Polo 6R 1.2 GT Tsi RHD
Re: Polo 6R 1.2 GT Tsi RHD
Hi, to activate GRA-high you need to read your CBZB ECU and send the file to whoever is going to activate it.
You can send the file reading to patil, me or whoever you prefer, we will return the ECU file with the active GRA-high to you.
To find out if the direct TPMS is present on that BCM check the Installation List on the GW (19). Address 65 should be present and codable.
I don't know for sure, but I think there shouldn't be any problem. What is the manufacturing date of that BCM?
sshakthi123
- Drives: Vento 1.5 TDI MT and Polo 6R 1.2 Tsi Dsg
I’ll send you the ECU file separately.
Date of manufacturing of the BCM is 05.07.2019
And part number 7E0937089D and H84
Ok, send the ECU file to my email whenever you want.
Pretty sure that on that 2019 'H84' BCM you can activate the direct TPMS.
sshakthi123
Sure, I will have to reachout a person to read the file. I will share it with you asap.
It is great to know 089 bcm supports TPMS. Thanks for the support.
ECU file returned with GRA_High enable.
CCS OFF/ON to activate it or check that it works.
When stopped the mileage is displayed, as soon as you move the symbol is displayed on the MFD instead of the total mileage.
sshakthi123
Great!
Enjoy it, it's a good driving aid. (magislavik things
Regarding your email queries about the BCM Max adaptation, here are two links to installation tutorials:
- https://drive.google.com/file/d/1k3dhAA ... sp=sharing
- https://drive.google.com/file/d/0B2nv91 ... qdpZaURD-g
Note: If necessary, request permission to download the PDF, as soon as possible it will be shared with anyone who requests it.
It is convenient that you have the VW wiring diagrams for your vehicle to understand the previous tutorials.
Regarding your specific questions, in the pairs of wires of the same color, yellow or black it doesn't matter which, one is for +30 power supply of 'one side' of the BCM, and the other to feed the low beam when required. The other pair is the same.
Look at the size of the terminals and the position they occupy in each BCM connector.
There are 'thousands' of people wanting to do the BCM Max adaptation in PQ25, so I do not provide anyone with technical support for the BCM Max adaptation by email, please ask your questions here or search for information on the network/forums, there is a huge amount of information available.
I hope you understand. Thank you very much.
I subscribe to your thread.
sshakthi123
Thanks Ciclo.
I was able to crack the pin numbers of both the pairs (yellow and black) and all set.
I have prepared the wirings on my own and will be installing anytime soon.
While I am able to make the BCM max adaptation wiring, I would need your help on auto lights wiring.
Is it possible to make auto light wiring for me? as it is very difficult to source the couplers terminals locally.
Thanks much for the understanding and support!
Sorry, I stopped making wiring harnesses for others a long time ago. I'm sincerely sorry.
Mainly due to health issues and disheartening demotivation on the part of third parties in the exchange of goods in the unfortunate place where I was accidentally born.
(Inefficient transport companies, abusive taxes, etc.)
Are you talking about Spain ?ciclo wrote: Thu Oct 17, 2024 3:32 am Sorry, I stopped making wiring harnesses for others a long time ago. I'm sincerely sorry.
sshakthi123
Not an issue, thanks for all the support.ciclo wrote: Thu Oct 17, 2024 3:32 am Sorry, I stopped making wiring harnesses for others a long time ago. I'm sincerely sorry.![]()
One quick query on the BCM max adaptation wiring.
For BCM max CAN lines has to be routed from BCM to IC -> T73B54 and T73B57
I already connected PDC CAN lines with IC lines - terminal 28, 29
Still should I isolate the original CAN lines? or should I tap?
Connect the new CAN lines (wires) for the instrument cluster (IC<->BCM).
You must isolate any free contact terminals from the 'old' powertrain CAN lines/Inst Cluster, these lines are completely 'live' for other very important systems.
CAN powertrain wires are fine with PDC.
sshakthi123
Ok fine. I’ll do accordingly. Thanks!
sshakthi123
sshakthi123
Something is coming up,
Friday,01,November,2024,22:37:39:00006
VCDS Version: 18.2.0.3
Data version: 20180212 DS287.0
www.Ross-Tech.com
VIN: MEXL15600GT052162 License Plate: GT
Mileage: 66520km-41333mi Repair Order: BCM-Max
Chassis Type: 60-VW25 (7E0)
Scan: 01 02 03 04 08 09 10 15 17 19 25 44 5F
VIN: MEXL15600GT052162 Mileage: 66520km-41333miles
Address 01: Engine (J623-CBZB) Labels:. 03F-906-070-CBZ.clb
Part No SW: 03F 906 070 KC HW: 03F 907 309 AJ
Component: SIMOS10.22AH10 6270
Revision: --H10--- Serial number:
Coding: 00250056232400080000
Shop #: WSC 01234 785 00200
ASAM Dataset: EV_ECM12TFS02103F906070KC 004006
VCID: 6DD17FB6BC91F82CC3-8038
Readiness: 0110 0101
Part No SW: 0AM 300 065 N HW: 0AM 927 769 D
Component: GSG DSG AG7 431 6561
Revision: 00043014 Serial number: CU501505175568
Coding: 0000024
Shop #: WSC 30641 005 1048576
VCID: 3A7B84EA755F9F9416-806E
Address 03: ABS Brakes (J104) Labels: None
Part No SW: 6R0 907 379 CB HW: 6R0 907 379 AS
Component: ESP9.0i front H03 0003
Serial number: --------------
Coding: 62DD2463422803C24615246F4253C0800909
VCID: 000F36029B03054418-8054
Serial number: 10051504650266
Coding: 01
Shop #: WSC 00000 000 00000
ROD: EV_LWSKLOVW25X.rod
VCID: 7EF348FAE1F773B46A-802A
Part No SW: 6R0 907 044 Q HW: 6R0 907 044 Q
Component: Climatronic H12 0615
Revision: V0000000
VCID: 4189F306D889CC4C57-8014
Part No SW: 7E0 937 089 D HW: 7E0 937 089 D
Component: BCM PQ25 MMI4 H84 0772
Revision: BB084001 Serial number: 2602 180190154
Coding: 3AB02BFF48A10000213806C07CEB9E90B0C041FF608C0000200400030000
Shop #: WSC 00046 123 12345
VCID: 3467AAD2973B69E4CC-8060
Component: RLHS 200618 0 50 0107
Coding: 0714DD
Subsystem 2 - Part No SW: 6R0 959 802 BH HW: 6R0 959 802 BH Labels: 6R0-959-802.CLB
Component: J386__TSG_FT 003 8612
Serial number: KU0KU031031440906027
Coding: 1400B3
Subsystem 3 - Part No SW: 6R0 959 801 BC HW: 6R0 959 801 BC Labels: 6R0-959-801.CLB
Component: J387__TSG_BT 003 8611
Serial number: KU0KU013011440132978
Coding: 0400B3
Subsystem 4 - Part No SW: 5TA 959 442 HW: 5TA 959 442
Serial number: 1131818514601282AJ1B
Coding: 250000
Subsystem 5 - Part No SW: 6R0 959 811 L HW: 6R0 959 811 L
Component: ------------- 006 5550
Serial number: 13202580150909024344
Coding: 020000
Subsystem 6 - Part No SW: 6R0 959 812 L HW: 6R0 959 812 L
Serial number: 13102581150901174201
Coding: 020000
2 Faults Found:
00975 - Heated Rear Window (Z1)
011 - Open Circuit
Fault Status: 01101011
Fault Priority: 3
Fault Frequency: 1
Reset counter: 130
Mileage: 66523 km
Time Indication: 0
Date: 2024.11.01
Time: 00:18:07
01504 - Bulb for License-Plate Light (X)
010 - Open or Short to Plus
Fault Status: 01101010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 130
Mileage: 66523 km
Time Indication: 0
Date: 2024.11.01
Time: 00:17:34
Address 10: Park/Steer Assist (J446) Labels:. 5Q0-919-294.clb
Part No SW: 1K8 919 472 C HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0480
Revision: -------- Serial number: 39391606504499
Coding: 0001151011
ASAM Dataset: EV_EPHVA18VW364GP00 001007
ROD: N/A
VCID: 377D9DDE8E4D82FCE9-8062
No ASAM data for: "EV_EPHVA18VW364GP00" (VW25)
1 Fault Found:
12718592 - ROD - Unknown Error Code
- 00 [008]
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Reset counter: 130
Mileage: 66523 km
Date: 2024.11.01
Time: 00:17:33
Part No SW: 6R0 959 655 J HW: 6R0 959 655 J
Revision: -------- Serial number: 003GW0115JH8
Coding: 003036
ROD: EV_AirbaVW10BPAVW250.rod
VCID: 4999EB26E8B9040C8F-801C
Part No SW: 6RD 920 870 A HW: 6RD 920 870 A
Component: KOMBI H05 0805
Coding: 140801
Shop #: WSC 00078 790 12345
VCID: 479DED1EFEADF27C99-8012
Part No SW: 7E0 909 901 HW: 7E0 937 089 D
Revision: BB084001
Coding: 002307
VCID: 68DF0EA29B73DD04B0-803C
Component: IMMO H05 0805
Serial number:
ROD: EV_Immo_UDS_VDD_RM09.rod
VCID: 6ADB74AA8D7FEF14A6-803E
Address 44: Steering Assist (J500) Labels:| 1Sx-909-144-44.clb
Part No SW: 1S2 909 144 P HW: 1S2 909 144 P
Component: EPS_ECU H61 1702
Coding: 0001000000000000
ROD: EV_SteerAssisNSK_014.rod
VCID: 4189F306D089CC4C57-8014
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-STD2.clb
Part No SW: 5K7 035 200 D HW: 5K7 035 200 D
Component: MU-S--ER H20 0240
Serial number: VWZAZ2R8806143
Coding: 02630100BE0000001111000101182A001F0100D60020010003
Shop #: WSC 00066 790 00056
ROD: EV_MUStd4CTSAT_VW27.rod
VCID: 2541479624E1006C4B-8070
1 Fault Found:
U1101 00 [009] - Active
Fault Priority: 4
Fault Frequency: 1
Reset counter: 130
Mileage: 66523 km
Date: 2024.11.01
Time: 00:17:33
Voltage terminal 30: 12.1 V
End-------------------------(Elapsed Time: 02:51)--------------------------
