Polo 6R ABS CODING
Re: Polo 6R ABS CODING
I guess you will indeed need to flash a different software to your abs unit
Piyush7243
- Drives: Vento 1.5TDi DSG
Any pointers on how to do that?
Best to talk to a local expert with vcp or Odis. Not something for the DIY people.
Piyush7243
I am not aware of anyone around me who does that. Let me see if I can find out else will see what's next.iichel wrote: Sun Mar 20, 2022 6:09 pm Best to talk to a local expert with vcp or Odis. Not something for the DIY people.
Piyush7243
Asked couple of people and it seems they are not aware of how to do. Any pointers from members out of India so that I can contact relevant people.
Also if no one then I might want to go diy way to get vcp and find software and flash or find an abs unit which has higher software version
- Platinum Member
Find someone who has VAS5054A or newer and has ODIS ( ODIS E ). I'm pretty sure that if you find someone with this that someone will send you the correct files to flash the abs module.Piyush7243 wrote: Mon Mar 21, 2022 5:51 pm Asked couple of people and it seems they are not aware of how to do. Any pointers from members out of India so that I can contact relevant people.
I'd start with Patil. Perhaps he knows how to help you out (local or remotely)
patil
Hey Piyush,
Your ABS module SW version must be updated to 6R0 907 379 CB (from BN
CB), which is the latest firmware. Unfortunately this firmware is not available in public domain.
It has to be purchased and also need access to ODIS-E or Original VCP to flash it. It is also important to know where you are located in my country.
Contact me by PM, I will try to help you.
Piyush7243
Thanks a lot Patil, i am located near by itself around 250-300kms from Your place. I have sent a PM. Thanks for trying to help mepatil wrote: Mon Mar 21, 2022 8:30 pm Hey Piyush,
Your ABS module SW version must be updated to 6R0 907 379 CB (from BNCB), which is the latest firmware. Unfortunately this firmware is not available in public domain.
Piyush7243
Also i am not sure i can send a PM to Patil. I have sent a PM but its still in my Outbox and doesn't show in Sent Items
Piyush7243
Talked to Patil few hours back, such a nice person. We discussed a lot and it seems there is a way he can help him. I am very grateful for all the help he has extended to me in this situation.
Also i recently became the owner of VAG car and did few things, nothing like legends here but will surely write a post on the same and will try to contribute as much as i can with my limited knowledge
- Jay-Jay
- Drives: Polo 6R HL 1.2TSI 77kw, Audi S1 MY2018
Could someone tell me what are the default values for these adaptation channels in ABS 8.2i unit please?
- 21 (0=small, 1=center, 2=large)
- 35 (1=on, 0=off)
- 51 (1=enabled, 0=deactivated)
- 73 (1=on, 0=off).
Also, does somebody know what they are for?
- 35 (1=on, 0=off)
- 73 (1=on, 0=off).
Hi Piyush7243, so did the flashing to CB help to accept 288mm + drum coding: 62DD4C63422B07C54614326A4256E0820908 ?Piyush7243 wrote: Wed Mar 23, 2022 3:50 pm Talked to Patil few hours back, such a nice person. We discussed a lot and it seems there is a way he can help him. I am very grateful for all the help he has extended to me in this situation.
Hi.Can I ask another time for help with coding abs in Polo?
VIN: WVWZZZ6RZAY208925
Adres 03: ABS/hamulce (3104)
Plik etykiet:. 6R0-907-37x-ESP82.clb
Oznaczenie elementu SW: 6R0 907 379 AF HW: GR0 907 379 AF
Komponent: ESP8.21 front H05 0005
Weryfikacja: Kodowanie:210224E3216D00BA842E24E484D600401100
Kod serwisu: WSC 02069 000 00000 VID: 020B3F0F990F189FD9-8056
1.2 TSI 2010
LHD
This code - 21 02 24 C2 21 6D 00 BA 84 2E 24 E4 84 D6 00 40 00 00 - its ok?
1.2 TSI 2010
LHD
What exactly is the problem?
