- Drives: T5
Hi am finally back after having problems with getting the right terminals, I have installed the new Bcm code the keys and done the wiring. So am just ready for the coding now I think. Thanks
- Drives: T5
Am in need of help it doing some weird stuff now
Feel free to comment on any circumstance of the events that occurred during the installation of your bi-xenon/bcm-max/wiring, a full Autoscan is essential to be able to develop a corrective action plan.
- Drives: T5
Chassis Type: 7H-VN75 (7E0)
Scan: 01 03 04 08 09 10 13 15 17 19 25 5F 61 69 0B
VIN: WV1ZZZ7HZFH036427 Mileage: 317930km-197552miles
08-Auto HVAC -- Status: Not registered 0011
10-Park/Steer Assist -- Status: Not registered 0011
13-Auto Dist. Reg -- Status: Cannot be reached 1100
5F-Information Electr. -- Status: Cannot be reached 1100
61-Battery Regul. -- Status: Malfunction 0010
69-Trailer -- Status: Not registered 0001
77-Telephone -- Status: Malfunction 0010
Address 01: Engine (J623-CAAC) Labels:. 03L-906-022-CAA.clb
Part No SW: 03L 906 019 GH HW: 03L 907 309 M
Component: R4 2,0L EDC H45 6303
Revision: 26H45--- Serial number: 00000000000000 CVN: 18CB76B8
Coding: 01194012233400080000
Shop #: WSC 65535 123 12345
ASAM Dataset: EV_ECM20TDI01103L906019GH 003004
ROD: EV_ECM20TDI01103L906019FM_003.rod
VCID: 77AA1E63BF4123121E9-8022
VINID: 9E606AAAA1D8A966000C61021C5A6BCCA8
Address 03: ABS Brakes (-----) Labels: 7E0-907-37x-MK25AXT.clb
Part No SW: 7E0 907 379 K HW: 7E0 907 379 E
Component: ESP MK25A XT H43 0110
Revision: 00H43001
Coding: 508724AD89A70A9B24A69173A96510
Shop #: WSC 02737 790 49152
VCID: 3A2CC757CC53FE7A217-806E
5 Faults Found:
01314 - Engine Control Module
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 246
Mileage: 315425 km
Time Indication: 0
Date: 2017.10.10
Time: 09:37:59
Count: 16384
Count: 1
Count: 8194
Count: 762
013 - Check DTC Memory - Intermittent
Fault Status: 00101101
Fault Priority: 2
Fault Frequency: 1
Reset counter: 246
Mileage: 315425 km
Time Indication: 0
Date: 2017.10.10
Time: 09:37:60
Count: 16384
Count: 257
Count: 8193
Count: 762
00778 - Steering Angle Sensor (G85)
Fault Priority: 2
Fault Frequency: 1
Reset counter: 245
Mileage: 317935 km
Time Indication: 0
Date: 2018.03.29
Time: 12:05:30
Count: 16384
Count: 1
Count: 8214
Count: 764
00668 - Supply Voltage Terminal 30
002 - Lower Limit Exceeded - Intermittent
Fault Status: 00100010
Fault Priority: 1
Fault Frequency: 1
Reset counter: 19
Time Indication: 0
Count: 16512
Count: 2305
Count: 128
Count: 762
01299 - Diagnostic Interface for Data Bus (J533)
Fault Priority: 2
Fault Frequency: 1
Reset counter: 0
Time Indication: 0
Count: 16448
Count: 1
Count: 8233
Count: 764
Serial number: 24071404652032
Coding: 01
Shop #: WSC 00000 000 00000
ROD: EV_LWSKLOVW25X.rod
VCID: 7EA40B47907B125A5DF-802A
3 Faults Found:
136194 - Supply voltage
U1011 00 [00001000] - Voltage too Low
Fault Priority: 2
Fault Frequency: 1
Reset counter: 30
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
Voltage terminal 15: 7.20 V
Voltage terminal 30: 7.25 V
Terminal 15 status: On
Entprellzeit: 90000 ms
332660 - Databus
U1121 00 [00001000] - Missing Message
Fault Priority: 6
Fault Frequency: 5
Reset counter: 60
Voltage terminal 15: 10.90 V
Voltage terminal 30: 5.00 V
Terminal 15 status: not coded/not installed
117060 - Databus
Fault Priority: 6
Fault Frequency: 5
Reset counter: 60
Address 08: Auto HVAC (J301) Labels:| 7E5-907-047.clb
Part No SW: 7E5 907 047 BN HW: 7E5 907 047 BN
Component: Climatic-T5 H20 0506
Revision: 00001012
Coding: 0000000002
Shop #: WSC 02737 790 50316
ROD: EV_ClimaT5Basis.rod
VCID: 7CA0014F8667004A73B-8028
5 Faults Found:
13701408 - Function Restricted due to Missing Message(s)
U1111 00 [00001000] - -
[Diagnoseinterface für Datenbus - kein Signal/Kommunikation]
Fault Priority: 6
Fault Frequency: 4
Reset counter: 60
Mileage: 317935 km
Date: 2023.11.06
Time: 12:37:19
13701424 - Function Restricted due to Missing Message(s)
[Steuergerät für Bordnetz - kein Signal/Kommunikation]
Fault Priority: 6
Fault Frequency: 4
Reset counter: 60
Mileage: 317935 km
Date: 2023.11.06
Time: 12:37:19
13701936 - Function Restriction due to Faults in Other Modules
U1113 00 [00001001] - -
[Steuergerät für Bordnetz - bitte Fehlerspeicher auslesen]
Fault Priority: 6
Fault Frequency: 11
Reset counter: 20
Date: 2000.00.00
Time: 00:00:00
13701456 - Function Restricted due to Missing Message(s)
U1111 00 [00001001] - -
[Steuergerät im Schalttafeleinsatz - kein Signal/Kommunikation]
Fault Priority: 6
Fault Frequency: 19
Reset counter: 20
Mileage: 317935 km
Date: 2023.11.06
Time: 12:37:19
9481748 - High Pressure Sensor
B10AE 14 [00001000] - Open or Short to Ground
Fault Priority: 2
Fault Frequency: 1
Reset counter: 30
Mileage: 317935 km
Date: 2023.11.06
Time: 12:11:50
Part No SW: 7E0 937 090 C HW: 7E0 937 090 C
Revision: B9082001 Serial number: 4000 322171666
Coding: 20A4303A0A21203100280F712C2B8451C284668F60855160320400030800
Shop #: WSC 02739 022 156892
VCID: 2B02F213330957F2AA1-807E
Subsystem 1 - Part No SW: 7E0 959 801 K HW: 7E0 959 801 K Labels: 7E0-959-80X-V2.CLB
Component: J386__TSG_FT 003 8653
Serial number: KU0KU005081442171296
Coding: 1000B0
Subsystem 2 - Part No SW: 7E0 959 802 K HW: 7E0 959 802 K Labels: 7E0-959-80X-V2.CLB
Component: J387__TSG_BT 003 8653
Serial number: KU0KU018081442302458
Coding: 0000A0
Subsystem 3 - Part No: 7E1 951 172
Component: DWA-Sensor 00 001 0104
Subsystem 4 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Subsystem 5 - Part No: 7E1 951 172
Subsystem 6 - Part No SW: 3C8 959 537 D HW: 3C8 959 537 D Labels: 3C8-959-537.CLB
Component: E221__MFL-TK6 H06 0022
Serial number: 70000000000000124169
Coding: E20000
8 Faults Found:
00886 - Turn Signal Switch (E2)
008 - Implausible Signal
Fault Status: 01101000
Fault Priority: 2
Fault Frequency: 6
Reset counter: 20
Time Indication: 0
00077 - Windshield Wiper Stop Switch (F229)
004 - No Signal/Communication
Fault Status: 01100100
Fault Priority: 3
Fault Frequency: 2
Reset counter: 20
Time Indication: 0
000 - -
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
02745 - Bulb for Daytime Running Light; Left
010 - Open or Short to Plus
Fault Status: 01101010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 20
Time Indication: 0
02746 - Bulb for Daytime Running Light; Right
Fault Priority: 3
Fault Frequency: 1
Reset counter: 20
Time Indication: 0
01504 - Bulb for License-Plate Light (X)
Fault Priority: 3
Fault Frequency: 1
Reset counter: 20
Time Indication: 0
02195 - Dimmer Switch Instrument Panel & Switch Lighting (E20)
Fault Priority: 3
Fault Frequency: 3
Reset counter: 20
Time Indication: 0
04194 - Vehicle Status with Under-Voltage
Fault Status: 01100010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 20
Time Indication: 0
Address 10: Park/Steer Assist (J446) Labels:| 7E0-919-475.clb
Part No SW: 7E0 919 475 K HW: 1Q0 919 475
Component: PARKHILFE 4K H03 0106
Revision: -------- Serial number: 32901415406603
Coding: 118001
Shop #: WSC 02739 790 50316
ASAM Dataset: EV_VW75XParkAssis4K 001004
ROD: EV_VW75XParkAssis4K_001.rod
VCID: 3A2CC757CCD3FE7A217-806E
4 Faults Found:
1080083 - Rear Parking Aid Sensor(s)
B107B 13 [00001000] - Open Circuit
Fault Priority: 3
Fault Frequency: 1
Reset counter: 245
Mileage: 317935 km
Date: 2023.11.05
Time: 18:39:26
13635840 - Supply voltage
[Versorgungsspannung - zu niedrig]
Fault Priority: 6
Fault Frequency: 1
Reset counter: 59
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
13893632 - Function Restricted due to Insufficient Voltage
U1400 00 [00001000] - -
[Funktionseinschränkung durch Unterspannung - unterer Grenzwert unterschritten]
Fault Priority: 6
Fault Frequency: 1
Reset counter: 59
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
12664832 - Function Restricted due to Missing Message(s)
[Steuergerät für Gateway - kein Signal/keine Kommunikation]
Fault Priority: 6
Fault Frequency: 5
Reset counter: 60
Mileage: 317935 km
Date: 2023.11.06
Time: 12:37:19
Address 13: Auto Dist. Reg
Cannot be reached
Part No SW: 7E0 959 655 B HW: 7E0 959 655 B
Component: VW10Airbag009 H07 0013
Revision: -------- Serial number: 003HL00S3ZU8 Dataset Number: 7E0003v____ 0471
Coding: 000000000000000000000000000000003039
Shop #: WSC 02734 790 50316
ROD: EV_AirbaVW10BPAVN750.rod
VCID: 3536D46BE5CD1102CC5-8060
Part No SW: 7E0 920 970 N HW: 7E0 920 970 N
Component: KOMBI H03 0805
Coding: 460A00
4 Faults Found:
12605440 - Databus
U1201 00 [00001000] - No Communications
Fault Priority: 6
Fault Frequency: 1
Reset counter: 60
Mileage: 317935 km
Date: 2023.11.19
Time: 03:41:27
[Steuergerät für BCM / Bordnetz / el. ZE: keine Kommunikation]
Fault Priority: 6
Fault Frequency: 4
Reset counter: 20
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
[Supply voltage too low]
Fault Priority: 6
Fault Frequency: 1
Reset counter: 40
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
13654640 - Function Restricted due to Missing Message(s)
[Steuergerät für Abstandsdistanzregelung Low: keine Kommunikation]
Fault Priority: 6
Fault Frequency: 1
Reset counter: 20
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
Part No SW: 7E0 909 901 HW: 7E0 937 090 C
Revision: B9082001
Coding: 042305
VCID: 68884D1FE27FBCEA873-803C
7 Faults Found:
000 - -
Fault Priority: 2
Fault Frequency: 6
Reset counter: 255
Mileage: 153604 km
Time Indication: 0
Date: 2015.04.13
Time: 13:25:41
00470 - Company Comfort Databus in Single Wire
012 - Electrical Fault in Circuit - Intermittent
Fault Status: 00101100
Fault Priority: 2
Fault Frequency: 2
Reset counter: 60
Time Indication: 0
01336 - Company Data Bus for Comfort System
Fault Priority: 2
Fault Frequency: 15
Reset counter: 59
Time Indication: 0
01319 - Control Module for Distance Control (J428)
Fault Priority: 2
Fault Frequency: 2
Reset counter: 19
Time Indication: 0
00381 - Databus Instrument Cluster
Fault Priority: 2
Fault Frequency: 55
Reset counter: 20
Time Indication: 0
03406 - Control Module for Battery Monitoring
Fault Priority: 2
Fault Frequency: 7
Reset counter: 60
Time Indication: 0
03158 - Control Module for Information Electronics 1 (J794)
Fault Priority: 2
Fault Frequency: 1
Reset counter: 19
Time Indication: 0
Component: IMMO H03 0805
Serial number:
VCID: 6A8C3717FCF38EFA917-803E
1 Fault Found:
13762816 - Databus
Fault Priority: 6
Fault Frequency: 1
Reset counter: 60
Mileage: 317935 km
Date: 2023.11.19
Time: 03:41:27
Address 5F: Information Electr.
Cannot be reached
Address 61: Battery Regul. (J840) Labels:. 1K0-907-534.clb
Part No SW: 7E0 907 534 HW: 7E0 937 090 C
Component: Batt.regelung H82 0752
Coding: 030B7A73
Shop #: WSC 02739 790 00000
3 Faults Found:
00458 - Control Module for Battery Monitoring (J367)
Fault Priority: 2
Fault Frequency: 1
Revision: 00H43001
5 Faults Found:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 246
Mileage: 315425 km
Time Indication: 0
Date: 2017.10.10
Time: 09:37:59
Count: 16384
Count: 1
Count: 8194
Count: 762
Fault Priority: 2
Fault Frequency: 1
Reset counter: 246
Mileage: 315425 km
Time Indication: 0
Date: 2017.10.10
Time: 09:37:60
Count: 16384
Count: 257
Count: 8193
Count: 762
Fault Priority: 2
Fault Frequency: 1
Reset counter: 245
Mileage: 317935 km
Time Indication: 0
Date: 2018.03.29
Time: 12:05:30
Count: 16384
Count: 1
Count: 8214
Count: 764
Fault Priority: 1
Fault Frequency: 1
Reset counter: 19
Time Indication: 0
Count: 16512
Count: 2305
Count: 128
Count: 762
Fault Priority: 2
Fault Frequency: 1
Reset counter: 0
Time Indication: 0
Count: 16448
Count: 1
Count: 8233
Count: 764
Coding: 01
3 Faults Found:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 30
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
332660 - Databus
Fault Priority: 6
Fault Frequency: 5
Reset counter: 60
117060 - Databus
Fault Priority: 6
Fault Frequency: 5
Reset counter: 60
Revision: 00001012
Coding: 0000000002
5 Faults Found:
Fault Priority: 6
Fault Frequency: 4
Reset counter: 60
Mileage: 317935 km
Date: 2023.11.06
Time: 12:37:19
Fault Priority: 6
Fault Frequency: 4
Reset counter: 60
Mileage: 317935 km
Date: 2023.11.06
Time: 12:37:19
Fault Priority: 6
Fault Frequency: 11
Reset counter: 20
Date: 2000.00.00
Time: 00:00:00
Fault Priority: 6
Fault Frequency: 19
Reset counter: 20
Mileage: 317935 km
Date: 2023.11.06
Time: 12:37:19
Fault Priority: 2
Fault Frequency: 1
Reset counter: 30
Mileage: 317935 km
Date: 2023.11.06
Time: 12:11:50
Coding: 1000B0
Coding: 0000A0
Coding: E20000
8 Faults Found:
Fault Priority: 2
Fault Frequency: 6
Reset counter: 20
Time Indication: 0
Fault Priority: 3
Fault Frequency: 2
Reset counter: 20
Time Indication: 0
000 - -
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
Fault Priority: 3
Fault Frequency: 1
Reset counter: 20
Time Indication: 0
Fault Priority: 3
Fault Frequency: 1
Reset counter: 20
Time Indication: 0
Fault Priority: 3
Fault Frequency: 1
Reset counter: 20
Time Indication: 0
Fault Priority: 3
Fault Frequency: 3
Reset counter: 20
Time Indication: 0
Fault Priority: 3
Fault Frequency: 1
Reset counter: 20
Time Indication: 0
Coding: 118001
4 Faults Found:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 245
Mileage: 317935 km
Date: 2023.11.05
Time: 18:39:26
Fault Priority: 6
Fault Frequency: 1
Reset counter: 59
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
Fault Priority: 6
Fault Frequency: 1
Reset counter: 59
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
Fault Priority: 6
Fault Frequency: 5
Reset counter: 60
Mileage: 317935 km
Date: 2023.11.06
Time: 12:37:19
Cannot be reached
Coding: 460A00
4 Faults Found:
12605440 - Databus
Fault Priority: 6
Fault Frequency: 1
Reset counter: 60
Mileage: 317935 km
Date: 2023.11.19
Time: 03:41:27
Fault Priority: 6
Fault Frequency: 4
Reset counter: 20
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
Fault Priority: 6
Fault Frequency: 1
Reset counter: 40
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
Fault Priority: 6
Fault Frequency: 1
Reset counter: 20
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
Revision: B9082001
Coding: 042305
7 Faults Found:
000 - -
Fault Priority: 2
Fault Frequency: 6
Reset counter: 255
Mileage: 153604 km
Time Indication: 0
Date: 2015.04.13
Time: 13:25:41
Fault Priority: 2
Fault Frequency: 2
Reset counter: 60
Time Indication: 0
Fault Priority: 2
Fault Frequency: 15
Reset counter: 59
Time Indication: 0
Fault Priority: 2
Fault Frequency: 2
Reset counter: 19
Time Indication: 0
Fault Priority: 2
Fault Frequency: 55
Reset counter: 20
Time Indication: 0
Fault Priority: 2
Fault Frequency: 7
Reset counter: 60
Time Indication: 0
Fault Priority: 2
Fault Frequency: 1
Reset counter: 19
Time Indication: 0
Serial number:
1 Fault Found:
13762816 - Databus
Fault Priority: 6
Fault Frequency: 1
Reset counter: 60
Mileage: 317935 km
Date: 2023.11.19
Time: 03:41:27
Cannot be reached
Coding: 030B7A73
3 Faults Found:
Fault Priority: 2
Fault Frequency: 1
- Drives: T5
The first link I got sent to follow. Don’t really understand what I needed to do with that the one with the VW Polo so I haven’t done that but the second link with wiring the headlights and running new cables. Keep the main beam on that’s all done. Thanks 4 the help
You deserve an award for the Autoscan with the most faults in the forum history.
It is obvious and evident that you have omitted some instructions from the links indicated in previous posts for the BCM replacement.
1- Please, now that you have 10 posts on the forum, post a complete Autoscan from when you had the BCM 087 installed with the halogen headlights and 'everything worked correctly', that is, without having touched the BCM coding. Thank you so much.
2- Have you correctly installed the new CAN lines (BCM-instrument cluster)? The old CAN lines that you remove from the instrument cluster connector 'Low and High' must be isolated 'separately' (they are still live lines for many other units).
3- Please read the ross-tech instructions for BCM replacement again, especially about transferring BCM coding, GW coding and GW installation list. Thanks a lot.
After this we start with the plan for debugging.
Note: Before doing any new Autoscan, you must 'Clear All DTCs' to avoid intermittent fault readings.
Note2: Please check the battery status, or use a power supply while using the diagnostic tool, or keep the engine running during the diagnostic process.
- Drives: T5
tell me about lol I haven’t done the instrument cluster cam lines. I’ve just been watching a video on YouTube in a polo. Will that be the same for the T5 .1.
Am not right good with technology sorry for being a pain
viewtopic.php?p=528735#p528735, https://drive.google.com/file/d/0B2nv91 ... 0ozRF3ht-w
Don't worry... we will solve everything step by step.
- Drives: T5
Do I do all of that or just the instrument cluster bit thanks
I don't know what you've already done, do just what you need.
The new CAN lines are essential in this retrofitting.
- Drives: T5
I have just done the instrument cluster canbus wires to night previously I have done the wires to keep the main beam on and fitted the the new bcm. On the link u sent it shows the wiring for the instrument cluster that I’ve just done 2 night and then there’s some more wiring that it’s on the light switch do I need to do that as well
- Drives: T5
You’re an absolute star I’ll get this done over the next couple of days and get back to you. Thank you
- Drives: T5
morning sorry i haven't been back in touch i lost my head with theses lights wise i hadn't started them..
so just i recap on what i have done. i have put the t6 bcm i have coped the code from the old one using coding helper and pasted in to the new one and coded the keys i have done the wiring to keep the headlights on with the main beam done the can lines to the instrument cluster and the t17/t6 wiring to the bcm but still no luck
so the head light works as should / main beam works when pulled back but intermittently works when push forward. i'm assuming i need a t6 stalk to fix this. i still don't have side lights working and now the drl have stoped working when i did the the wiring to the t17 connector. and i have lost number plate lights to i did rear some wear on hear about the drl wires going 2 different pins i have got the in pin 5 and 6 on the white B plug as instructed off kuftec
any help would be grateful or if there is anyone out there that i can just pay and they can come and do it for me would be much appreciated hahahah
ill put the latest scan up to thanks
- Drives: T5
Saturday,25,November,2023,09:55:59:50810
VCDS Version: 23.11.0.0 (x64) HEX-V2 CB: 0.4643.4
Data version: 20231027 DS351.0
www.Ross-Tech.com
VIN: WV1ZZZ7HZFH036427 License Plate:
Scan: 01 03 04 08 09 10 15 17 19 25 56 69 77 0B
25-Immobilizer -- Status: Malfunction 0010
5 Faults Found:
4708 - No Communications with HVAC Control Module (J301)
U0164 00 [00100000] - -
Intermittent - Not Confirmed - Tested Since Memory Clear
Fault Priority: 6
Fault Frequency: 1
Mileage: 317935 km
Date: 2000.00.00
Time: 00:00:00
Engine RPM: 0.00 /min
Normed load value: 0.0 %
Vehicle speed: 0 km/h
Coolant temperature: 19 °C
Intake air temperature: 14 °C
Ambient air pressure: 1010 mbar
Voltage terminal 30: 12.160 V
Unlearning counter according OBD: 39
Limitation: accelerator pedal: 92.4 Nm
CAN status - engine control module-Bits 0-7: 0
Cruise Control System (CCS): status-Bits 0-7: 200
CAN status - transmission control module-Bits 0-7: 0
CAN status - brake control module 1-Bits 0-7: 0
CAN status - brake control module 2-Bits 0-7: 0
selected gear-Bits 0-7: 0
4715 - No Communication with Instrument Cluster
U0155 00 [00100000] - -
[Lost Communication WithInstrument Panel Cluster (IPC) Control Module]
Fault Priority: 6
Fault Frequency: 1
Mileage: 317935 km
Date: 2000.00.00
Time: 00:00:00
Cruise Control System (CCS): status-Bits 0-7: 8
4717 - Body Control Module (Central Electric)
U0140 00 [00100000] - No Communications
Fault Priority: 6
Fault Frequency: 1
Mileage: 317935 km
Date: 2000.00.00
Time: 00:00:00
4719 - No Communication with Diagnostic Gateway
U0146 00 [00100000] - -
Fault Priority: 6
Fault Frequency: 1
Mileage: 317935 km
Date: 2000.00.00
Time: 00:00:00
5523 - Engine Start Blocked by Immobilizer
P1570 00 [00100000] - -
Fault Priority: 2
Fault Frequency: 1
Mileage: 317935 km
Date: 2000.00.00
Time: 00:00:00
Engine RPM: 934.50 /min
Intake air temperature: 15 °C
Voltage terminal 30: 11.680 V
Immobilizer snapshot A-Sia Error Snap A: 14 00 0A
Immobilizer snapshot B-Sia Error Snap B: 02 00 00
Readiness: 0 0 0 0 X
Revision: 00H43001
8 Faults Found:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 246
Mileage: 315425 km
Time Indication: 0
Date: 2017.10.10
Time: 09:37:59
Count: 16384
Count: 1
Count: 8194
Count: 762
Fault Priority: 2
Fault Frequency: 1
Reset counter: 246
Mileage: 315425 km
Time Indication: 0
Date: 2017.10.10
Time: 09:37:60
Count: 16384
Count: 257
Count: 8193
Count: 762
Fault Priority: 2
Fault Frequency: 1
Reset counter: 245
Mileage: 317935 km
Time Indication: 0
Date: 2018.03.29
Time: 12:05:30
Count: 16384
Count: 1
Count: 8214
Count: 764
Fault Priority: 1
Fault Frequency: 1
Reset counter: 19
Time Indication: 0
Count: 16512
Count: 2305
Count: 128
Count: 762
Fault Priority: 2
Fault Frequency: 1
Reset counter: 0
Time Indication: 0
Count: 16448
Count: 1
Count: 8207
Count: 764
01317 - Control Module in Instrument Cluster (J285)
Fault Priority: 3
Fault Frequency: 1
Reset counter: 245
Time Indication: 0
Count: 16384
Count: 1
Count: 8242
Count: 764
03391 - Coding Not Possible
000 - - - Intermittent
Fault Status: 00100000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 245
Time Indication: 0
Count: 16384
Count: 1
Count: 8254
Count: 764
00474 - Control Module for Immobilizer
Fault Priority: 2
Fault Frequency: 1
Reset counter: 245
Time Indication: 0
Count: 16384
Count: 1
Count: 8211
Count: 764
Coding: 01
4 Faults Found:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 30
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
332644 - Databus
Fault Priority: 6
Fault Frequency: 2
Reset counter: 60
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
Voltage terminal 15: 10.80 V
Voltage terminal 30: 11.15 V
Entprellzeit: 5000 ms
332660 - Databus
Fault Priority: 6
Fault Frequency: 6
Reset counter: 60
117060 - Databus
Fault Priority: 6
Fault Frequency: 6
Reset counter: 60
Revision: 00001012
Coding: 0000000002
5 Faults Found:
Fault Priority: 6
Fault Frequency: 4
Reset counter: 60
Mileage: 317935 km
Date: 2023.11.06
Time: 12:37:19
Fault Priority: 6
Fault Frequency: 4
Reset counter: 60
Mileage: 317935 km
Date: 2023.11.06
Time: 12:37:19
U1113 00 [00001000] - -
Fault Priority: 6
Fault Frequency: 16
Reset counter: 61
Date: 2000.00.00
Time: 00:00:00
Fault Priority: 6
Fault Frequency: 20
Reset counter: 60
Mileage: 317935 km
Date: 2023.11.06
Time: 12:37:19
Fault Priority: 2
Fault Frequency: 1
Reset counter: 30
Mileage: 317935 km
Date: 2023.11.06
Time: 12:11:50
Coding: A0A4303A0A613431922848116C2B8C550080672F60850000320000010800
Coding: 1000B0
Coding: 0000A0
Coding: E20000
15 Faults Found:
Fault Priority: 2
Fault Frequency: 60
Reset counter: 21
Time Indication: 0
03432 - Activation of Right Parking Light
011 - Open Circuit - Intermittent
Fault Status: 00101011
Fault Priority: 2
Fault Frequency: 1
Reset counter: 60
Mileage: 317935 km
Time Indication: 0
Date: 2018.04.14
Time: 17:45:49
03435 - Terminal 30 for Interior Light and Parking Light
Fault Priority: 3
Fault Frequency: 1
Reset counter: 60
Mileage: 317935 km
Time Indication: 0
Date: 2018.04.14
Time: 17:45:47
03303 - Response Closing Status of Rear Left Door
Fault Status: 00101000
Fault Priority: 2
Fault Frequency: 4
Reset counter: 61
Mileage: 317935 km
Time Indication: 0
Date: 2018.04.12
Time: 00:19:19
03396 - Supply voltage terminal 30 for central locking
Fault Priority: 2
Fault Frequency: 1
Reset counter: 60
Mileage: 317935 km
Time Indication: 0
Date: 2018.04.14
Time: 17:45:47
00920 - Heated Outside Mirrors; Driver Side (Z4) / Passenger Side (Z5)
Fault Priority: 3
Fault Frequency: 1
Reset counter: 60
Mileage: 317935 km
Time Indication: 0
Date: 2018.04.14
Time: 17:45:48
Fault Priority: 3
Fault Frequency: 9
Reset counter: 21
Time Indication: 0
Fault Priority: 2
Fault Frequency: 11
Reset counter: 255
Time Indication: 0
03591 - Control Circuit for Horn
Fault Priority: 3
Fault Frequency: 1
Reset counter: 60
Mileage: 317935 km
Time Indication: 0
Date: 2018.04.14
Time: 17:45:48
01516 - Terminal 30; Left
Fault Priority: 3
Fault Frequency: 1
Reset counter: 60
Mileage: 0 km
Time Indication: 0
Date: 2018.04.14
Time: 17:45:46
Fault Priority: 3
Fault Frequency: 1
Reset counter: 20
Time Indication: 0
Fault Priority: 3
Fault Frequency: 1
Reset counter: 20
Time Indication: 0
Fault Priority: 3
Fault Frequency: 1
Reset counter: 20
Time Indication: 0
Fault Priority: 3
Fault Frequency: 16
Reset counter: 61
Time Indication: 0
Fault Priority: 3
Fault Frequency: 1
Reset counter: 60
Time Indication: 0
Coding: 118001
5 Faults Found:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 245
Mileage: 317935 km
Date: 2023.11.05
Time: 18:39:26
Fault Priority: 6
Fault Frequency: 1
Reset counter: 59
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
Fault Priority: 6
Fault Frequency: 1
Reset counter: 59
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
12670208 - Function Restricted due to Missing Message(s)
[Steuergerät für Schalttafeleinsatz-J285 - kein Signal/keine Kommunikation]
Fault Priority: 6
Fault Frequency: 1
Reset counter: 60
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
Fault Priority: 6
Fault Frequency: 6
Reset counter: 60
Mileage: 317935 km
Date: 2023.11.06
Time: 12:37:19
2 Faults Found:
12670208 - Databus
U1122 00 [00001000] - Implausible Message
[Kombi1-3 Time Out Error]
Fault Priority: 6
Fault Frequency: 2
Reset counter: 60
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
12674816 - Databus
[VIN Time Out Error]
Fault Priority: 6
Fault Frequency: 2
Reset counter: 60
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
Coding: 460A00
3 Faults Found:
12605440 - Databus
Fault Priority: 6
Fault Frequency: 3
Reset counter: 60
Mileage: 317935 km
Date: 2023.11.19
Time: 03:41:27
Fault Priority: 6
Fault Frequency: 4
Reset counter: 40
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
Fault Priority: 6
Fault Frequency: 1
Reset counter: 40
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
Revision: B9082001
Coding: 042305
2 Faults Found:
000 - -
Fault Priority: 2
Fault Frequency: 5
Reset counter: 255
Mileage: 317935 km
Time Indication: 0
Date: 2018.04.12
Time: 00:08:14
Fault Priority: 2
Fault Frequency: 5
Reset counter: 61
Mileage: 0 km
Time Indication: 0
Date: 2018.04.12
Time: 00:21:10
Serial number:
1 Fault Found:
13762816 - Databus
Fault Priority: 6
Fault Frequency: 3
Reset counter: 60
Mileage: 317935 km
Date: 2023.11.19
Time: 03:41:27
Address 56: Radio
Cannot be reached
Address 69: Trailer (J345) Labels:. 1K0-907-383-V2.clb
Part No SW: 1K0 907 383 F HW: 1K0 907 383 F
Component: ConWysTrailer H07 0100
Revision: 3A001001 Serial number: 00000132425721
Coding: 0100000100000000
Shop #: WSC 00007 223 174336
VCID: 3038E57F1A2F342A9F3-8064
Address 77: Telephone (J412) Labels:| 7P6-035-730.clb
Part No SW: 7P6 035 730 M HW: 7P6 035 730 M
Component: TELEFON H16 4217
Revision: 1B001001 Serial number: 00007666502043 Dataset Number: 7P6035730M 0001
Coding: 0A01010000010101
ASAM Dataset: EV_UHVNA 002720
ROD: EV_UHVNA_002.rod
VCID: 3C20C14FC6E7C04A33B-8068
8 Faults Found:
9457427 - Left audio channel for speech/telephone
B104F 13 [00001001] - Short to GND
Fault Priority: 4
Fault Frequency: 1
Reset counter: 206
Mileage: 315425 km
Date: 2023.05.20
Time: 09:51:10
9457171 - Right audio channel for speech/telephone
B104E 13 [00001001] - Short to GND
Fault Priority: 4
Fault Frequency: 1
Reset counter: 206
Mileage: 315425 km
Date: 2023.05.20
Time: 09:51:10
12664832 - Body Control Module (Central Electric)
U0140 00 [00001000] - No Communications
Fault Priority: 6
Fault Frequency: 4
Reset counter: 30
Mileage: 317935 km
Date: 2023.11.06
Time: 12:37:19
12670208 - No Communication with Instrument Cluster
U0155 00 [00001000] - -
[Kombiinstument: keine Kommunikation]
Fault Priority: 6
Fault Frequency: 4
Reset counter: 30
12718592 - Steering Column Control Module
U0212 00 [00001000] - No Communications
Fault Priority: 6
Fault Frequency: 4
Reset counter: 30
Mileage: 317935 km
Date: 2023.11.06
Time: 12:37:19
13633792 - No Communication with Diagnostic Gateway
U0146 00 [00001000] - -
[Gateway: keine Kommunikation]
Fault Priority: 6
Fault Frequency: 31
Reset counter: 30
Mileage: 315689 km
Date: 2023.07.06
Time: 08:37:50
[Terminal 30: lower limit value not reached]
Fault Priority: 3
Fault Frequency: 1
Reset counter: 30
Fault Priority: 6
Fault Frequency: 1
Reset counter: 30
End----------(Elapsed Time: 01:40, VBatt start/end: 14.0V/14.1V)-----------
www.Ross-Tech.com
5 Faults Found:
Fault Priority: 6
Fault Frequency: 1
Mileage: 317935 km
Date: 2000.00.00
Time: 00:00:00
Fault Priority: 6
Fault Frequency: 1
Mileage: 317935 km
Date: 2000.00.00
Time: 00:00:00
Fault Priority: 6
Fault Frequency: 1
Mileage: 317935 km
Date: 2000.00.00
Time: 00:00:00
Fault Priority: 6
Fault Frequency: 1
Mileage: 317935 km
Date: 2000.00.00
Time: 00:00:00
Fault Priority: 2
Fault Frequency: 1
Mileage: 317935 km
Date: 2000.00.00
Time: 00:00:00
Revision: 00H43001
8 Faults Found:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 246
Mileage: 315425 km
Time Indication: 0
Date: 2017.10.10
Time: 09:37:59
Count: 16384
Count: 1
Count: 8194
Count: 762
Fault Priority: 2
Fault Frequency: 1
Reset counter: 246
Mileage: 315425 km
Time Indication: 0
Date: 2017.10.10
Time: 09:37:60
Count: 16384
Count: 257
Count: 8193
Count: 762
Fault Priority: 2
Fault Frequency: 1
Reset counter: 245
Mileage: 317935 km
Time Indication: 0
Date: 2018.03.29
Time: 12:05:30
Count: 16384
Count: 1
Count: 8214
Count: 764
Fault Priority: 1
Fault Frequency: 1
Reset counter: 19
Time Indication: 0
Count: 16512
Count: 2305
Count: 128
Count: 762
Fault Priority: 2
Fault Frequency: 1
Reset counter: 0
Time Indication: 0
Count: 16448
Count: 1
Count: 8207
Count: 764
Fault Priority: 3
Fault Frequency: 1
Reset counter: 245
Time Indication: 0
Count: 16384
Count: 1
Count: 8242
Count: 764
Fault Priority: 6
Fault Frequency: 1
Reset counter: 245
Time Indication: 0
Count: 16384
Count: 1
Count: 8254
Count: 764
Fault Priority: 2
Fault Frequency: 1
Reset counter: 245
Time Indication: 0
Count: 16384
Count: 1
Count: 8211
Count: 764
Coding: 01
4 Faults Found:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 30
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
332644 - Databus
Fault Priority: 6
Fault Frequency: 2
Reset counter: 60
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
332660 - Databus
Fault Priority: 6
Fault Frequency: 6
Reset counter: 60
117060 - Databus
Fault Priority: 6
Fault Frequency: 6
Reset counter: 60
Revision: 00001012
Coding: 0000000002
5 Faults Found:
Fault Priority: 6
Fault Frequency: 4
Reset counter: 60
Mileage: 317935 km
Date: 2023.11.06
Time: 12:37:19
Fault Priority: 6
Fault Frequency: 4
Reset counter: 60
Mileage: 317935 km
Date: 2023.11.06
Time: 12:37:19
Fault Priority: 6
Fault Frequency: 16
Reset counter: 61
Date: 2000.00.00
Time: 00:00:00
Fault Priority: 6
Fault Frequency: 20
Reset counter: 60
Mileage: 317935 km
Date: 2023.11.06
Time: 12:37:19
Fault Priority: 2
Fault Frequency: 1
Reset counter: 30
Mileage: 317935 km
Date: 2023.11.06
Time: 12:11:50
Coding: 1000B0
Coding: 0000A0
Coding: E20000
15 Faults Found:
Fault Priority: 2
Fault Frequency: 60
Reset counter: 21
Time Indication: 0
Fault Priority: 2
Fault Frequency: 1
Reset counter: 60
Mileage: 317935 km
Time Indication: 0
Date: 2018.04.14
Time: 17:45:49
Fault Priority: 3
Fault Frequency: 1
Reset counter: 60
Mileage: 317935 km
Time Indication: 0
Date: 2018.04.14
Time: 17:45:47
Fault Priority: 2
Fault Frequency: 4
Reset counter: 61
Mileage: 317935 km
Time Indication: 0
Date: 2018.04.12
Time: 00:19:19
Fault Priority: 2
Fault Frequency: 1
Reset counter: 60
Mileage: 317935 km
Time Indication: 0
Date: 2018.04.14
Time: 17:45:47
Fault Priority: 3
Fault Frequency: 1
Reset counter: 60
Mileage: 317935 km
Time Indication: 0
Date: 2018.04.14
Time: 17:45:48
Fault Priority: 3
Fault Frequency: 9
Reset counter: 21
Time Indication: 0
Fault Priority: 2
Fault Frequency: 11
Reset counter: 255
Time Indication: 0
Fault Priority: 3
Fault Frequency: 1
Reset counter: 60
Mileage: 317935 km
Time Indication: 0
Date: 2018.04.14
Time: 17:45:48
Fault Priority: 3
Fault Frequency: 1
Reset counter: 60
Mileage: 0 km
Time Indication: 0
Date: 2018.04.14
Time: 17:45:46
Fault Priority: 3
Fault Frequency: 1
Reset counter: 20
Time Indication: 0
Fault Priority: 3
Fault Frequency: 1
Reset counter: 20
Time Indication: 0
Fault Priority: 3
Fault Frequency: 1
Reset counter: 20
Time Indication: 0
Fault Priority: 3
Fault Frequency: 16
Reset counter: 61
Time Indication: 0
Fault Priority: 3
Fault Frequency: 1
Reset counter: 60
Time Indication: 0
Coding: 118001
5 Faults Found:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 245
Mileage: 317935 km
Date: 2023.11.05
Time: 18:39:26
Fault Priority: 6
Fault Frequency: 1
Reset counter: 59
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
Fault Priority: 6
Fault Frequency: 1
Reset counter: 59
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
Fault Priority: 6
Fault Frequency: 1
Reset counter: 60
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
Fault Priority: 6
Fault Frequency: 6
Reset counter: 60
Mileage: 317935 km
Date: 2023.11.06
Time: 12:37:19
2 Faults Found:
12670208 - Databus
Fault Priority: 6
Fault Frequency: 2
Reset counter: 60
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
12674816 - Databus
Fault Priority: 6
Fault Frequency: 2
Reset counter: 60
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
Coding: 460A00
3 Faults Found:
12605440 - Databus
Fault Priority: 6
Fault Frequency: 3
Reset counter: 60
Mileage: 317935 km
Date: 2023.11.19
Time: 03:41:27
Fault Priority: 6
Fault Frequency: 4
Reset counter: 40
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
Fault Priority: 6
Fault Frequency: 1
Reset counter: 40
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
Revision: B9082001
Coding: 042305
2 Faults Found:
000 - -
Fault Priority: 2
Fault Frequency: 5
Reset counter: 255
Mileage: 317935 km
Time Indication: 0
Date: 2018.04.12
Time: 00:08:14
Fault Priority: 2
Fault Frequency: 5
Reset counter: 61
Mileage: 0 km
Time Indication: 0
Date: 2018.04.12
Time: 00:21:10
Serial number:
1 Fault Found:
13762816 - Databus
Fault Priority: 6
Fault Frequency: 3
Reset counter: 60
Mileage: 317935 km
Date: 2023.11.19
Time: 03:41:27
Address 56: Radio
Cannot be reached
8 Faults Found:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 206
Mileage: 315425 km
Date: 2023.05.20
Time: 09:51:10
Fault Priority: 4
Fault Frequency: 1
Reset counter: 206
Mileage: 315425 km
Date: 2023.05.20
Time: 09:51:10
Fault Priority: 6
Fault Frequency: 4
Reset counter: 30
Mileage: 317935 km
Date: 2023.11.06
Time: 12:37:19
Fault Priority: 6
Fault Frequency: 4
Reset counter: 30
Fault Priority: 6
Fault Frequency: 4
Reset counter: 30
Mileage: 317935 km
Date: 2023.11.06
Time: 12:37:19
Fault Priority: 6
Fault Frequency: 31
Reset counter: 30
Mileage: 315689 km
Date: 2023.07.06
Time: 08:37:50
Fault Priority: 3
Fault Frequency: 1
Reset counter: 30
Fault Priority: 6
Fault Frequency: 1
Reset counter: 30
