Giannis20vt's Polo 6c 1.0MPI
Re: Giannis20vt's Polo 6c 1.0MPI
Yes in your case battery adaptation is done in the gateway
giannis20vt
Post by giannis20vt »
iichel wrote: Wed Jan 04, 2023 4:03 pm Yes in your case battery adaptation is done in the gateway
Found it at Gateway as you said.
giannis20vt
after the successful change of the BCM I can concentrate on other tasks.
Lighting in the lower part of the door panel
Image Image
Image Image
The electrical connection:
Image Image
Nice, well done. Looks very clean.
giannis20vt
This is a new scan with a VCDS cable.
VCDS Version: 22.10.0.1  HEX-V2 CB: 0.4622.4
Data version: 20221026 DS344.0
www.Ross-Tech.com
VIN: WVWZZZ6RZGY------   License Plate:
Mileage: 65219km-40525mi   Repair Order:
Chassis Type: 6R-VW26 (6C0)
Scan: 01 03 08 09 15 17 19 44 5F
VIN: WVWZZZ6RZGY308378   Mileage: 65219km-40525miles
Address 01: Engine (J623-CHYB)       Labels:. 04C-906-020-CHY.clb
   Part No SW: 04C 906 057 AB    HW: 04E 907 309 CB
   Component: R3 1.0l MPI   H20 2496
   Revision: 33H20000    CVN: DA6EEF6D
   Coding: 01110012020400080000
   Shop #: WSC 00788 648 00255
   ASAM Dataset: EV_ECM10MPI01104C906057AB 001002
   ROD: EV_ECM10MPI01104C906057AA_VW26.rod
   VCID: 6597B189C5E238F3784-8030
   VINID: 9E69EAAAA1A2A97A430080C720BAB66964
Readiness: 0000 0000
   Part No SW: 6C0 907 379 K    HW: 6R0 907 379 BA
   Component: ESP9.0i       H03 0004
   Serial number: 08512057160424
   Coding: 21DD2485492333C8091700700059842492CC90000005C9098F00
   Shop #: WSC 49716 005 1048576
   ASAM Dataset: EV_Brake1ESP90iBOSCHPQ26 100020
   ROD: EV_Brake1ESP90iBOSCHPQ26.rod
   VCID: 372B2BC12FCE7A631A8-8062
Address 08: Auto HVAC (J301)       Labels:| 6C0-820-045.clb
   Part No SW: 6C0 820 045 C    HW: 6C0 820 045 C
   Component: AC Manuell    H03 0202
   Serial number:  1605161B-0418
   Coding: 200000000000100000
   ASAM Dataset: EV_ACManueKMMValeoPQ26 002001
   ROD: EV_ACManueKMMValeoPQ26.rod
   VCID: 1F1BE361A73E2223F28-804A
Address 09: Cent. Elect. (J519)       Labels:| 6C0-937-090-V1.clb
   Part No SW: 6C0 937 090 E    HW: 6C0 937 090
   Component: BCM PQ26 HiKR H10 0101
   Serial number: 006738042497
   Coding: 000008404053005B4F844000400703000000580051010000000000000000
   Shop #: WSC 12345 123 12345
   ASAM Dataset: EV_BCMA0 006004
   ROD: EV_BCMA0_006_VW26.rod
   VCID: 2A0D02B5EC7CD78B956-807E
   Driver door control module:
   Subsystem 1 - Part No SW: 6R0 959 801 DG    HW: 6R0 959 801 DG  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  003 0610
   Serial number: KU0KU012051661335260
   Coding: 0000A0
   Front passenger door control module:
   Subsystem 2 - Part No SW: 6R0 959 802 DL    HW: 6R0 959 802 DL  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  003 0610
   Serial number: KU0KU030041661212448
   Coding: 1000A0
   Subsystem 3 - Part No SW: 6R0 959 811 AA    HW: 6R0 959 811 AA
   Component: J388__TSG_HL  003 0610
   Serial number: KU0KU028041661198823
   Coding: 0000A0
   Subsystem 4 - Part No SW: 6R0 959 812 AA    HW: 6R0 959 812 AA
   Component: J389__TSG_HR  003 0610
   Serial number: KU0KU002051661233279
   Coding: 1000A0
Address 15: Airbags (J234)       Labels:| 6C0-959-655.clb
   Part No SW: 6C0 959 655 J    HW: 6C0 959 655 J
   Component: VW20Airbag00A 002 0380
   Revision: --------    Serial number: 003TH006KLNX
   Coding: 88C0C000000000005C000000000800000000
   ASAM Dataset: EV_AirbaVW20BPAVW26X 001001
   ROD: EV_AirbaVW20BPAVW26X.rod
   VCID: 3A2D32F51CDC670BE56-806E
   Subsystem 1 - Part No SW: -----------    HW: 410 820 305 16
   Component: SideSensor_Df  151 0800
   Serial number: 3575H00A520BDDD2520R
   Coding: 2D2D2D
   Subsystem 2 - Part No SW: -----------    HW: 410 821 104 16
   Component: SideSensor_Pf  151 0800
   Serial number: 3585H00A5209A1C310AF
   Coding: 2D2D2D
   Subsystem 3 - Part No SW: -----------    HW: 442 152 204 16
   Component: SideSensor_Dr  1CA 0148
   Serial number: 3517A00AF1FACC94822/
   Coding: 2D2D2D
   Subsystem 4 - Part No SW: -----------    HW: 442 152 204 16
   Component: SideSensor_Pr  1CA 0148
   Serial number: 3527A00C12060D61520W
   Coding: 2D2D2D
1 Fault Found:
15360256 - Component Protection
          U1101 00 [137] - Active
          [ATP Error Counter]
                    Fault Status: 00000001
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 65177 km
                    Date: 2023.01.21
                    Time: 10:04:10
Address 17: Instruments (J285)       Labels:| 5G0-920-XXX-17.clb-SRI3
   Part No SW: 6C0 920 740 C    HW: 6C0 920 740 C
   Component: KOMBI         201 1420
   Coding: 070409002100000811082A000000000000000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009046
   ROD: EV_DashBoardVDDMQBAB_009_VW26.rod
   VCID: 221DEA95944C0FCBDD6-8076
Address 19: CAN Gateway (J533)       Labels:| 6C0-909-901-V1.clb
   Part No SW: 6C0 909 901 A    HW: 6C0 937 090
   Component: GW MQB A0     H10 0101
   Revision: --------    Serial number: 006738042497
   Coding: 01010008200A640071000000000000000001010000000000000000000000
   GVL: 01403C0000000000400000000000480000000000000000000000000000000000
   ASAM Dataset: EV_GatewA0Lear 013020
   ROD: EV_GatewA0Lear_013_VW26.rod
   VCID: 2615F685F864F3EBB1E-8072
   Multifunction steering wheel control module:
   Subsystem 1 - Part No SW: 6C0 959 442 B    HW: 6C0 959 442 B  Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAT  X03 X014
   Serial number: 13/11/2013  PV000031
   Coding: 2C0000
1 Fault Found:
131654 - No Communications with HVAC Control Module (J301)
          U0164 00 [008] - -
          [Timeout Knoten 0x46 / 08 - Steuergerδt fόr Klima]
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 89
                    Mileage: 65198 km
                    Date: 2023.01.24
                    Time: 10:38:58
                    Terminal 30 power supply: 12.2 V
                    Terminal 15: OFF
Address 44: Steering Assist (J792)       Labels:| 6Rx-909-144-V2.clb
   Part No SW: 6C1 909 144 AG    HW: 6C1 909 144 D
   Component: EPS_TRW_ALow  312 3232
   Serial number: PG5Q1139
   Coding: 000700
   ASAM Dataset: EV_SteerAssisUDSTRW 016026
   ROD: EV_SteerAssisUDSTRW.rod
   VCID: 6D87C9A91D1200B3304-8038
Address 5F: Information Electr. (J794)       Labels:| 5G0-035-MIB-ENT2.clb
   Part No SW: 6C0 035 888 B    HW: 6C0 035 888 B
   Component: MU-E--ER      851 6490
   Serial number: 19041600012060
   Coding: 026200003C00000041110001010000001F0000840000010001
   ASAM Dataset: EV_MUEnt4CGen2LGE 001025
   ROD: EV_MUEnt4CGen2LGE_VW26.rod
   VCID: 2B0307B1E386CE836E0-807E
End----------(Elapsed Time: 00:36, VBatt start/end: 12.4V/12.4V)-----------
Suddenly there is a CP for the Airbag module, i have to go to a garage with online connection to remove it, i don't know why this error came up.
Nor about the error with the communication with the HVAC module, I don't know what happened.
Does it return after you clear it? Probably a left-over of your BCM swap?
giannis20vt
iichel wrote: Thu Jan 26, 2023 5:22 pm Does it return after you clear it? Probably a left-over of your BCM swap?
Yes is does. The CP is something i can't remove myself.
It appeared some days after the swap.
giannis20vt
giannis20vt wrote: Thu Jan 26, 2023 5:23 pm
All right, i removed the CP error with an online connection.
Every time i scan for errors i find the some error
                Address 09: Cent. Elect.       Labels: 6C0-937-090-V1.clb
Control Module Part Number: 6C0 937 090 E    HW: 6C0 937 090
  Component and/or Version: BCM PQ26 HiKR H10 0101
           Software Coding: 000008404053005B4F844000400703000000580051010000000000000000
            Work Shop Code: WSC 12345 123 12345
              ASAM Dataset: EV_BCMA0 006004 (VW26)
1 Fault Found:
206604 - Locking Unit for Central Locking; Passenger Side
          B1680 29 [009] - Signal Implausible
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 153
                    Mileage: 65639 km
                    Date: 2023.03.08
                    Time: 18:59:50
                    Terminal 15 status: OFF
                    Terminal 50 status: OFF
                    Status Bremslichtschalter (HW): OFF
                    Status Bremslichtschalter (CAN): OFF
                    OFF: operated
                    Position lamps: Not operated
                    Automatic high beam assist: Not operated
                    Low beam: Not operated
                    Parking light left: Not operated
                    Parking light right: Not operated
                    Stoerschutzzaehler: 19
                    Voltage: 12.5 V
                    Outside temperature: 14.5 °C
There is no problem with the operation of the passenger door, except for the error code. It is possible that this error first appeared after installing my front door light. I am not sure.
It is easy to check by disconnecting the led light
giannis20vt
iichel wrote: Sun Mar 12, 2023 11:25 am It is easy to check by disconnecting the led light
Sure it is an easy try. I'll do it
giannis20vt
Hood strut. Done
Image Image Image
I made the metal parts and i painted them at the same color of the car. Them i mound them.
One strut with length 48cm and 300Nm. Very good result, smooth opening.
https://youtu.be/FPFMB13mT6Q
ag69
Drives: 1.2TSi 77Kw 7DSG
Post by ag69 »
giannis20vt --looks good.
What is ratings for these?
mine opens like a rocket :D
giannis20vt
ag69 wrote: Tue Apr 11, 2023 6:24 am giannis20vt --looks good.
Hi, 300Nm is the force for this gas strut. I have installed just one. A tip is that you have to put it upside down. The part with the thick diameter goes into the hood, the other with the thin diameter, goes into the fixed point. :wink:
Bravo! Looks good!
ndc78
Drives: Polo 6r 1.2 TSI
Post by ndc78 »
Hallo iichel
Wohne auch in der Schweiz (Aargau) wo bist du zuhause?
