Tyre Size for 14" Wheels
Petrified
Sponsor
Post by Petrified »
Anyone running 14" wheels can you tell me which tyre size you're using please??
I've got some BBS wheels from golf mk2 (6" wide?) and wanted to find the correct tyre size on a mk3.
Also can you tell me if you've lowered it and by how much.
Thanks!!
James.
metz
Moderator
Post by metz »
i have 6 x 14" 185 50 14 is the correct size mate..ive got continental contisports...like glue on the road, wet or dry.
lowered 40mm but going 60mm at front. no rubbing anywhere.
Petrified
Sponsor
Post by Petrified »
Cheers Mr. Just the info I was looking for,
:D
Gotsa find me some of those. How much did they cost?
I'll have a look around some websites now to give me an Idea.
I think I'm running on 60's or something at the moment, will have to check.
James.
Gareth_GT_Hatch
Post by Gareth_GT_Hatch »
Theres quite a few sizes you can use;
165/55/14
175/50/14
185/50/14
195/45/14
Theyre all about the right size, I think the closest two are the top and bottom ones in real life (as opposed to the tyre size calc) but obviously the bottom ones are slightly more favourable in terms of grip. You might also find that 195/45/14s are cheaper than 185/50s bizarrely
metz
Moderator
Post by metz »
My 185/50/14's were £40 a corner but i got a good deal off a mate.
But if you phone selecta tyres and enquire about some saying you have been quoted £40 each they will match it.
Nick at selecta tyres matched it for me.
Normal prices are around £50 a corner.
hardhitter
Moderator
Post by hardhitter »
I would say 185-50's are the better ones. Although theres a lot more choice in 195-45's plus they are up to a tenner cheaper for the same make and series tyre !
Petrified
Sponsor
Post by Petrified »
Sounds good. Can you go lower than 40mm with the 195/45 or 185/50 ?
Not that I'm planning to but I would be nice to see what can be done.
Also would you recommend any springs/shocks combo.
Cheers.
James.
metz
Moderator
Post by metz »
Well with my saloon the back wheels are in the arches at 40mm (on inspection they could go lower with no scrubbing) and the fronts are still high so its gunna be 60mm on them. I would say 70mm should be ok without scrubbing using 185 / 50 (not sure about other sizes as i havent used them.
Petrified
Sponsor
Post by Petrified »
Metz is my new wheel guru :mrgreen:
I may have some other questions when I get around to it.
Oh anyone know where I can get one Golf mk2 8v GTi14" BBS alloy from?
Had a look on ebay, incase anyone has one...
metz
Moderator
Post by metz »
Enquire with mr Petts (pettsy) hes the whore of the forum *wheels and otherthings from what he was saying over the weekend..dirty boy*
he may have one or more than likely have some grubby old paper with one for sale.
TheWhiteBeast
Post by TheWhiteBeast »
i have got 185/60/14
bstardchild
Moderator
Post by bstardchild »
TheWhiteBeast wrote:i have got 185/60/14
Speedo's gonna be dead sharp then :lol:
Petrified
Sponsor
Post by Petrified »
I have 185/60/14's on at the moment and the speedo is dead on,according to my RAII I havn't got it past 80 yet, well not with the RA connected.
I was quite supprised by how fast the GT can go before it starts shaking/falling apart.
I'm so used to driving with 6 gears now that I keep trying to change from 5th, luckily reverse is not in the place 6th would be on the polo. Not like the unfortunate Honda Jazz I had as a courtesy car :oops:
James.
heartagram
Post by heartagram »
I've got the same wheels as Metz and I run them with 195/45/14 tyres. They do me fine, hoping to go down 70mm without too much scrubbage! :roll:
jimbob
Post by jimbob »
I've got a set of 14" BBS alloys off a mk2 golf gti im running 185-50's and its not lowered but i get a bit of scrubbage on the front only a little bit thou, im pretty sure it rubs on the lip which the arch trim attaches to havent had chance to check yet.
