Polo 6R 1.2 GT Tsi RHD
sshakthi123
Drives: Vento 1.5 TDI MT and Polo 6R 1.2 Tsi Dsg
Re: Polo 6R 1.2 GT Tsi RHD
Post by sshakthi123 »
ciclo wrote: Thu Apr 14, 2022 4:51 am Thanks
It is clear that the electrical installation is not correct. You will have to review it, nobody better than you to know what was done.
My installation is simple (a new wire from SB7b (JPT) to headlight regulator T6/3) followed your diagram https://drive.google.com/file/d/0B2nv91 ... B4gGRBHy0g
and isolated original SB7b.
I don't think I messed up something here. I feel something is not right with the electrical signal from headlight switch to BCM but again it is outside my expertise.
ciclo wrote: Thu Apr 14, 2022 4:51 am JFYI; I am sorry to inform everyone that I no longer provide any kind of technical support, neither free nor paid.
Right now, are not ideal conditions for me, nothing personal against anyone or any other kind of weird story, I'm perfect condition or better.
I respect your decision btw you provided immersive support during my Vento upgrades. Whatever the little I learnt is from this forum, you and others. And this forum is a massive repository of all your knowledges and can be referred until the legacy (6R :D ) exists. As iichel said it would be great if you oversee what we do :mrgreen:
patil
Post by patil »
Well it looks like the Dimmer switch will not work fully with certain BCM High's (eg: 087M/087AF). Even I had same dimmer behaviour with my BCM High back then, but then I never reported it believing it's the way how it works, until it was also reported by Lizardking here viewtopic.php?p=560362#p560362
So I see a similar pattern which only leaves with a conclusion that all BCM low and many BCM High's doesn't support dimmer function fully.
I also know that with few BCM High's eg: 087R/T, dimmer works perfectly like with BCM Max. ( I don't have proof to claim this, but affirmative.)
Perhaps this problem can be solved by reparameterizing with VCP the voltage value for signal 58 through a comparative study between the BCMs in which it works correctly and those that have this problem.
I'm not sure about this, I've never had a BCM High in my hands for testing.
sshakthi123
So I will live with this for now until near future to plan for BCM Max.
But without you guys support it is a nightmare (may be I can try doing the wiring looms my own but definitely need a technical support on what needs to be done :!: )
sshakthi123
I have done with the most of the updates planned for (as Part 1 :wink: )
1. Dimmer switch - done
2. Front PDC OPS 4k to 8k - done
3. Rear flip cam on logo - done
4. RLS and Autodimming mirror - done, added few pictures below. All the expected features works flawless with BCM high 87AD (Auto wipers, Auto dimming, Rain closing, though it is unexpected with the trails I made in my Vento )
5. Indirect TPMS - installation done and coded. But it is not working as expected. I have rechecked the continuity but pressing SET button does nothing. Cluster doesn't illuminate the tyre pressure low SMD or cluster itself is not supporting. Ciclo / Patil - need your support here. PFB the latest scan report.
6. Side parking lights with BCM High - done
7. DRL - done, T17/3 to external DRL's behind the grill
8. Tweeters in A pillar - done
9. Number plate lights to LED - done
10. Lights in Glove box and Trunk (Completed) - done
Part 2 plan: BCM Max upgrade (along with too many other :roll: MFA+ cluster, direct TPMS, Composition/Discover media, etc etc)
Latest scan;
Sunday,15,May,2022,10:45:15:00006
VCDS Version: 18.2.0.3
Data version: 20180212 DS287.0
www.Ross-Tech.com
VIN: MEXL15600GT052162   License Plate: GT
Mileage: 41730km-25929mi   Repair Order:
Chassis Type: 60-VW25 (6R0)
Scan: 01 02 03 04 08 09 10 15 17 19 25 44 56
VIN: MEXL15600GT052162   Mileage: 41730km-25929miles
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CBZB)       Labels:. 03F-906-070-CBZ.clb
   Part No SW: 03F 906 070 KC    HW: 03F 907 309 AJ
   Component: SIMOS10.22AH10 6270
   Revision: --H10---    Serial number:
   Coding: 00250056232400080000
   Shop #: WSC 01234 785 00200
   ASAM Dataset: EV_ECM12TFS02103F906070KC 004006
   VCID: 6DD17FB6BC91F82CC3-8038
Readiness: 0110 0101
Address 02: Auto Trans        Labels: 0AM-927-769.clb
   Part No SW: 0AM 300 065 N    HW: 0AM 927 769 D
   Component: GSG DSG AG7     431 6561
   Revision: 00043014    Serial number: CU501505175568
   Coding: 0000020
   Shop #: WSC 30641 005 1048576
   VCID: 3A7B84EA755F9F9416-806E
   Part No SW: 6R0 907 379 BN    HW: 6R0 907 379 AS
   Component: ESP9.0i front H03 0001
   Serial number: --------------
   Coding: 62DD2463422803C24615246F4253C0800909
   VCID: 0B15112EA245561C7D-805E
   Serial number: 10051504650266
   Coding: 01
   Shop #: WSC 00000 000 00000
   ROD: EV_LWSKLOVW25X.rod
   VCID: 7EF348FAE1F773B46A-802A
   Part No SW: 6R0 907 044 Q    HW: 6R0 907 044 Q
   Component: Climatronic   H12 0615
   Revision: V0000000
   VCID: 4189F306D889CC4C57-8014
   Part No SW: 6R0 937 087 AF    HW: 6R0 937 087 AF
   Component: BCM PQ25 H+4  H43 0471
   Revision: BF043001    Serial number: 3001 301190588
   Coding: 3AB02BFF48A10000013806C07ECB9E90B0C041FF608C0000200000000000
   Shop #: WSC 12345 123 12345
   VCID: 0109330698090C4C17-8054
   Component: RLHS 200618 0  50  0107
   Coding: 0728DD
   Subsystem 2 - Part No SW: 6R0 959 802 CC    HW: 6R0 959 802 CC  Labels: 6R0-959-802.CLB
   Component: -------------  007 5551
   Serial number: 13102670150810032630
   Coding: 050000
   Subsystem 3 - Part No SW: 6R0 959 801 BT    HW: 6R0 959 801 BT  Labels: 6R0-959-801.CLB
   Serial number: 13102671150810005719
   Coding: 050000
   Subsystem 4 - Part No SW: 5TA 959 442     HW: 5TA 959 442
   Serial number: 1131818514601282AJ1B
   Coding: 250000
   Subsystem 5 - Part No SW: 6R0 959 811 L    HW: 6R0 959 811 L
   Component: -------------  006 5550
   Serial number: 13202580150909024344
   Coding: 020000
   Subsystem 6 - Part No SW: 6R0 959 812 L    HW: 6R0 959 812 L
   Serial number: 13102581150901174201
   Coding: 020000
1 Fault Found:
            000 -  -
                    Fault Status: 01100000
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 41731 km
                    Time Indication: 0
                    Date: 2020.06.08
                    Time: 10:38:44
Address 10: Park/Steer Assist (J446)       Labels:* None
   Part No SW: 6RU 919 475 A    HW: 7N0 919 475
   Component: PARKHILFE 8K  H06 0018
   Revision: --------    Serial number: 28231836203031
   Coding: 308001
   ASAM Dataset: EV_EPHVA18VW250GP00 001002
   ROD: EV_EPHVA18VW250GP00.rod
   VCID: 61C913867049AC4C77-8034
   Revision: --------    Serial number: 003GW0115JH8
   Coding: 003036
   ROD: EV_AirbaVW10BPAVW250.rod
   VCID: 4999EB26E8B9040C8F-801C
   Part No SW: 6RF 920 861     HW: 6RF 920 861
   Component: KOMBI         H01 0214
   Coding: 1408010000
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05729
   VCID: 081F2E22B3333D0450-805C
   Part No SW: 6R0 909 901     HW: 6R0 937 087 AF
   Component: GW-K-CAN TP20 H43 0471
   Revision: BF043001
   Coding: 002300
   VCID: 74E76AD2D7BB29E40C-8020
   Component: IMMO          H01 0214
   Serial number:
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 6ADB74AA8D7FEF14A6-803E
   Part No SW: 1S2 909 144 P    HW: 1S2 909 144 P
   Component: EPS_ECU       H61 1702
   Coding: 0001000000000000
   ROD: EV_SteerAssisNSK_014.rod
   VCID: 4189F306D089CC4C57-8014
Address 56: Radio (J503)       Labels: None
   Part No SW: 6RF 035 187 C    HW: 6RF 035 187 C
   Component: Radio         557 5532
   Revision: --------    Serial number: VWZ7Z2T4106143
   Coding: 0E000440000010
   VCID: 4999EB26E0B9040C8F-801C
End-------------------------(Elapsed Time: 02:55)--------------------------
ag69
Drives: 1.2TSi 77Kw 7DSG
Post by ag69 »
:D
If i am right you are having one Polo and one Vento -- to play, compare and make a beast out of it.
patil
Post by patil »
sshakthi123 wrote: Sun May 15, 2022 12:50 pm
Should have been a easy job for you, as you already did this on Vento. Share the details of your wiring connections done on Polo.
sshakthi123
Here is the wiring connection,
SET button T6
  • pin 3: illumination signal
  • pin 4: goes to pin 12 of ABS connector
  • pin 5: +15
  • pin 6: ground
PS: Sorry for the delay in responding.
patil
Post by patil »
Wiring scheme is correct. Recheck wiring again.
Coding is correct for addresses 03 & 17 according to recent scan posted.
Try resetting tpms warning display in basic settings of address 03 drop down menu.
sshakthi123
ag69 wrote: Mon May 16, 2022 5:35 am :D
True forever :mrgreen:
sshakthi123
Few more updates done recently,
1. Composition media installed
2. Indirect TPMS coding updates done and it provides only audio feedback and no display in the cluster. Possibly there is no SMD in position.
Latest auto scan here,
Saturday,21,January,2023,09:04:55:00006
www.Ross-Tech.com
Mileage: 48930km-30403mi   Repair Order:
Scan: 01 02 03 04 08 09 10 15 17 19 25 44 5F 77
VIN: MEXL15600GT052162   Mileage: 48930km-30403miles
   Coding: 0000020
   Coding: 62DD2463422803C24615246F4253C0800905
   Coding: 01
   Revision: V0000000
   Coding: 3AB02BFF48A10000213800C07C8B9E90B0C041FF608C0000200000000000
   Coding: 0728DD
   Subsystem 2 - Part No SW: 6R0 959 802 BH    HW: 6R0 959 802 BH  Labels: 6R0-959-802.CLB
   Component: J386__TSG_FT  003 8612
   Serial number: KU0KU031031440906027
   Coding: 1400B3
   Subsystem 3 - Part No SW: 6R0 959 801 BC    HW: 6R0 959 801 BC  Labels: 6R0-959-801.CLB
   Component: J387__TSG_BT  003 8611
   Serial number: KU0KU013011440132978
   Coding: 0400B3
   Coding: 250000
   Coding: 020000
   Coding: 020000
Address 10: Park/Steer Assist (J446)       Labels:. 5Q0-919-294.clb
   Part No SW: 1K8 919 472 C    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0480
   Revision: --------    Serial number: 39391606504499
   Coding: 0001151011
   ASAM Dataset: EV_EPHVA18VW364GP00 001007
   ROD: N/A
   VCID: 377D9DDE8E4D82FCE9-8062
No ASAM data for: "EV_EPHVA18VW364GP00" (VW25)
1 Fault Found:
12718592 - ROD - Unknown Error Code
          - 00 [009]
                    Fault Status: 00000001
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 225
                    Mileage: 48932 km
                    Date: 2021.02.12
                    Time: 20:58:29
   Coding: 003036
   Coding: 1408010000
   Revision: BF043001
   Coding: 002300
   Serial number:
   Part No SW: 5K7 035 200 D    HW: 5K7 035 200 D
   Component: MU-S--ER      H20 0240
   Serial number: VWZAZ2R8806143
   Coding: 02630100BE0000001111000101182A001F0100D60020010003
   Shop #: WSC 00066 790 00056
   ROD: EV_MUStd4CTSAT_VW27.rod
   VCID: 2541479624E1006C4B-8070
2 Faults Found:
          U1101 00 [009] - Active
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 225
                    Mileage: 48932 km
                    Date: 2021.02.12
                    Time: 20:58:29
                    Voltage terminal 30: 11.8 V
1637 - Interface for External Media
          U11B8 00 [009] - No Communications
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 225
                    Mileage: 48932 km
                    Date: 2021.02.12
                    Time: 20:58:30
                    Voltage terminal 30: 11.9 V
                    Interface for external media: status-Status: Open circuit
Address 77: Telephone
Cannot be reached
End-------------------------(Elapsed Time: 03:01)--------------------------
sshakthi123
sshakthi123 wrote: Fri Apr 15, 2022 4:55 am My installation is simple (a new wire from SB7b (JPT) to headlight regulator T6/3) followed your diagram https://drive.google.com/file/d/0B2nv91 ... B4gGRBHy0g
Finally I was able to resolve :mrgreen: the Dimmer switch issue (multiple issues when the park lights are on and dimmer regulator to "low")
By adding a new wire,
Headlight switch T17/13 to T73a/45
Thanks to Patil, Ciclo, Firegraphics for all the help.
sshakthi123
Maxidot cluster installed!!
Also updated the ABS firmware from BN to CB.
Sunday,11,August,2024,17:55:16:00006
www.Ross-Tech.com
Mileage: 63600km-39519mi   Repair Order:
VIN: MEXL15600GT052162   Mileage: 63600km-39519miles
Readiness: 0010 0001
   Coding: 0000020
Address 03: ABS Brakes (J104)       Labels: None
   Part No SW: 6R0 907 379 CB    HW: 6R0 907 379 AS
   Component: ESP9.0i front H03 0003
   VCID: 000F36029B03054418-8054
   Coding: 01
1 Fault Found:
332644 - Databus
          U1121 00 [008] - Missing Message
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 143
                    Mileage: 63767 km
                    Date: 2024.08.18
                    Time: 20:53:14
                    Voltage terminal 15: 12.00 V
                    Voltage terminal 30: 12.30 V
                    Terminal 15 status: On
                    Entprellzeit: 5000 ms
   Revision: V0000000
   Coding: 0714DD
   Coding: 1400B3
   Coding: 0400B3
   Coding: 250000
   Coding: 020000
   Coding: 020000
   Coding: 0001151011
   ROD: N/A
1 Fault Found:
          - 00 [008]
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 103
                    Mileage: 63501 km
                    Date: 2024.08.09
                    Time: 21:39:49
   Coding: 003036
   Part No SW: 6RD 920 870 A    HW: 6RD 920 870 A
   Component: KOMBI         H05 0805
   Coding: 140801
   Shop #: WSC 00078 790 12345
   VCID: 479DED1EFEADF27C99-8012
   Revision: BF043001
   Coding: 002300
   Component: IMMO          H05 0805
   Serial number:
4 Faults Found:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 101
                    Mileage: 63566 km
                    Date: 2024.08.13
                    Time: 12:17:08
                    Voltage terminal 30: 11.2 V
6706 - Databus
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 143
                    Mileage: 63767 km
                    Date: 2024.08.18
                    Time: 20:53:13
                    Voltage terminal 30: 11.5 V
                    Network diagnosis-Status: Not available
6714 - Databus
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 143
                    Mileage: 63767 km
                    Date: 2024.08.18
                    Time: 20:53:13
                    Voltage terminal 30: 11.6 V
          U11B8 00 [008] - No Communications
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 142
                    Mileage: 63566 km
                    Date: 2024.08.18
                    Time: 11:17:22
                    Voltage terminal 30: 13.6 V
Cannot be reached
End-------------------------(Elapsed Time: 03:13)--------------------------
sshakthi123
Hi friends, I’m looking for enabling GRA-high in my car with CBZB engine. I appreciate your help on this. Thanks.
@ciclo, iichel, firegrafic - can you help?
sshakthi123
Dear Ciclo,
Does 7E0937089D BCM supports TPMS?
And does it require headlight wiring changes from the light switch to the BCM? as indian version of 6R has the lights controlled by the headlight switch.
