Introducing my Lightning McQueen LM95
- ag69
- Drives: 1.2TSi 77Kw 7DSG
Re: Introducing my Lightning McQueen LM95
Can someone help me with wiring diagram for this map sensor connector?
I could not find any other color on white wires. ie orange on white or sort.
- ag69
After going through elsa, here is what i found:
https://en.kolhosniki.ru/elsaonline&ver ... m#id500014
Check No. 34 / 7
G42 and G71 connector have 4 wires
T4d/1 -- br -- Brown -- 283 (Earth Point 2)
T4d/2 -- ws -- White -- T60/42 -- J263
T4d/3 -- sw -- Black -- D141 (5V)
T4d/4 -- ws -- White -- T60/55 -- J263
Since both wires are white -- It is guess to which it should be connected.
Does anyone can help me understand T60/42 and T60/55 of J623 ie ECU does?
As there is no current flowing -- there is no harm in connecting them in any way.
Any advise on how to distinguish it from harness side -- would be welcome.
Check No. 34 / 7
/55 is a pressure transducer which probably will probably be a variable voltage output between 0 and 5V
/42 is a temperature sensor with a PTC or NTC over GND
Best practice is to disconnect T60 and find T60/55 (easiest) and connect it to T4d/4
And 'tother goes to T4d/2
- ag69
Thank you very much iichel.
- ag69
6RF035187C aka R 340G (PQ)
Finally, after a lot of searches, patience, being fooled by sellers, here is a legit used 6RF035187C.
Super packing 1
Super packing 2
Super packing 3
Super packing 4 / Box
Super packing 5
First Glimpse
Device in hand
Device in car
Device in car with illumination
This is an OEM Visteon unit (Manufactured in June 2021) which came in Polo. Seller sold his car, and I was prompt and lucky to be first in line to buy it.
No user manual was provided. However, anti-theft code was provided.
After opening all the packing took radio in car.
Removed existing stereo and unplugged ISO connectors and radio antenna cable.
Connected ISO to Quadlock adapter (with additional CAN+ and CAN - wires) to radio side.
Connected ISO to car ISO connector.
Turned Ignition turned ON.
Powered on radio with left round button.
Presented with "Anti-theft code" screen.
Entered Code
and got radio playing.
Pressed APP button and all three "android auto", "apple carplay" and "mirror link" options were present.
Connected VCDS and here is scan
Surprisingly, my last VCDS scan here
This did not have 56 Radio module installed/enabled.
And latest scan has it enabled.
Super packing 1
Super packing 2
Super packing 3
Super packing 5
First Glimpse
Device in hand
Device in car
Entered Code
Wednesday,24,January,2024,07:49:21:47040
VCDS Version: 23.3.1.0 (x64) HEX-V2 CB: 0.4631.4
Data version: 20230421 DS346.2
www.Ross-Tech.com
VIN: WVWL14601FT043293 License Plate: MH12LM0095
Mileage: 13060km-8115mi Repair Order:
Chassis Type: 60-VW25 (6N0)
Scan: 01 02 03 04 08 09 15 17 19 25 44 56
VIN: WVWL14601FT043293 Mileage: 13060km-8115miles
56-Radio -- Status: Not registered 0001
Address 01: Engine (J623-CBZB) Labels:. 03F-906-070-CBZ.clb
Part No SW: 03F 906 070 KC HW: 03F 907 309 AJ
Component: SIMOS10.22AH10 6270
Revision: --H10--- Serial number: CVN: 9408DB59
Coding: 00250056232400080000
Shop #: WSC 00793 648 00255
ASAM Dataset: EV_ECM12TFS02103F906070KC 004006
VCID: 6D84C0DFDD1A8262D4D-8038
VINID: 9E69DC0441800569001030890CB4E08725
Readiness: 0000 0000
Part No SW: 0AM 300 065 N HW: 0AM 927 769 D
Component: GSG DSG AG7 431 6561
Revision: 00043014 Serial number: CU501407085037
Coding: 0000020
Shop #: WSC 63002 002 1048576
VCID: 3A2E3B83D054E5DA01F-806E
Part No SW: 6R0 907 379 BH HW: 6R0 907 379 AS
Component: ESP9.0i front H03 0001
Serial number: --------------
Coding: 62DD2463422703C3461624724254C0800904
Shop #: WSC 00788 648 00255
ASAM Dataset: EV_Brake1ESP90iBOSCH 003020
VCID: 0554987FE5AA5A223CD-8050
Serial number: 14081404650280
Coding: 01
Shop #: WSC 00000 000 00000
ROD: EV_LWSKLOVW25X.rod
VCID: 7EA6F793807C09FA7D7-802A
Part No SW: 6R0 907 044 P HW: 6R0 907 044 P
Component: Climatronic H12 0614
Revision: V0000000
VCID: 40DA496BBA88BF0A4FB-8014
Part No SW: 6R0 937 087 R HW: 6R0 937 087
Component: BCM PQ25 H+4 H34 0424
Revision: BF034001 Serial number: 0681 233141094
Coding: 3AB82BBF08B30000003800006C2B049000C0414F608C0000200000000000
Shop #: WSC 124697 483 00190
VCID: 4CC26D5B86C06B6AA33-8018
Subsystem 1 - Part No SW: 6R0 959 802 AL HW: 6R0 959 802 AL Labels: 6R0-959-802.CLB
Component: ------------- 006 5550
Serial number: 13102576140821120301
Coding: 010000
Subsystem 2 - Part No SW: 6R0 959 801 AH HW: 6R0 959 801 AH Labels: 6R0-959-801.CLB
Serial number: 13202579140804112607
Coding: 010000
Subsystem 3 - Part No SW: 6C0 959 442 HW: 6C0 959 442
Component: E221__MFL-TAT H03 0015
Serial number: 1201410594800708AA1B
Coding: 250000
Subsystem 4 - Part No SW: 6R0 959 811 L HW: 6R0 959 811 L
Serial number: 13102580140812095241
Coding: 020000
Subsystem 5 - Part No SW: 6R0 959 812 L HW: 6R0 959 812 L
Serial number: 13202581140821150004
Coding: 020000
Part No SW: 6R0 959 655 J HW: 6R0 959 655 J
Revision: -------- Serial number: 003GW00VFBN2 Dataset Number: 00000000000 0001
Coding: 003036
VCID: 49CC544F89327E42985-801C
Part No SW: 6RF 920 860 Q HW: 6RF 920 860 Q
Component: KOMBI H02 0152
Coding: 140800
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04719
VCID: 58EA810B429817CA17B-800C
Address 19: CAN Gateway (J533) Labels:. 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 6R0 937 087
Component: GW-K-CAN TP20 H34 0424
Revision: BF034001
Coding: 002300
VCID: 70BAD9ABCAA86F8AFFB-8024
1 Fault Found:
000 - -
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
Component: IMMO H02 0152
Serial number:
VCID: 6A8ECBC3ECF4955AB1F-803E
Address 44: Steering Assist (J792) Labels:* 6Rx-909-144-V1.clb
Part No SW: 6RF 909 144 K HW: 6RF 909 144 J
Component: EPS_ECU H44 0401
Dataset Number: 6RF074v____ 6010
Coding: 0000
ASAM Dataset: EV_SteerAssisUDSNSK 005005
ROD: EV_SteerAssisUDSNSK.rod
VCID: 54F2753B5E7033AAFB3-8000
Part No SW: 6RF 035 187 C HW: 6RF 035 187 C
Component: Radio 557 5536
Revision: -------- Serial number: VWZ7Z2V5102817
Coding: 0E00044000000F
Shop #: WSC 31245 005 1048576
VCID: 49CC544F89B27E42985-801C
End----------(Elapsed Time: 01:09, VBatt start/end: 12.0V/12.0V)-----------
Tuesday,23,May,2023,15:36:34:47040
www.Ross-Tech.com
Mileage: 12140km-7543mi Repair Order:
VIN: WVWL14601FT043293 Mileage: 12140km-7543miles
44-Steering Assist -- Status: OK 0000And latest scan has it enabled.
Good upgrade!
giannis20vt
One of the best upgrades anyone can do. And easy.
Well done!
Excellent packing
Well done!
Excellent packing
- ag69
Thank you ciclo
Thank you Giannis20vtgiannis20vt wrote: Thu Jan 25, 2024 6:21 am One of the best upgrades anyone can do. And easy.
Well done!
Excellent packing![]()
Finally, could get 56 Radio enabled and changed one coding for radio
0E00044000000F
to:
0E00040000000F
So now no more come this once reverse gear is enagaged:
Also in addition to existing angled aux cable got this angled USB cable.
It is 9" odd long. So iPhone can be put upside down in compartment under climate control.
Just a precaution to avoid any damage.
Great, so now we know that Byte3 Bit6 enables RVC (I think I read this info in a thread from some D2 wizard a million years ago)... someone recently asked me about the possibility of enabling/disabling with VCDS the RVC and the OPS in this radio model.
By the way, does your model have RDS? shows radio stations?
I don't have this radio model but I find it very interesting and a good upgrade for 6R models... I'm going to investigate to see if I can get the latest FW. Wish me luck!
Update. Instructions:
https://www.drive2.ru/l/590711523584775820/
- ag69
Hey ciclo
Nope this does not get RDS.
I had downloaded the images from some VW site.
Some video had shown to go on radio screen and settings icon you get option to upload and then assign them.
— this was not for RCD340
I will click some more photos and also all VCDS screenshots if you want.
And a small video of all functions.
OK thanks. I saw in some of Ali's pictures of these radio models that they had the ability to display the tuned radio station.
For example... BBC CWR, in an Ali buyer review for 6RD035187B (PQ Platforms):
Component: Radio 541 5814
If you want you can make a 'collage' with screenshots of the VCDS label with the definitions/descriptions of the Bits. It's made in D2, but not everyone knows Russian, so it would be nice to have it in English for users who visit your thread (which has many views).
- ag69
Correction
Radio Lable are displayed for couple of stations.
List view
I misunderstood about image/icon for stations. I think it is displayed like this:
Here VCDS 56 Radio screenshots
01
02
03
04
05
06
07
Here are my RCD System information:
List view
01
02
03
04
05
06
07
For quick download/viewing.
For my CM and DM I downloaded the logos, I think from here https://www.phonostar.de/vw/de/download, unzipped them to an SD and added them with the Radio Settings. There are video tutorials on YT (easy).
I assume that the logos and the procedure for adding them will be the same for your radio model.
Related:
https://www.volkswagen.co.uk/en/owners- ... t-nav.html
- ag69
this is one of YT
however i doubt it works with PQ.
One observation is I could only get 8GB micro SD popped in SD card adapter working
Another one with 32 GB formatted to fat32 does not work. Shows "Device error" message.
- ag69
Here is actual player with OEM information sticker.
Here are Advanced Information from VCDS:
Sunday,04,February,2024,10:45:14:47040
VCDS Version: 23.11.0.0 (x64) HEX-V2 CB: 0.4643.4
Data version: 20231027 DS351.0
www.Ross-Tech.com
VIN: WVWL14601FT043293 License Plate: MH12LM0095-RCD340G
Address 56: Radio
Control Module Part Number: 6RF 035 187 C
Component and/or Version: Radio 557 5536
Software Coding: 0E00040000000F
Work Shop Code: WSC 31245
VCID: 49CC544F89B27E42B8D-801C
Advanced Identification
Identification: VNA-VEI
Revision: --------
Date: 27.06.21
Manufacturer number: 0799
Test stand number: 2817
Flash Status
Flash Date: 0000.00.00
Software
OSEK Net: 03.46.03
Unknown: 02.00.01
Diag: 01.03.00
TP 2.0: 03.05.01
KWP2000: 03.00.00
BAP: 01.07.01
Misc.
Hardware number: 6RF 035 187 C
Workshop System Name: J503
Equipment/PR Code: 0000000000000000
Dataset Number: -----------
Dataset Version: ----
End of Line Equipment Level: --------------------
VCDS Info:
Labels: 5M0-035-1XX-56.CLB
