Rear Wash failure
funkyfatbeatz
Rear Wash failure
Post by funkyfatbeatz »
Hi Guys,
I'm having problems with my rear wash/wipe.
When I squirt water on the rear window it comes out the front washers?
I've tried putting a pin in there to clean out any blockages
but still no luck!!
Has anyone else had this problem?
:roll:
bstardchild
Moderator
Re: Rear Wash failure
Post by bstardchild »
funkyfatbeatz wrote:Hi Guys,
but still no luck!!
:roll:
http://www.tigerstyle.co.uk/poloforum/v ... php?t=6730
Might help - specially if you find your carpets are wet in the back?
funkyfatbeatz
Just though I'd let you know it was a loose pipe
off the washer pump :D
