Favi's Polo 6R 1.2TSI Red Flash "strawberry" :)
Re: Favi's Polo 6R 1.2TSI Red Flash "strawberry" :)
I can do it by ODIS online in VW dealer?
I suppose not, but 'you can do it yourself'.
For easy installation and reliable clone tools I recommend: (READ!)
https://tools4car.co.uk/
- https://tools4car.co.uk/product/vas-5054/
- https://tools4car.co.uk/product/vas6154/
Advice:
Forget about Ali, you can waste a lot of time trying to install VAS clones if you don't choose the right store. Ali is only for experts on these matters.
The flash files are available from download links on some forums or from erWin. In Drive2.ru they are available, although it is not the most updated download link available on the NET...
Advice:
ECU software updated - not resolve problem
11003 - EVAP Emission Control Sys
P0441 00 [232] - Incorrect Flow
6330 - Air Intake System
P307A 00 [096] - Flow too Low
Solved
cleaned throttle nad new ring (03C 133 073 A).
Basic setting?
Hello everyone
I'm starting to complete the necessary parts for the HBA.
- stalks - 7E0 953 507 B 9B9 - brand new
- mirror with camera -7E0857511C or 3G0857511AK 9B9- it will be okay for HBA?
Do you have the correct slip ring? I see your car is 2011, so you probably have 6Q0 stalks and slip ring now.
On the 7E0 stalks, the best fit is 6R0 slip ring. It's plug and play for wiring, but you need to do a calibration of the steering angle sender after replacement.
Perfect, that will work.
now I''m waiting for the mirror
I have question about next new mod. I bought heated wiper ejectors.
Can I connect Heated wiper ejectors to heated mirror glass? I would like Heated wiper ejectors to work when the mirror heating function is turned on.
