Manually adjust the headlights?
- mirceaculita
- Drives: 6R 1.2TDI 75hp
I need to adjust my headlights. I have to keep them on the lowest position and I'm still flashbang-ing people in front of me. I tried spinning the white plastic screw but seems to be stuck...
Do I have to do something with VCDS to be able to turn it or could it be broken?
Re: Manually adjust the headlights?
What kind of headlights are we talking about?
- mirceaculita
Halogen H4
- Platinum Member
did you put them i lowest position on the switch?
I also found mine really stiff.
H4 lights are only mechanically controlled, not by a control module so VCDS won't help there.
- mirceaculita
- Platinum Member
Yes.
But if's not going, you can take out the headlight and try to lube a bit the gears. You will see them when you take the headlight from the car. Then try to move it.
- mirceaculita
Thanks I'll try it with them set on the lowest position and see if it works.
- mirceaculita
I set the headlights in the lowest position (number 3 on the dial) and still the screw wouldn't turn. I think I have to take out the headlights and lube the gears. It's weird they won't turn with that screw but turn just fine when using the dial inside the cabin...
- Platinum Member
the dial operates a motor inside the headlight that pushes a rod that is attached to headlight reflectior tilting it up and down
- mirceaculita
ah, I see. I though it was spinning up those gears
- Platinum Member
try.to lube those gears on the headlight. You can see the from the outside.
- mirceaculita
Took the headlights out, changed the bulbs to a set of Osram Nigh Breakers and adjusted to roughly to the correct level.
Had to use a bit of WD40 to lube the gears. Patience was key since I'm pretty sure they were completely filled with dirt since I could feel it grinding while turning the screw. Took about 5 minutes of continuously going back and forth little by little until they got unstuck.
For the first time in 2 years I can actually see the breakout line of the headlights on a distanced wall
