Hey fellow Polo people,
Wondering whether anyone has any experience in after market braided or stainless steel clutch line & brake line instillation?
I recently got a new clutch master & slave fitted due to the clutch pedal failing and everything seems ok again so far but I wonder if the original lines may have something to do with the spongy, light feeling that remains. Would braided lines stiffen up the clutch feel and potentially help the master and slave live a little longer?
My polo is a 2016 1.8 GTI (6r/6c).
Braided/stainless steel clutch and brake lines for 2016 GTI?
- Platinum Member
Re: Braided/stainless steel clutch and brake lines for 2016 GTI?
I doubt it would prolong the life of the part.
Its hard to bleed out air completely the cylinder because of the location of the nipple.
But you could bleed the air in reverse direction pushing fluid from nipple towards the reservoar.
If you mean the stifness od the pedal, that depends on clamping force of pressure plate.
Thanks, and yeah I’m gonna give it a go bleeding the clutch again as it definitely feels like some air may still be in the line. Was more so thinking that the lines may be slightly knackered and may be swelling slightly when clutch/brakes are depressed - I’ve heard that’s a common problem with the polo gti’s after 6 or so years.
- Platinum Member
It should be made from same material as the brake hoses.
If you can source the braided lines and want them, go for it. The lines will last longer than the rubber ones.
