How to roll a auto
TrebleTA
Drives: 2021-22 GTI+
How to roll a auto
Post by TrebleTA »
So as some of you may remember, Ive just got a dsg polo, I've always had a manual before.
My question is. In my manual I could brop the handbrake and roll the car, its been so long, I can not think how to do it with the auto, with the car turned off. When I tried to move the lever, it would not, also then apon starting i could hear a rattle under the car, it stopped once I drove off. Next day I tried to move to leave again, knowing it would not move, just to see if I got the rattle and did, only notice when I did the above, got cars first mot etc Oct so will get them to look, but how do I roll the car?
MikeDO
Drives: GTI 2022 (white)
Re: How to roll a auto
Post by MikeDO »
I would have thought that you need to start the engine and put it in Neutral, then take the hand brake off.
TrebleTA
Post by TrebleTA »
There must be a way to roll the car, there is many reasons why, and supplying power to do so should not be needed. something simple on a manual.
P.s I'm guessing there be like a pin hole under the gear lever boot?
i think you can put it into neutral with the engine off and otherwise there is a red emergency pin below the shift boot you can pull
Casbantam
Drives: 1.2 TSI Match
Post by Casbantam »
TrebleTA wrote: Wed Aug 14, 2024 3:27 pm So as some of you may remember, Ive just got a dsg polo, I've always had a manual before.
Sorry, don't want to hijack the post but how are you finding the Dsg? I like you have always had manual and are considering Dsg. Are you enjoying the experience?
ad_182_uk
Post by ad_182_uk »
Turn ignition on but don't put foot on brake. Move lever to N, handbrake off, push.
