Polo 6R 1.2 GT Tsi RHD
Re: Polo 6R 1.2 GT Tsi RHD
Good BCM for automatic lights, etc. Hopefully in the future it will accept direct TPMS without any problems.
Fortunately we have the coding from the original BCM in several posts in this thread in case we need to correct the BCM coding.
sshakthi123
Drives: Vento 1.5 TDI MT and Polo 6R 1.2 Tsi Dsg
Post by sshakthi123 »
Yes Ciclo, I have installed LED headlights with this BCM and without automatic lights.
DRL and parking lights are not working currently.
Can you help with the coding to enable full functionality.
I would need,
1. DRL enabled
2. DRL cut off upon indicator active
3. Turn off DRL upon handbrake engaged
Perhaps the following BCM coding (based on '6R' -Vento- IND with factory LED headlights) is what should be for your current LED headlight wiring setup. Diagnostic errors may occur depending on missing wiring for other lights.🤷‍♂️
3AB02BFF48A10000213806007CEB9E9000C0604F60CD19D0210400020020
adityagttsi
Drives: Polo GT 1.2 TSI
Post by adityagttsi »
For the GTI Led Lights you will need to run 3 wires from each headlight to BCM. On the headlights the wires go in Pin 10,12 and 14.
Also you would have to send a signal from Headlight Switch to BCM white connector Pin 29 for DRL function. Not sure whether the signal for parking lights need to be altered or not.
Also check the PWM signal for Parking lights once you have done the wiring. You don’t need to check this if you have taken the BCM from Vento Highline Plus.
sshakthi123
I have updated the given coding, and below is the latest scan report.
1. For BCM max adaptation I have followed https://drive.google.com/file/d/0B2nv91 ... qdpZaURD-g and also viewtopic.php?p=558376#p558376
upgraded from 6R0937087AF to 7E0937089D
Wiring mentions of WL0, WL1, WL2, WL5 are done
But I missed the connection of T73b/29 from light switch.
Now I have connected BCM T73b/29 to headlight switch T17/3
and now it is working as expected :mrgreen:
also referred to https://polo.blue/bcm-pq25-t73a-t73b/
2. Reverted the previous Dimmer change done as per https://drive.google.com/file/d/0B2nv91 ... B4gGRBHy0g as the new Dimmer line is taken from BCM T73b/4 to T6/3
3. Enabled Driver Assist by following the procedure of https://www.drive2.ru/l/533203766917202038/
Now I have one error hanging. pls help fixing this,
01504 - Bulb for License-Plate Light (X)
010 - Open or Short to Plus
Fault Status: 01101010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 147
Mileage: 66861 km
Time Indication: 0
Date: 2024.11.09
Time: 09:04:36
Saturday,09,November,2024,21:10:46:00006
VCDS Version: 18.2.0.3
Data version: 20180212 DS287.0
www.Ross-Tech.com
VIN: MEXL15600GT052162   License Plate: BCM-MAX-LED-HL
Mileage: 66860km-41544mi   Repair Order:
Chassis Type: 60-VW25 (7E0)
Scan: 01 02 03 04 08 09 10 15 17 19 25 44 5F 65
VIN: MEXL15600GT052162   Mileage: 66860km-41544miles
Address 01: Engine (J623-CBZB)       Labels:. 03F-906-070-CBZ.clb
   Part No SW: 03F 906 070 KC    HW: 03F 907 309 AJ
   Component: SIMOS10.22AH10 6270
   Revision: --H10---    Serial number:
   Coding: 00250056232400080000
   Shop #: WSC 01234 785 00200
   ASAM Dataset: EV_ECM12TFS02103F906070KC 004006
   VCID: 6DD17FB6BC91F82CC3-8038
Readiness: 0110 0101
Address 02: Auto Trans        Labels: 0AM-927-769.clb
   Part No SW: 0AM 300 065 N    HW: 0AM 927 769 D
   Component: GSG DSG AG7     431 6561
   Revision: 00043014    Serial number: CU501505175568
   Coding: 0000024
   Shop #: WSC 30641 005 1048576
   VCID: 3A7B84EA755F9F9416-806E
Address 03: ABS Brakes
Cannot be reached
   Serial number: 10051504650266
   Coding: 01
   Shop #: WSC 00000 000 00000
   ROD: EV_LWSKLOVW25X.rod
   VCID: 7EF348FAE1F773B46A-802A
   Part No SW: 6R0 907 044 Q    HW: 6R0 907 044 Q
   Component: Climatronic   H12 0615
   Revision: V0000000
   VCID: 4189F306D889CC4C57-8014
   Part No SW: 7E0 937 089 D    HW: 7E0 937 089 D
   Component: BCM PQ25 MMI4 H84 0772
   Revision: BB084001    Serial number: 2602 180190154
   Coding: 3AB02BFF48A10000213806007CEB9E9000C0604F60CD19D0210400020020
   Shop #: WSC 00046 123 12345
   VCID: 3467AAD2973B69E4CC-8060
   Component: RLHS 200618 0  50  0107
   Coding: 0714DD
   Subsystem 2 - Part No SW: 6R0 959 802 BH    HW: 6R0 959 802 BH  Labels: 6R0-959-802.CLB
   Component: J386__TSG_FT  003 8612
   Serial number: KU0KU031031440906027
   Coding: 1400B3
   Subsystem 3 - Part No SW: 6R0 959 801 BC    HW: 6R0 959 801 BC  Labels: 6R0-959-801.CLB
   Component: J387__TSG_BT  003 8611
   Serial number: KU0KU013011440132978
   Coding: 0400B3
   Subsystem 4 - Part No SW: 5TA 959 442     HW: 5TA 959 442
   Serial number: 1131818514601282AJ1B
   Coding: 250000
   Subsystem 5 - Part No SW: 6R0 959 811 L    HW: 6R0 959 811 L
   Component: -------------  006 5550
   Serial number: 13202580150909024344
   Coding: 020000
   Subsystem 6 - Part No SW: 6R0 959 812 L    HW: 6R0 959 812 L
   Serial number: 13102581150901174201
   Coding: 020000
3 Faults Found:
00978 - Lamp for Low Beam; Left (M29)
                    Fault Priority: 3
                    Fault Frequency: 73
                    Reset counter: 148
                    Mileage: 66861 km
                    Time Indication: 0
                    Date: 2024.11.09
                    Time: 09:04:36
00979 - Lamp for Low Beam; Right (M31)
                    Fault Priority: 3
                    Fault Frequency: 51
                    Reset counter: 148
                    Mileage: 66861 km
                    Time Indication: 0
                    Date: 2024.11.09
                    Time: 09:04:36
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 147
                    Mileage: 66861 km
                    Time Indication: 0
                    Date: 2024.11.09
                    Time: 09:04:36
Address 10: Park/Steer Assist (J446)       Labels:. 5Q0-919-294.clb
   Part No SW: 1K8 919 472 C    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0480
   Revision: --------    Serial number: 39391606504499
   Coding: 0001151011
   ASAM Dataset: EV_EPHVA18VW364GP00 001007
   ROD: N/A
   VCID: 377D9DDE8E4D82FCE9-8062
No ASAM data for: "EV_EPHVA18VW364GP00" (VW25)
1 Fault Found:
12718592 - ROD - Unknown Error Code
          - 00 [009]
                    Fault Status: 00000001
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 147
                    Mileage: 66861 km
                    Date: 2024.11.09
                    Time: 09:04:36
   Revision: --------    Serial number: 003GW0115JH8
   Coding: 003036
   ROD: EV_AirbaVW10BPAVW250.rod
   VCID: 4999EB26E8B9040C8F-801C
   Part No SW: 6RD 920 870 A    HW: 6RD 920 870 A
   Component: KOMBI         H05 0805
   Coding: 140801
   Shop #: WSC 00078 790 12345
   VCID: 479DED1EFEADF27C99-8012
   Part No SW: 7E0 909 901     HW: 7E0 937 089 D
   Revision: BB084001
   Coding: 002307
   VCID: 68DF0EA29B73DD04B0-803C
   Component: IMMO          H05 0805
   Serial number:
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 6ADB74AA8D7FEF14A6-803E
   Part No SW: 1S2 909 144 P    HW: 1S2 909 144 P
   Component: EPS_ECU       H61 1702
   Coding: 0001000000000000
   ROD: EV_SteerAssisNSK_014.rod
   VCID: 4189F306D089CC4C57-8014
   Part No SW: 5K7 035 200 D    HW: 5K7 035 200 D
   Component: MU-S--ER      H20 0240
   Serial number: VWZAZ2R8806143
   Coding: 02630100BE0000001111000101182A001F0100D60020010003
   Shop #: WSC 00066 790 00056
   ROD: EV_MUStd4CTSAT_VW27.rod
   VCID: 2541479624E1006C4B-8070
1 Fault Found:
          U1101 00 [009] - Active
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 147
                    Mileage: 66861 km
                    Date: 2024.11.09
                    Time: 09:04:35
                    Voltage terminal 30: 13.7 V
   Serial number: 40000000256160
   ROD: EV_RDKBERU30_005.rod
End-------------------------(Elapsed Time: 03:07)--------------------------
License Plate Lights.
Once the WL5 of the aforementioned guide (page 12) has been done, could you tell me what type of light is installed for the license plate lights, LEDs or filament bulbs?
Are they currently working despite the diagnosed fault?
sshakthi123
I have installed LED license plate lights long back and now I changed the wiring as per WL5
3AB02BFF48A10000213806207CEB9E9000C0604F60CD19D0210400030020
sshakthi123
License plate lights error disappeared now..
But cornering lights are not working, it flickers upon turning steering wheel. sometime it flickers and turn off. sometimes are not turning on at all. However fog lights works fine upon headlight switch on...
I'm using OSRAM LED bulbs for fog lights..
Sunday,10,November,2024,09:09:24:00006
www.Ross-Tech.com
VIN: MEXL15600GT052162   License Plate: GT-BCM-MAX-LED
Mileage: 66890km-41563mi   Repair Order:
VIN: MEXL15600GT052162   Mileage: 66890km-41563miles
   Coding: 0000024
Address 03: ABS Brakes (J104)       Labels: None
   Part No SW: 6R0 907 379 CB    HW: 6R0 907 379 AS
   Component: ESP9.0i front H03 0003
   Serial number: --------------
   Coding: 62DD2463422803C24615246F4253C0800909
   VCID: 000F36029B03054418-8054
   Coding: 01
   Revision: V0000000
   Coding: 3AB02BFF48A10000213806207CEB9E9000C0604F60CD19D0210400030020
   Coding: 0714DD
   Coding: 1400B3
   Coding: 0400B3
   Coding: 250000
   Coding: 020000
   Coding: 020000
4 Faults Found:
                    Fault Priority: 3
                    Fault Frequency: 60
                    Reset counter: 149
                    Mileage: 66894 km
                    Time Indication: 0
                    Date: 2024.11.10
                    Time: 21:04:20
                    Fault Priority: 3
                    Fault Frequency: 24
                    Reset counter: 149
                    Mileage: 66894 km
                    Time Indication: 0
                    Date: 2024.11.10
                    Time: 21:04:20
01495 - Bulb for High-Beams; Left (M30)
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 149
                    Mileage: 66894 km
                    Time Indication: 0
                    Date: 2024.11.10
                    Time: 21:04:38
01499 - Bulb for High-Beams; Right (M32)
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 149
                    Mileage: 66894 km
                    Time Indication: 0
                    Date: 2024.11.10
                    Time: 21:04:38
   Coding: 0001151011
   ROD: N/A
1 Fault Found:
          - 00 [009]
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 149
                    Mileage: 66894 km
                    Date: 2024.11.10
                    Time: 21:04:20
   Coding: 003036
   Coding: 140801
   Revision: BB084001
   Coding: 002307
   Serial number:
1 Fault Found:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 149
                    Mileage: 66894 km
                    Date: 2024.11.10
                    Time: 21:04:20
End-------------------------(Elapsed Time: 02:59)--------------------------
Well, Byte 18 was modified for LED Headlights (the current HEX value is the correct one), which changes the operating parameters for 'all lights'.
The problems you are now experiencing with those non-OEM LED bulbs in the front fog lights are related to this.
Try this new BCM coding to try to fix this... and other diagnostics seen in your previous Autoscan:
3AB02BFF48A10000213806207CEB9E9090C0606F60CD19D0210400030020
The diagnosis for HB, LB, and F-fog lights is removed.
This new BCM coding does not mean that it is appropriate for an OEM installation (wires and lamps), even if everything works perfectly forever.
BTW, congratulations on the direct TPMS. Enjoy it!🎉
sshakthi123
Other fault codes also removed with this update. However no change in the cornering lamp issues.
One cent, before installing this BCM in this car, I have tried swappping this in my Vento which also has same LED fog lights.
This BCM gave a same behavior in that car also but the original BCM of Vento 090B works flawless.
With this I suspect it is something an issue with the BCM.
Is it possible to fix this?
Sunday,10,November,2024,11:07:19:00006
www.Ross-Tech.com
VIN: MEXL15600GT052162   License Plate: GT-BCM-MAX-HL-FINAL
   Coding: 0000024
   Coding: 01
   Revision: V0000000
   Coding: 3AB02BFF48A10000213806207CEB9E9090C0606F60CD19D0210400030020
   Coding: 0714DD
   Coding: 1400B3
   Coding: 0400B3
   Coding: 250000
   Coding: 020000
   Coding: 020000
4 Faults Found:
                    Fault Priority: 3
                    Fault Frequency: 206
                    Reset counter: 150
                    Mileage: 66894 km
                    Time Indication: 0
                    Date: 2024.11.10
                    Time: 23:03:53
                    Fault Priority: 3
                    Fault Frequency: 150
                    Reset counter: 150
                    Mileage: 66894 km
                    Time Indication: 0
                    Date: 2024.11.10
                    Time: 23:03:52
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 149
                    Mileage: 66894 km
                    Time Indication: 0
                    Date: 2024.11.10
                    Time: 23:03:53
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 149
                    Mileage: 66894 km
                    Time Indication: 0
                    Date: 2024.11.10
                    Time: 23:03:53
   Coding: 0001151011
   ROD: N/A
1 Fault Found:
          - 00 [009]
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 149
                    Mileage: 66894 km
                    Date: 2024.11.10
                    Time: 23:03:25
   Coding: 003036
   Coding: 140801
   Revision: BB084001
   Coding: 002307
   Serial number:
1 Fault Found:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 149
                    Mileage: 66894 km
                    Date: 2024.11.10
                    Time: 23:03:24
                    Voltage terminal 30: 13.8 V
End-------------------------(Elapsed Time: 03:13)--------------------------
Maybe with the VCP application for BCM PQ25.
1- You read (TXT file) all the parameters from the BCM 089D as a backup.
2- You read (TXT file) all the parameters from the BCM 090B from Vento.
3- Two options:
3.1- You compare both files and modify the parameters.
or
3.2- You load the parameters from the BCM 090 into the BCM 089.
I'm trying to arrange to purchase some materials in Europe to make a pair of wiring harnesses for automatic lights like the ones I made a few years ago due to the large number of requests I received for them.
I don't know if anyone else is making these harnesses, I'm not aware of it and I don't intend to get into this again.
I'm mentioning this in case you or anyone else is interested in them.
I assume the price will be the same as before... no intention of becoming a millionaire with it. :lol:
sshakthi123
That’s a great news for me!
Definitely I would need one. It would be so great if you can give me an electric bridge as well as I currently have some temporary alternative installed (hard wired with some low quality pins).
Appreciate your help.
sshakthi123
ciclo wrote: Sun Nov 10, 2024 6:12 am 💡
3- Two options:
or
I will try this and share you the results. It may take sometime.
