Vinayak185
- Drives: 6R Polo GT 1.6 TDI
Re: iichels Polo 6R 1.6TDI DSG --> OEM++ R-Line conversion
Ok sir. Thanks.
The BCM 7H0937090D is the predecessor to the 7E0 BCMs.
-The hardware is there, I mean the pins, but I don't know the architecture of the motherboard, I never had one of these 7H0...090'D' BCMs.
-The software structure appears to be the same as for the 7E0 BCMs.
FYI, the 7E0...090E file will work for all 7E0 BCMs.
IMP: Remember to make a read/backup of the Coding and Adaptations (VCDS), 'and' Parameters (VCP) before flashing (ODIS).
Very interesting information. Thanks ciclo!
Vinayak185
Yes ciclo sir. Govind Sharma doesn't have the 7E0 file .
- Platinum Member
I will send you a pm, im not sure if Im allowed here to post this kinds of links.Vinayak185 wrote: Thu Jan 11, 2024 10:36 am Yes ciclo sir. Govind Sharma doesn't have the 7E0 file .
If you have time to download check if the file is inside.
There are no restrictions to post links with information, only the responsibility that one acquires for posting it.
As incredible as it may seem, some clueless person always appears trying to insert the software for a BCM into an old Casio watch... and many worse things.
- Platinum Member
Well here it is is someone wants to explore it
Im not sure if the file that he is looking for is in but...
https://disk.yandex.com/d/FUicbZJY74PokQ
Password: From_VagVag_for_cartechnology.co.uk_for_mhhauto.com- iichel
As far as I'm concerned you can post the link, that's fine.
Here you can check the latest updates of VAG files and the list of available files (just for checking, not downloads).
https://vag-flashinfo.de/
I mention this so as not to have to make unnecessary downloads in case someone wants to check if the file we are talking about is available... which is not yet available based on the information in the link above.
Vinayak185
Ciclo sir, the file required isn't available in the list.
Please read the email I sent you to find out what alternatives you have, thank you.Vinayak185 wrote: Sat Jan 13, 2024 5:14 am Ciclo sir, the file required isn't available in the list.
- Platinum Member
https://file.io/0FCGPYOu5C1GI've found that file, I'm not sure if it's correct or the integrity of it. If anyone wants to explore it feel free
Scanned by virustotal
bb9caf89ed91f987851c7588d15278d3fe17e0fe3190aa3e694e4fcfe473ba85
7E0937090E_0772.zip
amer6R, many people have that file...
We are hijacking iichel's thread.
patil
Sorry for being late to read/ reply to the interesting thread. With little personal experience, I say 7E0 firmware is not compatible with 7H0 BCM. ODIS-E returns error.
I will be happy if I am proved wrong
Thanks for your little experience. Clarified issue.
As we already mentioned, Vinayak will have to purchase a new BCM 7E0 (with B suffix at least) if he wants to see his new electric seats in the diagnosis.
