2015 1.4 tdi dual mass failure
Carrotracing
- Drives: 2011 VW Polo
Re: 2015 1.4 tdi dual mass failure
Thanks very much
i really hope so started thinking it had been installed wrong but it drives fine really just idle chattering sounds horrible noticed clutch out but raising revs over 1000 ish stops it anyone had else had the vw update and know what it drive like after?
Carrotracing
Hi again everyone just been to dealers and apparently had software update for this and seems no change how can I tell if its actually had the update as I read somewhere about idle rpm should be different or something Thanks
- Platinum Member
i think the rpm on idle should be close to 1 000 rpm, atleast that's what the after market tuners do
Carrotracing
Thanks that's what Darkside developments said and I'd go there but there millege away, surely when VW replaced the parts from a dual mass flywheel to solid there software should shut up the rattle seems strange unless the dealer has said they have done it when they havnt I'm at my whits end with the car just want to drive it how it use to be
Carrotracing
