The LSPI thing is also weird. When reading up on it they didn't know what was causing it.RUM4MO wrote: ↑Mon Oct 02, 2023 9:37 pm Without having any proper evidence to back me up, I also consider that Castrol products tend to be priced to support the Castrol name/brand, so quite a bit of your money goes just into you using that brand. I know that they do take on a lot of lab testing which will be funded by engine manufacturers - but that does not always guarantee that the product being sold to the end users is top class, I'm sure it is not pure rubbish, but just not a good reflection on the price that you end up paying, also, at least in UK, they do or used to protect their image through monitoring what outlets are charging for their products - which usually means if you trim a bit off the price, and so drop below their "intended" selling price, then they will make trading life slightly difficult, ie they protect their image and so unit selling price over everything else. Some outlets used to get round this by including "gifts" but even that seems to have stopped.
I'm currently putting together a kit of parts so that I can service my older daughter's 2019 SEAT Leon Cupra 290, and as I have been using Mobil One 5W-30 ESP on our own 2 cars for quite a few years, I was going to use Mobil One 5W-30 in this Leon Cupra 290 service, and conveniently, some outlets are currently selling Mobil One 5W-30 ESP at a discounted price, now I think that I know why this might be, and also the reason why some of the big sellers have no stocks of that oil, and that is that Mobil have revised this oil and now include the statement that it meets with API SP, which is the API rating that includes improved control of LSPI, now I don't necessarily see that as being an issue for the bigger EA888 DI Petrol engines, but it has said to be an issue with the smaller EA211 D1 Petrol engines, which these 1.2TSI engines are, so if I'm correct, then when this new formulation of Mobil One 5W-30 ESP appears, it will be better suited for use in these small engines.
Edit:- by the way, again with having no hard facts to back me up other than experience from using them, over using only them over a period of 23 years, I prefer to have Eldor coils in my VW Group engines.
But look now how the oils are the things that changed to control LSPI and not the engines.
Well if you engine wasn't consuming oil then they wouldn't have LSPI issues!
Oil in combustion mixture reduces octane rating. Shove that into a high compression, early-boosting turbo engine and see what happens.
I have no idea, but I'm guessing LSPI is an issue in the smaller engine due the smaller combustion chamber. Everything is just a little more intense in there, every little edge of a valve or corner in very close proximity making little hotspots everywhere.
The BG MOA also indicates reduction of LSPI. It claims to prevent build-up in the piston rings.
Is that the key then?
Prevent the build up, improving the seal, reducing the oil in the combustion chamber and therefore stop octane reduction and therefore no pre-ignition?
Or is the additive package just an octane booster and you still wind up consuming oil?
Mobil 1 is a rare find down here these days as well. I used to run it in my Audi 200 back in the day. Now you might find it on the other side of the country in a specialist shop.
You should hang around BITOG for a bit. Oil science will do your head in like it did mine.
Ban low tension piston rings!
![Mr. Green :mrgreen:](./images/smilies/icon_mrgreen.gif)
