Polo 6R ABS CODING
Re: Polo 6R ABS CODING
I was unaware that the POLO 6R 1.6l petrol (CLSA) were sold in the UK.🤔
Choose the appropriate one and send it to the mechanic:
(send it as text, not as an image, to make his/her work easier and avoid mistakes... copy from here and paste in the message).
230224E3217000B8C42724E884D800801000 (w/o HHC, w/o TPMS).
230224E3217000B8C42724E884D800801100 (with HHC, w/o TPMS).
230224E3217000B8C42724E884D800801200 (w/o HHC, with TPMS).
230224E3217000B8C42724E884D800801300 (with HHC, with TPMS).
Let's hope it works...🤷‍♂️
Please report the result.
My guess would be 230224E3437000B8C42724E8C2D800801300 but try ciclos suggestions first please
You can substitute the 1300 at the end with 1000 1100 or 1200 for options like HHC and TPMS like ciclo suggested
Sometimes it is very difficult to get references, luckily there was this one for CLSA ESP8.2i, https://forums.ross-tech.com/index.php?threads/14460/
About the transmission type is something uncertain for me, sometimes, what should be is just the opposite... 🤷‍♂️
yep I found the same one. the 21 you took for the engine type is usually petrol engine + LHD but the reference scan doesn't lie.
the SW part number here is BC (reference scan is AF) so that could also be interesting.
ESP codings, especially 8.2i, can sometimes be a small mystery by itself.
I guess we'll figure it out as soon as we hear back.
Dom101
Drives: 2012
Post by Dom101 »
Thanks guys
The first one of ciclos worked. Sorry it took so long to get back to you, I only got the car back a few hours ago. Much appreciate your time and efforts
Dom
Excellent, well done to both you and to ciclo for making a good coding. You probably managed al lthe basic settings for ESP unit and its sensors?
Thanks to you for informing.👍
Rst2023
Drives: 1.4
Post by Rst2023 »
Morning hope all well? Could anyone help me with coding on my Polo please. any help would be amazing.
VIN: WVWZZZ6RZDY051381 License Plate: POLO
Mileage: 185700km-115388mi Repair Order: 1234
Chassis Type: 6R-VW25 (6N0)
Scan: 01 03 04 08 09 15 17 19 25 2E 44 56
VIN: WVWZZZ6RZDY051381 Mileage: 185700km-115388miles
03-ABS Brakes -- Status: Malfunction 1010
2E-Media Player 3 -- Status: Malfunction 0010
Address 01: Engine Labels: 03C-906-024-BXW.lbl
Part No SW: 03C 906 024 CN HW: 03C 906 024 BH
Component: CGGB MM4HV 8994
Revision: --H09--- Serial number:
Coding: 0000071
Shop #: WSC 00788 648 00255
VCID: 6CD0482C4C8D29ED8F-5160
VINID: 9E69EAAAA1A2A94A401410C804DC879B07
Readiness: 0110 0001
Address 03: ABS Brakes (J104) Labels:. 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 BE HW: 6R0 907 379 AF
Revision: --------
Coding: 000000000000000000000000000000000000
Shop #: WSC 31414 790 31414
VCID: 020C06949909CF9D55-8056
3 Faults Found:
01042 - Control Module; Not Coded
000 - -
Fault Status: 01100000
Fault Priority: 0
Fault Frequency: 2
Reset counter: 121
Mileage: 185705 km
Time Indication: 0
Date: 2018.04.07
Time: 22:47:47
Hex Value: 0x4007
Hex Value: 0x0002
Hex Value: 0x3013
Hex Value: 0x1495
Hex Value: 0x00FF
Hex Value: 0x7F7F
Hex Value: 0x7F00
00778 - Steering Angle Sensor (G85)
005 - No or Incorrect Basic Setting / Adaptation
Fault Status: 01100101
Fault Priority: 0
Fault Frequency: 2
Reset counter: 121
Mileage: 185705 km
Time Indication: 0
Date: 2018.04.07
Time: 22:47:47
Hex Value: 0x4007
Hex Value: 0x0002
Hex Value: 0x3051
Hex Value: 0x1B95
Hex Value: 0x00FF
Hex Value: 0x7F7F
Hex Value: 0x7F00
00493 - ESP-Sensor Unit (G419)
Fault Priority: 0
Fault Frequency: 2
Reset counter: 121
Mileage: 185705 km
Time Indication: 0
Date: 2018.04.07
Time: 22:47:47
Hex Value: 0x4007
Hex Value: 0x0002
Hex Value: 0x30E1
Hex Value: 0x2095
Hex Value: 0x00FF
Hex Value: 0x7F7F
Hex Value: 0x7F00
Component: LENKW.SENSOR H06 0060
Serial number: 090465LGG0004J
Coding: 01
Shop #: WSC 00000 000 00000
ROD: EV_LWSKLOVW25X.rod
VCID: 7EF47264E1F1AB7D31-802A
2 Faults Found:
336900 - Databus
U1121 00 [008] - Missing Message
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 12
Reset counter: 161
Mileage: 185703 km
Date: 2023.11.15
Time: 00:36:50
Voltage terminal 15: 14.00 V
Voltage terminal 30: 14.20 V
Terminal 15 status: On
1140738 - Steering angle sensor
B1168 54 [009] - Missing Calibration / Basic Setting
Fault Priority: 2
Fault Frequency: 1
Reset counter: 121
Mileage: 185705 km
Date: 2023.11.15
Time: 19:45:23
Voltage terminal 15: 12.00 V
Voltage terminal 30: 12.10 V
Address 08: Auto HVAC (J301) Labels: 6R0-820-045-9AB.clb
Part No SW: 6R0 820 045 N HW: 6R0 820 045 N
Component: Man AC H02 0202
Revision: 0003SH02
VCID: 397EA178B05F4C4544-806C
1 Fault Found:
01316 - ABS Control Module
Fault Status: 00100100
Fault Priority: 6
Fault Frequency: 10
Reset counter: 161
Mileage: 185703 km
Time Indication: 0
Date: 2018.04.07
Time: 00:36:51
Part No SW: 6R0 937 087 K HW: 6R0 937 087
Component: BCM PQ25 H+4 H46 0254
Revision: BF046001 Serial number: 0434 189120136
Coding: 24B029BF08A10000002808002D2B0CD00040410F60060000200000000000
Shop #: WSC 124697 483 00190
VCID: 4586DD88CCA738A530-8010
Subsystem 1 - Part No SW: 6R0 959 802 AB HW: 6R0 959 802 AB Labels: 6R0-959-802.CLB
Component: J386__TSG_FT 008 1621
Serial number: KU0KU001061200016416
Coding: 18BC30
Subsystem 2 - Part No SW: 6R0 959 801 AD HW: 6R0 959 801 AD Labels: 6R0-959-801.CLB
Component: J387__TSG_BT 008 1621
Serial number: KU0KU014061200015087
Coding: 18BC30
Subsystem 3 - Part No SW: 5K0 959 542 C HW: 5K0 959 542 C Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H31 0033
Serial number: 0157933
Coding: 020000
Address 15: Airbags (J234) Labels:. 5K0-959-655.clb
Component: VW10Airbag01X H10 0020
Revision: -------- Serial number: 003GX01AJG6I
Coding: 003158
Shop #: WSC 01383 785 00200
ASAM Dataset: EV_ A01001
ROD: N/A
VCID: 4A9CEEB4EDB9D7DDDD-801E
Subsystem 1 - Serial number: 3575HRB405F1F0BAF8K7
Subsystem 2 - Serial number: 3585HRB405B1F0BA706H
Subsystem 3 - Serial number: 3515RRB400O4UJ4QNI0G
Subsystem 4 - Serial number: 3525RRB400G4UJ4QJ0UH
No ASAM data for: "EV_" (VW25)
2 Faults Found:
12854016 - ROD - Unknown Error Code
- 00 [008]
Fault Priority: 6
Fault Frequency: 254
Reset counter: 161
Mileage: 185703 km
Date: 2023.11.15
Time: 08:14:33
12656896 - ROD - Unknown Error Code
- 00 [008]
Fault Priority: 6
Fault Frequency: 9
Reset counter: 161
Mileage: 185703 km
Date: 2023.11.15
Time: 00:36:54
Part No SW: 6R0 920 960 K HW: 6R0 920 960 K
Component: KOMBI H04 0605
Coding: 440A01
VCID: 3D76B568AC77706568-8068
Address 19: CAN Gateway (J533) Labels:. 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 6R0 937 087
Component: GW-K-CAN TP20 H46 0254
Revision: BF046001
Coding: 002100
VCID: 70E85C5CA3A5CD0DB3-8024
1 Fault Found:
Fault Priority: 2
Fault Frequency: 12
Reset counter: 161
Mileage: 185703 km
Time Indication: 0
Date: 2018.04.07
Time: 00:36:52
Component: IMMO H04 0605
Serial number:
VCID: 6ADC4E348D7937DDFD-803E
Address 2E: Media Player 3 (J650) Labels:. 5N0-035-342.lbl
Part No SW: 5N0 035 342 F HW: 5N0 035 342 F
Component: SG EXT.PLAYER H18 0530
Revision: A1001003 Serial number: 7663077002
Coding: 010100
VCID: 2A5C8E3445F9F7DD3D-807E
1 Fault Found:
03138 - Input AUX IN
009 - Open or Short to Ground - Intermittent
Fault Status: 00101001
Fault Priority: 4
Fault Frequency: 1
Reset counter: 161
Mileage: 185703 km
Time Indication: 0
Date: 2018.04.07
Time: 00:37:40
Part No: 6R0 423 156 B
Component: LenkhilfeTRW V277
Coding: 11250
Shop #: WSC 00788
VCID: 2F6A9F20EA1B92F5EA-807A
1 Fault Found:
49-10 - No Communications - Intermittent
Part No SW: 5M0 035 186 L HW: 5M0 035 186 L
Component: Radio RCD310 004 0119
Revision: 00000001 Serial number: VWZ1Z2M2176280
Coding: 01000400020001
VCID: 3566AD489C47A825A0-8060
1 Fault Found:
00625 - Vehicle Speed Signal
Fault Priority: 6
Fault Frequency: 9
Reset counter: 161
Mileage: 185703 km
Time Indication: 0
Date: 2018.04.07
Time: 00:37:04
End-------------------------(Elapsed Time: 02:22)--------------------------
230224E3217200B3C42824EA84D200801300
Rst2023
Drives: 1.4
Post by Rst2023 »
Thank you will check tonight. Will keep you posted.😃
Rst2023
Drives: 1.4
Post by Rst2023 »
iichel wrote: Wed Nov 15, 2023 8:59 am 230224E3217200B3C42824EA84D200801300
Thank you so much mate, send me your pay pal will send you some beer tokens. 😃
Good job iichel, direct and straightforward.👏
I made some new tools to make my abs codings, a bit easier to use --> check your mail
Ok, thank you very much for sharing, without a doubt, a great tool to carry out these codings, ...a lot of work here. :shock: 👌
We will add data if necessary or evolutions of these units.
alessandrosx
Drives: polo 1.2
Post by alessandrosx »
Hi everyone,
dear friends, have any of you activated automatic city braking on esp8.2, controlled by the lidar sensor? do you know which byte they are?
