I am currently in the process of swapping a 2.0tsi CDLJ into my awd ibiza 6J
I have managed to get hold of a very nicely specced 7L6 2013 Ibiza Cupra loom, with Bosch ESP 9.0i already fitted.
I have managed to get the Polo WRC CDLJ ecu reading on the loom and can see it all good in VCDS. I was attempting to get the ABS coding to work, based on the info out in the world plus a WRC auto scan provided by the friendly iichel
However I keep getting request out of range when coding
This is the long coding i'm attempting: 21DD7885432302C184151E72C25A004D1501
Below is the coding from a successful WRC autoscan, and the ABS Software is the same
21 DD 78 85 43 28 02 C7 84 1C 1E 6A C2 56 40 4D 09 04
21 DD 78 85 43 23 02 C1 84 15 1E 72 C2 5A 00 4D 15 01
0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17
I have attached my autoscan (you'll have to excuse the amount of faults currently, the loom is sitting in my office hooked up to the bare minimum
This is the VIN being recognised from the cluster on the ABS pump measuring values
https://imgur.com/uZQbnUK
Whereas the VIN on the ecu is: WVWZZZ13ZCV001199
Autoscan:
Wednesday,09,November,2022,22:36:04:32543
VCDS Version: 22.9.0.0 (x64) HEX-V2 CB: 0.4623.4
Data version: 20220830 DS341.0
www.Ross-Tech.com
VIN: WVWZZZ13ZCV001199 License Plate:
Chassis Type: 13-VW36 (6N0)
Scan: 01 03 04 08 09 10 15 17 19 25 44 4B 55 56 0B
VIN: WVWZZZ13ZCV001199 Mileage: 162560km-101010miles
10-Park/Steer Assist -- Status: Cannot be reached 1100
15-Airbags -- Status: Cannot be reached 1100
25-Immobilizer -- Status: Malfunction 0010
44-Steering Assist -- Status: Cannot be reached 1100
4B-Multifunc. Module -- Status: OK 0000
55-Headlight Range -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
Address 01: Engine (CDL) Labels:. 06F-907-115-CDL.clb
Part No SW: 6R0 907 115 HW: 8P0 907 115 B
Component: 2.0l R4/4V TFSI 02 0020
Revision: 5BH20--- Serial number:
Coding: 040300101C070160
Shop #: WSC 00020 790 00000
VCID: 6FBBD9951B9AFD830E9-803A
VINID: 9E69EAAAA043A939800010492464C7B843
20 Faults Found:
005634 - Power Supply Terminal 30
P1602 - 002 - Voltage too Low - Intermittent
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 0 km
Time Indication: 0
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: -40.0°C
Absolute Pres.: 0.0 mbar
Voltage: 0.000 V
000291 - Throttle Position Sensor (G69)
P0123 - 001 - Signal too High
Fault Status: 01100001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 0 km
Time Indication: 0
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Absolute Pres.: 990.0 mbar
Voltage: 12.573 V
000546 - Angle Sensor 2 for Throttle (G188)
P0222 - 002 - Signal Too Low
Fault Status: 01100010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 0 km
Time Indication: 0
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Voltage: 12.573 V
008212 - Intake Manifold Flap Position Sensor (Bank 1)
P2014 - 001 - Electrical Malfunction
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 0 km
Time Indication: 0
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Voltage: 12.573 V
000568 - Manifold Pressure / Boost Sensor (G31)
P0238 - 001 - Signal too High
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 0 km
Time Indication: 0
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Voltage: 12.573 V
000256 - Mass Air Flow Sensor (G70)
P0100 - 004 - Supply Voltage
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 0 km
Time Indication: 0
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Voltage: 12.573 V
000400 - Fuel Pressure Sensor (G247)
P0190 - 001 - Circuit Malfunction
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 0 km
Time Indication: 0
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Absolute Pres.: 1000.0 mbar
Voltage: 12.573 V
005748 - Powertrain Data Bus
P1674 - 001 - Implausible Message from Instrument Cluster
Fault Priority: 2
Fault Frequency: 2
Reset counter: 255
Mileage: 0 km
Time Indication: 0
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Voltage: 12.573 V
005715 - Please check DTC Memory of ABS Controller
P1653 - 004 -
Fault Priority: 2
Fault Frequency: 2
Reset counter: 255
Mileage: 0 km
Time Indication: 0
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Voltage: 12.573 V
050197 - Implausible Data Received from ABS Control Module
U0415 - 004 -
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 0 km
Time Indication: 0
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Voltage: 12.573 V
049409 - No Communication with Transmission Control Module
U0101 - 008 -
Fault Status: 01101000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 0 km
Time Indication: 0
Date: 2017.04.01
Time: 00:00:01
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Voltage: 12.573 V
049489 - No Communications with Airbag Control Module
U0151 - 008 -
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 0 km
Time Indication: 0
Date: 2017.04.01
Time: 00:00:01
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Voltage: 12.573 V
009529 - Low Pressure Fuel Sensor (G410)
P2539 - 001 - Open Circuit
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 0 km
Time Indication: 0
Date: 2017.04.01
Time: 00:00:01
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Voltage: 12.573 V
049508 - No Communications with HVAC Control Module (J301)
U0164 - 008 -
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 0 km
Time Indication: 0
Date: 2017.04.01
Time: 00:00:01
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Voltage: 12.573 V
000280 - Engine Coolant Temp. Sensor (G62)
P0118 - 002 - Signal too High
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 162569 km
Time Indication: 0
Date: 2017.04.01
Time: 00:00:01
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Voltage: 12.573 V
000275 - Intake Air Temp. Sensor (G42)
P0113 - 002 - Signal too High
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 162569 km
Time Indication: 0
Date: 2017.04.01
Time: 00:00:01
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Voltage: 12.573 V
008581 - Engine Coolant Temp Sensor on Radiator Outlet (G83)
P2185 - 002 - Signal too High
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 162569 km
Time Indication: 0
Date: 2017.04.01
Time: 00:00:01
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Voltage: 12.573 V
005642 - Internal Control Module Memory
P160A - 004 - Check Sum Error
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 162569 km
Time Indication: 0
Date: 2017.04.01
Time: 00:00:01
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Voltage: 12.573 V
005784 - Please Check DTC Memory of Steering Wheel Electronics
P1698 - 001 -
Fault Priority: 2
Fault Frequency: 2
Reset counter: 255
Mileage: 162569 km
Time Indication: 0
Date: 2017.04.01
Time: 00:00:03
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Voltage: 12.573 V
049493 - No Communication with Instrument Cluster
U0155 - 008 - - Intermittent
Fault Status: 00101000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 162569 km
Time Indication: 0
Date: 2017.04.01
Time: 00:14:38
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Voltage: 12.446 V
Readiness: 0110 0101
Part No SW: 6R0 907 379 AS HW: 6R0 907 379 AS
Component: ESP9.0i front H01 0002
Serial number: --------------
Coding: 000000000000000000000000000000000000
Shop #: WSC 00788 648 00255
ASAM Dataset: EV_Brake1ESP90iBOSCH 003020
ROD: N/A
VCID: 0F7BB91577DA9D836E9-805A
No ASAM data for: "EV_Brake1ESP90iBOSCH" (VW36)
15 Faults Found:
0922 - ROD - Unknown Error Code
- 00 [009]
Fault Status: 00000001
Fault Priority: 3
Fault Frequency: 1
Reset counter: 107
Mileage: 162569 km
Date: 2022.11.09
Time: 00:03:57
0983 - ROD - Unknown Error Code
- 00 [009]
Fault Priority: 2
Fault Frequency: 1
Reset counter: 107
Mileage: 162569 km
Date: 2022.11.09
Time: 00:14:37
0943 - ROD - Unknown Error Code
- 00 [137]
Fault Priority: 2
Fault Frequency: 1
Reset counter: 107
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
0909 - ROD - Unknown Error Code
- 00 [137]
Fault Priority: 2
Fault Frequency: 1
Reset counter: 107
Mileage: 162569 km
Date: 2022.11.09
Time: 00:03:57
1146 - ROD - Unknown Error Code
- 00 [009]
Fault Priority: 2
Fault Frequency: 1
Reset counter: 107
Mileage: 162569 km
Date: 2022.11.09
Time: 00:03:57
0885 - ROD - Unknown Error Code
- 00 [129]
MIL ON - Not Confirmed - Tested Since Memory Clear
0883 - ROD - Unknown Error Code
- 00 [137]
Fault Priority: 2
Fault Frequency: 4
Reset counter: 107
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
0354 - ROD - Unknown Error Code
- 00 [137]
Fault Priority: 2
Fault Frequency: 1
Reset counter: 107
Mileage: 162569 km
Date: 2022.11.09
Time: 00:03:57
0364 - ROD - Unknown Error Code
- 00 [137]
Fault Priority: 2
Fault Frequency: 1
Reset counter: 107
Mileage: 162569 km
Date: 2022.11.09
Time: 00:03:57
0374 - ROD - Unknown Error Code
- 00 [137]
Fault Priority: 2
Fault Frequency: 1
Reset counter: 107
Mileage: 162569 km
Date: 2022.11.09
Time: 00:03:57
0384 - ROD - Unknown Error Code
- 00 [137]
Fault Priority: 2
Fault Frequency: 1
Reset counter: 107
Mileage: 162569 km
Date: 2022.11.09
Time: 00:03:57
0392 - ROD - Unknown Error Code
- 00 [129]
0393 - ROD - Unknown Error Code
- 00 [129]
0394 - ROD - Unknown Error Code
- 00 [129]
0395 - ROD - Unknown Error Code
- 00 [129]
Component: LENKW.SENSOR H06 0060
Serial number: 25111204652021
Coding: 01
Shop #: WSC 00000 000 00000
ROD: EV_LWSKLOVW25X.rod
VCID: 7EA5F4D14070840B95F-802A
5 Faults Found:
332644 - Databus
U1121 00 [008] - Missing Message
Fault Priority: 6
Fault Frequency: 2
Reset counter: 147
Voltage terminal 15: 12.30 V
Voltage terminal 30: 5.00 V
Terminal 15 status: not coded/not installed
Entprellzeit: 5000 ms
332660 - Databus
Fault Priority: 6
Fault Frequency: 1
Reset counter: 40
117060 - Databus
Fault Priority: 6
Fault Frequency: 1
Reset counter: 40
335876 - Powertrain Databus
U0002 00 [008] - No Communications
Fault Priority: 6
Fault Frequency: 1
Reset counter: 40
Voltage terminal 15: 12.40 V
335886 - Powertrain Databus
U0001 00 [008] - Unspecified Malfunction
[Datenbus Komfort defekt]
Fault Priority: 6
Fault Frequency: 1
Reset counter: 147
Voltage terminal 30: 12.45 V
Terminal 15 status: On
Address 08: Auto HVAC
Cannot be reached
Address 09: Cent. Elect. (J519) Labels:. 7H0-937-08x-09.clb
Part No SW: 7H0 937 090 HW: 7H0 937 090
Component: BCM PQ25 Max4 H72 0708
Revision: B9072001 Serial number: 0531 324120174
Coding: 3C882DE888F3250093280EF57ECB9FD80EC867E9608D3041200000020000
VCID: 6B83CD85238201A3221-803E
12 Faults Found:
00967 - Left Turn Signals
011 - Open Circuit
Fault Status: 01101011
Fault Priority: 2
Fault Frequency: 1
Reset counter: 107
Mileage: 162569 km
Time Indication: 0
Date: 2017.04.01
Time: 00:00:03
00329 - Control Circuit for Unlocking Rear Lid
011 - Open Circuit
Fault Priority: 2
Fault Frequency: 1
Reset counter: 107
Mileage: 162569 km
Time Indication: 0
Date: 2017.04.01
Time: 00:00:01
00975 - Heated Rear Window (Z1)
011 - Open Circuit
Fault Priority: 3
Fault Frequency: 1
Reset counter: 107
Mileage: 162569 km
Time Indication: 0
Date: 2017.04.01
Time: 00:00:02
00920 - Heated Outside Mirrors; Driver Side (Z4) / Passenger Side (Z5)
011 - Open Circuit
Fault Priority: 3
Fault Frequency: 1
Reset counter: 107
Mileage: 162569 km
Time Indication: 0
Date: 2017.04.01
Time: 00:00:02
00077 - Windshield Wiper Stop Switch (F229)
004 - No Signal/Communication
Fault Priority: 3
Fault Frequency: 2
Reset counter: 107
Mileage: 162569 km
Time Indication: 0
Date: 2017.04.01
Time: 00:00:40
01134 - Alarm Horn (H12)
Fault Priority: 2
Fault Frequency: 1
Reset counter: 107
Mileage: 162569 km
Time Indication: 0
Date: 2017.04.01
Time: 00:00:04
03156 - Sensor for Anti-Theft System (G578)
Fault Priority: 2
Fault Frequency: 1
Reset counter: 107
Mileage: 162569 km
Time Indication: 0
Date: 2017.04.01
Time: 00:00:04
01326 - Control Module for Multi-Function Steering Wheel (J453)
Fault Priority: 2
Fault Frequency: 1
Reset counter: 107
Mileage: 162569 km
Time Indication: 0
Date: 2017.04.01
Time: 00:00:04
01332 - Door Control Module; Passenger Side (J387)
Fault Priority: 2
Fault Frequency: 1
Reset counter: 107
Mileage: 162569 km
Time Indication: 0
Date: 2017.04.01
Time: 00:00:04
01331 - Door Control Module; Driver Side (J386)
Fault Priority: 2
Fault Frequency: 1
Reset counter: 107
Mileage: 162569 km
Time Indication: 0
Date: 2017.04.01
Time: 00:00:04
01520 - Rain and Light Recognition Sensor (G397)
Fault Priority: 2
Fault Frequency: 1
Reset counter: 107
Mileage: 162569 km
Time Indication: 0
Date: 2017.04.01
Time: 00:00:04
03591 - Control Circuit for Horn
011 - Open Circuit
Fault Priority: 3
Fault Frequency: 1
Reset counter: 107
Mileage: 162569 km
Time Indication: 0
Date: 2017.04.01
Time: 00:00:02
Address 10: Park/Steer Assist
Cannot be reached
Address 15: Airbags
Cannot be reached
Part No SW: 6J0 920 901 C HW: 6J0 920 901 C
Component: KOMBI H08 0110
Coding: 410800
Shop #: WSC 06403 785 00200
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04040
ROD: EV_Kombi_UDS_VDD_RM09_004_VW36.rod
VCID: 2809F289F274EABB8F3-807C
7 Faults Found:
9453074 - Fuel Level Sensor 1
B103E 1B [009] - Resistance Too High
Fault Priority: 2
Fault Frequency: 1
Reset counter: 107
Mileage: 162569 km
Date: 2022.11.09
Time: 00:22:23
13637376 - Please Check Fault Codes in Control Module for ABS Brakes
U1017 00 [009] - -
[Steuergerät für Bremse: bitte Fehlerspeicher auslesen]
Fault Priority: 6
Fault Frequency: 1
Reset counter: 107
Mileage: 162569 km
Date: 2022.11.09
Time: 00:00:05
12648448 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[Steuergerät für Motor: keine Kommunikation]
Fault Priority: 6
Fault Frequency: 1
Reset counter: 147
Mileage: 0 km
Date: 2022.11.09
Time: 00:00:00
12656896 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[Steuergerät für Bremse: keine Kommunikation]
Fault Priority: 6
Fault Frequency: 1
Reset counter: 147
Mileage: 0 km
Date: 2022.11.09
Time: 00:00:00
12669184 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[Steuergerät für Airbag: keine Kommunikation]
Fault Priority: 6
Fault Frequency: 3
Reset counter: 107
Mileage: 162569 km
Date: 2022.11.09
Time: 00:22:23
13638912 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[Steuergerät für Lenkhilfe: keine Kommunikation]
Fault Priority: 6
Fault Frequency: 3
Reset counter: 107
Mileage: 162569 km
Date: 2022.11.09
Time: 00:22:23
13639168 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[Steuergerät für Leuchtweitenregelung: keine Kommunikation]
Fault Priority: 6
Fault Frequency: 1
Reset counter: 147
Mileage: 0 km
Date: 2022.11.09
Time: 00:00:00
Address 19: CAN Gateway (J533) Labels:. 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 7H0 937 090
Component: GW-K-CAN TP20 H72 0708
Revision: B9072001
Coding: 002000
VCID: 70B9DAE90AA4E27B173-8024
5 Faults Found:
01336 - Company Data Bus for Comfort System
Fault Priority: 1
Fault Frequency: 1
Reset counter: 107
Mileage: 162569 km
Time Indication: 0
Date: 2017.04.01
Time: 00:00:02
01321 - Control Module for Airbags (J234)
Fault Priority: 2
Fault Frequency: 1
Reset counter: 107
Mileage: 0 km
Time Indication: 0
Date: 2017.04.01
Time: 00:00:01
01309 - Power Steering Control Module (J500)
Fault Priority: 2
Fault Frequency: 1
Reset counter: 107
Mileage: 0 km
Time Indication: 0
Date: 2017.04.01
Time: 00:00:01
03075 - Parallel Parking Assistance Control Module (J791)
Fault Priority: 2
Fault Frequency: 1
Reset counter: 107
Mileage: 162569 km
Time Indication: 0
Date: 2017.04.01
Time: 00:00:01
00381 - Databus Instrument Cluster
Fault Status: 00100100
Fault Priority: 1
Fault Frequency: 2
Reset counter: 147
Mileage: 162569 km
Time Indication: 0
Date: 2017.04.01
Time: 00:14:38
Address 25: Immobilizer (J334) Labels:. 5K0-920-xxx-25.clb
Component: IMMO H08 0110
Serial number:
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03004
2 Faults Found:
9456128 - Engine Control Module (ECM) not authorized
B104A 00 [009] - -
Fault Priority: 1
Fault Frequency: 1
Mileage: 162569 km
Date: 2022.11.09
Time: 02:04:13
9456433 - Key
B104B 31 [009] - No Signal
Fault Priority: 1
Fault Frequency: 1
Reset counter: 107
Mileage: 162569 km
Date: 2022.11.09
Time: 00:30:04
Address 44: Steering Assist
Cannot be reached
Address 4B: Multifunc. Module
Cannot be reached
Address 55: Headlight Range Labels: 7L6-907-357-A.lbl
Part No SW: 7L6 907 357 C HW: 7L6 907 357 C
Component: AFS-Steuergeraet 0147
Revision: 00H04000 Serial number:
Coding: 2688324
VCID: 3B233DC51F225123F21-806E
Subsystem 1 - Part No: ID-L fehlt Labels: ID-55-01.CLB
Component: AFS-Lst.-Modul l ....
Coding: 00000255
Subsystem 2 - Part No: ID-R fehlt Labels: ID-55-02.CLB
Component: AFS-Lst.-Modul r ....
Coding: 00000255
10 Faults Found:
02233 - Left Headlight Power Output Stage (J667)
004 - No Signal/Communication - MIL ON
Fault Status: 11100100
Fault Priority: 6
Fault Frequency: 5
Reset counter: 107
Mileage: 162569 km
Time Indication: 0
Date: 2017.04.01
Time: 00:24:06
Voltage: 12.35 V
Speed: 0.0 km/h
ABS 1
02234 - Right Headlight Power Output Stage (J668)
Fault Priority: 6
Fault Frequency: 5
Reset counter: 107
Mileage: 162569 km
Time Indication: 0
Date: 2017.04.01
Time: 00:24:06
Voltage: 12.35 V
Speed: 0.0 km/h
ABS 1
01042 - Control Module; Not Coded
000 - - - MIL ON
Fault Status: 11100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 107
Time Indication: 0
Invalid
Invalid
Invalid
02656 - Power Output Stage for Left Headlight (J667); Not Coded
000 - - - MIL ON
Fault Priority: 2
Fault Frequency: 1
Reset counter: 107
Time Indication: 0
Invalid
Invalid
Invalid
02657 - Power Output Stage for Right Headlight (J668); Not Coded
000 - - - MIL ON
Fault Priority: 2
Fault Frequency: 1
Reset counter: 107
Time Indication: 0
Invalid
Invalid
Invalid
01539 - Headlights Not Adjusted
005 - No or Incorrect Basic Setting / Adaptation - MIL ON
Fault Status: 11100101
Fault Priority: 3
Fault Frequency: 1
Reset counter: 107
Time Indication: 0
Invalid
Invalid
Invalid
01312 - Powertrain Data Bus
Fault Priority: 6
Fault Frequency: 1
Reset counter: 147
Time Indication: 0
Voltage: 12.35 V
Speed: 0.0 km/h
ABS 0
01316 - ABS Control Module
013 - Check DTC Memory - MIL ON
Fault Status: 11101101
Fault Priority: 6
Fault Frequency: 1
Reset counter: 107
Time Indication: 0
Voltage: 12.35 V
Speed: 0.0 km/h
ABS 1
00778 - Steering Angle Sensor (G85)
Fault Priority: 6
Fault Frequency: 1
Reset counter: 147
Mileage: 162569 km
Time Indication: 0
Date: 2017.04.01
Time: 00:00:14
Voltage: 12.35 V
Speed: 0.0 km/h
ABS 1
01317 - Control Module in Instrument Cluster (J285)
Fault Priority: 6
Fault Frequency: 1
Reset counter: 147
Mileage: 162569 km
Time Indication: 0
Date: 2017.04.01
Time: 00:14:38
Voltage: 12.21 V
Speed: 0.0 km/h
ABS 1
Address 56: Radio
Cannot be reached
End----------(Elapsed Time: 02:24, VBatt start/end: 12.4V/12.4V)-----------
Thanks in advance and if anyone can help further with this it would be amazing, it's certainly a challenge to make all this stuff work together, but the hunt for a true OEM engine swap has taken me into the depths of the minds of VW engineers once again lol
