Polo Stalling - Service or OBD2 adaptor?
JoshRhysThomas
Drives: 6R - 2010 1.4 Petrol - 5Dr
Post by JoshRhysThomas »
Morning Guys,
I’ve got a 2010 1.4 petrol, 5D polo which is great. I recently bought a Carista OBD2 adaptor, connected to my phone and enabled the following settings whilst the engine was running,
- Auto lock doors when above 10mph
- Auto lock boot when above 10Mph
- Auto unlock the above when key taken out of ignition
- Enable MFD giving miles left on tank
- Enable horn when ignition off
My question, since having my car serviced, minor, MOT plus Campbelt it starts, then the revs dip and often cuts out unless you rev whilst starting. Also it is a bit jerky if still whereas it used to be really smooth.
Do you guys think this was likely caused by the OBD2 adaptor or the service, this week I paid £155 for a new throttle sensor (apologies this isn’t quite the right nam) and diagnostics costing £155. The garage have just rung to say they want to refund and then have car in all next week.
Any help much appreciated!
Josh
Dink
Drives: 2015 GTI
Re: Polo Stalling - Service or OBD2 adaptor?
Post by Dink »
if it was me i wouldn't start or drive this car until it's fixed
i suspect that the cambelt has not been fitted properly so the timing is now out causing the problems.
was the throttle sensor fitted at the same time as the cambelt and service?
JoshRhysThomas
Thanks for your reply @dink, Cambelt was changed 7/8th of March, throttle sensor changed 2 days ago. Think OBD2 settings change is unrelated. Garage contacted VW yesterday who were confused as to what was going on.
Tommy6rpolo
Drives: 2011 Vw Polo 1,2 Tsi
Post by Tommy6rpolo »
Greetings. Did you ever manage to figure out what exactly was wrong?
Maarten
Post by Maarten »
Last active in 2018, don't think he will respond
