Dynamic blinker error 6C side mirror
javico
Drives: Polo 6C
Post by javico »
Hi there,
I have just bought a pair of dynamic blinker for my 6C side mirrors. The problem is when the engine is already running the blinker doesn’t works, however when the engine is still stopped or when I open or close the car through the remote they work properly.
I’m leaving the AliExpress link:
https://a.aliexpress.com/_B0gurY
Anyone knows how to solve it?
Shane_in_oz
Drives: 2016 Scirocco R - 2015 Polo GTi
Re: Dynamic blinker error 6C side mirror
Post by Shane_in_oz »
you need to change the VCDS setting for the the type of globe that the mirror blinkers are using, I think it was changed from led blinkleuchten to led tagfahrlichtmodul signal. Sorry if I cat help you out more
CarbonChaos
Post by CarbonChaos »
Why fit dynamic mirror indicators when no other lights on the vehicle act this way ?
Just looks odd IMO
Shane_in_oz
odd maybe in your opinion but maybe not in others, but what if you have these headlights.
https://youtu.be/AFerk5-auIo
illatus
Drives: VW Polo 6R 1.2 TSI 105HP
Post by illatus »
Hello..!! I just replaced my mirror indicators with the dynamic one's and i have the same issue. They are working fine with the ignition on but when iam starting the engine they are not working anymore .
Do i need to change the VCDS setting also ?
giannis20vt
Post by giannis20vt »
I have done the same change without any problem.
Please change the adaptation settings.
ENG124877-ENG115266-Leuchte16BLK SLC11-Type_Of_Load_16 >>>>>> LED Blinkleuchten
ENG124878-ENG115285-Leuchte17BLK SRA72-Type_Of_Load_17 >>>>>> LED Blinkleuchten
This is a copy of my adaptions for the side indicator lights It is for the left one, the right is exactly the same (Leuchte 17BLK )
ENG124877-ENG115271-Leuchte16BLK SLC11-Dimming_AB_16	100
ENG124877-ENG115275-Leuchte16BLK SLC11-Dimming_CD_16	0
ENG124877-ENG115276-Leuchte16BLK SLC11-Dimming_Direction_CD_16	maximize
ENG124877-ENG115280-Leuchte16BLK SLC11-Dimming_Direction_EF_16	maximize
ENG124877-ENG115284-Leuchte16BLK SLC11-Dimming_Direction_GH_16	maximize
ENG124877-ENG115279-Leuchte16BLK SLC11-Dimming_EF_16	0
ENG124877-ENG115283-Leuchte16BLK SLC11-Dimming_GH_16	0
ENG124877-ENG126591-Leuchte16BLK SLC11-Fehlerort_mittleres_Byte_DTC-DFCC_16	17
ENG124877-ENG115649-Leuchte16BLK SLC11-Lampendefektbit_Position_16	39
ENG124877-ENG115272-Leuchte16BLK SLC11-Light_Control_HD_AB_16	Always
ENG124877-ENG115269-Leuchte16BLK SLC11-Light_Function_A_16	Blinken links Hellphase
ENG124877-ENG115270-Leuchte16BLK SLC11-Light_Function_B_16	not active
ENG124877-ENG115273-Leuchte16BLK SLC11-Light_Function_C_16	not active
ENG124877-ENG115274-Leuchte16BLK SLC11-Light_Function_D_16	not active
ENG124877-ENG115277-Leuchte16BLK SLC11-Light_Function_E_16	not active
ENG124877-ENG115278-Leuchte16BLK SLC11-Light_Function_F_16	not active
ENG124877-ENG115281-Leuchte16BLK SLC11-Light_Function_G_16	not active
ENG124877-ENG115282-Leuchte16BLK SLC11-Light_Function_H_16	not active
ENG124877-ENG115266-Leuchte16BLK SLC11-Type_Of_Load_16	LED Blinkleuchten
illatus
Post by illatus »
Thank you very much for the information ..!! I will visit today someone how has the appropriate equipment and knows how to change those settings via VCDS..!!
illatus
Post by illatus »
No luck… we couldn’t find any information inside the adaptation settings about signals or mirror indicators .. Can you guys tell me where exactly do you make those changes ?
EDIT: Also maybe for Polo 6R there isnt any kind of setting for it ?
giannis20vt
illatus wrote: Fri Apr 28, 2023 4:19 pm No luck… we couldn’t find any information inside the adaptation settings about signals or mirror indicators .. Can you guys tell me where exactly do you make those changes ?
Hello,
using VCDS:
Go to 09 (Central Electrics)
Go to Adaptation-10
When the drop menu opens, seach for "Leuchte16BLK"
You will see some lines with that word.
Choose the "ENG124877-ENG115266-Leuchte16BLK SLC11-Type_Of_Load_16"
Set the new value to "LED Blinkleuchten" . (photos are for reference only, do not accurately represent the process)
Select Do it !
Then do exactly the same thing with the "Leuchte17BLK"
Done !!!
