- Platinum Member
Re: iichels Polo 6R 1.6TDI DSG --> OEM++ R-Line conversion
If you measure the flange to flange lenght with the suspension in full travel it coupd help you decide the better option for inner CV ( two variants)
What do you mean by 2 variants, Amer? There is only one CV joint listed for the DQ250 inner side, right? Even though it has a lot of part numbers. The SKF VKJA 8788
- Platinum Member
I meant on triple roller and rzeppa
DSG 02E upgrade oil cooler (OEM) 02E409061C vs 02E409061B
DSG6 02E coolant circulation with oil cooler:
Did some work on the car tonight...
- VCDS --> to version 22.9
- Changed the alarm horn for a working one
- Changed the extra filter for a fresh one (this one: viewtopic.php?f=56&t=65724&start=75#p529918)
- Replaced the rubber for the boot
- Replaced the window mechanism for the driver door
- Changed the wiring for the DSG lever
- some VCDS tweaks
- some VCDS tweaks
Wednesday,28,September,2022,22:53:22:11868
VCDS Version: 22.9.0.0 (x64) HEX-V2 CB: 0.4623.4
Data version: 20220830 DS341.0
www.Ross-Tech.com
Workshop Code: 123 30389 056831
VIN: License Plate:
Mileage: 86050km-53468mi Repair Order:
Chassis Type: 6R-VW25 (7E0)
Scan: 01 02 03 04 05 08 09 10 14 15 17 19 20 25 2B 36 37 3C 44 47
55 5F 61 65 69 77 B9
VIN: Mileage: 86050km-53468miles
05-Acc/Start Auth. -- Status: OK 0000
14-Susp. Elect. -- Status: Malfunction 0010
2B-Steer. Col. Lock -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
47-Sound System -- Status: OK 0000
55-Headlight Range -- Status: Malfunction 0010
69-Trailer -- Status: OK 0000
B9-Aux. Display -- Status: Malfunction 0010
Address 01: Engine (J623-CAYC) Labels: None
Part No SW: 03L 906 023 KE HW: 03L 907 425 C
Component: R4 1.6l TDI H43 9978
Revision: --H43--- Serial number: 00000000000000 CVN: 3BB1FB41
Coding: 00254036032401080000
Shop #: WSC 00066 000 00237
ASAM Dataset: EV_ECM16TDI02103L906023KE 003009
ROD: GV_ECM16TDI021VW32X.rod
VCID: 73B3228D2B37CD53EA1-8026
VINID: 9E69EAAAA1A2A92A42085185103550A70A
Readiness: 0 0 0 0 0
Address 02: Auto Trans
Cannot be reached
Part No SW: 6R0 907 379 AS HW: 6R0 907 379 AS
Component: ESP9.0i front H02 0002
Serial number: --------------
Coding: 21DD2885412500C5841A146E825500521504
Shop #: WSC 30389 123 56831
ASAM Dataset: EV_Brake1ESP90iBOSCH 003020
VCID: 0F7B4E7D27DF89B36E9-805A
Address 05: Acc/Start Auth. (J518) Labels:| 5K0-959-434.clb
Part No SW: 5K0 959 434 E HW: 5K0 959 434
Component: VWKESSYPQ35GP 092 1202
Revision: 00092000 Serial number: 0346244897
Coding: 030C0C
Shop #: WSC 31889 047 31889
ASAM Dataset: EV_KESSYPQ35G A02717
ROD: EV_KESSY_PQ35GP.rod
VCID: 372BD69D7FCF6173169-8062
Part No SW: 6R0 907 044 H HW: 6R0 907 044 H
Component: Climatronic H12 0812
Revision: V0000000
VCID: 3829D5A172516E0B1F3-806C
Part No SW: 7E0 937 090 C HW: 7E0 937 090 C
Revision: B9082001 Serial number: 4000 173171327
Coding: 3EB82BBFA8EB3400B33807E0FFCB9FF0E68067EFE08D78D031E400030800
VCID: 2B03FAEDB307D593621-807E
Component: RLHS 220816 0 42 0106
Coding: 0214DD
Subsystem 2 - Part No SW: 6R0 959 801 BD HW: 6R0 959 801 BD Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 003 8611
Serial number: KU0KU011111300010103
Coding: 0200A3
Subsystem 3 - Part No SW: 6R0 959 802 BF HW: 6R0 959 802 BF Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 003 8611
Serial number: KU0KU007111300016463
Coding: 1000AB
Component: DWA-Sensor 00 001 0103
Subsystem 5 - Part No: 1K8 951 171 A
Subsystem 7 - Part No SW: 6R0 959 811 G HW: 6R0 959 811 G
Component: J388__TSG_HL 008 1611
Serial number: KU0KU027011200011418
Coding: 58BC32
Subsystem 8 - Part No SW: 6R0 959 812 B HW: 6R0 959 812 B
Component: J389__TSG_HR 002 0803
Serial number: KU0-KU004.06.0913330
Coding: 08BC32
1 Fault Found:
01134 - Alarm Horn (H12)
004 - No Signal/Communication
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 147
Mileage: 86056 km
Time Indication: 0
Date: 2017.02.18
Time: 21:33:55
Address 10: Park/Steer Assist (J446) Labels:| 5Q0-919-294.clb
Part No SW: 1K8 919 472 C HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0480
Revision: -------- Serial number: 39391528804191
Coding: 0031195151
ASAM Dataset: EV_EPHVA18VW364GP00 001007
ROD: EV_EPHVA18VW364GP00_VW32.rod
2 Faults Found:
1113875 - Parking Aid Indicator Lamp
B10FF 13 [009] - Open Circuit
Fault Status: 00000001
Fault Priority: 3
Fault Frequency: 1
Reset counter: 141
12718592 - Databus
U1121 00 [008] - Missing Message
[Steuerger‰t f¸r Lenks‰ulenelektronik-J527/BCM - mZAS_1 - kein Signal/keine Kommunikation]
Fault Priority: 6
Fault Frequency: 1
Reset counter: 147
Mileage: 86056 km
Date: 2022.09.28
Time: 21:32:58
Address 14: Susp. Elect. (J250) Labels:. 3C0-907-376.clb
Part No SW: 3C0 907 376 A HW: 3C0 907 376
Component: DAEMPFUNGS-SG H07 0070
Revision: 00000000 Serial number: 31080904160002
Coding: 000180
VCID: 270B06DDAFEFF1F3869-8072
8 Faults Found:
01087 - Basic Setting Not Performed
000 - - - MIL ON
Fault Status: 11100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 147
Mileage: 86056 km
Time Indication: 0
Date: 2017.02.18
Time: 21:32:57
01769 - Sensor for Vehicle Leveling; Front Right (G289)
010 - Open or Short to Plus
Fault Status: 01101010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 147
Mileage: 86056 km
Time Indication: 0
Date: 2017.02.18
Time: 21:32:57
00149 - End of Line Programming not Completed
000 - - - MIL ON
Fault Priority: 2
Fault Frequency: 1
Reset counter: 147
Mileage: 86056 km
Time Indication: 0
Date: 2017.02.18
Time: 21:32:57
00139 - Left Front Body Acceleration Sensor (G341)
009 - Open or Short to Ground
Fault Status: 01101001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 147
Mileage: 86056 km
Time Indication: 0
Date: 2017.02.18
Time: 21:32:57
00140 - Front Right Body Acceleration Sensor (G342)
Fault Priority: 2
Fault Frequency: 1
Reset counter: 147
Mileage: 86056 km
Time Indication: 0
Date: 2017.02.18
Time: 21:32:57
00141 - Rear Body Acceleration Sensor (G343)
Fault Priority: 2
Fault Frequency: 1
Reset counter: 147
Mileage: 86056 km
Time Indication: 0
Date: 2017.02.18
Time: 21:32:57
00774 - Level Control System Sensor; Rear Left (G76)
Fault Priority: 2
Fault Frequency: 1
Reset counter: 147
Mileage: 86056 km
Time Indication: 0
Date: 2017.02.18
Time: 21:32:57
00776 - Level Control System Sensor; Left Front (G78)
Fault Priority: 2
Fault Frequency: 1
Reset counter: 147
Mileage: 86056 km
Time Indication: 0
Date: 2017.02.18
Time: 21:32:57
Component: VW10Airbag01M H10 0020
Revision: -------- Serial number: 003GX0142TCE
Coding: 00314D
Shop #: WSC 01383 785 00200
VCID: 4ACD9F691C3DEC9B797-801E
Serial number: 3575HRB40650BI7U48C8
Serial number: 3585HRB405J09RECEOUJ
Serial number: 3515RRB405T0BTBEF9G7
Serial number: 3525RRB405R0BTBEKPFQ
2 Faults Found:
9446677 - Redundant signal path for airbag shut-off; passenger side
B1025 15 [137] - Open or Short to Plus
Fault Priority: 2
Fault Frequency: 1
Mileage: 86056 km
Date: 2022.09.28
Time: 21:33:01
9445397 - Key switch for deactivation of passenger-side airbag
B1020 15 [137] - Open or Short to Plus
Fault Priority: 2
Fault Frequency: 1
Mileage: 86056 km
Date: 2022.09.28
Time: 21:33:01
Part No SW: 6R0 920 870 A HW: 6R0 920 870 A
Component: KOMBI H04 0709
Coding: 140F01
VCID: 3333E28D6BB78D532A1-8066
1 Fault Found:
12658432 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[Steuerger‰t f¸r Reifendruck¸berwachung: keine Kommunikation]
Fault Priority: 6
Fault Frequency: 3
Reset counter: 187
Mileage: 86056 km
Date: 2022.09.28
Time: 21:34:06
Part No SW: 7E0 909 901 HW: 7E0 937 090 C
Revision: B9082001
Coding: 042204
VCID: 688945E162713E8B4F3-803C
Address 20: High Beam Assist. (J844) Labels:| 8S0-857-511.clb
Part No SW: 7E0 857 511 G HW: 7E0 857 511 E
Component: FLA H10 0003
Revision: AA001001
Coding: 0404000000000000010000
Shop #: WSC 12345 123 12345
VCID: 2E05F3F98095A0BB45F-807A
Component: IMMO H04 0709
Coding: 000007
VCID: 6A8D3FE97CFD0C9B597-803E
Address 2B: Steer. Col. Lock (J764) Labels:* 5K0-905-861.clb
Part No SW: 5K0 905 861 B HW: 5K0 905 861 B
Component: ELV-PQ35 H20 0240
Revision: 00000000 Serial number: 11000256123005
Coding: 4900000000000000
Shop #: WSC 31889 470 31889
ASAM Dataset: EV_ELVMarquMPVW36X A01001
ROD: EV_ELVMarquMPVW36X.rod
VCID: 2F3BEEFD879FA9B34E9-807A
Address 36: Seat Mem. Drvr (J810) Labels: 3C0-959-760.lbl
Part No SW: 3C8 959 760 B HW: 3C8 959 760 B
Component: Sitzmemory H02 1001
Revision: 00H02000
Coding: 000039
Shop #: WSC 40022 666 40022
VCID: 3431E1916E398A6B33B-8060
Address 37: Navigation
Cannot be reached
Address 3C: Lane Change Labels: Redir Fail!
Part No SW: 7E0 907 566 B HW: 4L0 907 566 A
Component: J0769 SWA MasterH13 0120
Revision: 00H13000 Serial number: 6PZ 009 014-07
Coding: 0010161
Shop #: WSC 02756 790 00000
VCID: 2F3BEEFD8B1FA9B34E9-807A
Subsystem 1 - Part No: 7E0 907 568 B
Component: J0770 SWA Slave H09 0110
Subsystem 2 - Serial number: 6PZ 009 014-27
Subsystem 3 - Serial number: 5F31.03.1100H090003CH21982ˇ
Subsystem 4 - Serial number: H21982ˇ
Address 44: Steering Assist (J792) Labels:| 6Rx-909-144-V2.clb
Part No SW: 6R1 909 144 AD HW: 6R1 909 144 E
Component: EPS_TRW_ALow 312 3124
Serial number: CF3F0205
Coding: 001F00
ASAM Dataset: EV_SteerAssisUDSTRW 014026
ROD: EV_SteerAssisUDSTRW_014.rod
VCID: 79AF10A5095BB703A0D-802C
Address 47: Sound System (R12) Labels: 5K0-035-456.clb
Part No SW: 5C6 035 456 C HW: 5C6 035 456 C
Component: KonzernAmp10K H08 6831
Revision: -------- Serial number: EAA098C0000052
ASAM Dataset: EV_AudioVerst10KanalSTT4 001001
ROD: EV_AudioVerst10KanalSTT4.rod
VCID: 280905E1A271FE8B8F3-807C
Address 55: Headlight Range (J431) Labels:. 6R0-907-357.clb
Part No SW: 6R0 907 357 C HW: 6R0 907 357 B
Component: AFS-ECU 005 0050
Revision: -------- Serial number: --------------
Coding: 0D42000001000000
ROD: EV_HeadlRegulVWLWRCC.rod
VCID: 3A2DCFA94CDD7C1BE97-806E
3 Faults Found:
5275220 - Headlight
C107E 54 [137] - Missing Calibration / Basic Setting
Fault Priority: 1
Fault Frequency: 1
Reset counter: 147
Mileage: 86056 km
Date: 2022.09.28
Time: 21:32:58
13705989 - Databus
U1123 00 [137] - Received Error Message
[Fehlerwert im Signal NI2_Hoehe_HL]
Fault Priority: 6
Fault Frequency: 1
Reset counter: 147
Mileage: 86056 km
Date: 2022.09.28
Time: 21:32:58
13705988 - Databus
[Fehlerwert im Signal NI2_Hoehe_VL]
Fault Priority: 6
Fault Frequency: 1
Reset counter: 147
Mileage: 86056 km
Date: 2022.09.28
Time: 21:32:58
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-STD2.clb
Part No SW: 5C0 035 680 G HW: 5C0 035 680 G
Component: MU-S-ND-ER H41 0478
Serial number: VWZAZ2W1425226
Coding: 02620001AA00000011111103C00D0A201F0100D401200100CE
ROD: EV_MUStd4CTSAT_VW37.rod
VCID: 25170CD5D563E3E3B45-8070
Data carrier:
Subsystem 1 - Part No SW: V03 825 254 AD HW: -----------
Component: ECE DL2 22/23 --- 1810
2 Faults Found:
1556 - Internal Control Module Memory Check Sum Error
B2000 87 [009] - Missing Message
Fault Priority: 6
Fault Frequency: 1
Reset counter: 147
Mileage: 86056 km
Date: 2022.09.28
Time: 21:39:08
Voltage terminal 30: 13.1 V
System_Software_Error-SW_Status_Consistency: 04 01 01
System_Software_Error-SW_Status_Device: o
15360256 - Component Protection
U1101 00 [009] - Active
[Anti-theft protection - component protection active (0xEA6100)]
Fault Priority: 4
Fault Frequency: 1
Reset counter: 147
Mileage: 86056 km
Date: 2022.09.28
Time: 21:32:58
Voltage terminal 30: 12.9 V
Address 61: Battery Regul. (J840) Labels:. 1K0-907-534.clb
Part No SW: 7E0 907 534 HW: 7E0 937 090 C
Component: Batt.regelung H82 0752
Coding: 03037A5A
Subsystem 1 - Part No SW: 6C0 915 181 HW: 6C0 915 181
Component: J367-BDM H08 0223
Serial number: 61083A44504351928092
Address 65: Tire Pressure (J502) Labels: 3AA-907-273.clb
Part No SW: 3AA 907 273 F HW: 5Q0 907 273
Component: RDKBERU30 H04 0011
Serial number: 40000000058319
ROD: EV_RDKBERU30_005.rod
Address 69: Trailer (J345) Labels:. 1K0-907-383-V2.clb
Part No SW: 1K0 907 383 F HW: 1K0 907 383 F
Component: Anhaenger H09 0100
Revision: 3A001001 Serial number: 00008200133984
Coding: 4100000101000000
VCID: 3039ED819A21B64B573-8064
Address 77: Telephone
Cannot be reached
Address B9: Aux. Display (J285) Labels:* 5C5-919-527.clb
Part No SW: 1K8 919 527 HW: 1K8 919 527
Component: ZUSATZANZEIGE H08 0003
Coding: 05
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_Auxi_Disp_Unit_UDS_VDD 001010
ROD: EV_Auxi_Disp_Unit_UDS_VDD.rod
VCID: 75B71C952543D363C45-8020
1 Fault Found:
2097171 - Databus
U1123 00 [008] - Received Error Message
[control unit for brake: please read out error memory]
Fault Priority: 6
Fault Frequency: 1
Reset counter: 187
Mileage: 86056 km
Date: 2022.09.28
Time: 21:39:15
End----------(Elapsed Time: 02:21, VBatt start/end: 12.6V/13.3V)-----------
3T0 flash light/interior light
3T0947509A holder for flashlight
3T0947417F flashlight
5L6867559 cover for flashlight holder
1K0972703 T3 connector
wiring (by ciclo):
1 +30g from interior lighting
2 switched GND for turning the light on
3 permanent GND for charging the flashlight
Inside of the flashlight with magnet (source unknown):
https://imgur.com/a/sqnWXwD
applications in various cars (source unknown):
https://imgur.com/a/GYvIEep
wiring (by ciclo):
Some piping in preparation of the DCC wiring:
N90682001 endpiece 7,5mm
N10732501 piping 7,5mm 1 meter
N90680701 Y-splitter
N10732401 piping 4,5mm
N90681901 endpiece 4,5mm
With this, I hope to make the wiring a bit more resistant to all the flying stuff near the front wheels for the ride height sensors and the brake pad indicator wires.
Yes it will. That also uses switched grounds for lighting
---> viewtopic.php?p=593065#p593065
That's the front brakes installed... Needs a 27mm spacer
It does brake very nicely with the steel brake lines.
As soon as the adapters for the rear axle are finished, the rear brakes will be installed.
- Platinum Member
Those look mean! Awesome upgrade
Done
Installation was fairly simple. I used a push button on the side of the glove box to make a switched GND.
When the lid is closed, the button is pushed. When the lid is opened, the button is not pushed.
With a relay, I convert the GND-when-closed to a GND-when-open and wire it all in accordance with the wiring diagram.
And I needed to modify the plastic on the inside of the dashboard a bit, to clear the flashlight
Extra pics: https://imgur.com/a/laqI0Tp
Continuation of the DCC wiring
--> viewtopic.php?p=593493#p593493
--> viewtopic.php?p=593064#p593064
I've installed the wiring to the level sensor on the front wishbone and the brake pad wear indicator.
The wires go from the end actuator/sensor to a Y piece and into the engine bay. I still need to continue the wiring from there.
T10 DCC coupling point, near windscreen wiper
Left
Right
Left
T10 DCC
1 shock absorber T2/1 red
2 shock absorber T2/2 black
3 brake pad wear indicator T2/1 white
4 brake pad wear indicator T2/2 white grey
5 Accelerometer T3/1 red
6 Accelerometer T3/2 blue
7 Accelerometer T3/3 white
8 Ride height sensor T4/1 yellow
9 Ride height sensor T4/2 green
10 Ride height sensor T4/3 black
T10 DCC
1 shock absorber T2/1 black/grey
3 brake pad wear indicator T2/1 red
4 brake pad wear indicator T2/2 black
5 Accelerometer T3/1 yellow
6 Accelerometer T3/2 green
7 Accelerometer T3/3 black
8 Ride height sensor T4/1 red
9 Ride height sensor T4/2 blue
10 Ride height sensor T4/3 white
Continuation of DCC wiring and sensor install
--> viewtopic.php?p=593594#p593594
This is the connector to the front shock absorber 6C0972483 with rubber cap 6C0971841
Resistance is OK!
Wiring from the acceleration sensor and shock absorber joins the wiring of the height sensor and brake pad wear indicator...
You can see the T10 coupling point just below the gas spring.
The same wiring on the other side. You can see the T10 coupling point in the background.
.. under strict supervision
Wiring length is always a guess
The big wiring loom (2x height sensor, 2x accelerometer, 2x shock absorber) enters the cabin in the OEM hole below the windscreen wiper.
T10 DCC coupling point, near windscreen wiper, 'inside'':
Left
Right
Resistance is OK!
Left
T10 DCC
5 Accelerometer T3/1 red/blue
6 Accelerometer T3/2 green/blue
7 Accelerometer T3/3 white/blue
T10 DCC
4 brake pad wear indicator T2/2 white/grey
5 Accelerometer T3/1 black
6 Accelerometer T3/2 yellow
7 Accelerometer T3/3 green
9 Ride height sensor T4/2 white
10 Ride height sensor T4/3 blue
