HELP front wipers and washers not working 64 reg
sukhbinder
- Drives: VW Polo 1.4 TDI 2014 64 reg
Hi guys
Have a 64 reg new shape 1.4tdi se polo and having some issues. My front wipers are not working nor are my washers.
Fuse 23 was blown which I’ve since replaced but still not working. New fuse not blown either so really confused.
Am I missing something?
Any ideas on what I should do?
Steve
Steve
sukhbinder
Re: HELP front wipers and washers not working 64 reg
Update.
When I put old broken fuse in, front wipers work when I press down front washers. Wipers don’t work normally though.
Washers don’t work or make any noise.
I’m stuck!
I’m stuck!
joe6
- Drives: Golf Mk6 GTI (Scirocco gone) Polo 6c GTI
Put the new fuse back in and try disconnecting and reconnecting the battery as this some times resets the system.
- gaza1994
- Drives: Match 1.4 2012 (6r) (85ps)
chances are, your car's computer still remembers a fault with itself.
So with the new fuse in, try clearing any faults and it should work
check fuse 8 in the E box in engine bay.
sukhbinder
Thanks guys. Checked fuse 8 as well in the engine and seems fine so doesn’t look like that.
I’m on the move this weekend and don’t have tools to safely disconnect battery. Is there any way we can reset fault codes without disconnecting battery?
Thanks in advance
Thanks in advance
- gaza1994
VagCom can clear it, not sure if a obd2 reader would pick it upsukhbinder wrote: Sat Jan 13, 2018 8:53 pm Thanks guys. Checked fuse 8 as well in the engine and seems fine so doesn’t look like that.
Thanks in advance
Pritesh222
- Drives: 2012 1.2 3 Cylinder
Hi mate did you get to the bottom of this. . I have a problem with my wipers. The front are not working , whilst the back one is.
check your fuses please
Pritesh222
Checked fuses can not see to work out what exact fuse itis.
Does a blown fuse cause this kind of issue?
2fast4ya
- Drives: polo 1.8 tsi gti bluetec
Have you done a voltage check?
Check the wiper adapters for voltage you might have a short ,
Pritesh222
Hi, I have not been able to do a voltage check.
Its very bizaare i was trying to use the washer in the morning when it was completely icy .
2fast4ya
May have strained the motor ?
Damp in the electrical connector on wiper motor possibly?
Yes it can be a blown fuse but Polo 6C wiper stalks are also known to fail prematurely.Pritesh222 wrote: Thu Dec 08, 2022 3:53 pm Checked fuses can not see to work out what exact fuse itis.
Pritesh222
I think I need reassurance that the fuses are okay before going down the motor root. Im thinking if its the stalk why is the back wiper still working..
