I mentioned to my dad in passing that my heated mirrors seemed to stay on all the time. He has a VAGCOM device and suggested adjusting it in the control module to limit the amount of time they can stay on at a time. He adjusted it, and now they come on for 20 minutes at a time. Happy days.
However, since that day, I've had two permanent issues. The boot now will not open (it's one of those without a key hole on it, so all electrically actuated) and the automatic wipers don't work. When I set the wipers to the first position up from off that used to set them as automatic, now it just sets them to intermittent.
I've done some testing as best I can with my multimeter at the tailgate switch and it seems to be working properly. Resistance is low and I get good continuation along all the wires. I've not messed around with the wipers at all, but they're definitely working as manual wipers.
It seems like too much of a coincidence that they were working before the VAGCOM connection and immediately afterwards didn't work. If I take it to VW are they likely to be able to do a reset of the modules that control the wipers and boot? I'm really not savvy with this kind of stuff!
Strange gremlins after VAGCOM connection
- Maarten
Re: Strange gremlins after VAGCOM connection
Look in adress 17 instruments
You must add the numbers up to your cars specs
+00001 trailer
+00002 remotecontrol boot
+00004 electric weight management
+00008 interior lights , clamp S
+00016 backrest recognition
+00032 heated frontseats
+00064 not used
+00128 heated sidemirrors
+00256 wiper system
+00512 rainsensor
+01024 remote boot impuls
+02048 separate switch sidemirrors
+04096 not used
+08192 rear wiper with comfort wiping
+16384 electric fuelpump management
Maybe something went wrong there.
Does your rainsensor still work?
+00001 trailer
+00064 not used
+00256 wiper system
+00512 rainsensor
+04096 not used
