Giannis20vt's Polo 6c 1.0MPI
Re: Giannis20vt's Polo 6c 1.0MPI
Use ODIS to install and adapt the BCM
giannis20vt
I am going to go to a garage with online connection with the VW servers for this job.
I am exciting for this but also i am afraid of failure, i have already tried 3 times to swap the BCM without any luck. The first 2 BCMs were used, the 3rd was "new" but it wasn't so new as the seller claimed.
giannis20vt
And suddenly a strange problem. I want your help.
First the right turn signal started working all the time by itself. It stops only when i turn the ignition off.
The left turn signal working fine, as it is suppose to work, but the right doesn't stop at all. The hazard switch working fine also.
I checked all the bulbs and the fuses.
And after an hour trying to find any solution, the car doesn't start. It's not a battery problem, i checked it, even try to start it with wires from another car. Nothing.
I took a message on the screen "Press clutch to start" but i am pressing the clutch.
I unplugged the car battery for half an hour, nothing. I unplugged the BCM still nothing. I am at dead end. Any suggestion, would be appreciated
is this problem out of nowhere or after a bcm swap?
giannis20vt
I didn't do anything with the car, apart from some wiring between the roof and the fuse box. I am preparing for the Rain/light sensor installation.
Today i will connect the VCDS to scan for errors.
giannis20vt
Lots of errors, it's like nothing is working.
I don't know what to say.
I am thinking of towing the car to a garage for further diagnosis and repair.
Chassis Type: 6R-VW26 (6C0)
Scan: 01 03 08 09 15 17 19 44 5F
VIN: WVWZZZ6RZGY308378 Mileage: 64776km-40249miles
15-Airbags -- Status: Cannot be reached 0100
Address 01: Engine (J623-CHYB) Labels:. 04C-906-020-CHY.clb
Part No SW: 04C 906 057 AB HW: 04E 907 309 CB
Component: R3 1.0l MPI H20 2496
Revision: 33H20000
Coding: 01110012020400080000
Shop #: WSC 00788 648 00255
ASAM Dataset: EV_ECM10MPI01104C906057AB 001002
ROD: EV_ECM10MPI01104C906057AB.rod
VCID: 65C104936461CFA350-8030
3 Faults Found:
5273 - Output for Starter Relay
P0616 00 [167] - Short to Ground
MIL ON - Not Confirmed - Tested Since Memory Clear
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 64776 km
Date: 2022.12.12
Time: 21:54:11
Engine RPM: 0.00 /min
Normed load value: 0.0 %
Vehicle speed: 0 km/h
Coolant temperature: 12 °C
Intake air temperature: 12 °C
Ambient air pressure: 990 mbar
Voltage terminal 30: 11.049 V
Starter control: terminal 50 feedback-Bits 0-7: 0
Number of manual engine starts-Bits 0-7: 0
Number of automatic engine starts-Bits 0-7: 0
5459 - Control Circuit for Starter Relay 2
P3048 00 [167] - Short to Ground
Fault Priority: 2
Fault Frequency: 1
Mileage: 64776 km
Date: 2022.12.12
Time: 21:54:11
4710 - No Communications with Airbag Control Module
U0151 00 [039] - -
Fault Priority: 6
Fault Frequency: 1
Mileage: 64776 km
Date: 2022.12.12
Time: 21:54:10
CAN status - engine control module-Bits 0-7: 0
selected gear-Bits 0-7: 0
Readiness: 1110 0001
Part No SW: 6C0 907 379 K HW: 6R0 907 379 BA
Component: ESP9.0i H03 0004
Serial number: 08512057160424
Coding: 21DD2485492333C8091700700059842492CC90000005C9098F00
Shop #: WSC 49716 005 1048576
ASAM Dataset: EV_Brake1ESP90iBOSCHPQ26 100020
ROD: EV_Brake1ESP90iBOSCHPQ26.rod
VCID: 377D9EDB8E4D8D3332-8062
2 Faults Found:
0922 - No Communications with Airbag Control Module
U0151 00 [009] - -
Fault Priority: 3
Fault Frequency: 1
Reset counter: 216
Mileage: 64776 km
Date: 2022.12.12
Time: 21:59:24
1171 - Multiple collision brake
B13BC F2 [009] - No function
Fault Priority: 3
Fault Frequency: 3
Reset counter: 216
Mileage: 64776 km
Date: 2022.12.12
Time: 21:59:24
Address 08: Auto HVAC (J301) Labels:| 6C0-820-045.clb
Part No SW: 6C0 820 045 C HW: 6C0 820 045 C
Component: AC Manuell H03 0202
Serial number: 1605161B-0418
Coding: 200000000000100000
ASAM Dataset: EV_ACManueKMMValeoPQ26 002001
ROD: EV_ACManueKMMValeoPQ26.rod
VCID: 1F4D567B06BDD573DA-804A
4 Faults Found:
262916 - High Pressure Sensor
B10AE 14 [013] - Open or Short to Ground
Fault Priority: 2
Fault Frequency: 1
Reset counter: 216
Mileage: 64776 km
Date: 2022.12.12
Time: 21:55:03
262917 - High Pressure Sensor
B10AE 29 [013] - Signal Implausible
Fault Priority: 2
Fault Frequency: 1
Reset counter: 216
Mileage: 64776 km
Date: 2022.12.12
Time: 21:55:03
459009 - Databus
U1121 00 [013] - Missing Message
Fault Priority: 6
Fault Frequency: 1
Reset counter: 216
Mileage: 64776 km
Date: 2022.12.12
Time: 21:55:03
1114115 - Fan 2 Control Circuit
P0693 00 [013] - Short to GND
Fault Priority: 2
Fault Frequency: 1
Reset counter: 216
Mileage: 64776 km
Date: 2022.12.12
Time: 21:55:08
Address 09: Cent. Elect. (J519) Labels:* Redir Fail!
Part No SW: 6C0 937 087 C HW: 6C0 937 087
Component: BCM PQ26 Me4R H08 0087
Serial number: 006088052444
Coding: 000008404053005B4F844000400703000000580051010000000000000000
Shop #: WSC 131071 1023 2097151
ASAM Dataset: EV_BCMA0 005005
ROD: EV_BCMA0_005.rod
VCID: 2E53BBBF71174CFB61-807A
Driver door control module:
Subsystem 1 - Part No SW: 6R0 959 801 DG HW: 6R0 959 801 DG Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 003 0610
Serial number: KU0KU012051661335260
Coding: 0000A0
Front passenger door control module:
Subsystem 2 - Part No SW: 6R0 959 802 DL HW: 6R0 959 802 DL Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 003 0610
Serial number: KU0KU030041661212448
Coding: 1000A0
Subsystem 3 - Part No SW: 6R0 959 811 AA HW: 6R0 959 811 AA
Component: J388__TSG_HL 003 0610
Serial number: KU0KU028041661198823
Coding: 0000A0
Subsystem 4 - Part No SW: 6R0 959 812 AA HW: 6R0 959 812 AA
Component: J389__TSG_HR 003 0610
Serial number: KU0KU002051661233279
Coding: 1000A0
3 Faults Found:
227080 - Turn Signal Switch
B1144 29 [009] - Signal Implausible
Fault Priority: 2
Fault Frequency: 4
Mileage: 64776 km
Date: 2022.12.12
Time: 21:56:25
528405 - Databus
U1121 00 [009] - Missing Message
Fault Priority: 4
Fault Frequency: 4
Reset counter: 216
Mileage: 64776 km
Date: 2022.12.12
Time: 21:56:25
558101 - Databus
Fault Priority: 6
Fault Frequency: 3
Reset counter: 216
Mileage: 64776 km
Date: 2022.12.12
Time: 21:56:25
Address 15: Airbags
Cannot be reached
Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb-SRI3
Part No SW: 6C0 920 740 C HW: 6C0 920 740 C
Component: KOMBI 201 1420
Coding: 0724090021000008110828000000000000000000
ASAM Dataset: EV_DashBoardVDDMQBAB 009046
ROD: EV_DashBoardVDDMQBAB_009_VW26.rod
VCID: 224B5F8F35CFF89BF5-8076
3 Faults Found:
13697024 - Component Protection
U1100 00 [009] - No Basic Setting
Fault Priority: 4
Fault Frequency: 1
Reset counter: 195
Mileage: 63548 km
Date: 2022.01.14
Time: 00:07:17
16776962 - Databus
Fault Priority: 2
Fault Frequency: 3
Reset counter: 216
Mileage: 64776 km
Date: 2022.12.12
Time: 21:58:26
9603840 - Incorrect Key Programming for Remote Control
B128B 00 [009] - -
Fault Priority: 2
Fault Frequency: 1
Reset counter: 26
Mileage: 63548 km
Date: 2022.01.14
Time: 17:45:46
Address 19: CAN Gateway (J533) Labels:| 6C0-909-901-V1.clb
Part No SW: 6C0 909 901 HW: 6C0 937 087
Component: GW MQB A0 H08 0087
Revision: -------- Serial number: 006088052444
Coding: 01000008200A640071000000000000000001010000000000000000000000
Shop #: WSC 12345 123 12345
ASAM Dataset: EV_GatewA0Lear 013020
ROD: EV_GatewA0Lear_013_VW26.rod
1 Fault Found:
131605 - No Communications with Airbag Control Module
U0151 00 [009] - -
Fault Priority: 2
Fault Frequency: 1
Reset counter: 216
Mileage: 64776 km
Date: 2022.12.12
Time: 21:56:52
Terminal 30 power supply: 11.2 V
Terminal 15: On
Address 44: Steering Assist (J792) Labels:| 6Rx-909-144-V2.clb
Part No SW: 6C1 909 144 AG HW: 6C1 909 144 D
Component: EPS_TRW_ALow 312 3232
Serial number: PG5Q1139
Coding: 000700
ASAM Dataset: EV_SteerAssisUDSTRW 016026
ROD: EV_SteerAssisUDSTRW.rod
VCID: 6DD17CB3BC91F7E318-8038
9 Faults Found:
1072128 - Databus
U1121 00 [008] - Missing Message
Fault Priority: 6
Fault Frequency: 2
Reset counter: 1
Engine RPM: 0 /min
Vehicle speed: 0.00 km/h
System status: Waiting for start request
Terminal 15 status: Terminal 15 on
Voltage terminal 30: 10.71 V
Power steering current consumption: 0.50 A
max.value: 0.50 A
End stage temperature: 21 °C
Steering assistance: engine output: 0.00 %
Engine angle: 0 °
Electric motor speed: 0 /min
Steering assistance: target engine torque: 0.00 Nm
Steering torque: 0.08 Nm
Status: OK
1065472 - Databus
Fault Priority: 6
Fault Frequency: 2
Reset counter: 1
Engine RPM: 0 /min
Voltage terminal 30: 11.09 V
max.value: 0.50 A
Engine angle: 0 °
Status: OK
1066752 - Function Restricted due to Insufficient Voltage
U1400 00 [008] - -
Fault Priority: 2
Fault Frequency: 1
Reset counter: 1
Mileage: 64772 km
Date: 2022.12.11
Time: 00:16:31
Engine RPM: 153 /min
Vehicle speed: 19.88 km/h
System status: Driving mode
Voltage terminal 30: 8.54 V
max.value: 24.82 A
End stage temperature: 30 °C
Steering assistance: engine output: 0.95 %
Engine angle: 158 °
Electric motor speed: 7 /min
Steering torque: 0.27 Nm
Status: OK
1068288 - Databus
Fault Priority: 6
Fault Frequency: 1
Reset counter: 1
Engine RPM: 0 /min
Voltage terminal 30: 11.29 V
max.value: 0.50 A
Engine angle: 0 °
Steering torque: 0.11 Nm
Status: OK
1068800 - Databus
Fault Priority: 6
Fault Frequency: 2
Reset counter: 1
Engine RPM: 0 /min
max.value: 0.50 A
Engine angle: 0 °
Status: OK
1070336 - Databus
Fault Priority: 6
Fault Frequency: 2
Reset counter: 1
Engine RPM: 0 /min
Voltage terminal 30: 11.32 V
max.value: 0.50 A
Engine angle: 0 °
Status: OK
1069568 - Databus
Fault Priority: 6
Fault Frequency: 1
Reset counter: 1
Engine RPM: 0 /min
max.value: 0.50 A
Engine angle: 0 °
Status: OK
1048832 - Databus
Fault Priority: 6
Fault Frequency: 1
Reset counter: 216
Date: 2000.00.00
Time: 00:00:00
Engine RPM: 0 /min
Voltage terminal 30: 12.00 V
max.value: 0.50 A
End stage temperature: 17 °C
Engine angle: 0 °
Steering torque: -0.02 Nm
Status: OK
1052160 - Databus
Fault Priority: 6
Fault Frequency: 2
Reset counter: 1
Engine RPM: 0 /min
max.value: 0.50 A
Engine angle: 0 °
Status: OK
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-ENT2.clb
Part No SW: 6C0 035 888 B HW: 6C0 035 888 B
Component: MU-E--ER 851 6490
Serial number: 19041600012060
Coding: 026200003C00000041110001010000001F0000840000010001
ASAM Dataset: EV_MUEnt4CGen2LGE 001025
ROD: EV_MUEnt4CGen2LGE_VW26.rod
VCID: 2B55B2AB420539D346-807E
1 Fault Found:
6697 - Databus
Fault Priority: 6
Fault Frequency: 1
Reset counter: 216
Mileage: 64776 km
Date: 2022.12.12
Time: 22:01:51
Voltage terminal 30: 11.0 V
Network diagnosis-Status: Enabled
End-------------------------(Elapsed Time: 02:15)--------------------------
looks like a ground point in your interior wiring harness is having a bad time. but that's a very rough guess!
giannis20vt
It's a thought that i have done, but it is very difficult to search it.iichel wrote: Tue Dec 13, 2022 8:06 pm looks like a ground point in your interior wiring harness is having a bad time. but that's a very rough guess!
Yes, I agree it's not easy. Here I'm seeing an increase in failures of electrical components due to water/corrosion because of cold weather and bad batteries.
I would start with a certain error like a starter relay and measure all wires to it. Or find a common denominator in the wiring schemes like a relay, ground point, fuse, etc.
giannis20vt
I am reading the faults and i feel very sad.
To much error codes, so much different issues. I really hope this ends easily without many changes and big costs.
Today I am going to tow the car to a garage for further diagnosis and repair.
I understand, this is a complex case. But I think you can get a good start with simply a wiring diagram and a multimeter. You can very easily reach the E box in the engine bay, for example, where the starter relays are.
giannis20vt
giannis20vt
Update for those problems.
1rst problem: broken stalks (turn signal switch). It gives signal for the right turn light all the time.
2nd problem. 2 broken fuses (i checked all the fuses without removing all of them). Maybe i didn't check them right or i took a false measurement.
3rd problem. I remove a couple of fuses from the fusebox to check the operation of their circuit, but i didn't put them to the right place
On the garage the electrician guy found the problem in 15 minutes. I was sure for the faulty stalks because i test them with my original ones.
So final the car is running again without any problem until now.
Make a picture of your fusebox next time before you work on it.
