prtvrk
Drives: 6C
Re: iichels Polo 6R 1.6TDI DSG --> OEM++ R-Line conversion
Post by prtvrk »
iichel wrote: Thu Nov 24, 2022 8:33 pm Yep I had the same regarding pq35. On the T6 forum i read some positive outcomes for retrofits to pq platform.
I've successfully fitted 2q0 bsd on my pq46, it was all trial and error trying different datasets from vcp. I did do manual lc before for the radars to think they were in pq car.
My connectors are faced inwards, some datasets have them facing outside, mine calibrated within 60km and everything is working now.
Cool, thanks. What dataset and coding are you using?
Shadow109
Drives: Vw t5.1 2013
Post by Shadow109 »
Can you tell me from what car your radar came ?
“SW” number will help too
I think our radars just simply doesn’t have have data for pq cars
prtvrk
Drives: 6C
Post by prtvrk »
I want to say I ended up using vw36 dataset from vcp. There was one big pack there and I tried a few of them, first that enabled assistants in cluster I went with, it was late in the day and documentation was not a priority.
Don't forget the voltage changers and resistors for the side mirror leds.
Coding: 52 94 A4 20
One adaptation that made some difference, 'no ecu for draw bar', rest are self explanatory.
My radars came from Audi Q1 if i were to believe the seller.
2q0907686b, did not need to flash them to VW, only dataset.
Index C has CP-enabled.
thank you - highly appreciated. yes I've seen that the PQ radars use a 12V LED while the MQB radars are 5V. 100 ohms of resistor should be OK.
Shadow109
Post by Shadow109 »
Thanks for the info
benmet
Drives: Polo 6R 105PS TDI
Post by benmet »
Hi iichels,
sorry for my bad english :)
I saw that you installed the amrok speedometer in your polo. I also did the construction and took over the EEPROM data. Now the error in the brake control unit is displayed to me Wrong wheel speed from the Kombiinstrument(Tacho) cluster. I also get the message Check brake fluid log with a red exclamation mark symbol. Do you have to reconnect something on the cable? Do you have an idea what I might have forgotten or a tip for me? You can also send me a PM message.
Best regards
Benjamin
could you share your eeprom please?
In other news, the Polo (finally) has its MQB brother, A VW Passat B8 2.0 TSI DSG 4-motion from 2017:
https://imgur.com/a/Kxgf148
Wednesday,14,December,2022,19:00:45:11868
VCDS Version: 22.9.0.0 (x64)  HEX-V2 CB: 0.4623.4
Data version: 20220830 DS341.0
www.Ross-Tech.com
Workshop Code: 123 30389 056831
VIN: WVWZZZ3CZJEiichel   License Plate:
Mileage: 131667km-81814mi   Repair Order:
Chassis Type: 3C-VW48 (3Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 18 19 22 2B 36 3C 42 44
          47 4B 52 5F 65 69 6C 6D A5 BB BC CA CF D6 D7
VIN: WVWZZZ3CZJEiichel   Mileage: 131667km-81814miles
05-Acc/Start Auth. -- Status: OK 0000
14-Susp. Elect. -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
18-Aux. Heat -- Status: OK 0000
22-AWD -- Status: OK 0000
2B-Steer. Col. Lock -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
47-Sound System -- Status: OK 0000
4B-Multifunc. Module -- Status: OK 0000
69-Trailer -- Status: OK 0000
6D-Trunk Elect. -- Status: OK 0000
A5-Frt Sens. Drv. Assist -- Status: OK 0000
BB-Door Rear Drv -- Status: OK 0000
BC-Door Rear Pass -- Status: OK 0000
CA-Sunroof -- Status: OK 0000
CF-Lane Chge Asst 2 -- Status: OK 0000
D6-Light Ctrl Left 2 -- Status: OK 0000
D7-Light Ctrl Right 2 -- Status: OK 0000
Address 01: Engine (J623-CJXA)       Labels:. 06K-907-425-V1.clb
   Part No SW: 3G0 906 259 B    HW: 06K 907 425 B
   Component: 2.0l R4 TFSI  H13 0002
   Revision: --H13---    CVN: 73B77959
   Coding: 091D003A2476050B3004
   Shop #: WSC 05311 115 00319
   ASAM Dataset: EV_ECM20TFS0203G0906259B 001003
   ROD: EV_ECM20TFS0203G0906259B.rod
   VCID: 2B03FAEDB387D593621-807E
   VINID: 9E69EAAAA0D3A9A54008518520274044B7
Readiness: 1110 0001
Address 02: Auto Trans (J743)       Labels: 0D9-927-770.clb
   Part No SW: 0D9 300 018 C    HW: 02E 927 770 AS
   Component: DQ250-6A MQB  H54 5201
   Revision: 06454104    Serial number: TFK01706160335 CVN: 0000580D
   Coding: 0014
   Shop #: WSC 05311 115 00065
   ASAM Dataset: EV_TCMDQ250021 001001
   ROD: EV_TCMDQ250021.rod
   VCID: 1C612931E629222B1BB-8048
Address 03: ABS Brakes (J104)       Labels: 5Q0-907-379-IPB-V1.clb
   Part No SW: 5Q0 614 517 CH    HW: 5Q0 614 517 AH
   Component: ESC           H62 0743
   Revision: 00000000    Serial number: 61907000000236
   Coding: 0FEC6B8F54222371477D070540CB69F0D62AC4E2E00296753842508842A9420000000012121212B835351919323200
   Shop #: WSC 00015 115 00001
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 036010
   ROD: EV_Brake1UDSContiMK100IPB_036_VW48.rod
   VCID: 79AF10A5095BB703A0D-802C
Address 05: Acc/Start Auth. (J518)       Labels:| 5Q0-959-435.clb
   Part No SW: 3Q0 959 435 G    HW: 3Q0 959 435 G
   Component: VWKESSYMQB    037 0906
   Revision: 00037000    Serial number: 0448732144
   Coding: 1F20000723
   ASAM Dataset: EV_KessyHellaMQBAB 004041
   ROD: EV_KessyHellaMQBAB.rod
   VCID: 3E25C3B950F5503BD5F-806A
   Rear lid opener control module:
Address 08: Auto HVAC (J255)       Labels:| 5G0-907-044.clb
   Part No SW: 5G0 907 044 DQ    HW: 5G0 907 044 DQ
   Component: Climatronic   H04 2001
   Revision: 00001K10
   Coding: 1202002420411101111550000010192A
   ASAM Dataset: EV_ACClimaBHBVW37X 006146
   ROD: EV_ACClimaBHBVW37X_006_VW37.rod
   Fresh air blower control module (front):
   A/C pressure/coolant temperature sensor:
   Air quality sensor:
   Humidity sensor: exterior:
Address 09: Cent. Elect. (J519)       Labels:. 5Q0-937-08X-V2.clb
   Part No SW: 5Q0 937 086 BM    HW: 5Q0 937 086 BH
   Component: BCM PQ37BOSCH 034 0242
   Revision: --------    Serial number: 865829061700DO
   ASAM Dataset: EV_BodyContrModul1UDSBosc 018001
   ROD: EV_BCMBOSCH_018.rod
   VCID: 06556B5948A5C8FBDDF-8052
   Wiper motor control module:
   Subsystem 1 - Part No SW: 3G1 955 119 A    HW: 3G1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS    170615  042 0607
   Serial number:         170629234856
   Coding: 0E4DDD
   Rain/Light Recognition Sensor:
   Subsystem 2 - Part No SW: 5Q0 955 547 B    HW: 5Q0 955 547 B  Labels: 5Q0-955-547.CLB
   Component: RLHS  042 0105
   Serial number: S4Y17M06D29H19M25S21
   Coding: 00A8DD
   Light switch:
   Subsystem 3 - Part No SW: 3G0 941 633 H    HW: 3G0 941 633 H
   Component: E1 - LDS MQB  H01 0032
   Serial number: 14 04 2017  10001690
   Anti-theft alarm system sensor:
   Subsystem 4 - Part No SW: 5Q0 951 172     HW: 5Q0 951 172
   Component: Sensor, DWA  005 0316
   Serial number: 000000000ZY1714382PB
   Alarm horn:
   Subsystem 5 - Part No SW: 5Q0 951 605 A    HW: 5Q0 951 605 A
   Component: Sirene, DWA  005 0314
   Serial number: 00000000000070188699
   Humidity sensor: interior:
Address 10: Park/Steer Assist (J791)       Labels:| 5Q0-919-298.clb
   Part No SW: 5QA 919 298 C    HW: 5QA 919 298 A
   Component: PLA 3.0 12KH07 0045
   Serial number: 000308417617172
   Coding: 0271167951
   ASAM Dataset: EV_EPHVA2CAU3700000 009037
   ROD: EV_EPHVA2CAU3700000.rod
   VCID: 50F98D01FA61D64B373-8004
Address 13: Auto Dist. Reg (J428)       Labels:| 3Q0-907-572.clb
   Part No SW: 3Q0 907 572 C    HW: 3Q0 907 572 C
   Component: ACC BOSCH MQB H04 0195
   Coding: 320467DB59FFC428949C8045
   ASAM Dataset: EV_ACCBOSCHVW48X 001009
   ROD: EV_ACCBOSCHVW48X.rod
   VCID: 3537DC9565C39363045-8060
Address 14: Susp. Elect. (J250)       Labels: 5Q0-907-376.clb
   Part No SW: 5Q0 907 376 B    HW: 5Q0 907 376 A
   Component: DAEMPFUNGS-SG H17 0121
   Serial number: 25061741350001
   ASAM Dataset: EV_DRCONTITEMIC 001019
   ROD: EV_DRCONTITEMIC_001_VW48.rod
   VCID: 3829D5A172D16E0B1F3-806C
Address 15: Airbags (J234)       Labels:| 5Q0-959-655.clb
   Part No SW: 3Q0 959 655 BK    HW: 3Q0 959 655 BK
   Component: Airbag VW21   006 0703
   Revision: --------    Serial number: 003W6PCG5P2/
   Coding: 98FCC0C0008000005C5400CF000800000065
   Shop #: WSC 05314 000 00001
   ASAM Dataset: EV_AirbaVW21TS6VW48X 001014
   ROD: EV_AirbaVW21TS6VW48X_VW37.rod
   VCID: 0849656142B1DE8BAF3-805C
   Left seat belt tensioner:
   Subsystem 1 - Part No SW: 4M0 980 945 A    HW: 4M0 980 945 A
   Component: BeltPretRevFL  106 1040
   Serial number: 3G0857705 0031T01500
   Coding: 80000D
   Right seat belt tensioner:
   Subsystem 2 - Part No SW: 4M0 980 946 A    HW: 4M0 980 946 A
   Component: BeltPretRevFR  106 1032
   Serial number: 3G1857706G0185R01460
   Coding: 80000D
   Subsystem 3 - Part No SW: -----------    HW: 454 001 606 17
   Component: SideSensor_Df  008 0887
   Serial number: 357000000000507D3628
   Coding: 2D2D2D
   Subsystem 4 - Part No SW: -----------    HW: 454 001 806 17
   Component: SideSensor_Pf  008 0887
   Serial number: 358000000008D140C62J
   Coding: 2D2D2D
   Subsystem 5 - Part No SW: -----------    HW: 454 801 106 17
   Component: SideSensor_Dr  301 0148
   Serial number: 3510091305210000000U
   Coding: 2D2D2D
   Subsystem 6 - Part No SW: -----------    HW: 454 801 106 17
   Component: SideSensor_Pr  301 0148
   Serial number: 352002F2F52100000009
   Coding: 2D2D2D
   Subsystem 7 - Part No SW: -----------    HW: 454 801 406 17
   Component: FrontSensor_D  304 0149
   Serial number: 3550040279610000000%
   Coding: 2D2D2D
Address 16: Steering wheel (J524)       Labels:| 5Q0-953-549.clb
   Part No SW: 5Q0 953 521 BB    HW: 5Q0 953 569 A
   Component: Lenks.Modul   075 0235
   Revision: FF033033    Serial number: 20170627200018
   Coding: 0C10
   ASAM Dataset: EV_SMLSVALEOMQB 001016
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 73B3228D2B37CD53EA1-8026
Address 17: Instruments (J285)       Labels:| 5G0-920-XXX-17.clb-SRI3
   Part No SW: 3G0 920 791 C    HW: 3G0 920 791 C
   Component: KOMBI         406 3193
   Coding: 07A40898FE8C000801886B0F1001000080000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009058
   ROD: EV_DashBoardVDDMQBAB_009_VW26.rod
   VCID: 290F00E5B97BC78390D-807C
Address 18: Aux. Heat (J364)       Labels:| 5Q0-963-272.clb
   Part No SW: 5Q0 963 272 H    HW: 5Q0 963 272 H
   Component: STH-MQB       008 0075
   Coding: 9309
   ASAM Dataset: EV_AuxilParkiHeateWOS 002018
   ROD: EV_AuxilParkiHeateWOS.rod
   VCID: 3B23CAAD43E74513F21-806E
   Auxiliary heating remote control:
   Subsystem 1 - Part No SW: 3Q0 963 513     HW: 3Q0 963 513
   Component: R64 D208L  004 0401
   Serial number: 00000000000000276932
Address 19: CAN Gateway (J533)       Labels:| 3Q0-907-530-V1.clb
   Part No SW: 3Q0 907 530 G    HW: 3Q0 907 530 C
   Component: GW MQB High   518 5304
   Serial number: 06071710802132
   Coding: 0B0300347F015900FB00025E9C0F00010001070000000000000000000000
   GVL: 01DE3C0008000600C0DC80000006CC0010040000000200000000000000000000
   ASAM Dataset: EV_GatewNF 013023
   ROD: EV_GatewNF_VW37.rod
   VCID: 3333E28D6BB78D532A1-8066
   Generator:
   Multifunction steering wheel control module:
   Subsystem 2 - Part No SW: 5G0 959 442 N    HW: 5G0 959 442 N  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H11 0040
   Serial number: 29170001407150107262
   Coding: 2DFFFF
   Subsystem 3 - Part No SW: 3Q0 915 181 B    HW: 3Q0 915 181 B
   Component: J367-BDMHella  H10 9070
   Serial number: 5131394104
   Inverter for electrical outlet:
   Subsystem 4 - Part No SW: 5Q0 907 155 C    HW: 5Q0 907 155 C
   Component: U13DCAC  H26 0780
   Serial number: 0066181
   Analog clock:
   Subsystem 5 - Part No SW: 3G0 919 204 C    HW: 3G0 919 204 C
   Component: Analoguhr  111 1004
   Serial number: 3003201700010095
Address 22: AWD (J492)       Labels:* 0CQ-907-554.clb
   Part No SW: 0CQ 907 554 H    HW: 0CQ 525 130
   Component: Haldex4Motion H52 7083
   Serial number: HA1-00017.05.17
   Coding: 0301
   ASAM Dataset: EV_AllWheelContrHA1VW37X 004013
   ROD: EV_AllWheelContrHA1VW37X_004.rod
   VCID: 4ACD9F691C3DEC9B797-801E
Address 2B: Steer. Col. Lock (J764)       Labels:* 5Q0-905-861.clb
   Part No SW: 3Q0 905 861     HW: 3Q0 905 861
   Component: ELV-MQBB      H05 0032
   Serial number: 17000160250002
   Coding: 0800000000000000
   ASAM Dataset: EV_ELVMarquMQBB 001007
   ROD: EV_ELVMarquMQBB.rod
   VCID: 71BF2885512BFF4318D-8024
Address 36: Seat Mem. Drvr (J810)       Labels:* None
   Part No SW: 3Q0 959 760 B    HW: 3Q0 959 760 B
   Component: Sitzmemory    H05 0022
   Serial number: Y0006QFD15173
   Coding: 001000020000050081C280808080000000008181000000F400
   ASAM Dataset: EV_SeatMemorDriveSide 002021
   ROD: EV_SeatMemorDriveSide.rod
   VCID: 3A2DCFA94CDD7C1BE97-806E
Address 3C: Lane Change (J769)       Labels:| 3Q0-907-566.clb
   Part No SW: 3Q0 907 566 E    HW: 3Q0 907 566
   Component: MRR1Rear      H20 0510
   Revision: --------
   Coding: 14C002
   ASAM Dataset: EV_RearRadarS1BoschVW48X 001007
   ROD: EV_RearRadarS1BoschVW48X_VW37.rod
Address 42: Door Elect, Driver (J386)       Labels:| 5QX-959-X93-42.clb
   Part No SW: 5Q0 959 593 E    HW: 5Q0 959 593 B
   Component: TSG FS        020 0041
   Serial number: 190417EDJ1110A
   Coding: 003F1A20D200028000001000
   ASAM Dataset: EV_DCUDriveSideEWMAXKLO 006003
   ROD: EV_DCUDriveSideEWMAXCONT.rod
   VCID: 43D3B24D3B173DD3BA1-8016
Address 44: Steering Assist (J500)       Labels:| 5Q0-909-144.clb
   Part No SW: 3Q0 909 144 K    HW: 3Q0 909 144 H
   Component: EPS_MQB_ZFLS  506 5072
   Coding: 9307
   Shop #: WSC 00015 115 00319
   ASAM Dataset: EV_SteerAssisMQB 013144
   ROD: EV_SteerAssisMQB_013.rod
Address 47: Sound System (J525)       Labels:| 3Q0-035-466.clb
   Part No SW: 3Q0 035 465     HW: 3Q0 035 465
   Component: MIB2_amp_P_VW H60 0440
   Revision: 00000001    Serial number: VWZ8Z1HJD00RUVL
   Coding: 1284020001AA0A2AAA0000000000
   ASAM Dataset: EV_AMPMst16C3Gen2ALPI 001016
   ROD: EV_AMPMst16C3Gen2ALPI_VW37.rod
   VCID: 6B833AED73071593221-803E
Address 4B: Multifunc. Module (J745)       Labels:| 3Q0-907-338-V1.clb
   Part No SW: 3Q0 907 338     HW: 3Q0 907 338
   Component: FCM MQB Low   002 0286
   Serial number: 01071710801233
   Coding: 000000060100035207004F01020000000000000000000000000000000000
   Shop #: WSC 05311 000 00001
   ASAM Dataset: EV_MultiModulContiVW48X 001010
   ROD: EV_MultiModulContiVW48X_001.rod
   VCID: 72BD2789542DC45BE17-8026
   Left Headlamp Power Output Stage:
   Subsystem 1 - Part No SW: 3G0 941 329 _    HW: 3G0 941 329 _
   Component: Leimo links  H02 0003
   Coding: E02400
   Right Headlamp Power Output Stage:
   Subsystem 2 - Part No SW: 3G0 941 329 _    HW: 3G0 941 329 _
   Component: Leimo rechts  H02 0003
   Coding: E02400
Address 52: Door Elect, Pass. (J387)       Labels:| 5QX-959-X92-52.clb
   Part No SW: 5Q0 959 592 E    HW: 5Q0 959 592 B
   Component: TSG BFS       020 0041
   Serial number: 170617EFH29274
   Coding: 003F1020DE00028200001000
   ASAM Dataset: EV_DCUPasseSideEWMAXKLO 006003
   ROD: EV_DCUPasseSideEWMAXCONT.rod
   VCID: 42DDB749240D34DBB17-8016
Address 5F: Information Electr. (J794)       Labels:| 5G0-035-MIB-HGH2.clb
   Part No SW: 5NA 035 042 A    HW: 5NA 035 042
   Component: MU-H-LN-EU    H54 1121
   Serial number: A847G0HB006263
   Coding: 02840201000000005111000200080A101F0106E4012004009F
   ASAM Dataset: EV_MUHig4CGen2HBAS 001001
   ROD: EV_MUHig4CGen2HBAS_VW37.rod
   Display and control head 1 for information electronics:
   Subsystem 1 - Part No SW: 5G6 919 606     HW: 5G6 919 606
   Component: ABT_High-2  H50 9130
   Serial number: VWZ6ZJT1915518
   Data carrier:
   Subsystem 2 - Part No SW: V03 959 809 PA    HW: -----------
   Component: ECE 2022  --- 0195
   Compact disc data bank:
   Subsystem 3 - Part No SW: V03 959 800 EG    HW: -----------
   Component: Gracenote2  --- 1016
   Part No SW: 5Q0 907 273 B    HW: 5Q0 907 273
   Component: RDKBERU30     H04 0009
   Serial number: 40000000081630
   ROD: EV_RDKBERU30_006_VW37.rod
   VCID: 3431E1916EB98A6B33B-8060
Address 69: Trailer (J345)       Labels:| 5Q0-907-383.clb
   Part No SW: 5Q0 907 383 N    HW: 5Q0 907 383 N
   Component: Anhaenger     H27 0264
   Revision: 8A001003    Serial number: 0446947174
   Coding: 0100000202000000
   ASAM Dataset: EV_TrailFunctGener2Hella 001008
   ROD: EV_TrailFunctGener2Hella_VW26.rod
Address 6C: Back-up Cam. (J772)       Labels:| 5Q0-980-556.clb
   Part No SW: 5Q0 980 556 B    HW: 5Q0 980 556 B
   Component: RVC Compact   H12 0231
   Coding: 0184020163002017000040
   ASAM Dataset: EV_CamSysRVRVCPANAMQBAB 006009
   ROD: EV_CamSysRVRVCPANAMQBAB_006_VW37.rod
   VCID: 392FD0A549DB7703E0D-806C
Address 6D: Trunk Elect. (J605)       Labels:| 5Q0-959-107.clb
   Part No SW: 5Q0 959 107 L    HW: 5Q0 959 107 J
   Component: HDSG-Modul    H13 0261
   Revision: --------    Serial number: 31433445900000
   Coding: 0288
   ASAM Dataset: EV_DeckLidCONTIAU736 001014
   ROD: EV_DeckLidCONTIAU736_VW41.rod
   VCID: 41DFB845210B2FC3A8D-8014
Address A5: Frt Sens. Drv. Assist (R242)       Labels:| 3Q0-980-65X-A5.clb
   Part No SW: 3Q0 980 654 H    HW: 3Q0 980 654 A
   Component: MQB_B_MFK     H07 0272
   Serial number: 14061711P11354
   Coding: 000408020000040100222347C150A90094000E300040
   ASAM Dataset: EV_MFKBoschMQBB 001001
   ROD: EV_MFKBoschMQBB_001_VW36.rod
   VCID: 3C21C9B146E9422BFBB-8068
Address BB: Door Rear Drv (J388)       Labels:* None
   Part No SW: 5Q0 959 595 E    HW: 5Q0 959 595 B
   Component: TSG HFS       020 0041
   Serial number: 070617EF614855
   Coding: 000E10200100028000001000
   ASAM Dataset: EV_DCURearDriveMAXKLO 006003
   ROD: EV_DCURearDriveMAXCONT.rod
   VCID: 45D7AC55352303E3945-8010
Address BC: Door Rear Pass (J389)       Labels:* None
   Component: TSG HBFS      020 0041
   Serial number: 070617EF613546
   ASAM Dataset: EV_DCURearPasseMAXKLO 006003
   ROD: EV_DCURearPasseMAXCONT.rod
Address CA: Sunroof (J245)       Labels:| 4M0-907-594.clb
   Part No SW: 4M0 907 594 J    HW: 4M0 907 594
   Component: SAD_STG_1     014 0005
   Coding: 208040748202
   ASAM Dataset: EV_SunRoofCONTIAU736 006008
   ROD: EV_SunRoofCONTIAU736_006.rod
   VCID: 3D27C4B55DF34B23CC5-8068
Address CF: Lane Chge Asst 2 (J770)       Labels:. 3Q0-907-566.clb
   Part No SW: 3Q0 907 590 E    HW: 3Q0 907 590
   Revision: --------
   Coding: 14C002
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_RearRadarS2BoschVW48X 001007
   ROD: EV_RearRadarS2BoschVW48X_VW37.rod
   VCID: 372BD69D7FCF6173169-8062
Address D6: Light Ctrl Left 2 (A31)       Labels: 7PP-941-572.clb
   Part No SW: 7PP 941 572 AB    HW: 7PP 941 572 A
   Component: LED1L         H09 0003
   ASAM Dataset: EV_LEDModLeftMELCOAU736 001004
   ROD: EV_LEDModLeftMELCOAU736_VW37.rod
   VCID: 16753B191805787B2DF-8042
Address D7: Light Ctrl Right 2 (A27)       Labels: 7PP-941-572.clb
   Component: LED1R         H09 0003
   ASAM Dataset: EV_LEDModRightMELCOAU736 001004
End----(Elapsed Time: 02:50, VBatt start/end: 12.0V/11.9V. VIgn 11.9V)-----
Is this the donor for the polo :mrgreen: :twisted:
mirceaculita
Drives: 6R 1.2TDI 75hp
Post by mirceaculita »
Imagine a 4-motion polo 6r :shock: :shock:
I think its easier just to put a polo logo on the Passat lol
Lucero79
Drives: Polo
Post by Lucero79 »
Hi iichel. Just returning here quickly to ask. Do you think it's possible to fit the DSG gearbox to a CAYC Ibiza?
I'm still pulling parts together to bring it inline with the MQB platform, such as Dash, wiring, etc
Yes I think so
til3tsio
Drives: Seat Toledo KG
Post by til3tsio »
I am searching for info on how to activate gra high and acc on my cayc pcr2.1 ecu.
I saw in one of the above posts that you managed to activate gra high.
was it already active on the new beetle ecu or you did some king of software mod ?
