileage: 182370km-113319miles
Revision: 00H43001
Coding: 01
Revision: 00001012
Coding: 0000000002
Coding: F9A839BA0A21209101280E602CEB8E50C0807389600220C03200003D0800
Coding: 2630AD
Coding: 1000B3
Coding: 0000B3
Coding: A4FFFF
3 Faults Found:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 61
Mileage: 182371 km
Time Indication: 0
Date: 2016.07.12
Time: 23:28:25
Fault Priority: 3
Fault Frequency: 2
Reset counter: 61
Mileage: 182371 km
Time Indication: 0
Date: 2016.07.12
Time: 23:28:25
Fault Priority: 3
Fault Frequency: 1
Reset counter: 61
Mileage: 182371 km
Time Indication: 0
Date: 2016.07.12
Time: 23:28:25
Coding: 760E01
1 Fault Found:
13654544 - Databus
Fault Priority: 6
Fault Frequency: 11
Reset counter: 61
Mileage: 182371 km
Date: 2022.02.19
Time: 01:28:02
Revision: B9080001
Coding: 042300
4 Faults Found:
01304 - Radio
Fault Priority: 2
Fault Frequency: 1
Reset counter: 61
Mileage: 182371 km
Time Indication: 0
Date: 2016.07.12
Time: 01:28:06
Fault Priority: 2
Fault Frequency: 1
Reset counter: 61
Mileage: 182371 km
Time Indication: 0
Date: 2016.07.12
Time: 01:28:06
Fault Priority: 2
Fault Frequency: 1
Reset counter: 61
Mileage: 182371 km
Time Indication: 0
Date: 2016.07.12
Time: 01:28:06
03406 - Control Module for Battery Monitoring
Fault Priority: 2
Fault Frequency: 3
Reset counter: 61
Mileage: 182371 km
Time Indication: 0
Date: 2016.07.12
Time: 03:06:05
Revision: AA002001
Serial number:
Cannot be reached
Address 56: Radio
Cannot be reached
Coding: 00001A00
Cannot be reached
End----------(Elapsed Time: 01:23, VBatt start/end: 14.4V/14.5V)-----------
On a side note: I have my own trade account with VWAG for parts so if it will be a big benefit to get a later BCM then I can acquire one. If not then I am happy with the 090
I just wish the rain would go away for another day!
Viperslider
Hi Ciclo,
I thought I would add another update as I have now adjusted the wiring for the number plate lights (X)
The keen eye will see that I no longer have a fault code for the number plate lights. Woohoo!
The same keen eye will see that I no longer have comms with my HBA module. However, I am still experimenting with this retrofit (moving CANBUS lines etc) as I had good direct comms with it on the powertrain BUS but reports of no comms fault code stored in the gateway (always showing up after I did the autoscans, hence why they haven't shown up in any of the scans I have posted so far). However, I have now moved it to the correct BUS (same as the IC) and now I have no direct comms with the HBA module but it appears to be functional LOL
So this is still an ongoing joyride. As long as it functions then I'm happy. I will be experimenting tonight under the cloak of darkness!
Saturday,19,February,2022,15:23:46:50827
www.Ross-Tech.com
Revision: 00H43001
Coding: 01
Revision: 00001012
Coding: 0000000002
Coding: 2630AD
Coding: 1000B3
Coding: 0000B3
Coding: A4FFFF
2 Faults Found:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 61
Mileage: 182371 km
Time Indication: 0
Date: 2016.07.12
Time: 06:19:08
Fault Priority: 3
Fault Frequency: 1
Reset counter: 61
Mileage: 182371 km
Time Indication: 0
Date: 2016.07.12
Time: 06:19:08
Coding: 760E01
1 Fault Found:
13654544 - Databus
Fault Priority: 6
Fault Frequency: 1
Reset counter: 61
Mileage: 182371 km
Date: 2022.02.19
Time: 06:19:08
Revision: B9080001
Coding: 042300
3 Faults Found:
01304 - Radio
Fault Priority: 2
Fault Frequency: 1
Reset counter: 61
Mileage: 182371 km
Time Indication: 0
Date: 2016.07.12
Time: 06:19:12
Fault Priority: 2
Fault Frequency: 1
Reset counter: 61
Mileage: 182371 km
Time Indication: 0
Date: 2016.07.12
Time: 06:19:12
Fault Priority: 2
Fault Frequency: 1
Reset counter: 61
Mileage: 182371 km
Time Indication: 0
Date: 2016.07.12
Time: 06:19:12
Cannot be reached
Serial number:
Cannot be reached
Address 56: Radio
Cannot be reached
Coding: 00001A00
Cannot be reached
End----------(Elapsed Time: 01:21, VBatt start/end: 14.3V/14.3V)-----------
Cris-87
ciclo wrote: Sat Feb 19, 2022 8:40 am @Cris-87
If I understand you correctly, you still have the H7 headlights installed (waiting for the Bixenon headlights to arrive)...thank you very much for the speed in replying, you are really helpful to me. anyway I had the h7 but today I mounted the bixenon. my current situation is this: bixenon installed, RLS sensor installed and blackout mirror installed.
wiring for car switch installed
switch on car goes nothing
switch on positions does not go anything
switch on headlights go the low beams
with the lever I can flash but the fixed high beams do not go
In such a case:
09
19
GW coding:
042200
this is the gateway coding with the bcm 087
Address 19: CAN Gateway (J533) Labels:. 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 7H0 937 087
Component: GW-K-CAN TP20 H34 0411
Revision: BO034001
Coding: 042200
VCID: 70EA5550A3F32109B1-8024
Component: GW-K-CAN TP20 H81 0744
Revision: B9081001
Coding: 042207
Shop #: WSC 02737 534 423142
VCID: 68DA3D309B23E9C9E9-803C
the first thing I did after installing the bmc 090 was to copy the old encoding and re-encode the remote which now works correctly.
I hope I explained myself well, if you need more information I will be more precise/i]
In this Autoscanhttps://www.uk-polos.net/viewtopic.php?p=589273#p589273, I think that you did not transfer the codings from your old BCM and GW to the new one 090B, as indicated in the link I posted to ross-tech for BCM replacement, that is why I requested the Autoscan with the old BCM 087.
If it's any consolation for you today it's also raining around here, but we're looking forward to this rain, we need it to rain for a couple of weeks at least.Viperslider wrote: Sat Feb 19, 2022 4:21 pm Hi Ciclo,
The keen eye will see that I no longer have a fault code for the number plate lights. Woohoo!Code: Select all
Saturday,19,February,2022,15:23:46:50827 VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64 VCDS Version: 21.9.0.2 (x64) HEX-NET CB: 0.4555.4 Data version: 20210903 DS330.0 www.Ross-Tech.com VIN: WV1ZZZ7HZEH093353 License Plate: Chassis Type: 7H-VN75 (7E0) Scan: 01 03 04 08 09 15 17 19 20 25 37 56 61 77 0B VIN: WV1ZZZ7HZEH093353 Mileage: 182370km-113319miles 01-Engine -- Status: OK 0000 03-ABS Brakes -- Status: OK 0000 04-Steering Angle -- Status: OK 0000 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: Malfunction 0010 15-Airbags -- Status: OK 0000 17-Instruments -- Status: Malfunction 0010 19-CAN Gateway -- Status: Malfunction 0010 20-High Beam Assist. -- Status: OK 0000 25-Immobilizer -- Status: OK 0000 37-Navigation -- Status: Cannot be reached 1100 56-Radio -- Status: Cannot be reached 1100 61-Battery Regul. -- Status: OK 0000 77-Telephone -- Status: Cannot be reached 1100 ------------------------------------------------------------------------------- Address 01: Engine (J623-CAAC) Labels:. 03L-906-022-CAA.clb Part No SW: 03L 906 019 GH HW: 03L 907 309 M Component: R4 2,0L EDC X45 5576 Revision: 26X45--- Serial number: 00000000000000 CVN: 8C42185C Coding: 01194012232400080000 Shop #: WSC 92521 052 00000 ASAM Dataset: EV_ECM20TDI01103L906019GH 003003 ROD: EV_ECM20TDI01103L906019FM_003.rod VCID: 77BE1AA7CE0BCF3170-8022 VINID: 9E606AAAA1D8A956002430C50C00D7DA0A No fault code found. Readiness: 0 0 0 0 1 ------------------------------------------------------------------------------- Address 03: ABS Brakes (-----) Labels: 7E0-907-37x-MK25AXT.clb Part No SW: 7E0 907 379 K HW: 7E0 907 379 E Component: ESP MK25A XT H43 0110 Revision: 00H43001 Coding: 708724AD89AD0E9824A59176A96110 Shop #: WSC 02736 790 49152 VCID: 3A38C393B59912594F-806E No fault code found. ------------------------------------------------------------------------------- Address 04: Steering Angle (G085) Labels:* 6R0-959-654.clb Part No SW: 6R0 959 654 HW: 6R0 959 654 Component: LENKW.SENSOR H07 0070 Serial number: 28011404650720 Coding: 01 Shop #: WSC 00000 000 00000 ASAM Dataset: EV_LWSKLOVW25X 005001 ROD: EV_LWSKLOVW25X.rod VCID: 7EB00F83E131FE7933-802A No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC (J301) Labels:| 7E5-907-047.clb Part No SW: 7E5 907 047 BN HW: 7E5 907 047 BN Component: Climatic-T5 H20 0506 Revision: 00001012 Coding: 0000000002 Shop #: WSC 02736 790 50316 ASAM Dataset: EV_ClimaticT5 A01003 ROD: EV_ClimaT5Basis.rod VCID: 7CB4058BF72DEC691D-8028 No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. (J519) Labels:. 7E0-937-BCM-V1.clb Part No SW: 7E0 937 090 HW: 7E0 937 090 Component: BCM PQ25 Max4 H80 0736 Revision: B9080001 Serial number: 0771 035161868 Coding: F9A839BA0A21209101280E602CEB8E50C0807389600220C03200003D0800 Shop #: WSC 12345 210 12345 VCID: 689C49DB9BB550C9E9-803C Subsystem 1 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB Component: RLS 030216 05 54 0403 Coding: 2630AD Subsystem 2 - Part No SW: 7E0 959 801 Q HW: 7E0 959 801 R Labels: 7E0-959-80X-V2.CLB Component: J386__TSG_FT 005 0653 Serial number: KU0KU022101992950515 Coding: 1000B3 Subsystem 3 - Part No SW: 7E0 959 802 Q HW: 7E0 959 802 Q Labels: 7E0-959-80X-V2.CLB Component: J387__TSG_BT 004 0653 Serial number: KU0KU010041991001759 Coding: 0000B3 Subsystem 4 - Part No SW: 5G0 959 442 L HW: 5G0 959 442 L Component: E221__MFL-DC1 H11 0103 Serial number: 29180000513380048213 Coding: A4FFFF 2 Faults Found: 00978 - Lamp for Low Beam; Left (M29) 010 - Open or Short to Plus Freeze Frame: Fault Status: 01101010 Fault Priority: 3 Fault Frequency: 1 Reset counter: 61 Mileage: 182371 km Time Indication: 0 Date: 2016.07.12 Time: 06:19:08 00979 - Lamp for Low Beam; Right (M31) 010 - Open or Short to Plus Freeze Frame: Fault Status: 01101010 Fault Priority: 3 Fault Frequency: 1 Reset counter: 61 Mileage: 182371 km Time Indication: 0 Date: 2016.07.12 Time: 06:19:08 ------------------------------------------------------------------------------- Address 15: Airbags (J234) Labels:| 5K0-959-655.clb Part No SW: 7E0 959 655 B HW: 7E0 959 655 B Component: VW10Airbag009 H07 0013 Revision: -------- Serial number: 003HL00MSSRH Coding: 000000000000000000000000000000003039 Shop #: WSC 02734 790 50316 ASAM Dataset: EV_AirbaVW10BPAVN750 A01026 ROD: EV_AirbaVW10BPAVN750.rod VCID: 3522D0AF9487FD21A2-8060 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI1 Part No SW: 7E0 920 970 J HW: 7E0 920 970 J Component: KOMBI H04 0710 Serial number: 00000000000000 Coding: 760E01 Shop #: WSC 12345 210 12345 ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04723 ROD: EV_Kombi_UDS_VDD_RM09_004_VW36.rod VCID: 312AE4BF60EFD101FE-8064 1 Fault Found: 13654544 - Databus U1121 00 [009] - Missing Message [Steuergerät für Telefon keine Kommunikation] Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 1 Reset counter: 61 Mileage: 182371 km Date: 2022.02.19 Time: 06:19:08 ------------------------------------------------------------------------------- Address 19: CAN Gateway (J533) Labels:. 7E0-909-901.clb Part No SW: 7E0 909 901 HW: 7E0 937 090 Component: GW-K-CAN TP20 H80 0736 Revision: B9080001 Coding: 042300 Shop #: WSC 12345 210 12345 VCID: 689C49DB9BB550C9E9-803C 3 Faults Found: 01304 - Radio 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 61 Mileage: 182371 km Time Indication: 0 Date: 2016.07.12 Time: 06:19:12 01300 - Control Module for Navigation with CD-Rom (J401) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 61 Mileage: 182371 km Time Indication: 0 Date: 2016.07.12 Time: 06:19:12 01303 - Telephone Transceiver (R36) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 61 Mileage: 182371 km Time Indication: 0 Date: 2016.07.12 Time: 06:19:12 ------------------------------------------------------------------------------- Address 20: High Beam Assist. Cannot be reached ------------------------------------------------------------------------------- Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb Part No SW: 5K0 953 234 HW: 5K0 953 234 Component: IMMO H04 0710 Serial number: Coding: 000000 Shop #: WSC 00000 000 00000 ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03710 ROD: EV_Immo_UDS_VDD_RM09_VW21.rod VCID: 6A9833D38DB962D9FF-803E No fault code found. ------------------------------------------------------------------------------- Address 37: Navigation Cannot be reached ------------------------------------------------------------------------------- Address 56: Radio Cannot be reached ------------------------------------------------------------------------------- Address 61: Battery Regul. (J840) Labels:. 1K0-907-534.clb Part No SW: 7E0 907 534 HW: 7E0 937 090 Component: Batt.regelung H80 0736 Serial number: 0771 035161868 Coding: 00001A00 Shop #: WSC 02739 790 12345 VCID: 689C49DB9BB550C9E9-803C No fault code found. ------------------------------------------------------------------------------- Address 77: Telephone Cannot be reached End----------(Elapsed Time: 01:21, VBatt start/end: 14.3V/14.3V)-----------
Once the matter of the number plate lights has been solved (well done)... have you checked the operation of all the lights included in the tail lights? Once checked, you should verify that there are no related DTCs in the scan.
There is a possible solution for "low beam" faults in your Replica headlights. I suppose that your Osram LED bulbs are without drive unit, which is very low consumption, installing LEDs with a drive unit will not cause these faults.
E.g (just to visualize it, - my wife's Golf -): viewtopic.php?p=563461#p563461
They were tests that I did to know what people were installing in their Golf MK7. It currently has the original MATRIX LED headlights installed.
I also did tests with the Scirocco HBA mirror before installing the T6 HBA mirror.
I recommend installing the T6 HBA mirror (works perfectly or better
I do not know if having activated channel 53 in the BCM your Scirocco HBA mirror will work correctly. You get the symbol on the IC, but...
