Please Advise
- Drives: VW Polo 1.2 9N
Please Advise
- Maarten
- Drives: AW R-line FL 110hp MY2022 Vibrant Violet
Re: Please Advise
Looks like you are at the right sub forum.
What are your questions?
Re: Please Advise
Hi Maarten
Sorry for the delay
I am looking to save money and learn more about my car.
Can you recommend a good ODB Diagnostic brand please?
I have an error light on, and unsure why?
Sorry for the delay
- Maarten
Re: Please Advise
There are a lot of different OBD scantools.
Some swear to OBD11 others to Ross-Tech, some to the AliExpress Clone cable.
For my 9N3 I used the VAGCOM409.1 and later a VCDS AliExpress Clone Cable.
Nowadays my friend has the original Ross-Tech Cable, so I go to him for it.
VCDS Clone is around 25€ (euro's)
VCDS original around 500-700 € depending on nr of VIN's you want to use (3 - 10 or unlimited)
OBD11 Is around 70€ purchase, but needs credits for some actions.
Re: Please Advise
- Maarten
Re: Please Advise
The iCar one, I don't know anything about that.
There must by someone at this forum who does.
Did your scan have any problems regarding to the car?
Re: Please Advise
- Maarten
Re: Please Advise
If memory is correct, those are in the exhaust.
Re: Please Advise
Maarten Thanks
I need to get the door switch fixed, as I use the drivers window a lot for work
- Maarten
Re: Please Advise
You must really pay attention in ordering the right doormodule!
There are differences in 3-door and 5-door and in 9N and 9N3. (probably also in LHD and RHD)
Changing is about 1 hour work, when you are custom to take off the doorpanel.
Get the right tools for the job.
Window has to come out or fixed to the door.
This is necessary because the inner doorplate (iron part) has to come off to change the lock.
Windowmotor and lifter and a part of the doorlock are connected to the inner door part.
There are lots of tutorials on YT on removing doorcard and inner door.
Good luck.
Keep us posted!
Good luck.
Keep us posted!
Re: Please Advise
- Maarten
Re: Please Advise
When no change if you remove a coil than that one is probably busted.
I would say look at the brand your other coils are.
To be save, try to change coil 3 for 2 or 1.
If same reaction on cilinder 3, there could be a wire problem at coil pos. 3
Than it is useless to purchase a new coil.
Like said before, a scan will reveal al lot more, for me it is guessing what could be wrong.
Re: Please Advise
Hi Maarten
Sorry for the delay
A Coil had failed, and was running terribly badly
It seems like you have been very helpful to me, which I appreciate.
Just a Thought !!
Would you like me to Pay Pal you some money for your Time, or so the Tax man cant complain, a small financial Gift?
Stay Safe
Sorry for the delay
Just a Thought !!
Stay Safe
- Maarten
Re: Please Advise
Hi, great all is solved.
Advise is free on this forum.
Just to hear back is payment enough, it will also help other forummembers later on.
I do appreciate the gesture
